Date/Time: Wed, 12 Feb 2025 04:09:13 +0000
2nd Denali Feed
View Count: 857
[2020-10-05 23:44:20]
User736044 - Posts: 51
I paid for the second Denali feed, and for some reason it only shows that I have 1 active.
Thank You!
[2020-10-06 08:32:10]
Yes we do see that you do have 2 Denali data feed connections.
We recommend reconnecting to the data feed all installations of Sierra Chart:
Let us know if you still have a problem.
[2020-10-06 21:15:14]
I have to keep doing that, the comp keep disconnecting one another
[2020-10-06 22:32:40]
Provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-10-07 13:00:37]
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:10:14.640
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:10:14.640
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:10:14.640
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:10:14.640
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:10:14.640
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:10:14.640
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:10:14.640
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:10:14.640
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:10:14.641
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:10:14.653
DTC Client socket (1) | Closed. | 2020-10-07 00:10:14.653
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:10:44.643
DTC Client socket (1) | Creating socket. | 2020-10-07 00:10:44.644
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:10:44.644
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:10:44.644
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:10:44.676
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:10:44.676
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:10:44.676
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:10:44.717
SC Data - All Services | Sending logon request message. | 2020-10-07 00:10:44.717
SC Data - All Services | Received logon response. | 2020-10-07 00:10:45.338
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:10:45.338
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:10:45.338
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:10:45.338
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:10:45.338
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:10:45.338
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:10:45.338
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:10:45.339
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:10:45.339
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:10:45.339
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:10:45.356
DTC Client socket (1) | Closed. | 2020-10-07 00:10:45.356
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:11:15.349
DTC Client socket (1) | Creating socket. | 2020-10-07 00:11:15.349
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:11:15.349
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:11:15.350
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:11:15.381
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:11:15.381
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:11:15.381
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:11:15.419
SC Data - All Services | Sending logon request message. | 2020-10-07 00:11:15.419
SC Data - All Services | Received logon response. | 2020-10-07 00:11:16.122
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:11:16.122
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:11:16.122
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:11:16.122
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:11:16.122
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:11:16.122
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:11:16.122
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:11:16.122
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:11:16.122
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:11:16.122
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:11:16.149
DTC Client socket (1) | Closed. | 2020-10-07 00:11:16.149
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:11:46.124
DTC Client socket (1) | Creating socket. | 2020-10-07 00:11:46.125
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:11:46.125
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:11:46.125
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:11:46.150
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:11:46.150
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:11:46.150
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:11:46.198
SC Data - All Services | Sending logon request message. | 2020-10-07 00:11:46.198
SC Data - All Services | Received logon response. | 2020-10-07 00:11:46.831
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:11:46.831
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:11:46.831
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:11:46.831
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:11:46.831
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:11:46.831
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:11:46.831
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:11:46.831
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:11:46.831
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:11:46.831
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:11:46.844
DTC Client socket (1) | Closed. | 2020-10-07 00:11:46.844
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:12:16.823
DTC Client socket (1) | Creating socket. | 2020-10-07 00:12:16.823
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:12:16.823
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:12:16.823
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:12:16.851
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:12:16.851
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:12:16.851
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:12:16.881
SC Data - All Services | Sending logon request message. | 2020-10-07 00:12:16.881
SC Data - All Services | Received logon response. | 2020-10-07 00:12:17.527
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:12:17.527
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:12:17.527
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:12:17.527
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:12:17.527
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:12:17.527
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:12:17.527
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:12:17.527
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:12:17.527
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:12:17.527
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:12:17.539
DTC Client socket (1) | Closed. | 2020-10-07 00:12:17.539
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1129 seconds. | 2020-10-07 00:12:25.032
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0388 seconds. | 2020-10-07 00:12:25.072
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:12:47.536
DTC Client socket (1) | Creating socket. | 2020-10-07 00:12:47.536
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:12:47.536
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:12:47.536
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:12:47.559
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:12:47.559
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:12:47.559
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:12:47.592
SC Data - All Services | Sending logon request message. | 2020-10-07 00:12:47.593
SC Data - All Services | Received logon response. | 2020-10-07 00:12:48.228
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:12:48.228
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:12:48.228
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:12:48.228
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:12:48.228
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:12:48.228
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:12:48.228
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:12:48.228
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:12:48.228
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:12:48.228
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:12:48.242
DTC Client socket (1) | Closed. | 2020-10-07 00:12:48.242
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:13:18.241
DTC Client socket (1) | Creating socket. | 2020-10-07 00:13:18.242
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:13:18.242
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:13:18.242
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:13:18.268
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:13:18.268
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:13:18.268
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:13:18.303
SC Data - All Services | Sending logon request message. | 2020-10-07 00:13:18.303
SC Data - All Services | Received logon response. | 2020-10-07 00:13:18.989
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:13:18.989
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:13:18.989
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:13:18.989
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:13:18.989
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:13:18.989
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:13:18.989
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:13:18.989
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:13:18.989
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:13:18.989
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:13:19.015
DTC Client socket (1) | Closed. | 2020-10-07 00:13:19.015
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:13:48.982
DTC Client socket (1) | Creating socket. | 2020-10-07 00:13:48.983
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:13:48.983
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:13:48.983
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:13:49.007
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:13:49.007
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:13:49.007
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:13:49.039
SC Data - All Services | Sending logon request message. | 2020-10-07 00:13:49.039
SC Data - All Services | Received logon response. | 2020-10-07 00:13:49.672
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:13:49.672
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:13:49.672
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:13:49.672
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:13:49.672
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:13:49.672
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:13:49.672
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:13:49.672
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:13:49.672
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:13:49.672
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:13:49.685
DTC Client socket (1) | Closed. | 2020-10-07 00:13:49.685
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:14:19.673
DTC Client socket (1) | Creating socket. | 2020-10-07 00:14:19.674
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:14:19.674
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:14:19.674
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:14:19.696
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:14:19.696
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:14:19.696
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:14:19.741
SC Data - All Services | Sending logon request message. | 2020-10-07 00:14:19.741
SC Data - All Services | Received logon response. | 2020-10-07 00:14:20.363
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:14:20.363
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:14:20.363
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:14:20.363
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:14:20.363
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:14:20.364
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:14:20.364
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:14:20.364
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:14:20.364
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:14:20.364
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:14:20.376
DTC Client socket (1) | Closed. | 2020-10-07 00:14:20.376
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:14:50.357
DTC Client socket (1) | Creating socket. | 2020-10-07 00:14:50.357
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:14:50.357
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:14:50.357
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:14:50.388
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:14:50.388
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:14:50.388
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:14:50.415
SC Data - All Services | Sending logon request message. | 2020-10-07 00:14:50.415
SC Data - All Services | Received logon response. | 2020-10-07 00:14:51.070
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:14:51.070
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:14:51.070
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:14:51.070
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:14:51.070
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:14:51.070
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:14:51.070
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:14:51.070
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:14:51.070
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:14:51.070
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:14:51.085
DTC Client socket (1) | Closed. | 2020-10-07 00:14:51.085
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:15:21.074
DTC Client socket (1) | Creating socket. | 2020-10-07 00:15:21.075
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:15:21.075
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:15:21.075
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:15:21.097
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:15:21.097
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:15:21.097
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:15:21.134
SC Data - All Services | Sending logon request message. | 2020-10-07 00:15:21.134
SC Data - All Services | Received logon response. | 2020-10-07 00:15:21.839
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:15:21.839
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:15:21.839
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:15:21.839
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:15:21.839
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:15:21.839
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:15:21.839
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:15:21.839
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:15:21.839
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:15:21.839
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:15:21.863
DTC Client socket (1) | Closed. | 2020-10-07 00:15:21.863
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:15:51.838
DTC Client socket (1) | Creating socket. | 2020-10-07 00:15:51.839
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:15:51.839
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:15:51.839
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:15:51.867
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:15:51.867
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:15:51.867
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:15:51.914
SC Data - All Services | Sending logon request message. | 2020-10-07 00:15:51.914
SC Data - All Services | Received logon response. | 2020-10-07 00:15:52.601
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:15:52.601
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:15:52.601
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:15:52.601
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:15:52.601
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:15:52.601
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:15:52.601
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:15:52.601
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:15:52.601
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:15:52.601
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:15:52.618
DTC Client socket (1) | Closed. | 2020-10-07 00:15:52.618
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:16:22.602
DTC Client socket (1) | Creating socket. | 2020-10-07 00:16:22.602
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:16:22.603
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:16:22.603
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:16:22.620
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:16:22.620
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:16:22.620
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:16:22.665
SC Data - All Services | Sending logon request message. | 2020-10-07 00:16:22.665
SC Data - All Services | Received logon response. | 2020-10-07 00:16:23.270
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:16:23.270
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:16:23.270
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:16:23.270
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:16:23.270
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:16:23.270
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:16:23.270
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:16:23.270
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:16:23.270
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:16:23.270
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:16:23.286
DTC Client socket (1) | Closed. | 2020-10-07 00:16:23.286
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:16:53.261
DTC Client socket (1) | Creating socket. | 2020-10-07 00:16:53.261
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:16:53.261
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:16:53.261
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:16:53.276
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:16:53.276
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:16:53.276
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:16:53.307
SC Data - All Services | Sending logon request message. | 2020-10-07 00:16:53.307
SC Data - All Services | Received logon response. | 2020-10-07 00:16:53.907
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:16:53.907
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:16:53.907
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:16:53.907
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:16:53.907
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:16:53.907
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:16:53.907
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:16:53.907
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:16:53.907
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:16:53.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:16:53.923
DTC Client socket (1) | Closed. | 2020-10-07 00:16:53.923
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:17:23.900
DTC Client socket (1) | Creating socket. | 2020-10-07 00:17:23.901
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:17:23.902
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:17:23.902
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:17:23.935
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:17:23.935
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:17:23.935
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:17:23.977
SC Data - All Services | Sending logon request message. | 2020-10-07 00:17:23.977
SC Data - All Services | Received logon response. | 2020-10-07 00:17:24.663
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:17:24.663
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:17:24.663
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:17:24.663
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:17:24.663
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:17:24.663
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:17:24.663
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:17:24.663
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:17:24.663
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:17:24.663
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:17:24.689
DTC Client socket (1) | Closed. | 2020-10-07 00:17:24.689
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:17:54.655
DTC Client socket (1) | Creating socket. | 2020-10-07 00:17:54.656
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:17:54.656
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:17:54.656
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:17:54.677
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:17:54.677
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:17:54.677
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:17:54.702
SC Data - All Services | Sending logon request message. | 2020-10-07 00:17:54.702
SC Data - All Services | Received logon response. | 2020-10-07 00:17:55.335
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:17:55.335
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:17:55.335
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:17:55.335
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:17:55.335
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:17:55.335
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:17:55.335
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:17:55.335
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:17:55.335
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:17:55.335
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:17:55.353
DTC Client socket (1) | Closed. | 2020-10-07 00:17:55.353
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:18:25.322
DTC Client socket (1) | Creating socket. | 2020-10-07 00:18:25.323
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:18:25.323
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:18:25.323
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:18:25.346
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:18:25.346
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:18:25.346
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:18:25.376
SC Data - All Services | Sending logon request message. | 2020-10-07 00:18:25.376
SC Data - All Services | Received logon response. | 2020-10-07 00:18:25.998
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:18:25.998
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:18:25.998
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:18:25.998
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:18:25.998
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:18:25.998
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:18:25.998
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:18:25.998
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:18:25.998
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:18:25.998
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:18:26.010
DTC Client socket (1) | Closed. | 2020-10-07 00:18:26.010
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:18:56.003
DTC Client socket (1) | Creating socket. | 2020-10-07 00:18:56.004
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:18:56.004
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:18:56.004
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:18:56.020
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:18:56.020
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:18:56.020
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:18:56.043
SC Data - All Services | Sending logon request message. | 2020-10-07 00:18:56.043
SC Data - All Services | Received logon response. | 2020-10-07 00:18:56.653
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:18:56.653
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:18:56.653
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:18:56.653
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:18:56.653
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:18:56.653
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:18:56.653
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:18:56.653
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:18:56.653
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:18:56.653
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:18:56.666
DTC Client socket (1) | Closed. | 2020-10-07 00:18:56.666
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:19:26.648
DTC Client socket (1) | Creating socket. | 2020-10-07 00:19:26.649
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:19:26.649
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:19:26.649
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:19:26.687
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:19:26.687
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:19:26.687
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:19:26.734
SC Data - All Services | Sending logon request message. | 2020-10-07 00:19:26.734
SC Data - All Services | Received logon response. | 2020-10-07 00:19:27.476
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:19:27.476
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:19:27.476
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:19:27.476
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:19:27.476
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:19:27.477
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:19:27.477
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:19:27.477
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:19:27.477
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:19:27.477
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:19:27.502
DTC Client socket (1) | Closed. | 2020-10-07 00:19:27.503
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:19:57.488
DTC Client socket (1) | Creating socket. | 2020-10-07 00:19:57.488
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:19:57.488
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:19:57.488
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:19:57.509
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:19:57.509
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:19:57.509
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:19:57.550
SC Data - All Services | Sending logon request message. | 2020-10-07 00:19:57.550
SC Data - All Services | Received logon response. | 2020-10-07 00:19:58.204
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:19:58.204
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:19:58.204
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:19:58.204
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:19:58.204
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:19:58.204
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:19:58.204
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:19:58.204
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:19:58.204
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:19:58.204
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:19:58.221
DTC Client socket (1) | Closed. | 2020-10-07 00:19:58.222
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:20:28.207
DTC Client socket (1) | Creating socket. | 2020-10-07 00:20:28.208
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:20:28.208
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:20:28.208
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:20:28.229
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:20:28.229
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:20:28.229
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:20:28.263
SC Data - All Services | Sending logon request message. | 2020-10-07 00:20:28.263
SC Data - All Services | Received logon response. | 2020-10-07 00:20:28.843
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:20:28.843
