Date/Time: Mon, 14 Sep 2026 01:12:10 +0000
Waiting to reconnect
View Count: 946
| [2020-10-26 14:47:07] |
| User223281 - Posts: 59 |
Both the services I use (SC Futures Order routing/data and Bitmex) have been waiting to reconnect for 24 hours.. Im not sure whats happened, how do I fix it?
| [2020-10-26 16:03:20] |
| John - SC Support - Posts: 47854 |
We are not having any problems with the data connections for these services. Exit from Sierra Chart and use the Forced Login option. Refer to the following instructions: Sierra Chart - Software Login Instructions: Forced Login For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-26 16:09:39] |
After doing the forced login, I receive this message HTTP Error: socket connection closed during the connection attempt
| [2020-10-26 17:15:06] |
Please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-26 17:20:17] |
Software version: 2182 64-bit | 2020-10-26 11:19:27.681 Primary Thread ID: 3804 | 2020-10-26 11:19:27.681 Usage end date: 2020-11-09 | 2020-10-26 11:19:27.681 Enabled for: Advanced Features 2. | 2020-10-26 11:19:27.681 Enabled for: Sierra Chart Historical Data Service. | 2020-10-26 11:19:27.681 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-26 11:19:27.681 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-26 11:19:27.681 Enabled for exchange2: CME (Trading Account Required) | 2020-10-26 11:19:27.681 Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-26 11:19:27.681 Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-26 11:19:27.681 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-26 11:19:27.681 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-26 11:19:27.681 Current selected Data/Trading service: BitMEX Trading Direct | 2020-10-26 11:19:27.681 Custom symbol settings values: enabled | 2020-10-26 11:19:27.681 Chart Update Interval: 500 | 2020-10-26 11:19:27.681 Intraday Data Storage Time Unit: 1 | 2020-10-26 11:19:27.681 Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-26 11:19:27.681 2020-10-26 11:19:27 Local computer time | 2020-10-26 11:19:27.681 2020-10-26 17:19:27 Local computer time in UTC | 2020-10-26 11:19:27.682 2020-10-26 11:19:27 Local computer time in SC Time Zone | 2020-10-26 11:19:27.682 Program path: C:\SierraChartBitMex\ | 2020-10-26 11:19:27.682 Data Files path: C:\SierraChartBitMex\Data\ | 2020-10-26 11:19:27.682 OS Version Number: 10.0 | 2020-10-26 11:19:27.682 Locale Setting: C | 2020-10-26 11:19:27.682 DLLs: DOM.dll, GomMPPro.dll, GomMPPro_2151.dll, GomMPPro_2151_64.dll, GomMPPro_64.dll, GomOrderFlowPro.dll, GomOrderFlowPro_2151.dll, GomOrderFlowPro_2151_64.dll, GomOrderFlowPro_64.dll, OFA Bars (by Zdislav)_64.dll, rbcc_64 (1).dll, rbcc_footprint_64 (1).dll, UserContributedStudies_64.dll, zyp sierra free (2020).dll, zyp sierra free (2020)_64.dll, zyp sierra free.dll, zyp sierra free_64.dll | 2020-10-26 11:19:27.682 Allowed protected custom studies: GomOrderFlowPro, zyp_download_free | 2020-10-26 11:19:27.682 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:31.720 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:31.720 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:31.721 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:31.721 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:31.721 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:31.721 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:31.721 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:31.721 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:31.721 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:31.728 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:31.729 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:31.729 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:34.744 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:34.744 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:34.746 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:34.750 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:34.750 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:34.750 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:34.750 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:34.750 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:34.750 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:34.760 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:34.760 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:34.760 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:37.775 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:37.775 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:37.776 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:37.780 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:37.780 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:37.780 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:37.780 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:37.780 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:37.780 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:37.790 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:37.790 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:37.790 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:40.791 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:40.791 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:40.793 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:40.797 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:40.797 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:40.797 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:40.797 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:40.797 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:40.797 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:40.822 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:40.822 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:40.822 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:43.821 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:43.821 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:43.822 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:43.825 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:43.825 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:43.825 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:43.825 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:43.825 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:43.825 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:43.837 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:43.837 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:43.837 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:46.838 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:46.838 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:46.838 