Date/Time: Thu, 13 Feb 2025 17:38:57 +0000
Program doesnt start
View Count: 618
[2020-12-16 11:17:29] |
User936545 - Posts: 3 |
I used Sierra chart, and yesterday it asked me to update the programm, i did it, and i can not start the program, it doesnt open, it doesnt start work. I deleted program and installed new program from website, anyway, i still have the same problem. I have Windows 7. I click the sierra chart, black window opens for 1 second and then disappear.
Attachment Deleted. 9018EA80-A72A-4B12-9608-284B521CE312.png / V - Attached On 2020-12-16 11:12:37 UTC - Size: 8.02 MB - 200 views |
[2020-12-16 14:40:06] |
John - SC Support - Posts: 37934 |
It sounds like your computer may not be a 64-bit computer. The latest releases of Sierra Chart are no longer sending out the 32-bit executable. Refer to the information in the Release Notes here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2177 If this is the case, then you will need to go to a release prior to 2177. You can obtain a prior release by following these instructions: Software Download: Full Control Rollback Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-12-17 02:53:14] |
Your computer is likely 64-bit, but you need to be running a 64-bit Windows operating system. Update your operating system to a 64-bit version of Windows. Windows 7 is available as 64-bit.
[2020-12-17 06:10:41] |
Yes, i have 32-bit, and i have no opportunity to update my operating system, i tried to download specific version 2177, but it still didnt work, can you tell me which version else i can use?
[2020-12-17 06:29:44] |
Ok, i got it, thank you. Prior version works.