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:20:28.843
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:20:28.843
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:20:28.843
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:20:28.843
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:20:28.843
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:20:28.843
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:20:28.843
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:20:28.843
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:20:28.859
DTC Client socket (1) | Closed. | 2020-10-07 00:20:28.859
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:20:58.839
DTC Client socket (1) | Creating socket. | 2020-10-07 00:20:58.839
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:20:58.840
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:20:58.840
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:20:58.854
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:20:58.854
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:20:58.854
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:20:58.876
SC Data - All Services | Sending logon request message. | 2020-10-07 00:20:58.876
SC Data - All Services | Received logon response. | 2020-10-07 00:20:59.517
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:20:59.517
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:20:59.517
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:20:59.517
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:20:59.517
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:20:59.517
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:20:59.517
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:20:59.517
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:20:59.517
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:20:59.517
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:20:59.532
DTC Client socket (1) | Closed. | 2020-10-07 00:20:59.532
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:21:29.517
DTC Client socket (1) | Creating socket. | 2020-10-07 00:21:29.518
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:21:29.518
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:21:29.518
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:21:29.543
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:21:29.543
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:21:29.543
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:21:29.576
SC Data - All Services | Sending logon request message. | 2020-10-07 00:21:29.576
SC Data - All Services | Received logon response. | 2020-10-07 00:21:30.288
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:21:30.288
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:21:30.288
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:21:30.288
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:21:30.288
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:21:30.288
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:21:30.288
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:21:30.288
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:21:30.288
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:21:30.289
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:21:30.315
DTC Client socket (1) | Closed. | 2020-10-07 00:21:30.315
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:22:00.303
DTC Client socket (1) | Creating socket. | 2020-10-07 00:22:00.304
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:22:00.304
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:22:00.304
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:22:00.324
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:22:00.324
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:22:00.324
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:22:00.346
SC Data - All Services | Sending logon request message. | 2020-10-07 00:22:00.346
SC Data - All Services | Received logon response. | 2020-10-07 00:22:01.002
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:22:01.002
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:22:01.002
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:22:01.002
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:22:01.003
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:22:01.003
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:22:01.003
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:22:01.003
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:22:01.003
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:22:01.003
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:22:01.015
DTC Client socket (1) | Closed. | 2020-10-07 00:22:01.016
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:22:31.003
DTC Client socket (1) | Creating socket. | 2020-10-07 00:22:31.004
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:22:31.004
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:22:31.004
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:22:31.022
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:22:31.022
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:22:31.022
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:22:31.057
SC Data - All Services | Sending logon request message. | 2020-10-07 00:22:31.057
SC Data - All Services | Received logon response. | 2020-10-07 00:22:31.698
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:22:31.699
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:22:31.699
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:22:31.699
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:22:31.699
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:22:31.699
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:22:31.699
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:22:31.699
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:22:31.699
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:22:31.699
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:22:31.715
DTC Client socket (1) | Closed. | 2020-10-07 00:22:31.715
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:23:01.708
DTC Client socket (1) | Creating socket. | 2020-10-07 00:23:01.708
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:23:01.708
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:23:01.708
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:23:01.731
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:23:01.731
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:23:01.731
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:23:01.744
SC Data - All Services | Sending logon request message. | 2020-10-07 00:23:01.744
SC Data - All Services | Received logon response. | 2020-10-07 00:23:02.373
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:23:02.373
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:23:02.373
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:23:02.373
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:23:02.373
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:23:02.373
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:23:02.373
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:23:02.373
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:23:02.373
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:23:02.373
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:23:02.386
DTC Client socket (1) | Closed. | 2020-10-07 00:23:02.386
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:23:32.384
DTC Client socket (1) | Creating socket. | 2020-10-07 00:23:32.384
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:23:32.384
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:23:32.384
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:23:32.415
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:23:32.415
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:23:32.415
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:23:32.473
SC Data - All Services | Sending logon request message. | 2020-10-07 00:23:32.473
SC Data - All Services | Received logon response. | 2020-10-07 00:23:33.165
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:23:33.165
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:23:33.165
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:23:33.165
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:23:33.165
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:23:33.165
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:23:33.165
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:23:33.165
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:23:33.165
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:23:33.165
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:23:33.191
DTC Client socket (1) | Closed. | 2020-10-07 00:23:33.191
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:24:03.177
DTC Client socket (2) | Creating socket. | 2020-10-07 00:24:03.177
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 00:24:03.178
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:24:03.178
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:24:03.194
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:24:03.194
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:24:03.194
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:24:03.236
SC Data - All Services | Sending logon request message. | 2020-10-07 00:24:03.237
SC Data - All Services | Received logon response. | 2020-10-07 00:24:03.891
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:24:03.891
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:24:03.891
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:24:03.891
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:24:03.891
DTC Client socket (2) | CloseSocket call. | 2020-10-07 00:24:03.891
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:24:03.891
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:24:03.891
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:24:03.891
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:24:03.891
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 00:24:03.904
DTC Client socket (2) | Closed. | 2020-10-07 00:24:03.904
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:24:33.893
DTC Client socket (1) | Creating socket. | 2020-10-07 00:24:33.894
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:24:33.894
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:24:33.894
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:24:33.916
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:24:33.916
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:24:33.916
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:24:33.953
SC Data - All Services | Sending logon request message. | 2020-10-07 00:24:33.953
SC Data - All Services | Received logon response. | 2020-10-07 00:24:34.503
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:24:34.503
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:24:34.503
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:24:34.503
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:24:34.503
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:24:34.503
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:24:34.503
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:24:34.503
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:24:34.503
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:24:34.503
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:24:34.519
DTC Client socket (1) | Closed. | 2020-10-07 00:24:34.519
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:25:04.503
DTC Client socket (1) | Creating socket. | 2020-10-07 00:25:04.503
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:25:04.503
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:25:04.503
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:25:04.525
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:25:04.525
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:25:04.525
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:25:04.541
SC Data - All Services | Sending logon request message. | 2020-10-07 00:25:04.542
SC Data - All Services | Received logon response. | 2020-10-07 00:25:05.121
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:25:05.121
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:25:05.121
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:25:05.121
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:25:05.122
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:25:05.122
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:25:05.122
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:25:05.122
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:25:05.122
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:25:05.122
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:25:05.138
DTC Client socket (1) | Closed. | 2020-10-07 00:25:05.138
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:25:35.117
DTC Client socket (1) | Creating socket. | 2020-10-07 00:25:35.117
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:25:35.117
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:25:35.117
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:25:35.145
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:25:35.145
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:25:35.146
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:25:35.179
SC Data - All Services | Sending logon request message. | 2020-10-07 00:25:35.179
SC Data - All Services | Received logon response. | 2020-10-07 00:25:35.872
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:25:35.872
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:25:35.872
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:25:35.872
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:25:35.872
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:25:35.872
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:25:35.872
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:25:35.872
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:25:35.872
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:25:35.872
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:25:35.897
DTC Client socket (1) | Closed. | 2020-10-07 00:25:35.897
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:26:05.876
DTC Client socket (1) | Creating socket. | 2020-10-07 00:26:05.877
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:26:05.877
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:26:05.877
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:26:05.892
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:26:05.892
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:26:05.892
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:26:05.938
SC Data - All Services | Sending logon request message. | 2020-10-07 00:26:05.938
SC Data - All Services | Received logon response. | 2020-10-07 00:26:06.614
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:26:06.614
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:26:06.614
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:26:06.614
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:26:06.614
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:26:06.614
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:26:06.614
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:26:06.614
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:26:06.614
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:26:06.614
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:26:06.626
DTC Client socket (1) | Closed. | 2020-10-07 00:26:06.626
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:26:36.611
DTC Client socket (1) | Creating socket. | 2020-10-07 00:26:36.611
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:26:36.611
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:26:36.611
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:26:36.632
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:26:36.632
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:26:36.632
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:26:36.687
SC Data - All Services | Sending logon request message. | 2020-10-07 00:26:36.687
SC Data - All Services | Received logon response. | 2020-10-07 00:26:37.325
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:26:37.325
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:26:37.325
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:26:37.325
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:26:37.325
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:26:37.326
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:26:37.326
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:26:37.326
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:26:37.326
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:26:37.326
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:26:37.339
DTC Client socket (1) | Closed. | 2020-10-07 00:26:37.340
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:27:07.325
DTC Client socket (1) | Creating socket. | 2020-10-07 00:27:07.326
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:27:07.326
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:27:07.326
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:27:07.340
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:27:07.340
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:27:07.340
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:27:07.384
SC Data - All Services | Sending logon request message. | 2020-10-07 00:27:07.385
SC Data - All Services | Received logon response. | 2020-10-07 00:27:08.035
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:27:08.035
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:27:08.035
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:27:08.035
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:27:08.035
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:27:08.035
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:27:08.035
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:27:08.035
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:27:08.035
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:27:08.035
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:27:08.049
DTC Client socket (1) | Closed. | 2020-10-07 00:27:08.049
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1102 seconds. | 2020-10-07 00:27:25.184
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0340 seconds. | 2020-10-07 00:27:25.219
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:27:38.031
DTC Client socket (1) | Creating socket. | 2020-10-07 00:27:38.032
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:27:38.032
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:27:38.032
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:27:38.071
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:27:38.071
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:27:38.071
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:27:38.118
SC Data - All Services | Sending logon request message. | 2020-10-07 00:27:38.118
SC Data - All Services | Received logon response. | 2020-10-07 00:27:38.782
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:27:38.782
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:27:38.782
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:27:38.782
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:27:38.782
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:27:38.782
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:27:38.782
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:27:38.782
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:27:38.782
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:27:38.782
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:27:38.809
DTC Client socket (1) | Closed. | 2020-10-07 00:27:38.809
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:28:08.777
DTC Client socket (1) | Creating socket. | 2020-10-07 00:28:08.777
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:28:08.777
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:28:08.777
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:28:08.801
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:28:08.801
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:28:08.801
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:28:08.830
SC Data - All Services | Sending logon request message. | 2020-10-07 00:28:08.830
SC Data - All Services | Received logon response. | 2020-10-07 00:28:09.486
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:28:09.486
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:28:09.486
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:28:09.486
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:28:09.486
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:28:09.486
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:28:09.486
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:28:09.486
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:28:09.486
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:28:09.486
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:28:09.500
DTC Client socket (1) | Closed. | 2020-10-07 00:28:09.500
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:28:39.481
DTC Client socket (1) | Creating socket. | 2020-10-07 00:28:39.482
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:28:39.482
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:28:39.482
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:28:39.502
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:28:39.502
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:28:39.502
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:28:39.534
SC Data - All Services | Sending logon request message. | 2020-10-07 00:28:39.534
SC Data - All Services | Received logon response. | 2020-10-07 00:28:40.173
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:28:40.173
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:28:40.173
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:28:40.173
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:28:40.173
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:28:40.173
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:28:40.173
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:28:40.173
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:28:40.173
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:28:40.173
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:28:40.185
DTC Client socket (1) | Closed. | 2020-10-07 00:28:40.185
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:29:10.174
DTC Client socket (1) | Creating socket. | 2020-10-07 00:29:10.174
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:29:10.174
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:29:10.174
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:29:10.187
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:29:10.187
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:29:10.187
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:29:10.219
SC Data - All Services | Sending logon request message. | 2020-10-07 00:29:10.219
SC Data - All Services | Received logon response. | 2020-10-07 00:29:10.871
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:29:10.871
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:29:10.871
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:29:10.871
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:29:10.871
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:29:10.872
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:29:10.872
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:29:10.872
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:29:10.872
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:29:10.872
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:29:10.888
DTC Client socket (1) | Closed. | 2020-10-07 00:29:10.888
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:29:40.876
DTC Client socket (1) | Creating socket. | 2020-10-07 00:29:40.877
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:29:40.877
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:29:40.877
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:29:40.907
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:29:40.907
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:29:40.907
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:29:40.948
SC Data - All Services | Sending logon request message. | 2020-10-07 00:29:40.948
SC Data - All Services | Received logon response. | 2020-10-07 00:29:41.636
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:29:41.636
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:29:41.636
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:29:41.636
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:29:41.636
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:29:41.636
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:29:41.636
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:29:41.636
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:29:41.636
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:29:41.636
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:29:41.662
DTC Client socket (1) | Closed. | 2020-10-07 00:29:41.662
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:30:11.641
DTC Client socket (1) | Creating socket. | 2020-10-07 00:30:11.642
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:30:11.642
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:30:11.642
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:30:11.664
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:30:11.664
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:30:11.664
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:30:11.718
SC Data - All Services | Sending logon request message. | 2020-10-07 00:30:11.718
SC Data - All Services | Received logon response. | 2020-10-07 00:30:12.382
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:30:12.382
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:30:12.382
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:30:12.382
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:30:12.382
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:30:12.382
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:30:12.382
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:30:12.382
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:30:12.382
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:30:12.382
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:30:12.397
DTC Client socket (1) | Closed. | 2020-10-07 00:30:12.397
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:30:42.386
DTC Client socket (1) | Creating socket. | 2020-10-07 00:30:42.386
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:30:42.387
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:30:42.387
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:30:42.401
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:30:42.401
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:30:42.401
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:30:42.439
SC Data - All Services | Sending logon request message. | 2020-10-07 00:30:42.439
SC Data - All Services | Received logon response. | 2020-10-07 00:30:43.084
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:30:43.084
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:30:43.084
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:30:43.084
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:30:43.084
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:30:43.084
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:30:43.084
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:30:43.084
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:30:43.084
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:30:43.084
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:30:43.098
DTC Client socket (1) | Closed. | 2020-10-07 00:30:43.098
