Date/Time: Sun, 20 Sep 2026 08:16:30 +0000
Denali Data - Delay
View Count: 1082
[2020-10-20 12:42:19]
User889687 - Posts: 12
I pay for Real time data from Denali.
From 19.10.2020 the data is delayed by 10 minutes!
I compare the data with data from the broker - AMP Futures.
Where is the problem?
[2020-10-20 13:25:55]
John - SC Support - Posts: 47939
You only have the CME with Market Depth for Non-Professionals exchange active. So if you are looking at any symbol that is not traded on the CME exchange itself (not the CME Group), then those will be delayed.
For example, you should get data for the ES in Real-Time, but data for the CL will be delayed as CL is traded on the NYMEX exchange.
If this does not resolve your problem, then we need to see your Message Log following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2020-10-20 14:19:29]
Software version: 2182 64-bit | 2020-10-20 16:12:39.135
Primary Thread ID: 9840 | 2020-10-20 16:12:39.135
Usage end date: 2020-12-12 | 2020-10-20 16:12:39.135
Enabled for: Advanced Features 2. | 2020-10-20 16:12:39.135
Enabled for: Sierra Chart Historical Data Service. | 2020-10-20 16:12:39.135
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-20 16:12:39.135
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-20 16:12:39.135
Enabled for exchange2: CME | 2020-10-20 16:12:39.135
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-20 16:12:39.135
Current selected Data/Trading service: SC Data - All Services | 2020-10-20 16:12:39.135
Custom symbol settings values: enabled | 2020-10-20 16:12:39.135
Chart Update Interval: 500 | 2020-10-20 16:12:39.135
Intraday Data Storage Time Unit: 0 | 2020-10-20 16:12:39.135
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-10-20 16:12:39.135
2020-10-20 16:12:39 Local computer time | 2020-10-20 16:12:39.135
2020-10-20 14:12:39 Local computer time in UTC | 2020-10-20 16:12:39.135
2020-10-20 16:12:39 Local computer time in SC Time Zone | 2020-10-20 16:12:39.135
2020-10-20 14:07:22 Server time in UTC | 2020-10-20 16:12:39.135
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-10-20 16:12:39.135
Program path: C:\SierraChart\ | 2020-10-20 16:12:39.135
Data Files path: C:\SierraChart\Data\ | 2020-10-20 16:12:39.136
OS Version Number: 10.0 | 2020-10-20 16:12:39.136
Locale Setting: C | 2020-10-20 16:12:39.136
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-20 16:12:39.136
Allowed protected custom studies: | 2020-10-20 16:12:39.136
File >> Disconnect selected. | 2020-10-20 16:13:02.317
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2020-10-20 16:13:02.318
DTC Client socket (2) | CloseSocket call. | 2020-10-20 16:13:02.318
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-20 16:13:02.318
SC DTC Delayed Exchange Data | Disconnected from the server. | 2020-10-20 16:13:02.318
SC Data - All Services | Disconnected. | 2020-10-20 16:13:02.318
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-20 16:13:02.318
SC Data - All Services | Connected to server complete. | 2020-10-20 16:13:09.840
Triggering next historical data download in queue. | 2020-10-20 16:13:09.840
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-20 16:13:09.840
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2020-10-20 16:13:09.840
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10058 | 2020-10-20 16:13:09.840
SC DTC Delayed Exchange Data | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2020-10-20 16:13:09.840
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-20 16:13:09.840
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-20 16:13:09.840
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2020-10-20 16:13:09.840
Delaying start of download for ESZ20 | 2020-10-20 16:13:09.840
DTC Client socket (1) | Creating socket. | 2020-10-20 16:13:09.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-20 16:13:09.840
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-20 16:13:09.840
SC DTC Delayed Exchange Data | Network connection to server complete. | 2020-10-20 16:13:09.980
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2020-10-20 16:13:09.980
