Date/Time: Tue, 14 Jan 2025 23:48:33 +0000
Chart Vertical Grid Lines and Time Line Study not aligned for same timestamp
View Count: 621
[2020-10-25 06:56:48] |
User992529 - Posts: 32 |
On a Volume Bar chart where "Advanced Settings 2 - Vertical Grid Lines" is Enabled at Session Start (eg 09:00:00) and a Time Line Study with time of 09:00:00 is added, the two are not drawn on the same location. The VGL is drawn before the session first bar (inbetween last O/N bar and first session bar), whereas the TL is drawn at the center of the first bar correctly. This does not always happen for all days, sometimes the Fri Vertical Grid Line is correctly drawn. If switching to Time Bars, the two are coinciding as one would expect. Moreover, probably related, when transitioning through the Time Line timestamp (Replay or during real time), the text label shows more than once, sometimes twice, sometimes 3 times, sometimes 4 times at slightly different horizontal offsets. Recalculate (Ctrl+Ins) seems to clear them. Switching from Nearest to Containing seems to fix it. Example for 09:30:00 I would get "BBB", one left, one centered, one to the right of the bar instead of just one "B". I was running this setup since one year but this all has started happening since a month or so so I assume there were some changes in this area that broke it. Date Time Of Last Edit: 2020-10-25 06:58:42
Private File |
[2020-10-26 04:05:58] |
This is nothing new and is by design and will not change: The VGL is drawn before the session first bar (inbetween last O/N bar and first session bar), whereas the TL is drawn at the center of the first bar correctly.
Regarding the multiple labels issue with the Time Line study, that is resolved. Update to the latest prerelease: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-26 04:06:15