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:31:13.076
DTC Client socket (1) | Creating socket. | 2020-10-07 00:31:13.076
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:31:13.076
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:31:13.076
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:31:13.098
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:31:13.098
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:31:13.099
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:31:13.122
SC Data - All Services | Sending logon request message. | 2020-10-07 00:31:13.122
SC Data - All Services | Received logon response. | 2020-10-07 00:31:13.748
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:31:13.748
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:31:13.748
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:31:13.748
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:31:13.748
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:31:13.749
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:31:13.749
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:31:13.749
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:31:13.749
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:31:13.749
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:31:13.762
DTC Client socket (1) | Closed. | 2020-10-07 00:31:13.762
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:31:43.751
DTC Client socket (1) | Creating socket. | 2020-10-07 00:31:43.751
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:31:43.751
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:31:43.752
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:31:43.781
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:31:43.781
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:31:43.781
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:31:43.832
SC Data - All Services | Sending logon request message. | 2020-10-07 00:31:43.832
SC Data - All Services | Received logon response. | 2020-10-07 00:31:44.537
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:31:44.537
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:31:44.537
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:31:44.537
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:31:44.537
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:31:44.538
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:31:44.538
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:31:44.538
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:31:44.538
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:31:44.538
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:31:44.564
DTC Client socket (1) | Closed. | 2020-10-07 00:31:44.564
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:32:14.535
DTC Client socket (1) | Creating socket. | 2020-10-07 00:32:14.535
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:32:14.535
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:32:14.535
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:32:14.561
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:32:14.561
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:32:14.561
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:32:14.580
SC Data - All Services | Sending logon request message. | 2020-10-07 00:32:14.580
SC Data - All Services | Received logon response. | 2020-10-07 00:32:15.251
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:32:15.251
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:32:15.251
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:32:15.251
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:32:15.251
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:32:15.251
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:32:15.251
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:32:15.251
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:32:15.251
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:32:15.252
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:32:15.264
DTC Client socket (1) | Closed. | 2020-10-07 00:32:15.265
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:32:45.257
DTC Client socket (1) | Creating socket. | 2020-10-07 00:32:45.257
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:32:45.257
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:32:45.257
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:32:45.288
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:32:45.288
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:32:45.288
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:32:45.323
SC Data - All Services | Sending logon request message. | 2020-10-07 00:32:45.323
SC Data - All Services | Received logon response. | 2020-10-07 00:32:45.958
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:32:45.958
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:32:45.958
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:32:45.958
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:32:45.958
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:32:45.959
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:32:45.959
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:32:45.959
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:32:45.959
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:32:45.959
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:32:45.975
DTC Client socket (1) | Closed. | 2020-10-07 00:32:45.975
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:33:15.959
DTC Client socket (1) | Creating socket. | 2020-10-07 00:33:15.959
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:33:15.959
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:33:15.960
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:33:15.974
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:33:15.974
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:33:15.974
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:33:15.997
SC Data - All Services | Sending logon request message. | 2020-10-07 00:33:15.997
SC Data - All Services | Received logon response. | 2020-10-07 00:33:16.657
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:33:16.657
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:33:16.657
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:33:16.657
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:33:16.657
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:33:16.658
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:33:16.658
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:33:16.658
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:33:16.658
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:33:16.658
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:33:16.673
DTC Client socket (1) | Closed. | 2020-10-07 00:33:16.673
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:33:46.651
DTC Client socket (1) | Creating socket. | 2020-10-07 00:33:46.652
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:33:46.652
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:33:46.652
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:33:46.680
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:33:46.680
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:33:46.680
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:33:46.728
SC Data - All Services | Sending logon request message. | 2020-10-07 00:33:46.728
SC Data - All Services | Received logon response. | 2020-10-07 00:33:47.423
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:33:47.423
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:33:47.423
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:33:47.423
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:33:47.423
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:33:47.423
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:33:47.423
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:33:47.423
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:33:47.423
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:33:47.423
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:33:47.449
DTC Client socket (1) | Closed. | 2020-10-07 00:33:47.449
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:34:17.421
DTC Client socket (1) | Creating socket. | 2020-10-07 00:34:17.421
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:34:17.421
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:34:17.421
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:34:17.435
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:34:17.435
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:34:17.435
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:34:17.475
SC Data - All Services | Sending logon request message. | 2020-10-07 00:34:17.475
SC Data - All Services | Received logon response. | 2020-10-07 00:34:18.129
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:34:18.129
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:34:18.129
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:34:18.129
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:34:18.129
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:34:18.129
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:34:18.129
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:34:18.129
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:34:18.129
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:34:18.129
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:34:18.144
DTC Client socket (1) | Closed. | 2020-10-07 00:34:18.144
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:34:48.124
DTC Client socket (1) | Creating socket. | 2020-10-07 00:34:48.124
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:34:48.125
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:34:48.125
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:34:48.139
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:34:48.139
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:34:48.139
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:34:48.156
SC Data - All Services | Sending logon request message. | 2020-10-07 00:34:48.156
SC Data - All Services | Received logon response. | 2020-10-07 00:34:48.842
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:34:48.842
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:34:48.842
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:34:48.842
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:34:48.842
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:34:48.842
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:34:48.842
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:34:48.842
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:34:48.842
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:34:48.842
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:34:48.857
DTC Client socket (1) | Closed. | 2020-10-07 00:34:48.857
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:35:18.847
DTC Client socket (1) | Creating socket. | 2020-10-07 00:35:18.848
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:35:18.848
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:35:18.848
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:35:18.864
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:35:18.864
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:35:18.864
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:35:18.908
SC Data - All Services | Sending logon request message. | 2020-10-07 00:35:18.908
SC Data - All Services | Received logon response. | 2020-10-07 00:35:19.554
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:35:19.554
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:35:19.554
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:35:19.554
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:35:19.554
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:35:19.554
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:35:19.554
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:35:19.554
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:35:19.554
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:35:19.554
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:35:19.569
DTC Client socket (1) | Closed. | 2020-10-07 00:35:19.569
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:35:49.541
DTC Client socket (1) | Creating socket. | 2020-10-07 00:35:49.542
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:35:49.542
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:35:49.542
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:35:49.574
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:35:49.574
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:35:49.574
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:35:49.636
SC Data - All Services | Sending logon request message. | 2020-10-07 00:35:49.636
SC Data - All Services | Received logon response. | 2020-10-07 00:35:50.324
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:35:50.324
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:35:50.324
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:35:50.324
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:35:50.324
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:35:50.324
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:35:50.324
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:35:50.324
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:35:50.324
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:35:50.324
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:35:50.351
DTC Client socket (1) | Closed. | 2020-10-07 00:35:50.351
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:36:20.320
DTC Client socket (1) | Creating socket. | 2020-10-07 00:36:20.320
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:36:20.320
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:36:20.320
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:36:20.335
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:36:20.335
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:36:20.335
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:36:20.369
SC Data - All Services | Sending logon request message. | 2020-10-07 00:36:20.369
SC Data - All Services | Received logon response. | 2020-10-07 00:36:21.056
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:36:21.056
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:36:21.056
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:36:21.056
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:36:21.056
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:36:21.056
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:36:21.056
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:36:21.056
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:36:21.056
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:36:21.056
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:36:21.068
DTC Client socket (1) | Closed. | 2020-10-07 00:36:21.068
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:36:51.057
DTC Client socket (1) | Creating socket. | 2020-10-07 00:36:51.057
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:36:51.057
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:36:51.057
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:36:51.073
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:36:51.073
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:36:51.073
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:36:51.104
SC Data - All Services | Sending logon request message. | 2020-10-07 00:36:51.104
SC Data - All Services | Received logon response. | 2020-10-07 00:36:51.741
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:36:51.741
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:36:51.741
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:36:51.741
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:36:51.741
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:36:51.741
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:36:51.741
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:36:51.742
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:36:51.742
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:36:51.742
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:36:51.754
DTC Client socket (1) | Closed. | 2020-10-07 00:36:51.754
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:37:21.742
DTC Client socket (1) | Creating socket. | 2020-10-07 00:37:21.742
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:37:21.742
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:37:21.743
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:37:21.764
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:37:21.764
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:37:21.764
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:37:21.785
SC Data - All Services | Sending logon request message. | 2020-10-07 00:37:21.785
SC Data - All Services | Received logon response. | 2020-10-07 00:37:22.398
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:37:22.398
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:37:22.398
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:37:22.398
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:37:22.398
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:37:22.398
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:37:22.398
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:37:22.398
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:37:22.398
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:37:22.398
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:37:22.411
DTC Client socket (1) | Closed. | 2020-10-07 00:37:22.411
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:37:52.396
DTC Client socket (1) | Creating socket. | 2020-10-07 00:37:52.397
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:37:52.397
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:37:52.397
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:37:52.423
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:37:52.423
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:37:52.423
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:37:52.458
SC Data - All Services | Sending logon request message. | 2020-10-07 00:37:52.458
SC Data - All Services | Received logon response. | 2020-10-07 00:37:53.150
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:37:53.150
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:37:53.150
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:37:53.150
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:37:53.150
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:37:53.150
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:37:53.150
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:37:53.150
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:37:53.150
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:37:53.150
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:37:53.175
DTC Client socket (1) | Closed. | 2020-10-07 00:37:53.175
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:38:23.159
DTC Client socket (1) | Creating socket. | 2020-10-07 00:38:23.160
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:38:23.160
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:38:23.160
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:38:23.190
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:38:23.190
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:38:23.190
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:38:23.238
SC Data - All Services | Sending logon request message. | 2020-10-07 00:38:23.238
SC Data - All Services | Received logon response. | 2020-10-07 00:38:23.904
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:38:23.904
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:38:23.904
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:38:23.904
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:38:23.904
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:38:23.905
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:38:23.905
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:38:23.905
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:38:23.905
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:38:23.905
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:38:23.920
DTC Client socket (1) | Closed. | 2020-10-07 00:38:23.920
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:38:53.909
DTC Client socket (1) | Creating socket. | 2020-10-07 00:38:53.909
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:38:53.909
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:38:53.909
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:38:53.932
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:38:53.932
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:38:53.932
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:38:53.975
SC Data - All Services | Sending logon request message. | 2020-10-07 00:38:53.975
SC Data - All Services | Received logon response. | 2020-10-07 00:38:54.636
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:38:54.636
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:38:54.636
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:38:54.636
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:38:54.636
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:38:54.636
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:38:54.636
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:38:54.636
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:38:54.636
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:38:54.636
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:38:54.649
DTC Client socket (1) | Closed. | 2020-10-07 00:38:54.649
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:39:24.638
DTC Client socket (1) | Creating socket. | 2020-10-07 00:39:24.639
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:39:24.639
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:39:24.639
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:39:24.660
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:39:24.660
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:39:24.660
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:39:24.709
SC Data - All Services | Sending logon request message. | 2020-10-07 00:39:24.709
SC Data - All Services | Received logon response. | 2020-10-07 00:39:25.286
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:39:25.286
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:39:25.286
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:39:25.286
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:39:25.286
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:39:25.286
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:39:25.286
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:39:25.286
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:39:25.286
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:39:25.286
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:39:25.300
DTC Client socket (1) | Closed. | 2020-10-07 00:39:25.300
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:39:55.283
DTC Client socket (1) | Creating socket. | 2020-10-07 00:39:55.283
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:39:55.283
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:39:55.284
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:39:55.314
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:39:55.314
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:39:55.314
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:39:55.372
SC Data - All Services | Sending logon request message. | 2020-10-07 00:39:55.372
SC Data - All Services | Received logon response. | 2020-10-07 00:39:56.067
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:39:56.067
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:39:56.067
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:39:56.067
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:39:56.067
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:39:56.068
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:39:56.068
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:39:56.068
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:39:56.068
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:39:56.068
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:39:56.098
DTC Client socket (1) | Closed. | 2020-10-07 00:39:56.098
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:40:26.058
DTC Client socket (1) | Creating socket. | 2020-10-07 00:40:26.059
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:40:26.059
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:40:26.059
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:40:26.072
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:40:26.072
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:40:26.072
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:40:26.104
SC Data - All Services | Sending logon request message. | 2020-10-07 00:40:26.104
SC Data - All Services | Received logon response. | 2020-10-07 00:40:26.773
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:40:26.773
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:40:26.773
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:40:26.773
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:40:26.773
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:40:26.773
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:40:26.773
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:40:26.773
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:40:26.773
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:40:26.773
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:40:26.787
DTC Client socket (1) | Closed. | 2020-10-07 00:40:26.787
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:40:56.776
DTC Client socket (1) | Creating socket. | 2020-10-07 00:40:56.777
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:40:56.777
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:40:56.777
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:40:56.792
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:40:56.792
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:40:56.792
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:40:56.824
SC Data - All Services | Sending logon request message. | 2020-10-07 00:40:56.824
SC Data - All Services | Received logon response. | 2020-10-07 00:40:57.496
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:40:57.496
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:40:57.496
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:40:57.496
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:40:57.496
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:40:57.496
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:40:57.496
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:40:57.497
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:40:57.497
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:40:57.497
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:40:57.514
DTC Client socket (1) | Closed. | 2020-10-07 00:40:57.514
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:41:27.499
DTC Client socket (1) | Creating socket. | 2020-10-07 00:41:27.500
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:41:27.500
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:41:27.500
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:41:27.527
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:41:27.527
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:41:27.527
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:41:27.554
SC Data - All Services | Sending logon request message. | 2020-10-07 00:41:27.554
SC Data - All Services | Received logon response. | 2020-10-07 00:41:28.213
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:41:28.213
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:41:28.213
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:41:28.213
