Date/Time: Thu, 13 Feb 2025 16:59:50 +0000
problem with order flow setting
View Count: 533
[2020-12-16 14:35:36] |
User281941 - Posts: 3 |
I am using order flow chart it is ok with other symbols but on GCG21-COMEX it is not working properly and candles look too long So what should I do? http://www.sierrachart.com/image.php?Image=1608129224950.png |
[2020-12-16 16:09:45] |
John - SC Support - Posts: 37934 |
It just looks like you have a scaling issue. Be sure the scale is set to Automatic and then reset the scale. Refer to the information here: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
