Date/Time: Tue, 04 Nov 2025 14:13:48 +0000
Study Subgraph Above/Below Bar as Text - Option to left/right align text
View Count: 1364
|   [2020-10-18 23:48:39]     |
| logi - Posts: 1 |
                I am using Split Profiles on the Numbers Bars study and I want to display text above the Bid side and the Ask side of the profile. The Study Subgraph Above/Below Bar as Text only displays text in the center above the profile. I want an option to left-align, center-align and right-align the text. Or an offset field to enter positive or negative numbers to shift the text right or left of center.  Is there a different indicator or method that can achieve my desired result?  |
|   [2020-10-19 14:42:16]     |
                We will see about adding new  Draw Styles to support this.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2020-11-09 12:52:21]     |
| Ackin - Posts: 1865 |
                Thanks for that but: When using left and right text, the text is merged.....Would it be possible to insert a separator there? 1) One character from center to left and one character from center to right (as native function ... not as initialization in every uses and defined by the programmer by modifying the string) or 2) directly insert the separator tag with optional color or 3) Separator drawstyle Thank you Date Time Of Last Edit: 2020-11-09 13:17:08
|   [2020-11-09 13:22:40]     |
                btw for site admin "in good" the description is not updated ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle  |