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:41:28.213
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:41:28.213
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:41:28.213
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:41:28.213
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:41:28.213
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:41:28.213
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:41:28.227
DTC Client socket (1) | Closed. | 2020-10-07 00:41:28.227
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:41:58.217
DTC Client socket (1) | Creating socket. | 2020-10-07 00:41:58.217
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:41:58.217
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:41:58.217
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:41:58.245
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:41:58.245
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:41:58.245
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:41:58.310
SC Data - All Services | Sending logon request message. | 2020-10-07 00:41:58.310
SC Data - All Services | Received logon response. | 2020-10-07 00:41:58.990
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:41:58.990
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:41:58.990
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:41:58.990
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:41:58.991
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:41:58.991
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:41:58.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:41:58.991
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:41:58.991
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:41:58.991
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:41:59.017
DTC Client socket (1) | Closed. | 2020-10-07 00:41:59.017
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1121 seconds. | 2020-10-07 00:42:25.332
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0395 seconds. | 2020-10-07 00:42:25.372
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:42:28.976
DTC Client socket (1) | Creating socket. | 2020-10-07 00:42:28.976
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:42:28.976
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:42:28.976
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:42:29.003
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:42:29.003
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:42:29.003
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:42:29.032
SC Data - All Services | Sending logon request message. | 2020-10-07 00:42:29.032
SC Data - All Services | Received logon response. | 2020-10-07 00:42:29.676
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:42:29.676
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:42:29.676
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:42:29.676
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:42:29.676
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:42:29.676
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:42:29.676
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:42:29.676
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:42:29.676
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:42:29.676
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:42:29.690
DTC Client socket (1) | Closed. | 2020-10-07 00:42:29.690
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:42:59.669
DTC Client socket (1) | Creating socket. | 2020-10-07 00:42:59.669
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:42:59.669
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:42:59.669
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:42:59.684
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:42:59.684
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:42:59.684
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:42:59.708
SC Data - All Services | Sending logon request message. | 2020-10-07 00:42:59.708
SC Data - All Services | Received logon response. | 2020-10-07 00:43:00.384
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:43:00.384
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:43:00.384
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:43:00.384
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:43:00.384
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:43:00.384
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:43:00.384
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:43:00.384
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:43:00.384
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:43:00.384
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:43:00.396
DTC Client socket (1) | Closed. | 2020-10-07 00:43:00.396
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:43:30.385
DTC Client socket (1) | Creating socket. | 2020-10-07 00:43:30.385
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:43:30.385
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:43:30.386
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:43:30.407
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:43:30.407
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:43:30.407
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:43:30.427
SC Data - All Services | Sending logon request message. | 2020-10-07 00:43:30.427
SC Data - All Services | Received logon response. | 2020-10-07 00:43:31.070
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:43:31.070
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:43:31.070
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:43:31.070
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:43:31.070
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:43:31.070
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:43:31.070
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:43:31.070
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:43:31.070
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:43:31.070
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:43:31.086
DTC Client socket (1) | Closed. | 2020-10-07 00:43:31.086
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:44:01.059
DTC Client socket (1) | Creating socket. | 2020-10-07 00:44:01.060
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:44:01.060
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:44:01.060
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:44:01.105
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:44:01.105
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:44:01.105
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:44:01.137
SC Data - All Services | Sending logon request message. | 2020-10-07 00:44:01.137
SC Data - All Services | Received logon response. | 2020-10-07 00:44:01.839
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:44:01.839
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:44:01.839
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:44:01.839
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:44:01.839
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:44:01.840
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:44:01.840
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:44:01.840
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:44:01.840
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:44:01.840
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:44:01.868
DTC Client socket (1) | Closed. | 2020-10-07 00:44:01.868
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:44:31.841
DTC Client socket (1) | Creating socket. | 2020-10-07 00:44:31.841
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:44:31.841
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:44:31.841
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:44:31.856
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:44:31.856
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:44:31.856
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:44:31.878
SC Data - All Services | Sending logon request message. | 2020-10-07 00:44:31.878
SC Data - All Services | Received logon response. | 2020-10-07 00:44:32.536
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:44:32.536
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:44:32.536
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:44:32.536
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:44:32.536
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:44:32.537
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:44:32.537
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:44:32.537
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:44:32.537
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:44:32.537
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:44:32.554
DTC Client socket (1) | Closed. | 2020-10-07 00:44:32.554
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:45:02.528
DTC Client socket (2) | Creating socket. | 2020-10-07 00:45:02.529
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 00:45:02.529
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:45:02.529
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:45:02.542
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:45:02.542
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:45:02.542
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:45:02.573
SC Data - All Services | Sending logon request message. | 2020-10-07 00:45:02.573
SC Data - All Services | Received logon response. | 2020-10-07 00:45:03.234
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:45:03.234
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:45:03.234
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:45:03.234
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:45:03.234
DTC Client socket (2) | CloseSocket call. | 2020-10-07 00:45:03.234
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:45:03.234
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:45:03.234
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:45:03.234
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:45:03.234
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 00:45:03.247
DTC Client socket (2) | Closed. | 2020-10-07 00:45:03.247
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:45:33.236
DTC Client socket (1) | Creating socket. | 2020-10-07 00:45:33.236
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:45:33.236
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:45:33.236
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:45:33.251
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:45:33.251
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:45:33.251
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:45:33.266
SC Data - All Services | Sending logon request message. | 2020-10-07 00:45:33.266
SC Data - All Services | Received logon response. | 2020-10-07 00:45:33.885
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:45:33.885
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:45:33.885
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:45:33.885
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:45:33.885
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:45:33.885
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:45:33.885
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:45:33.885
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:45:33.885
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:45:33.885
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:45:33.899
DTC Client socket (1) | Closed. | 2020-10-07 00:45:33.899
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:46:03.886
DTC Client socket (1) | Creating socket. | 2020-10-07 00:46:03.887
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:46:03.887
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:46:03.887
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:46:03.917
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:46:03.917
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:46:03.917
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:46:03.962
SC Data - All Services | Sending logon request message. | 2020-10-07 00:46:03.962
SC Data - All Services | Received logon response. | 2020-10-07 00:46:04.648
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:46:04.648
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:46:04.648
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:46:04.648
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:46:04.648
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:46:04.648
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:46:04.648
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:46:04.648
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:46:04.648
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:46:04.648
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:46:04.674
DTC Client socket (1) | Closed. | 2020-10-07 00:46:04.674
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:46:34.636
DTC Client socket (1) | Creating socket. | 2020-10-07 00:46:34.637
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:46:34.637
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:46:34.637
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:46:34.653
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:46:34.653
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:46:34.653
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:46:34.683
SC Data - All Services | Sending logon request message. | 2020-10-07 00:46:34.683
SC Data - All Services | Received logon response. | 2020-10-07 00:46:35.355
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:46:35.355
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:46:35.355
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:46:35.355
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:46:35.355
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:46:35.355
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:46:35.355
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:46:35.356
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:46:35.356
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:46:35.356
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:46:35.369
DTC Client socket (1) | Closed. | 2020-10-07 00:46:35.370
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:47:05.354
DTC Client socket (1) | Creating socket. | 2020-10-07 00:47:05.354
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:47:05.354
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:47:05.354
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:47:05.378
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:47:05.378
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:47:05.378
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:47:05.417
SC Data - All Services | Sending logon request message. | 2020-10-07 00:47:05.417
SC Data - All Services | Received logon response. | 2020-10-07 00:47:06.040
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:47:06.040
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:47:06.040
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:47:06.040
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:47:06.040
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:47:06.040
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:47:06.040
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:47:06.041
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:47:06.041
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:47:06.041
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:47:06.057
DTC Client socket (1) | Closed. | 2020-10-07 00:47:06.057
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:47:36.056
DTC Client socket (1) | Creating socket. | 2020-10-07 00:47:36.056
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:47:36.056
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:47:36.056
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:47:36.073
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:47:36.073
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:47:36.073
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:47:36.126
SC Data - All Services | Sending logon request message. | 2020-10-07 00:47:36.126
SC Data - All Services | Received logon response. | 2020-10-07 00:47:36.747
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:47:36.747
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:47:36.747
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:47:36.747
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:47:36.747
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:47:36.747
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:47:36.747
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:47:36.747
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:47:36.747
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:47:36.747
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:47:36.760
DTC Client socket (1) | Closed. | 2020-10-07 00:47:36.761
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:48:06.755
DTC Client socket (1) | Creating socket. | 2020-10-07 00:48:06.755
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:48:06.755
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:48:06.755
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:48:06.783
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:48:06.783
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:48:06.783
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:48:06.832
SC Data - All Services | Sending logon request message. | 2020-10-07 00:48:06.832
SC Data - All Services | Received logon response. | 2020-10-07 00:48:07.556
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:48:07.557
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:48:07.557
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:48:07.557
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:48:07.557
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:48:07.557
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:48:07.557
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:48:07.557
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:48:07.557
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:48:07.557
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:48:07.587
DTC Client socket (1) | Closed. | 2020-10-07 00:48:07.587
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:48:37.566
DTC Client socket (1) | Creating socket. | 2020-10-07 00:48:37.566
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:48:37.566
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:48:37.566
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:48:37.591
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:48:37.591
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:48:37.591
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:48:37.622
SC Data - All Services | Sending logon request message. | 2020-10-07 00:48:37.622
SC Data - All Services | Received logon response. | 2020-10-07 00:48:38.263
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:48:38.263
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:48:38.263
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:48:38.263
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:48:38.263
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:48:38.263
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:48:38.263
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:48:38.263
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:48:38.263
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:48:38.263
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:48:38.276
DTC Client socket (1) | Closed. | 2020-10-07 00:48:38.276
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:49:08.264
DTC Client socket (1) | Creating socket. | 2020-10-07 00:49:08.265
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:49:08.265
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:49:08.265
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:49:08.286
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:49:08.286
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:49:08.286
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:49:08.315
SC Data - All Services | Sending logon request message. | 2020-10-07 00:49:08.315
SC Data - All Services | Received logon response. | 2020-10-07 00:49:08.551
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:49:08.551
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:49:08.551
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:49:08.551
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:49:08.551
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:49:08.551
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:49:08.551
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:49:08.551
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:49:08.551
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:49:08.551
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:49:08.563
DTC Client socket (1) | Closed. | 2020-10-07 00:49:08.563
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:49:38.540
DTC Client socket (1) | Creating socket. | 2020-10-07 00:49:38.541
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:49:38.541
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:49:38.541
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:49:38.553
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:49:38.553
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:49:38.553
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:49:38.602
SC Data - All Services | Sending logon request message. | 2020-10-07 00:49:38.602
SC Data - All Services | Received logon response. | 2020-10-07 00:49:39.243
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:49:39.243
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:49:39.243
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:49:39.243
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:49:39.243
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:49:39.243
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:49:39.243
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:49:39.243
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:49:39.243
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:49:39.243
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:49:39.258
DTC Client socket (1) | Closed. | 2020-10-07 00:49:39.258
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:50:09.257
DTC Client socket (1) | Creating socket. | 2020-10-07 00:50:09.257
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:50:09.257
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:50:09.257
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:50:09.287
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:50:09.287
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:50:09.287
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:50:09.335
SC Data - All Services | Sending logon request message. | 2020-10-07 00:50:09.335
SC Data - All Services | Received logon response. | 2020-10-07 00:50:10.017
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:50:10.017
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:50:10.017
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:50:10.017
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:50:10.017
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:50:10.017
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:50:10.017
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:50:10.017
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:50:10.017
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:50:10.017
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:50:10.042
DTC Client socket (1) | Closed. | 2020-10-07 00:50:10.042
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:50:40.010
DTC Client socket (1) | Creating socket. | 2020-10-07 00:50:40.011
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:50:40.011
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:50:40.011
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:50:40.043
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:50:40.043
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:50:40.043
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:50:40.080
SC Data - All Services | Sending logon request message. | 2020-10-07 00:50:40.080
SC Data - All Services | Received logon response. | 2020-10-07 00:50:40.728
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:50:40.728
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:50:40.728
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:50:40.728
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:50:40.728
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:50:40.729
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:50:40.729
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:50:40.729
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:50:40.729
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:50:40.729
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:50:40.743
DTC Client socket (1) | Closed. | 2020-10-07 00:50:40.744
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:51:10.739
DTC Client socket (1) | Creating socket. | 2020-10-07 00:51:10.739
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:51:10.739
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:51:10.739
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:51:10.761
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:51:10.761
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:51:10.761
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:51:10.798
SC Data - All Services | Sending logon request message. | 2020-10-07 00:51:10.798
SC Data - All Services | Received logon response. | 2020-10-07 00:51:11.379
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:51:11.379
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:51:11.379
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:51:11.379
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:51:11.379
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:51:11.380
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:51:11.380
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:51:11.380
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:51:11.380
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:51:11.380
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:51:11.395
DTC Client socket (1) | Closed. | 2020-10-07 00:51:11.395
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:51:41.367
DTC Client socket (1) | Creating socket. | 2020-10-07 00:51:41.367
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:51:41.367
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:51:41.367
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:51:41.385
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:51:41.385
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:51:41.385
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:51:41.407
SC Data - All Services | Sending logon request message. | 2020-10-07 00:51:41.407
SC Data - All Services | Received logon response. | 2020-10-07 00:51:42.038
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:51:42.038
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:51:42.038
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:51:42.038
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:51:42.038
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:51:42.038
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:51:42.038
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:51:42.038
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:51:42.038
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:51:42.038
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:51:42.055
DTC Client socket (1) | Closed. | 2020-10-07 00:51:42.055
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:52:12.026
DTC Client socket (1) | Creating socket. | 2020-10-07 00:52:12.027
