Date/Time: Wed, 12 Feb 2025 09:51:33 +0000
Issue with 3rd Sierra logging in
View Count: 517
[2020-10-16 05:48:59]
Mila - Posts: 44
Hi, I am on a 15 day trial of Sierra, I have 5 more days left. I managed to connect first Sierra to TWS on the same computer, second Sierra on my laptop running separately but connected to the TWS on my initial desktop, I am now trying to run a 3rd Sierra on yet another laptop, connecting to the same TWS running on my desktop, but when I try to connect my 3rd Sierra, and go into Global Settings > Data /Trade Service Settings> in the Service window the only thing available for Interactive Brokers is: Interactive Brokers (not enabled on package) [trading]. So the 3rd Sierra is not able to connect.
I thought I was allowed multiple Sierras or is it because I am on a trial 15 day version that I can only get two going at the same time and are not allowed to connect the third one? or is there something I have to do with the settings?
Please help.
Thank you
Mila
[2020-10-16 05:55:47]
Mila - Posts: 44
also here is the log:
Reading Internal Order ID file. | 2020-10-16 01:55:03.689
Reading Trade Orders file. | 2020-10-16 01:55:03.774
Reading Trade Positions file. | 2020-10-16 01:55:03.774
Reading Account Balance file. | 2020-10-16 01:55:03.775
UDPListener (1408). Port 22904 | Listening on UDP port 22904. | 2020-10-16 01:55:03.794
Software version: 2182 64-bit | 2020-10-16 01:55:03.794
Primary Thread ID: 2660 | 2020-10-16 01:55:03.794
Usage end date: 2020-10-30 | 2020-10-16 01:55:03.794
Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2020-10-16 01:55:03.794
To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2020-10-16 01:55:03.794 *
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-16 01:55:03.794
Current selected Data/Trading service: Interactive Brokers | 2020-10-16 01:55:03.794
Custom symbol settings values: enabled | 2020-10-16 01:55:03.794
Chart Update Interval: 500 | 2020-10-16 01:55:03.794
Intraday Data Storage Time Unit: 1 | 2020-10-16 01:55:03.794
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-16 01:55:03.794
2020-10-16 01:55:03 Local computer time | 2020-10-16 01:55:03.794
2020-10-16 05:55:03 Local computer time in UTC | 2020-10-16 01:55:03.794
2020-10-16 01:55:03 Local computer time in SC Time Zone | 2020-10-16 01:55:03.794
2020-10-16 05:55:01 Server time in UTC | 2020-10-16 01:55:03.794
Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-10-16 01:55:03.794
Program path: C:\SierraChart\ | 2020-10-16 01:55:03.794
Data Files path: C:\SierraChart\Data\ | 2020-10-16 01:55:03.794
OS Version Number: 10.0 | 2020-10-16 01:55:03.795
Locale Setting: C | 2020-10-16 01:55:03.795
DLLs: UserContributedStudies_64.dll | 2020-10-16 01:55:03.795
Allowed protected custom studies: | 2020-10-16 01:55:03.795
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2020-10-16 01:55:03.816
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-16 01:55:03.843
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-16 01:55:04.121
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-16 01:55:04.121
Received 5 login tokens. | 2020-10-16 01:55:04.943
Symbol settings MD5 received. Request ID: 1. | 2020-10-16 01:55:05.747
Symbol settings are up-to-date for interactive_brokers.trading. | 2020-10-16 01:55:05.747
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-10-16 01:55:08.475
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-10-16 01:55:10.486 *
[2020-10-16 06:52:57]
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu.
You can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password.
2. Choose the particular Service Package that you want to automatically renew and press the "Update" button.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
[2020-10-16 13:44:08]
John - SC Support - Posts: 37891
With regards to the number of Sierra Chart installations you can run, you can only have 2 running at the same time on different computers. You are not allowed to have a 3rd computer running at the same time unless you pay extra for it. Refer to the information here:
Sierra Chart Purchase and License Information: Licensing / Number of Systems
[2020-10-16 19:26:45]
Mila - Posts: 44
Ok got it, thank you but I am still having an issue logging in.
I opened Sierra on my desktop, so that is one instance, then opened it on my 3rd laptop which is a second instance, and Sierra on my 3rd laptop is not connecting, still showing Interactive Brokers (not enabled on package) [trading]. I am not running Sierra anywhere else at the same time, just one instance on my desktop, so why is my 3rd laptop has Interactive Brokers (not enabled on package) [trading] showing? and how to reset it so Interactive Brokers [trading] is showing on this 3r laptop?
the Sierra charts that I downloaded to my 2nd laptop is shut down, so really i am just trying to have 2 instances working but the 3rd laptop IB is not activated. Please help.
thank you
[2020-10-16 19:43:58]
Actually, we see the issue. Your account got flagged since there was a login from another account on the same computer. That is why your log is showing that you do not have any time and why you are getting the messages that IB is not enabled on your package.
We have cleared your account, so you should be good for now.
[2020-10-16 19:48:40]
Mila - Posts: 44
yes i was trying to go from laptop and activate it from there, that is why i opened second account because i couldn't get in on the first account. so 3rd lap top is working and i will sign up for paid Sierra serice soon. thank you for all the help.