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:46.838 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:46.838 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:46.838 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:46.838 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:46.838 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:46.838 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:46.869 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:46.869 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:46.869 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:49.884 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:49.884 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:49.885 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:49.885 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:49.885 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:49.885 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:49.885 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:49.885 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:49.885 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:49.900 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:49.900 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:49.901 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:52.916 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:52.916 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:52.917 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:52.917 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:52.917 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:52.917 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:52.917 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:52.917 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:52.917 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:52.931 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:52.932 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:52.932 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:55.948 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:55.948 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:55.949 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:55.949 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:55.949 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:55.949 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:55.949 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:55.949 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:55.949 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:55.963 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:55.963 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:55.963 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:19:58.978 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:19:58.978 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:19:58.978 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:19:58.978 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:19:58.978 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:58.978 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:19:58.978 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:19:58.978 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:58.978 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:19:58.994 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:19:58.994 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:19:58.994 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2020-10-26 11:20:01.994 BitMEX Trading Direct | Connecting to WebSocket server www.bitmex.com:443 | 2020-10-26 11:20:01.994 Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known. | 2020-10-26 11:20:01.995 BitMEX Trading Direct socket (1) | CloseSocket call. | 2020-10-26 11:20:01.995 BitMEX Trading Direct socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-26 11:20:01.995 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:20:01.995 BitMEX Trading Direct | WebSocket closed. | 2020-10-26 11:20:01.995 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-26 11:20:01.995 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:20:01.995 BitMEX Trading Direct socket (0) | CloseSocket call. | 2020-10-26 11:20:02.010 BitMEX Trading Direct | Disconnected. | 2020-10-26 11:20:02.010 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-26 11:20:02.010 |
| [2020-10-26 17:52:48] |
The relevant messages are the following: Error getting address info for www.bitmex.com. Windows error code 11001: No such host is known.
This would mean that either your computer does not know how to connect to www.bitmex.com, which would be a network issue. Or the bitmex site is not working, but we can connect to the Bitmex site just fine, so that is not the issue. Refer to the information at the following link: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-26 19:49:45] |
The interesting part is it wont connect to SC data either.. And yes, internet is working on my side as well connecting to bitmex.com. Also, even when not forcing connection to the SC data instance, it wont let me log in and brings up the same error Date Time Of Last Edit: 2020-10-26 19:50:33
| [2020-10-26 20:01:18] |
Set your service to SC Data - All Services, then follow these instructions to get us your Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-26 20:04:09] |
It wont even let me log in, even when not forcing login. Not sure what to do? It just brings up the same error message
Date Time Of Last Edit: 2020-10-26 20:04:46
| [2020-10-26 20:12:35] |
Sorry, we are a bit confused. If you can't login to your Sierra Chart program, then how did you get us the Message Log for the BitMex connection? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-10-26 20:16:33] |
The instance I use for bitmex is letting me login.. The one I use for SC data let me log in once today, but ever since then it goes straight to the error message during login
| [2020-10-26 20:19:42] |
Are these on different computers or the same computer?
| [2020-10-26 20:21:03] |
And have you rebooted the system(s)? If not, then reboot and see if you still have a problem.
| [2020-10-26 20:22:57] |
They are on the same computer. I have rebooted and still the same issue. I have also turned off the firewalls
| [2020-10-26 20:29:14] |
So at this point we understand you are having a problem logging into Sierra Chart due to a connectivity issue. Therefore, refer to: HTTP Communication Errors This is definitely caused by a connectivity issue on your side. That is very clear. There is some network connectivity issue you are having on your side that is at least affecting Sierra Chart. You need to figure this out and resolve. We cannot resolve this problem for you. You need to solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-26 20:29:53