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:52:12.027
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:52:12.027
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:52:12.061
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:52:12.061
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:52:12.061
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:52:12.111
SC Data - All Services | Sending logon request message. | 2020-10-07 00:52:12.111
SC Data - All Services | Received logon response. | 2020-10-07 00:52:12.791
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:52:12.791
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:52:12.791
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:52:12.791
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:52:12.791
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:52:12.792
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:52:12.792
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:52:12.792
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:52:12.792
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:52:12.792
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:52:12.816
DTC Client socket (1) | Closed. | 2020-10-07 00:52:12.816
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:52:42.794
DTC Client socket (1) | Creating socket. | 2020-10-07 00:52:42.794
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:52:42.794
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:52:42.794
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:52:42.817
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:52:42.817
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:52:42.817
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:52:42.847
SC Data - All Services | Sending logon request message. | 2020-10-07 00:52:42.847
SC Data - All Services | Received logon response. | 2020-10-07 00:52:43.536
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:52:43.536
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:52:43.536
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:52:43.536
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:52:43.536
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:52:43.537
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:52:43.537
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:52:43.537
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:52:43.537
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:52:43.537
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:52:43.550
DTC Client socket (1) | Closed. | 2020-10-07 00:52:43.550
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:53:13.532
DTC Client socket (1) | Creating socket. | 2020-10-07 00:53:13.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:53:13.533
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:53:13.533
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:53:13.543
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:53:13.543
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:53:13.543
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:53:13.562
SC Data - All Services | Sending logon request message. | 2020-10-07 00:53:13.562
SC Data - All Services | Received logon response. | 2020-10-07 00:53:14.187
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:53:14.187
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:53:14.187
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:53:14.187
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:53:14.187
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:53:14.187
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:53:14.187
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:53:14.187
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:53:14.187
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:53:14.187
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:53:14.200
DTC Client socket (1) | Closed. | 2020-10-07 00:53:14.200
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:53:44.191
DTC Client socket (1) | Creating socket. | 2020-10-07 00:53:44.191
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:53:44.191
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:53:44.192
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:53:44.214
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:53:44.214
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:53:44.214
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:53:44.259
SC Data - All Services | Sending logon request message. | 2020-10-07 00:53:44.259
SC Data - All Services | Received logon response. | 2020-10-07 00:53:44.887
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:53:44.887
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:53:44.887
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:53:44.887
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:53:44.887
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:53:44.887
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:53:44.887
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:53:44.887
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:53:44.887
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:53:44.887
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:53:44.901
DTC Client socket (1) | Closed. | 2020-10-07 00:53:44.901
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:54:14.893
DTC Client socket (1) | Creating socket. | 2020-10-07 00:54:14.893
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:54:14.893
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:54:14.893
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:54:14.933
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:54:14.933
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:54:14.933
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:54:14.988
SC Data - All Services | Sending logon request message. | 2020-10-07 00:54:14.988
SC Data - All Services | Received logon response. | 2020-10-07 00:54:15.656
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:54:15.656
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:54:15.656
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:54:15.656
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:54:15.656
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:54:15.657
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:54:15.657
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:54:15.657
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:54:15.657
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:54:15.657
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:54:15.683
DTC Client socket (1) | Closed. | 2020-10-07 00:54:15.683
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:54:45.659
DTC Client socket (1) | Creating socket. | 2020-10-07 00:54:45.660
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:54:45.660
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:54:45.660
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:54:45.680
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:54:45.680
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:54:45.680
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:54:45.715
SC Data - All Services | Sending logon request message. | 2020-10-07 00:54:45.715
SC Data - All Services | Received logon response. | 2020-10-07 00:54:46.351
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:54:46.351
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:54:46.351
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:54:46.351
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:54:46.351
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:54:46.351
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:54:46.351
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:54:46.351
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:54:46.351
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:54:46.351
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:54:46.364
DTC Client socket (1) | Closed. | 2020-10-07 00:54:46.364
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:55:16.352
DTC Client socket (1) | Creating socket. | 2020-10-07 00:55:16.352
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:55:16.352
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:55:16.352
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:55:16.367
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:55:16.367
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:55:16.367
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:55:16.388
SC Data - All Services | Sending logon request message. | 2020-10-07 00:55:16.388
SC Data - All Services | Received logon response. | 2020-10-07 00:55:17.040
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:55:17.040
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:55:17.040
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:55:17.040
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:55:17.040
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:55:17.040
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:55:17.040
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:55:17.040
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:55:17.040
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:55:17.040
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:55:17.051
DTC Client socket (1) | Closed. | 2020-10-07 00:55:17.052
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:55:47.047
DTC Client socket (1) | Creating socket. | 2020-10-07 00:55:47.047
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:55:47.048
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:55:47.048
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:55:47.062
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:55:47.062
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:55:47.062
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:55:47.089
SC Data - All Services | Sending logon request message. | 2020-10-07 00:55:47.089
SC Data - All Services | Received logon response. | 2020-10-07 00:55:47.722
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:55:47.722
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:55:47.722
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:55:47.722
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:55:47.722
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:55:47.722
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:55:47.722
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:55:47.722
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:55:47.722
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:55:47.722
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:55:47.736
DTC Client socket (1) | Closed. | 2020-10-07 00:55:47.736
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:56:17.713
DTC Client socket (2) | Creating socket. | 2020-10-07 00:56:17.714
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 00:56:17.714
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:56:17.714
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:56:17.744
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:56:17.744
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:56:17.745
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:56:17.785
SC Data - All Services | Sending logon request message. | 2020-10-07 00:56:17.785
SC Data - All Services | Received logon response. | 2020-10-07 00:56:18.475
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:56:18.475
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:56:18.475
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:56:18.475
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:56:18.475
DTC Client socket (2) | CloseSocket call. | 2020-10-07 00:56:18.475
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:56:18.475
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:56:18.475
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:56:18.475
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:56:18.475
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 00:56:18.500
DTC Client socket (2) | Closed. | 2020-10-07 00:56:18.500
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:56:48.465
DTC Client socket (1) | Creating socket. | 2020-10-07 00:56:48.466
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:56:48.466
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:56:48.466
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:56:48.490
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:56:48.490
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:56:48.490
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:56:48.521
SC Data - All Services | Sending logon request message. | 2020-10-07 00:56:48.521
SC Data - All Services | Received logon response. | 2020-10-07 00:56:49.162
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:56:49.162
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:56:49.162
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:56:49.162
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:56:49.162
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:56:49.162
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:56:49.162
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:56:49.162
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:56:49.162
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:56:49.162
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:56:49.176
DTC Client socket (1) | Closed. | 2020-10-07 00:56:49.176
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:57:19.152
DTC Client socket (1) | Creating socket. | 2020-10-07 00:57:19.153
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:57:19.153
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:57:19.153
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:57:19.174
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:57:19.174
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:57:19.174
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:57:19.230
SC Data - All Services | Sending logon request message. | 2020-10-07 00:57:19.230
SC Data - All Services | Received logon response. | 2020-10-07 00:57:19.832
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:57:19.832
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:57:19.832
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:57:19.832
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:57:19.832
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:57:19.832
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:57:19.832
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:57:19.832
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:57:19.832
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:57:19.832
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:57:19.847
DTC Client socket (1) | Closed. | 2020-10-07 00:57:19.847
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1053 seconds. | 2020-10-07 00:57:25.475
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0352 seconds. | 2020-10-07 00:57:25.512
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:57:49.825
DTC Client socket (1) | Creating socket. | 2020-10-07 00:57:49.825
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:57:49.825
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:57:49.825
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:57:49.847
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:57:49.847
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:57:49.848
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:57:49.887
SC Data - All Services | Sending logon request message. | 2020-10-07 00:57:49.887
SC Data - All Services | Received logon response. | 2020-10-07 00:57:50.520
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:57:50.520
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:57:50.520
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:57:50.520
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:57:50.520
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:57:50.520
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:57:50.520
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:57:50.520
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:57:50.520
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:57:50.520
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:57:50.533
DTC Client socket (1) | Closed. | 2020-10-07 00:57:50.533
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 00:58:20.509
DTC Client socket (1) | Creating socket. | 2020-10-07 00:58:20.510
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:58:20.510
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 00:58:20.510
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:58:20.539
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:58:20.539
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:58:20.539
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:58:20.571
SC Data - All Services | Sending logon request message. | 2020-10-07 00:58:20.571
SC Data - All Services | Received logon response. | 2020-10-07 00:58:21.260
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:58:21.260
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:58:21.260
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:58:21.260
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:58:21.260
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:58:21.260
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:58:21.260
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:58:21.260
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:58:21.260
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:58:21.260
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:58:21.286
DTC Client socket (1) | Closed. | 2020-10-07 00:58:21.286
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 00:58:51.271
DTC Client socket (1) | Creating socket. | 2020-10-07 00:58:51.271
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:58:51.271
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 00:58:51.271
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:58:51.293
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:58:51.293
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:58:51.293
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:58:51.332
SC Data - All Services | Sending logon request message. | 2020-10-07 00:58:51.332
SC Data - All Services | Received logon response. | 2020-10-07 00:58:51.980
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:58:51.980
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:58:51.980
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:58:51.980
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:58:51.980
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:58:51.981
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:58:51.981
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:58:51.981
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:58:51.981
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:58:51.981
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:58:51.994
DTC Client socket (1) | Closed. | 2020-10-07 00:58:51.995
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 00:59:21.976
DTC Client socket (1) | Creating socket. | 2020-10-07 00:59:21.977
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:59:21.977
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 00:59:21.977
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:59:21.992
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:59:21.992
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:59:21.992
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:59:22.032
SC Data - All Services | Sending logon request message. | 2020-10-07 00:59:22.032
SC Data - All Services | Received logon response. | 2020-10-07 00:59:22.623
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:59:22.623
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:59:22.623
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:59:22.623
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:59:22.623
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:59:22.623
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:59:22.623
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:59:22.623
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:59:22.623
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:59:22.623
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:59:22.636
DTC Client socket (1) | Closed. | 2020-10-07 00:59:22.636
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 00:59:52.631
DTC Client socket (1) | Creating socket. | 2020-10-07 00:59:52.631
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 00:59:52.631
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 00:59:52.631
SC Data - All Services | Network connection to server complete. | 2020-10-07 00:59:52.657
SC Data - All Services | Starting socket receive thread. | 2020-10-07 00:59:52.657
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 00:59:52.657
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 00:59:52.674
SC Data - All Services | Sending logon request message. | 2020-10-07 00:59:52.674
SC Data - All Services | Received logon response. | 2020-10-07 00:59:53.342
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 00:59:53.342
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 00:59:53.342
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 00:59:53.342
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 00:59:53.342
DTC Client socket (1) | CloseSocket call. | 2020-10-07 00:59:53.342
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 00:59:53.342
SC Data - All Services | Disconnected from the server. | 2020-10-07 00:59:53.342
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 00:59:53.342
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 00:59:53.343
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 00:59:53.360
DTC Client socket (1) | Closed. | 2020-10-07 00:59:53.360
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:00:23.344
DTC Client socket (1) | Creating socket. | 2020-10-07 01:00:23.344
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:00:23.345
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:00:23.345
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:00:23.376
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:00:23.376
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:00:23.376
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:00:23.419
SC Data - All Services | Sending logon request message. | 2020-10-07 01:00:23.419
SC Data - All Services | Received logon response. | 2020-10-07 01:00:24.113
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:00:24.113
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:00:24.113
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:00:24.113
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:00:24.113
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:00:24.113
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:00:24.113
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:00:24.113
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:00:24.113
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:00:24.113
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:00:24.141
DTC Client socket (1) | Closed. | 2020-10-07 01:00:24.141
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:00:54.115
DTC Client socket (1) | Creating socket. | 2020-10-07 01:00:54.116
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:00:54.116
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:00:54.116
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:00:54.131
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:00:54.131
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:00:54.131
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:00:54.174
SC Data - All Services | Sending logon request message. | 2020-10-07 01:00:54.174
SC Data - All Services | Received logon response. | 2020-10-07 01:00:54.812
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:00:54.812
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:00:54.812
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:00:54.812
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:00:54.812
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:00:54.812
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:00:54.812
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:00:54.812
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:00:54.812
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:00:54.812
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:00:54.826
DTC Client socket (1) | Closed. | 2020-10-07 01:00:54.826
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:01:24.814
DTC Client socket (1) | Creating socket. | 2020-10-07 01:01:24.815
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:01:24.815
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:01:24.815
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:01:24.845
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:01:24.845
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:01:24.845
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:01:24.871
SC Data - All Services | Sending logon request message. | 2020-10-07 01:01:24.871
SC Data - All Services | Received logon response. | 2020-10-07 01:01:25.516
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:01:25.516
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:01:25.516
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:01:25.516
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:01:25.516
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:01:25.516
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:01:25.516
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:01:25.516
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:01:25.516
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:01:25.516
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:01:25.530
DTC Client socket (1) | Closed. | 2020-10-07 01:01:25.530
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:01:55.509
DTC Client socket (1) | Creating socket. | 2020-10-07 01:01:55.509
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:01:55.509
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:01:55.509
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:01:55.538
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:01:55.538
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:01:55.538
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:01:55.562
SC Data - All Services | Sending logon request message. | 2020-10-07 01:01:55.562
SC Data - All Services | Received logon response. | 2020-10-07 01:01:56.207
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:01:56.207
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:01:56.207
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:01:56.207
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:01:56.207
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:01:56.207
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:01:56.207
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:01:56.207
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:01:56.208
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:01:56.208
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:01:56.224
DTC Client socket (1) | Closed. | 2020-10-07 01:01:56.224
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:02:26.204
DTC Client socket (1) | Creating socket. | 2020-10-07 01:02:26.204
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:02:26.205
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:02:26.205
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:02:26.235
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:02:26.235
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:02:26.235
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:02:26.281
SC Data - All Services | Sending logon request message. | 2020-10-07 01:02:26.281
SC Data - All Services | Received logon response. | 2020-10-07 01:02:26.990
