Date/Time: Wed, 12 Feb 2025 15:38:31 +0000
Infinity orders and Sierra chart based orders are not working
View Count: 436
[2020-11-05 15:12:58]
vijayrams - Posts: 5
Infinity dome rejected orders due to margin, however Sierra chart held orders to short at 3498 ES and it did not allow to cancel either, this is after the upgrade, there is a bug in Sierrac chart, it should not have any orders if there is no working or pending orders on Infinity platform, it must be in sync to keep the books clean or to avoid any issue or please review this issue as serious matter since account is using this live feature and sierra should not be having orders on its own when there is nothing present on Infinity platform. Also, noticed latency in orders between Sierra and Infinity on live accounts to cancellation.
[2020-11-05 21:21:20]
Understand that we do not have control over the issues you describe. The interface to the Transact trading server, is properly implemented and has been tested and certified but we have no control over that server.
We recommend that you change to the Sierra Chart Order Routing Service for the best and most reliable trading from Sierra Chart:
Sierra Chart / Trading Technologies Futures Order Routing Service
You will notice a dramatic improvement in all areas. As you read through the beginning portion of that page, you can see all of the advantages.
Date Time Of Last Edit: 2020-11-05 21:21:54
[2020-11-06 02:51:15]
SC Support - Posts: 1930
Hi Vijayrams, we can give you a call to speak about this if you wish, even help with set-up depending upon how you decide you want to proceed.
