Date/Time: Wed, 12 Feb 2025 12:13:58 +0000
Hi can you help
View Count: 477
[2020-10-22 12:25:11]
Tommy O Gorman - Posts: 3
Thanks for emailing me back and Clarifying that I am not allowed to send a video to explain my problems and so you can see what I am and where I am at I thought this would be very relevant so you could pinpoint things very fast but not to worry I will do it in a PDF instead.
Looking forward to your reply to my Questions.
Thanking You
Blessings
Tommy
Date Time Of Last Edit: 2020-10-23 09:32:34
attachmentSierra Chart Thu 22 10 2020 PDF.pdf - Attached On 2020-10-22 12:24:27 UTC - Size: 671.24 KB - 268 views
[2020-10-22 13:51:59]
John - SC Support - Posts: 37891
The choice of Service Package level does not have any impact on live data or not. Refer to the following for the differences between the packages:
Description of Service Packages and Pricing: Packages
If you need Real-Time data for the CME Group, then you can get this from us using the Denali Exchange Data Feed. You will find the information for this feed along with pricing on this page:
Note the need to have a trading account in order to qualify for the lower-priced Non-Professional exchange fees. There are links in the above page to more information on this topic.
When you select a service level, you are also selecting the length of time that it will renew. Right now, you have selected Monthly, so every 31 days your service will renew and funds will be taken from your account to renew the service. If you do not have enough funds in your account, then the service will not renew. You can add funds to your account on this page:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
When you have purchased your Sierra Chart through us (not through a reseller or broker), then you can have Sierra Chart running on 2 computers at the same time. That is what the statement "1 out of a total of 2 system(s) is currently being used" is referencing on the Control Panel. Just be aware, that even though you can run Sierra Chart on 2 computers at the same time, you may not be able to get the data to both systems at the same time without paying additional fees.