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:02:26.990
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:02:26.990
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:02:26.990
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:02:26.990
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:02:26.991
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:02:26.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:02:26.991
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:02:26.991
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:02:26.991
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:02:27.017
DTC Client socket (1) | Closed. | 2020-10-07 01:02:27.017
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:02:56.985
DTC Client socket (1) | Creating socket. | 2020-10-07 01:02:56.988
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:02:56.988
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:02:56.988
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:02:57.004
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:02:57.004
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:02:57.004
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:02:57.049
SC Data - All Services | Sending logon request message. | 2020-10-07 01:02:57.049
SC Data - All Services | Received logon response. | 2020-10-07 01:02:57.691
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:02:57.691
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:02:57.691
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:02:57.691
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:02:57.691
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:02:57.691
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:02:57.691
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:02:57.691
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:02:57.691
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:02:57.691
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:02:57.707
DTC Client socket (1) | Closed. | 2020-10-07 01:02:57.707
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:03:27.684
DTC Client socket (1) | Creating socket. | 2020-10-07 01:03:27.685
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:03:27.685
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:03:27.685
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:03:27.695
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:03:27.695
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:03:27.695
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:03:27.712
SC Data - All Services | Sending logon request message. | 2020-10-07 01:03:27.712
SC Data - All Services | Received logon response. | 2020-10-07 01:03:28.327
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:03:28.327
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:03:28.327
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:03:28.327
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:03:28.327
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:03:28.327
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:03:28.327
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:03:28.328
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:03:28.328
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:03:28.328
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:03:28.339
DTC Client socket (1) | Closed. | 2020-10-07 01:03:28.339
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:03:58.328
DTC Client socket (1) | Creating socket. | 2020-10-07 01:03:58.328
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:03:58.328
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:03:58.328
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:03:58.357
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:03:58.357
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:03:58.357
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:03:58.406
SC Data - All Services | Sending logon request message. | 2020-10-07 01:03:58.406
SC Data - All Services | Received logon response. | 2020-10-07 01:03:59.058
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:03:59.058
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:03:59.058
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:03:59.058
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:03:59.058
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:03:59.058
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:03:59.058
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:03:59.059
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:03:59.059
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:03:59.059
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:03:59.073
DTC Client socket (1) | Closed. | 2020-10-07 01:03:59.073
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:04:29.069
DTC Client socket (1) | Creating socket. | 2020-10-07 01:04:29.069
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:04:29.069
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:04:29.069
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:04:29.109
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:04:29.109
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:04:29.109
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:04:29.154
SC Data - All Services | Sending logon request message. | 2020-10-07 01:04:29.154
SC Data - All Services | Received logon response. | 2020-10-07 01:04:29.822
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:04:29.822
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:04:29.822
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:04:29.822
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:04:29.822
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:04:29.822
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:04:29.822
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:04:29.822
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:04:29.822
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:04:29.822
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:04:29.849
DTC Client socket (1) | Closed. | 2020-10-07 01:04:29.849
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:04:59.829
DTC Client socket (1) | Creating socket. | 2020-10-07 01:04:59.829
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:04:59.830
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:04:59.830
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:04:59.857
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:04:59.857
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:04:59.857
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:04:59.889
SC Data - All Services | Sending logon request message. | 2020-10-07 01:04:59.889
SC Data - All Services | Received logon response. | 2020-10-07 01:05:00.540
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:05:00.540
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:05:00.540
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:05:00.540
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:05:00.540
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:05:00.541
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:05:00.541
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:05:00.541
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:05:00.541
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:05:00.541
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:05:00.555
DTC Client socket (1) | Closed. | 2020-10-07 01:05:00.555
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:05:30.542
DTC Client socket (1) | Creating socket. | 2020-10-07 01:05:30.542
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:05:30.542
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:05:30.542
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:05:30.573
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:05:30.573
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:05:30.573
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:05:30.613
SC Data - All Services | Sending logon request message. | 2020-10-07 01:05:30.613
SC Data - All Services | Received logon response. | 2020-10-07 01:05:31.238
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:05:31.238
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:05:31.238
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:05:31.238
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:05:31.238
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:05:31.238
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:05:31.238
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:05:31.238
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:05:31.238
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:05:31.238
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:05:31.253
DTC Client socket (1) | Closed. | 2020-10-07 01:05:31.253
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:06:01.234
DTC Client socket (1) | Creating socket. | 2020-10-07 01:06:01.235
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:06:01.235
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:06:01.235
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:06:01.259
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:06:01.259
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:06:01.259
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:06:01.300
SC Data - All Services | Sending logon request message. | 2020-10-07 01:06:01.300
SC Data - All Services | Received logon response. | 2020-10-07 01:06:01.947
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:06:01.947
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:06:01.947
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:06:01.947
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:06:01.947
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:06:01.947
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:06:01.947
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:06:01.947
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:06:01.947
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:06:01.947
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:06:01.962
DTC Client socket (1) | Closed. | 2020-10-07 01:06:01.962
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:06:31.946
DTC Client socket (1) | Creating socket. | 2020-10-07 01:06:31.946
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:06:31.946
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:06:31.946
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:06:31.973
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:06:31.973
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:06:31.973
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:06:32.009
SC Data - All Services | Sending logon request message. | 2020-10-07 01:06:32.009
SC Data - All Services | Received logon response. | 2020-10-07 01:06:32.662
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:06:32.662
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:06:32.662
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:06:32.662
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:06:32.662
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:06:32.663
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:06:32.663
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:06:32.663
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:06:32.663
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:06:32.663
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:06:32.689
DTC Client socket (1) | Closed. | 2020-10-07 01:06:32.689
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:07:02.663
DTC Client socket (2) | Creating socket. | 2020-10-07 01:07:02.663
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 01:07:02.663
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:07:02.663
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:07:02.686
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:07:02.686
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:07:02.686
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:07:02.741
SC Data - All Services | Sending logon request message. | 2020-10-07 01:07:02.741
SC Data - All Services | Received logon response. | 2020-10-07 01:07:03.414
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:07:03.414
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:07:03.414
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:07:03.414
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:07:03.414
DTC Client socket (2) | CloseSocket call. | 2020-10-07 01:07:03.414
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:07:03.414
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:07:03.414
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:07:03.414
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:07:03.414
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 01:07:03.428
DTC Client socket (2) | Closed. | 2020-10-07 01:07:03.428
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:07:33.425
DTC Client socket (1) | Creating socket. | 2020-10-07 01:07:33.425
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:07:33.425
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:07:33.425
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:07:33.447
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:07:33.447
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:07:33.447
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:07:33.465
SC Data - All Services | Sending logon request message. | 2020-10-07 01:07:33.465
SC Data - All Services | Received logon response. | 2020-10-07 01:07:34.141
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:07:34.141
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:07:34.141
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:07:34.141
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:07:34.141
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:07:34.141
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:07:34.141
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:07:34.141
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:07:34.141
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:07:34.141
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:07:34.156
DTC Client socket (1) | Closed. | 2020-10-07 01:07:34.156
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:08:04.146
DTC Client socket (1) | Creating socket. | 2020-10-07 01:08:04.146
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:08:04.146
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:08:04.146
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:08:04.170
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:08:04.170
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:08:04.170
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:08:04.207
SC Data - All Services | Sending logon request message. | 2020-10-07 01:08:04.207
SC Data - All Services | Received logon response. | 2020-10-07 01:08:04.843
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:08:04.843
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:08:04.843
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:08:04.843
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:08:04.843
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:08:04.843
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:08:04.844
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:08:04.844
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:08:04.844
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:08:04.844
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:08:04.859
DTC Client socket (1) | Closed. | 2020-10-07 01:08:04.860
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:08:34.845
DTC Client socket (1) | Creating socket. | 2020-10-07 01:08:34.846
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:08:34.846
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:08:34.846
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:08:34.885
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:08:34.885
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:08:34.885
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:08:34.950
SC Data - All Services | Sending logon request message. | 2020-10-07 01:08:34.950
SC Data - All Services | Received logon response. | 2020-10-07 01:08:35.643
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:08:35.643
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:08:35.643
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:08:35.643
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:08:35.643
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:08:35.644
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:08:35.644
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:08:35.644
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:08:35.644
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:08:35.644
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:08:35.670
DTC Client socket (1) | Closed. | 2020-10-07 01:08:35.670
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:09:05.640
DTC Client socket (1) | Creating socket. | 2020-10-07 01:09:05.641
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:09:05.641
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:09:05.641
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:09:05.671
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:09:05.671
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:09:05.672
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:09:05.697
SC Data - All Services | Sending logon request message. | 2020-10-07 01:09:05.697
SC Data - All Services | Received logon response. | 2020-10-07 01:09:06.390
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:09:06.390
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:09:06.390
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:09:06.390
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:09:06.390
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:09:06.390
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:09:06.390
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:09:06.390
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:09:06.390
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:09:06.390
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:09:06.419
DTC Client socket (1) | Closed. | 2020-10-07 01:09:06.419
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:09:36.388
DTC Client socket (1) | Creating socket. | 2020-10-07 01:09:36.389
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:09:36.389
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:09:36.389
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:09:36.411
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:09:36.411
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:09:36.411
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:09:36.442
SC Data - All Services | Sending logon request message. | 2020-10-07 01:09:36.442
SC Data - All Services | Received logon response. | 2020-10-07 01:09:37.111
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:09:37.111
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:09:37.111
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:09:37.111
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:09:37.111
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:09:37.111
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:09:37.111
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:09:37.111
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:09:37.111
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:09:37.111
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:09:37.124
DTC Client socket (1) | Closed. | 2020-10-07 01:09:37.125
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:10:07.109
DTC Client socket (1) | Creating socket. | 2020-10-07 01:10:07.110
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:10:07.110
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:10:07.110
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:10:07.140
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:10:07.140
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:10:07.140
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:10:07.180
SC Data - All Services | Sending logon request message. | 2020-10-07 01:10:07.180
SC Data - All Services | Received logon response. | 2020-10-07 01:10:07.832
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:10:07.832
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:10:07.832
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:10:07.832
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:10:07.832
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:10:07.832
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:10:07.832
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:10:07.832
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:10:07.832
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:10:07.832
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:10:07.847
DTC Client socket (1) | Closed. | 2020-10-07 01:10:07.847
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:10:37.821
DTC Client socket (1) | Creating socket. | 2020-10-07 01:10:37.822
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:10:37.822
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:10:37.822
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:10:37.851
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:10:37.851
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:10:37.851
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:10:37.880
SC Data - All Services | Sending logon request message. | 2020-10-07 01:10:37.880
SC Data - All Services | Received logon response. | 2020-10-07 01:10:38.584
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:10:38.584
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:10:38.584
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:10:38.584
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:10:38.584
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:10:38.584
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:10:38.584
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:10:38.584
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:10:38.585
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:10:38.585
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:10:38.609
DTC Client socket (1) | Closed. | 2020-10-07 01:10:38.609
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:11:08.578
DTC Client socket (1) | Creating socket. | 2020-10-07 01:11:08.579
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:11:08.579
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:11:08.579
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:11:08.597
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:11:08.597
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:11:08.597
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:11:08.625
SC Data - All Services | Sending logon request message. | 2020-10-07 01:11:08.625
SC Data - All Services | Received logon response. | 2020-10-07 01:11:09.277
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:11:09.277
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:11:09.278
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:11:09.278
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:11:09.278
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:11:09.279
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:11:09.279
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:11:09.279
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:11:09.279
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:11:09.279
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:11:09.292
DTC Client socket (1) | Closed. | 2020-10-07 01:11:09.292
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:11:39.281
DTC Client socket (1) | Creating socket. | 2020-10-07 01:11:39.281
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:11:39.282
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:11:39.282
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:11:39.312
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:11:39.312
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:11:39.312
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:11:39.352
SC Data - All Services | Sending logon request message. | 2020-10-07 01:11:39.352
SC Data - All Services | Received logon response. | 2020-10-07 01:11:40.011
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:11:40.011
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:11:40.011
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:11:40.011
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:11:40.011
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:11:40.011
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:11:40.011
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:11:40.011
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:11:40.012
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:11:40.012
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:11:40.025
DTC Client socket (1) | Closed. | 2020-10-07 01:11:40.025
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:12:10.018
DTC Client socket (1) | Creating socket. | 2020-10-07 01:12:10.018
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:12:10.018
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:12:10.018
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:12:10.045
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:12:10.045
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:12:10.045
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:12:10.082
SC Data - All Services | Sending logon request message. | 2020-10-07 01:12:10.082
SC Data - All Services | Received logon response. | 2020-10-07 01:12:10.728
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:12:10.728
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:12:10.728
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:12:10.728
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:12:10.728
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:12:10.728
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:12:10.728
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:12:10.728
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:12:10.728
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:12:10.728
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:12:10.745
DTC Client socket (1) | Closed. | 2020-10-07 01:12:10.745
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1292 seconds. | 2020-10-07 01:12:25.640
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0346 seconds. | 2020-10-07 01:12:25.676
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:12:40.735
DTC Client socket (1) | Creating socket. | 2020-10-07 01:12:40.735
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:12:40.735
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:12:40.735
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:12:40.762
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:12:40.762
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:12:40.762
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:12:40.805
SC Data - All Services | Sending logon request message. | 2020-10-07 01:12:40.805
SC Data - All Services | Received logon response. | 2020-10-07 01:12:41.493
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:12:41.493
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:12:41.493
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:12:41.493
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:12:41.493
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:12:41.494
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:12:41.494
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:12:41.494
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:12:41.494
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:12:41.494
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:12:41.521
DTC Client socket (1) | Closed. | 2020-10-07 01:12:41.521
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:13:11.505
DTC Client socket (1) | Creating socket. | 2020-10-07 01:13:11.506
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:13:11.506
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:13:11.506
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:13:11.523
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:13:11.523
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:13:11.523
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:13:11.542
SC Data - All Services | Sending logon request message. | 2020-10-07 01:13:11.542
SC Data - All Services | Received logon response. | 2020-10-07 01:13:12.198
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:13:12.198
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:13:12.198
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:13:12.198
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:13:12.198
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:13:12.200
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:13:12.200
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:13:12.200
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:13:12.200
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:13:12.200
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:13:12.213
DTC Client socket (1) | Closed. | 2020-10-07 01:13:12.213
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:13:42.201
DTC Client socket (1) | Creating socket. | 2020-10-07 01:13:42.202
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:13:42.202
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:13:42.202
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:13:42.224
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:13:42.224
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:13:42.224
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:13:42.256
SC Data - All Services | Sending logon request message. | 2020-10-07 01:13:42.256
SC Data - All Services | Received logon response. | 2020-10-07 01:13:42.924
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:13:42.924
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:13:42.924
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:13:42.924
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:13:42.924
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:13:42.924
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:13:42.924
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:13:42.924
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:13:42.924
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:13:42.924
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:13:42.937
DTC Client socket (1) | Closed. | 2020-10-07 01:13:42.937
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:14:12.919
DTC Client socket (1) | Creating socket. | 2020-10-07 01:14:12.919
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:14:12.919
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:14:12.919
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:14:12.936
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:14:12.936
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:14:12.936
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:14:12.981
SC Data - All Services | Sending logon request message. | 2020-10-07 01:14:12.981
SC Data - All Services | Received logon response. | 2020-10-07 01:14:13.618
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:14:13.618
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:14:13.618
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:14:13.618
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:14:13.618
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:14:13.618
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:14:13.618
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:14:13.618
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:14:13.618
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:14:13.618
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:14:13.633
DTC Client socket (1) | Closed. | 2020-10-07 01:14:13.633
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:14:43.623
DTC Client socket (1) | Creating socket. | 2020-10-07 01:14:43.624
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:14:43.624
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:14:43.624
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:14:43.650
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:14:43.650
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:14:43.650
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:14:43.714
SC Data - All Services | Sending logon request message. | 2020-10-07 01:14:43.714
SC Data - All Services | Received logon response. | 2020-10-07 01:14:44.428
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:14:44.428
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:14:44.428
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:14:44.428
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:14:44.428
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:14:44.428
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:14:44.428
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:14:44.428
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:14:44.428
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:14:44.428
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:14:44.457
DTC Client socket (1) | Closed. | 2020-10-07 01:14:44.457
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:15:14.415
DTC Client socket (1) | Creating socket. | 2020-10-07 01:15:14.416
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:15:14.416
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:15:14.416
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:15:14.430
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:15:14.430
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:15:14.430
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:15:14.459
SC Data - All Services | Sending logon request message. | 2020-10-07 01:15:14.459
SC Data - All Services | Received logon response. | 2020-10-07 01:15:15.116
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:15:15.116
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:15:15.116
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:15:15.116
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:15:15.116
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:15:15.116
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:15:15.116
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:15:15.116
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:15:15.116
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:15:15.116
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:15:15.130
DTC Client socket (1) | Closed. | 2020-10-07 01:15:15.130
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:15:45.102
DTC Client socket (1) | Creating socket. | 2020-10-07 01:15:45.102
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:15:45.102
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:15:45.102
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:15:45.116
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:15:45.116
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:15:45.116
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:15:45.162
SC Data - All Services | Sending logon request message. | 2020-10-07 01:15:45.162
SC Data - All Services | Received logon response. | 2020-10-07 01:15:45.811
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:15:45.811
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:15:45.811
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:15:45.811
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:15:45.811
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:15:45.812
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:15:45.812
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:15:45.812
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:15:45.812
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:15:45.812
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:15:45.829
DTC Client socket (1) | Closed. | 2020-10-07 01:15:45.829
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:16:15.814
DTC Client socket (2) | Creating socket. | 2020-10-07 01:16:15.815
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 01:16:15.815
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:16:15.815
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:16:15.838
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:16:15.838
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:16:15.838
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:16:15.869
SC Data - All Services | Sending logon request message. | 2020-10-07 01:16:15.869
SC Data - All Services | Received logon response. | 2020-10-07 01:16:16.497
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:16:16.497
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:16:16.497
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:16:16.497
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:16:16.497
DTC Client socket (2) | CloseSocket call. | 2020-10-07 01:16:16.497
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:16:16.497
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:16:16.497
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:16:16.497
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:16:16.497
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 01:16:16.512
DTC Client socket (2) | Closed. | 2020-10-07 01:16:16.512
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:16:46.492
DTC Client socket (1) | Creating socket. | 2020-10-07 01:16:46.492
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:16:46.492
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:16:46.492
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:16:46.520
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:16:46.520
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:16:46.520
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:16:46.566
SC Data - All Services | Sending logon request message. | 2020-10-07 01:16:46.566
SC Data - All Services | Received logon response. | 2020-10-07 01:16:47.280
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:16:47.280
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:16:47.280
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:16:47.280
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:16:47.280
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:16:47.280
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:16:47.280
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:16:47.280
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:16:47.280
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:16:47.280
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:16:47.305
DTC Client socket (1) | Closed. | 2020-10-07 01:16:47.305
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:17:17.277
DTC Client socket (1) | Creating socket. | 2020-10-07 01:17:17.277
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:17:17.277
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:17:17.277
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:17:17.305
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:17:17.305
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:17:17.306
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:17:17.340
SC Data - All Services | Sending logon request message. | 2020-10-07 01:17:17.340
SC Data - All Services | Received logon response. | 2020-10-07 01:17:17.993
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:17:17.993
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:17:17.993
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:17:17.993
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:17:17.993
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:17:17.993
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:17:17.993
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:17:17.994
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:17:17.994
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:17:17.994
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:17:18.006
DTC Client socket (1) | Closed. | 2020-10-07 01:17:18.006
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:17:48.007
DTC Client socket (1) | Creating socket. | 2020-10-07 01:17:48.007
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:17:48.007
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:17:48.007
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:17:48.023
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:17:48.023
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:17:48.023
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:17:48.065
SC Data - All Services | Sending logon request message. | 2020-10-07 01:17:48.065
SC Data - All Services | Received logon response. | 2020-10-07 01:17:48.707
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:17:48.707
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:17:48.707
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:17:48.707
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:17:48.707
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:17:48.708
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:17:48.708
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:17:48.708
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:17:48.709
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:17:48.709
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:17:48.724
DTC Client socket (1) | Closed. | 2020-10-07 01:17:48.724
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:18:18.702
DTC Client socket (1) | Creating socket. | 2020-10-07 01:18:18.703
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:18:18.703
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:18:18.703
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:18:18.725
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:18:18.725
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:18:18.725
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:18:18.773
SC Data - All Services | Sending logon request message. | 2020-10-07 01:18:18.773
SC Data - All Services | Received logon response. | 2020-10-07 01:18:19.422
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:18:19.422
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:18:19.422
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:18:19.422
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:18:19.422
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:18:19.422
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:18:19.422
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:18:19.422
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:18:19.422
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:18:19.422
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:18:19.436
DTC Client socket (1) | Closed. | 2020-10-07 01:18:19.436
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:18:49.424
DTC Client socket (1) | Creating socket. | 2020-10-07 01:18:49.424
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:18:49.424
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:18:49.425
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:18:49.472
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:18:49.472
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:18:49.472
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:18:49.502
SC Data - All Services | Sending logon request message. | 2020-10-07 01:18:49.502
SC Data - All Services | Received logon response. | 2020-10-07 01:18:50.210
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:18:50.210
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:18:50.210
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:18:50.210
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:18:50.210
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:18:50.210
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:18:50.210
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:18:50.210
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:18:50.210
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:18:50.210
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:18:50.236
DTC Client socket (1) | Closed. | 2020-10-07 01:18:50.236
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:19:20.198
DTC Client socket (1) | Creating socket. | 2020-10-07 01:19:20.199
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:19:20.199
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:19:20.199
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:19:20.223
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:19:20.223
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:19:20.224
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:19:20.292
SC Data - All Services | Sending logon request message. | 2020-10-07 01:19:20.292
SC Data - All Services | Received logon response. | 2020-10-07 01:19:20.973
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:19:20.973
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:19:20.973
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:19:20.973
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:19:20.973
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:19:20.974
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:19:20.974
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:19:20.974
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:19:20.974
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:19:20.974
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:19:20.992
DTC Client socket (1) | Closed. | 2020-10-07 01:19:20.992
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:19:50.965
DTC Client socket (1) | Creating socket. | 2020-10-07 01:19:50.965
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:19:50.965
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:19:50.965
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:19:50.989
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:19:50.989
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:19:50.989
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:19:51.027
SC Data - All Services | Sending logon request message. | 2020-10-07 01:19:51.027
SC Data - All Services | Received logon response. | 2020-10-07 01:19:51.727
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:19:51.727
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:19:51.727
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:19:51.727
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:19:51.727
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:19:51.727
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:19:51.727
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:19:51.727
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:19:51.727
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:19:51.727
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:19:51.748
DTC Client socket (1) | Closed. | 2020-10-07 01:19:51.748
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:20:21.739
DTC Client socket (1) | Creating socket. | 2020-10-07 01:20:21.739
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:20:21.739
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:20:21.739
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:20:21.769
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:20:21.769
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:20:21.769
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:20:21.823
SC Data - All Services | Sending logon request message. | 2020-10-07 01:20:21.823
SC Data - All Services | Received logon response. | 2020-10-07 01:20:22.471
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:20:22.471
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:20:22.471
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:20:22.471
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:20:22.471
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:20:22.471
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:20:22.471
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:20:22.471
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:20:22.471
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:20:22.471
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:20:22.485
DTC Client socket (1) | Closed. | 2020-10-07 01:20:22.485
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:20:52.476
DTC Client socket (1) | Creating socket. | 2020-10-07 01:20:52.477
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:20:52.477
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:20:52.477
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:20:52.508
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:20:52.508
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:20:52.508
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:20:52.554
SC Data - All Services | Sending logon request message. | 2020-10-07 01:20:52.554
SC Data - All Services | Received logon response. | 2020-10-07 01:20:52.755
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:20:52.755
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:20:52.755
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:20:52.755
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:20:52.755
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:20:52.755
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:20:52.755
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:20:52.755
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:20:52.755
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:20:52.755
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:20:52.781
DTC Client socket (1) | Closed. | 2020-10-07 01:20:52.782
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:21:22.754
DTC Client socket (1) | Creating socket. | 2020-10-07 01:21:22.754
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:21:22.754
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:21:22.754
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:21:22.775
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:21:22.775
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:21:22.775
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:21:22.792
SC Data - All Services | Sending logon request message. | 2020-10-07 01:21:22.792
SC Data - All Services | Received logon response. | 2020-10-07 01:21:23.505
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:21:23.505
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:21:23.505
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:21:23.505
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:21:23.505
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:21:23.505
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:21:23.505
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:21:23.505
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:21:23.505
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:21:23.505
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:21:23.524
DTC Client socket (1) | Closed. | 2020-10-07 01:21:23.524
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:21:53.503
DTC Client socket (1) | Creating socket. | 2020-10-07 01:21:53.503
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:21:53.503
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:21:53.503
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:21:53.532
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:21:53.532
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:21:53.532
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:21:53.582
SC Data - All Services | Sending logon request message. | 2020-10-07 01:21:53.582
SC Data - All Services | Received logon response. | 2020-10-07 01:21:54.195
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:21:54.195
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:21:54.195
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:21:54.195
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:21:54.195
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:21:54.195
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:21:54.195
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:21:54.195
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:21:54.195
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:21:54.195
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:21:54.207
DTC Client socket (1) | Closed. | 2020-10-07 01:21:54.207
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:22:24.204
DTC Client socket (1) | Creating socket. | 2020-10-07 01:22:24.205
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:22:24.205
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:22:24.205
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:22:24.227
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:22:24.227
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:22:24.227
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:22:24.265
SC Data - All Services | Sending logon request message. | 2020-10-07 01:22:24.265
SC Data - All Services | Received logon response. | 2020-10-07 01:22:24.881
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:22:24.881
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:22:24.881
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:22:24.881
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:22:24.881
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:22:24.881
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:22:24.881
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:22:24.881
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:22:24.881
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:22:24.881
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:22:24.897
DTC Client socket (1) | Closed. | 2020-10-07 01:22:24.897
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:22:54.874
DTC Client socket (1) | Creating socket. | 2020-10-07 01:22:54.874
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:22:54.874
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:22:54.874
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:22:54.902
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:22:54.902
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:22:54.902
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:22:54.945
SC Data - All Services | Sending logon request message. | 2020-10-07 01:22:54.945
SC Data - All Services | Received logon response. | 2020-10-07 01:22:55.652
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:22:55.652
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:22:55.652
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:22:55.652
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:22:55.652
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:22:55.653
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:22:55.653
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:22:55.653
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:22:55.653
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:22:55.653
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:22:55.683
DTC Client socket (1) | Closed. | 2020-10-07 01:22:55.683
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:23:25.666
DTC Client socket (1) | Creating socket. | 2020-10-07 01:23:25.667
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:23:25.667
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:23:25.667
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:23:25.684
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:23:25.684
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:23:25.684
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:23:25.737
SC Data - All Services | Sending logon request message. | 2020-10-07 01:23:25.737
SC Data - All Services | Received logon response. | 2020-10-07 01:23:26.406
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:23:26.406
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:23:26.406
