Date/Time: Fri, 19 Jun 2026 13:34:24 +0000
problem when rolling over
View Count: 701
[2020-12-15 18:34:59]
User281941 - Posts: 3
I try to rollover ESZ20-CME to ESH21-CME but after rolling over price stops moving although ESH21-CME have a much more trading volume.
please help me as soon as possible
[2020-12-15 19:48:46]
John - SC Support - Posts: 46778
Usually when there is something like this it is because you are using a mix of old and new symbols. Make sure that all your symbols are using the new format by selecting Edit >> Translate Symbols to Current Service. Refer to the information here:
Edit Menu: Edit >> Translate Symbols To Current Service
If this is not the case, then we would need to see your Message Log.
[2020-12-15 19:54:53]
Let us know if you are still not receiving the data after following the above instructions.
[2020-12-16 04:46:44]
again I did the same instructions as you told but the price is not moving again and I am in a hurry please help me and I am sending a screenshot of message log.
http://www.sierrachart.com/image.php?Image=160809387622.png
[2020-12-16 08:07:29]
The two symbols we see in the screenshot, are no longer trading. You need to roll them over to the current contracts:
Changing to a New Futures Contract Month