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS | 2020-10-20 16:13:09.981
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2020-10-20 16:13:10.163
SC DTC Delayed Exchange Data | Sending logon request message. | 2020-10-20 16:13:10.163
SC DTC Delayed Exchange Data | Received logon response. | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Successfully connected. | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Trading is not supported. | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESZ20 -> ESZ20 | 2020-10-20 16:13:10.850
SC DTC Delayed Exchange Data | Received security definition for symbol ESZ20 | 2020-10-20 16:13:11.071
HD Request # 3 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-20 16:13:16.152
Enabling compression for file: C:\SierraChart\Data\ESZ20.scid. This may take a while. | 2020-10-20 16:13:16.152 *
HD Request # 3 | Download start date-time: 2020-10-20 16:02:51.000000. File last date-time: 2020-10-20 16:02:51.023000 | 2020-10-20 16:13:16.152
HD Request # 3 | Using server: ds21.sierracharts.com port 10149 | 2020-10-20 16:13:16.152
Socket (3) | Creating socket. | 2020-10-20 16:13:16.152
Socket (3) | New receive buffer size: 5242880 | 2020-10-20 16:13:16.152
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-10-20 16:13:16.152
HD Request # 3 | Setting DTC encoding to Binary VLS | 2020-10-20 16:13:16.433
HD Request # 3 | Sending historical data logon request message. | 2020-10-20 16:13:16.433
HD Request # 3 | Requesting Intraday data. Start date-time: 2020-10-20 16:02:51. Record interval: 0. Symbol: ESZ20 | 2020-10-20 16:13:16.989
HD Request # 3 | Decompressing data. | 2020-10-20 16:13:17.128
HD Request # 3 | Receiving Intraday data for ESZ20 starting at 2020-10-20 16:02:51.023000 | 2020-10-20 16:13:17.130
Socket (3) | CloseSocket call. | 2020-10-20 16:13:17.266
Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-20 16:13:17.266
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-20 16:13:17.266
Historical data download thread signaled to stop. | 2020-10-20 16:13:17.266
HD Request # 3 | Timestamp of first Intraday data file record written: 2020-10-20 16:02:51.833000 | 2020-10-20 16:13:17.266
HD Request # 3 | Received 1301 records from 2020-10-20 16:02:51.023000 to 2020-10-20 16:03:15.551000 (24.5 seconds) and wrote 1300 records for ESZ20 | 2020-10-20 16:13:17.266
HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2020-10-20 14:03:15.551000 | 2020-10-20 16:13:17.267
HD Request # 3 | Completion time: 1s | 2020-10-20 16:13:17.267
HD Request # 3 | Intraday data download complete for ESZ20. Unique request ID: 3 | 2020-10-20 16:13:17.267
Removing historical data download ID 3. | 2020-10-20 16:13:17.267
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-20 16:13:17.267
Intraday chart data file opened for ESZ20 | 2020-10-20 16:13:17.267
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2020-10-20 16:13:17.267
Triggering next historical data download in queue. | 2020-10-20 16:13:17.267
Socket (3) | Socket gracefully closed by remote side. | 2020-10-20 16:13:17.403
Socket (3) | Closed. | 2020-10-20 16:13:17.404
Opened cached Intraday file: C:\SierraChart\Data\ESZ20.scid. Thread ID: 4600 | 2020-10-20 16:13:17.471
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-10-20 16:15:17.903
DTC Client socket (2) | Closed. | 2020-10-20 16:15:17.903
DTC Client socket (2) | Deleting network socket now after delay. | 2020-10-20 16:15:47.908
ESZ20 1 Min #1 | Reloading chart. | 2020-10-20 16:17:37.079
ESZ20 3 Min #2 | Reloading chart. | 2020-10-20 16:17:37.088
ESZ20 15 Min #3 | Reloading chart. | 2020-10-20 16:17:37.096
ESZ20 60 Min #4 | Reloading chart. | 2020-10-20 16:17:37.107
ESZ20 1 Day #5 | Reloading chart. | 2020-10-20 16:17:37.115
Here is my Message Log
I have a problem with data for ES.
They are delayed by 10 min.
Thanks for the help
[2020-10-20 14:34:46]
This is the relevant line:
You need to connect to your trading account in order to authorize the Real-Time data from the CME. This expired on October 16. Refer to the following for more information:
