Date/Time: Sat, 26 Sep 2026 13:45:32 +0000
Como abrir mi plataforma en una segunda laptop
View Count: 1064
| [2020-12-07 23:54:15] |
| Cecy - Posts: 2 |
Buenas tardes. Quiero abrir mi plataforma ya configurada en una segunda laptop. Ya tenia instalada la plataforma en la laptop, pero al escribir mis credenciales no se conecta. Luego he intentado conectarme en File, Data Trade Service Settings, pero no me funciona. Que tengo que hacer? Gracias, |
| [2020-12-08 14:59:53] |
| John - SC Support - Posts: 48028 |
From Google Translate: Good afternoon.
I want to open my already configured platform on a second laptop. I already had the platform installed on the laptop, but when I entered my credentials it did not connect. Then I have tried to connect in File, Data Trade Service Settings, but it doesn't work for me. That I have to do? Thank you, The account from which you posted is expired. If you are trying to use this account, then that would explain why you are not able to use Sierra Chart on another system. If you have another account that you are using to login to your Sierra Chart software that is not expired, then we would need for you to log into this Support Board with that Account Name and post using that account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-08 20:14:58] |
| User543464 - Posts: 14 |
Buenas tardes. Quiero abrir mi plataforma ya configurada en una segunda laptop. Ya tenia instalada la plataforma en la laptop, pero al escribir mis credenciales no se conecta. Luego él intentado conectarme en File, Data Trade Service Settings, pero no me funciona. Que tengo que hacer? Gracias |
| [2020-12-08 20:30:21] |
I want to open my already configured platform on a second laptop. I already had the platform installed on the laptop, but when I entered my credentials it did not connect. Then he tried to connect me in File, Data Trade Service Settings, but it doesn't work for me. That I have to do? Thank you It sounds like you are having a problem connecting to CQG. Given what you have stated, it sounds like it may just be because you are trying to connect to CQG from two different systems at the same time. You would need to check with your Broker about whether you can make multiple connections to CQG at the same time. If you are only connecting from your Laptop and you are positive that you have fully exited Sierra Chart on your other system, such that the installation on the Laptop is the only running Sierra Chart, then we would need to see your Message Log in order to understand what may be occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-12-08 23:32:22] |
If you want to use Sierra Chart from two different computers at the same time you will need to use the Sierra Chart Order Routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-12-08 23:32:31
| [2021-01-17 01:37:56] |
Buenas tardes. Deseo saber si cuentan con alguna app de la plataforma para el teléfono móvil, aunque sea de pago. También quiero saber lo siguiente: si yo tengo una operación abierta con su limit y su stop puestos, y desconecto la plataforma y apago mi laptop, entonces, siempre la operación tomara mi limit o mi stop? aunque yo no este conectada? Gracias por su ayuda. Saludos, |
| [2021-01-18 15:07:38] |
I want to know if they have any app on the platform for the mobile phone, even if it is paid. I also want to know the following: if I have an open trade with its limit and stop set, and I disconnect the platform and turn off my laptop, then will the trade always take my limit or my stop? even though I'm not connected? Thanks for your help. Cheers, The Sierra Chart Order Routing Service does have a Web-based trading portal. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel With the Sierra Chart Order Routing Service, the orders are on the Server, so you would not need to have Sierra Chart running. The orders will be taken care of on the server. Refer to the following: Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-19 04:44:26] |
I want to know if they have an app on the platform for the mobile phone, even if it is paid.
There is a trade panel that can be used with the Sierra Chart Order Routing Service for a mobile phone, refer to:https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel I also want to know the following: if I have an open trade with its limit and stop set, and I disconnect the platform and turn off my laptop, then will the trade always take my limit or my stop? even though I'm not connected? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-19 04:45:32
