Date/Time: Wed, 23 Sep 2026 18:04:08 +0000
Custom Data Charting Issue
View Count: 1048
[2020-10-13 04:55:27]
User353585 - Posts: 69
Hello, When I use custom .csv file for charting, I can't set the Start Time any other than 00:00:00. It just returns a blank chart.
I'd like to have it fixed because vertical lines in forward bar area are not correct if I don't set correct times. It used to be fine in older versions.
I attach a sample .csv data file. thanks.
Date Time Of Last Edit: 2020-10-13 04:56:56
Private File
[2020-10-13 14:28:50]
John - SC Support - Posts: 47990
We are not having any problem with the file you sent and changing the Chart Times.
The most likely reason you cannot change the Chart Times is that there is another chart that is referencing this one and it requires that they have the same times. Refer to the following information:
Chart Session Times: Session Times Automatically Changing Unexpectedly
[2020-10-13 15:17:05]
Reading Internal Order ID file. | 2020-10-13 15:13:42.135
Reading Trade Orders file. | 2020-10-13 15:13:42.186
Reading Trade Positions file. | 2020-10-13 15:13:42.186
Reading Account Balance file. | 2020-10-13 15:13:42.186
UDPListener (1528). Port 22904 | Listening on UDP port 22904. | 2020-10-13 15:13:42.197
Software version: 2181 64-bit | 2020-10-13 15:13:42.197
Primary Thread ID: 5468 | 2020-10-13 15:13:42.197
Usage end date: 2021-02-21 | 2020-10-13 15:13:42.197
Enabled for: Advanced Features 2. | 2020-10-13 15:13:42.198
Enabled for: Sierra Chart Historical Data Service. | 2020-10-13 15:13:42.198
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-13 15:13:42.198
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-13 15:13:42.198
Enabled for exchange2: CME (Trading Account Required) | 2020-10-13 15:13:42.198
Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-13 15:13:42.198
Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-13 15:13:42.198
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-13 15:13:42.198
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-13 15:13:42.198
Current selected Data/Trading service: SC Data - All Services | 2020-10-13 15:13:42.198
Custom symbol settings values: disabled | 2020-10-13 15:13:42.198
Chart Update Interval: 500 | 2020-10-13 15:13:42.198
Intraday Data Storage Time Unit: 1 | 2020-10-13 15:13:42.198
Time Zone: +00:00:00 (UTC+00) | 2020-10-13 15:13:42.198
2020-10-14 00:13:42 Local computer time | 2020-10-13 15:13:42.198
2020-10-13 15:13:42 Local computer time in UTC | 2020-10-13 15:13:42.198
2020-10-13 15:13:42 Local computer time in SC Time Zone | 2020-10-13 15:13:42.198
2020-10-13 15:13:43 Server time in UTC | 2020-10-13 15:13:42.198
Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-10-13 15:13:42.198
Program path: C:\SierraChart-Test\ | 2020-10-13 15:13:42.198
Data Files path: C:\SierraChart-Test\Data\ | 2020-10-13 15:13:42.198
OS Version Number: 10.0 | 2020-10-13 15:13:42.198
Locale Setting: C | 2020-10-13 15:13:42.198
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-13 15:13:42.198
Allowed protected custom studies: zyp_download_free | 2020-10-13 15:13:42.198
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-10-13 15:13:42.198
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-13 15:13:42.216
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-13 15:13:42.508
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-13 15:13:42.508
Received 5 login tokens. | 2020-10-13 15:13:43.230
Symbol settings MD5 received. Request ID: 1. | 2020-10-13 15:13:43.899
Symbol settings are up-to-date for scdataallservices. | 2020-10-13 15:13:43.899
Example Daily #1 | Reloading chart. | 2020-10-13 15:13:46.330
SC Data - All Services | Connected to server complete. | 2020-10-13 15:13:48.461
Triggering next historical data download in queue. | 2020-10-13 15:13:48.461
Example Daily #1 | Reloading chart. | 2020-10-13 15:14:03.108
Example Daily #1 | Reloading chart. | 2020-10-13 15:14:09.438
Example 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart-Test\Data\Example.csv | 2020-10-13 15:14:09.477
This is the log from the unmodified installation & new chart and I still experience the problem as I try to change the Start Time(from 00:00:00 to 09:00:00, for example). I can record the screen if you need. Could you help me further?
[2020-10-13 19:55:35]
Do the Session Times settings remain after you set them?
[2020-10-14 02:00:55]
yes.
And more seriously, the bar period seems to be fixed at 1 Day length, regardless of its settings.
Date Time Of Last Edit: 2020-10-14 05:29:36
[2020-10-14 11:11:34]
Ok so there is something about the timestamps of the data that you are using that is the issue.
Date Time Of Last Edit: 2020-10-14 11:11:40
[2020-10-14 13:27:11]
Can you tell me what's the issue from the original attached file? I couldn't find a problem.
[2020-10-14 23:24:22]
This is not within the scope of our support.
[2020-10-15 05:04:49]
The same problem persists even with the example data made from the documentation(I just pasted them and saved as a .csv file), so it doesn't look like a data problem. I don't know what to do if it still happens with the fresh installation & official example.
Text/CSV Data Format
Example for Intraday Data
Date, Time, Open, High, Low, Close, Volume
2013/06/10, 09:45, 19.17, 19.18, 19.16, 19.17, 5000
2013/06/10, 09:46, 19.16, 19.16, 19.13, 19.16, 2600
2013/06/10, 09:47, 19.17, 19.17, 19.13, 19.14, 8400
2013/06/10, 09:48, 19.13, 19.14, 19.05, 19.08, 8400
2013/06/10, 09:49, 19.08, 19.08, 19.04, 19.04, 8100
Additional note : I tested and there is no problem with version 2000, so there must be some glitch in newer versions I believe.
Date Time Of Last Edit: 2020-10-15 06:44:26
