Date/Time: Thu, 24 Sep 2026 16:48:16 +0000
switched computer and cant get live feed
View Count: 781
[2020-10-23 15:05:37]
User700573 - Posts: 16
I had lag and switched to another computer. I noticed I couldn't take live trades so I signed in to sierra with my old computer to see what settings I needed from Data/Trade service settings. I copied those into my new computer and it worked fine. But then I logged out of Sierra on the new computer and when I logged back in I can't get live data. The old computer does get live data. Can you help me?
[2020-10-23 15:14:53]
John - SC Support - Posts: 47996
You can only be getting data on one computer at a time. Make sure the Sierra Chart software is not running on the other computer.
Given the above, if you still have a problem, then post your Message Log here following these instructions:
Reconnect to the data feed:
[2020-10-23 15:34:38]
Software version: 2171 64-bit | 2020-10-23 11:29:02.904
Primary Thread ID: 4644 | 2020-10-23 11:29:02.904
Usage end date: 2020-11-05 | 2020-10-23 11:29:02.904
Enabled for: Advanced Features 2. | 2020-10-23 11:29:02.904
Enabled for: Sierra Chart Historical Data Service. | 2020-10-23 11:29:02.904
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-23 11:29:02.904
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-23 11:29:02.904
Enabled for exchange2: CME (Trading Account Required) | 2020-10-23 11:29:02.904
Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-23 11:29:02.904
Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-23 11:29:02.904
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-23 11:29:02.904
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-23 11:29:02.904
Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-10-23 11:29:02.904
Custom symbol settings values: enabled | 2020-10-23 11:29:02.904
Chart Update Interval: 500 | 2020-10-23 11:29:02.904
Intraday Data Storage Time Unit: 1 | 2020-10-23 11:29:02.904
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-23 11:29:02.904
2020-10-23 11:29:02 Local computer time | 2020-10-23 11:29:02.904
2020-10-23 15:29:02 Local computer time in UTC | 2020-10-23 11:29:02.904
2020-10-23 11:29:02 Local computer time in SC Time Zone | 2020-10-23 11:29:02.904
2020-10-23 14:32:37 Server time in UTC | 2020-10-23 11:29:02.904
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-10-23 11:29:02.904
Program path: C:\SierraChart\ | 2020-10-23 11:29:02.904
Data Files path: C:\SierraChart\Data\ | 2020-10-23 11:29:02.904
OS Version Number: 6.1 | 2020-10-23 11:29:02.905
Locale Setting: C | 2020-10-23 11:29:02.905
DLLs: sst_ateam_2151_64.dll, sst_ateam_64.dll, SST_ATEAM_RX.dll, SST_ATEAM_RX_2151.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-23 11:29:02.905
Allowed protected custom studies: SST_ATEAM, SST_ATEAM_PS | 2020-10-23 11:29:02.905
sending this in accordance with sierra's request - I can;t get data on my new computer. Old computer is now closed.Thx
[2020-10-23 15:51:06]
What is the symbol of one of the charts that is not getting data?
[2020-10-23 16:08:53]
ESZ20 and GCZ20 are the two symbols I have tried - neither gets data
[2020-10-23 16:10:34]
I have replied again just now on support board thread
[2020-10-23 17:03:04]
Those are not the right symbols to be using for the Sierra Chart Order Routing service. Select Edit >> Translate Symbols to Current Service to change the symbols in the charts you have open.
[2020-10-23 17:44:00]
That worked. Thanks!