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:23:26.406
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:23:26.406
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:23:26.407
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:23:26.407
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:23:26.407
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:23:26.407
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:23:26.407
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:23:26.420
DTC Client socket (1) | Closed. | 2020-10-07 01:23:26.420
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:23:56.404
DTC Client socket (1) | Creating socket. | 2020-10-07 01:23:56.405
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:23:56.405
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:23:56.405
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:23:56.420
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:23:56.420
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:23:56.420
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:23:56.467
SC Data - All Services | Sending logon request message. | 2020-10-07 01:23:56.467
SC Data - All Services | Received logon response. | 2020-10-07 01:23:57.107
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:23:57.107
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:23:57.107
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:23:57.107
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:23:57.107
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:23:57.107
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:23:57.107
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:23:57.107
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:23:57.107
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:23:57.107
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:23:57.119
DTC Client socket (1) | Closed. | 2020-10-07 01:23:57.120
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:24:27.109
DTC Client socket (1) | Creating socket. | 2020-10-07 01:24:27.110
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:24:27.110
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:24:27.110
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:24:27.125
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:24:27.125
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:24:27.125
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:24:27.147
SC Data - All Services | Sending logon request message. | 2020-10-07 01:24:27.147
SC Data - All Services | Received logon response. | 2020-10-07 01:24:27.774
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:24:27.774
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:24:27.774
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:24:27.774
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:24:27.774
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:24:27.775
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:24:27.775
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:24:27.775
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:24:27.775
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:24:27.775
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:24:27.789
DTC Client socket (1) | Closed. | 2020-10-07 01:24:27.789
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:24:57.783
DTC Client socket (1) | Creating socket. | 2020-10-07 01:24:57.783
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:24:57.783
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:24:57.783
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:24:57.811
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:24:57.811
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:24:57.811
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:24:57.876
SC Data - All Services | Sending logon request message. | 2020-10-07 01:24:57.876
SC Data - All Services | Received logon response. | 2020-10-07 01:24:58.531
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:24:58.531
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:24:58.531
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:24:58.531
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:24:58.531
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:24:58.531
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:24:58.531
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:24:58.531
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:24:58.531
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:24:58.531
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:24:58.556
DTC Client socket (1) | Closed. | 2020-10-07 01:24:58.556
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:25:28.524
DTC Client socket (1) | Creating socket. | 2020-10-07 01:25:28.525
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:25:28.525
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:25:28.525
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:25:28.556
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:25:28.556
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:25:28.556
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:25:28.601
SC Data - All Services | Sending logon request message. | 2020-10-07 01:25:28.601
SC Data - All Services | Received logon response. | 2020-10-07 01:25:29.258
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:25:29.258
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:25:29.258
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:25:29.258
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:25:29.258
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:25:29.258
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:25:29.258
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:25:29.259
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:25:29.259
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:25:29.259
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:25:29.273
DTC Client socket (1) | Closed. | 2020-10-07 01:25:29.273
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:25:59.259
DTC Client socket (1) | Creating socket. | 2020-10-07 01:25:59.260
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:25:59.260
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:25:59.260
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:25:59.289
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:25:59.289
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:25:59.289
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:25:59.311
SC Data - All Services | Sending logon request message. | 2020-10-07 01:25:59.311
SC Data - All Services | Received logon response. | 2020-10-07 01:25:59.923
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:25:59.923
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:25:59.923
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:25:59.923
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:25:59.923
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:25:59.923
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:25:59.923
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:25:59.923
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:25:59.923
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:25:59.923
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:25:59.937
DTC Client socket (1) | Closed. | 2020-10-07 01:25:59.937
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:26:29.915
DTC Client socket (1) | Creating socket. | 2020-10-07 01:26:29.916
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:26:29.916
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:26:29.916
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:26:29.937
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:26:29.937
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:26:29.937
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:26:29.963
SC Data - All Services | Sending logon request message. | 2020-10-07 01:26:29.963
SC Data - All Services | Received logon response. | 2020-10-07 01:26:30.583
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:26:30.583
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:26:30.583
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:26:30.583
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:26:30.583
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:26:30.583
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:26:30.583
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:26:30.583
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:26:30.583
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:26:30.583
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:26:30.598
DTC Client socket (1) | Closed. | 2020-10-07 01:26:30.598
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:27:00.578
DTC Client socket (1) | Creating socket. | 2020-10-07 01:27:00.578
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:27:00.578
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:27:00.578
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:27:00.610
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:27:00.610
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:27:00.610
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:27:00.663
SC Data - All Services | Sending logon request message. | 2020-10-07 01:27:00.663
SC Data - All Services | Received logon response. | 2020-10-07 01:27:01.340
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:27:01.340
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:27:01.340
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:27:01.340
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:27:01.340
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:27:01.341
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:27:01.341
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:27:01.341
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:27:01.341
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:27:01.341
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:27:01.377
DTC Client socket (1) | Closed. | 2020-10-07 01:27:01.377
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1047 seconds. | 2020-10-07 01:27:25.771
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0442 seconds. | 2020-10-07 01:27:25.816
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:27:31.336
DTC Client socket (1) | Creating socket. | 2020-10-07 01:27:31.337
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:27:31.337
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:27:31.337
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:27:31.360
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:27:31.360
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:27:31.361
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:27:31.378
SC Data - All Services | Sending logon request message. | 2020-10-07 01:27:31.378
SC Data - All Services | Received logon response. | 2020-10-07 01:27:32.016
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:27:32.016
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:27:32.016
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:27:32.016
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:27:32.016
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:27:32.017
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:27:32.017
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:27:32.017
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:27:32.017
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:27:32.017
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:27:32.031
DTC Client socket (1) | Closed. | 2020-10-07 01:27:32.031
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:28:02.016
DTC Client socket (1) | Creating socket. | 2020-10-07 01:28:02.017
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:28:02.017
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:28:02.017
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:28:02.038
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:28:02.038
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:28:02.038
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:28:02.085
SC Data - All Services | Sending logon request message. | 2020-10-07 01:28:02.085
SC Data - All Services | Received logon response. | 2020-10-07 01:28:02.676
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:28:02.676
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:28:02.676
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:28:02.676
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:28:02.676
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:28:02.676
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:28:02.676
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:28:02.677
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:28:02.677
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:28:02.677
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:28:02.690
DTC Client socket (1) | Closed. | 2020-10-07 01:28:02.690
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:28:32.675
DTC Client socket (1) | Creating socket. | 2020-10-07 01:28:32.676
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:28:32.676
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:28:32.676
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:28:32.702
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:28:32.702
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:28:32.702
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:28:32.746
SC Data - All Services | Sending logon request message. | 2020-10-07 01:28:32.746
SC Data - All Services | Received logon response. | 2020-10-07 01:28:33.373
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:28:33.373
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:28:33.373
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:28:33.373
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:28:33.373
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:28:33.373
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:28:33.373
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:28:33.373
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:28:33.373
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:28:33.373
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:28:33.389
DTC Client socket (1) | Closed. | 2020-10-07 01:28:33.390
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:29:03.371
DTC Client socket (1) | Creating socket. | 2020-10-07 01:29:03.371
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:29:03.372
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:29:03.372
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:29:03.408
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:29:03.408
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:29:03.408
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:29:03.440
SC Data - All Services | Sending logon request message. | 2020-10-07 01:29:03.440
SC Data - All Services | Received logon response. | 2020-10-07 01:29:04.140
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:29:04.140
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:29:04.140
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:29:04.140
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:29:04.140
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:29:04.140
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:29:04.140
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:29:04.140
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:29:04.140
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:29:04.140
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:29:04.167
DTC Client socket (1) | Closed. | 2020-10-07 01:29:04.167
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:29:34.143
DTC Client socket (1) | Creating socket. | 2020-10-07 01:29:34.143
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:29:34.143
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:29:34.143
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:29:34.171
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:29:34.171
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:29:34.171
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:29:34.205
SC Data - All Services | Sending logon request message. | 2020-10-07 01:29:34.205
SC Data - All Services | Received logon response. | 2020-10-07 01:29:34.893
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:29:34.893
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:29:34.893
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:29:34.893
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:29:34.893
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:29:34.893
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:29:34.893
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:29:34.893
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:29:34.893
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:29:34.893
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:29:34.908
DTC Client socket (1) | Closed. | 2020-10-07 01:29:34.908
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:30:04.895
DTC Client socket (1) | Creating socket. | 2020-10-07 01:30:04.896
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:30:04.896
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:30:04.896
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:30:04.911
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:30:04.911
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:30:04.911
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:30:04.958
SC Data - All Services | Sending logon request message. | 2020-10-07 01:30:04.958
SC Data - All Services | Received logon response. | 2020-10-07 01:30:05.571
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:30:05.571
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:30:05.571
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:30:05.571
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:30:05.571
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:30:05.571
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:30:05.571
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:30:05.571
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:30:05.571
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:30:05.571
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:30:05.587
DTC Client socket (1) | Closed. | 2020-10-07 01:30:05.587
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:30:35.578
DTC Client socket (1) | Creating socket. | 2020-10-07 01:30:35.578
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:30:35.578
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:30:35.578
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:30:35.602
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:30:35.602
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:30:35.602
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:30:35.631
SC Data - All Services | Sending logon request message. | 2020-10-07 01:30:35.631
SC Data - All Services | Received logon response. | 2020-10-07 01:30:36.263
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:30:36.263
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:30:36.263
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:30:36.263
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:30:36.263
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:30:36.263
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:30:36.263
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:30:36.263
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:30:36.263
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:30:36.263
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:30:36.276
DTC Client socket (1) | Closed. | 2020-10-07 01:30:36.276
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:31:06.263
DTC Client socket (1) | Creating socket. | 2020-10-07 01:31:06.263
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:31:06.263
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:31:06.263
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:31:06.292
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:31:06.292
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:31:06.292
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:31:06.339
SC Data - All Services | Sending logon request message. | 2020-10-07 01:31:06.340
SC Data - All Services | Received logon response. | 2020-10-07 01:31:07.022
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:31:07.022
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:31:07.022
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:31:07.022
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:31:07.022
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:31:07.023
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:31:07.023
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:31:07.023
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:31:07.023
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:31:07.023
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:31:07.049
DTC Client socket (1) | Closed. | 2020-10-07 01:31:07.049
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:31:37.009
DTC Client socket (1) | Creating socket. | 2020-10-07 01:31:37.010
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:31:37.010
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:31:37.010
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:31:37.031
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:31:37.031
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:31:37.031
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:31:37.062
SC Data - All Services | Sending logon request message. | 2020-10-07 01:31:37.062
SC Data - All Services | Received logon response. | 2020-10-07 01:31:37.716
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:31:37.716
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:31:37.716
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:31:37.716
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:31:37.716
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:31:37.716
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:31:37.716
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:31:37.716
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:31:37.717
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:31:37.717
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:31:37.731
DTC Client socket (1) | Closed. | 2020-10-07 01:31:37.731
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:32:07.720
DTC Client socket (1) | Creating socket. | 2020-10-07 01:32:07.721
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:32:07.721
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:32:07.721
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:32:07.743
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:32:07.743
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:32:07.743
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:32:07.758
SC Data - All Services | Sending logon request message. | 2020-10-07 01:32:07.758
SC Data - All Services | Received logon response. | 2020-10-07 01:32:08.404
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:32:08.405
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:32:08.405
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:32:08.405
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:32:08.405
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:32:08.405
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:32:08.405
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:32:08.405
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:32:08.405
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:32:08.405
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:32:08.418
DTC Client socket (1) | Closed. | 2020-10-07 01:32:08.418
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:32:38.412
DTC Client socket (1) | Creating socket. | 2020-10-07 01:32:38.413
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:32:38.413
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:32:38.413
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:32:38.444
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:32:38.444
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:32:38.444
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:32:38.487
SC Data - All Services | Sending logon request message. | 2020-10-07 01:32:38.487
SC Data - All Services | Received logon response. | 2020-10-07 01:32:39.129
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:32:39.129
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:32:39.129
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:32:39.129
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:32:39.129
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:32:39.130
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:32:39.130
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:32:39.130
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:32:39.130
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:32:39.130
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:32:39.145
DTC Client socket (1) | Closed. | 2020-10-07 01:32:39.145
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:33:09.125
DTC Client socket (1) | Creating socket. | 2020-10-07 01:33:09.126
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:33:09.126
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:33:09.126
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:33:09.152
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:33:09.152
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:33:09.152
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:33:09.196
SC Data - All Services | Sending logon request message. | 2020-10-07 01:33:09.196
SC Data - All Services | Received logon response. | 2020-10-07 01:33:09.900
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:33:09.900
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:33:09.900
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:33:09.900
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:33:09.900
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:33:09.900
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:33:09.900
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:33:09.900
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:33:09.900
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:33:09.900
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:33:09.926
DTC Client socket (1) | Closed. | 2020-10-07 01:33:09.926
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:33:39.914
DTC Client socket (1) | Creating socket. | 2020-10-07 01:33:39.915
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:33:39.915
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:33:39.915
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:33:39.933
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:33:39.933
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:33:39.933
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:33:39.957
SC Data - All Services | Sending logon request message. | 2020-10-07 01:33:39.957
SC Data - All Services | Received logon response. | 2020-10-07 01:33:40.646
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:33:40.646
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:33:40.646
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:33:40.646
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:33:40.646
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:33:40.647
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:33:40.647
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:33:40.647
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:33:40.647
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:33:40.647
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:33:40.661
DTC Client socket (1) | Closed. | 2020-10-07 01:33:40.661
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:34:10.634
DTC Client socket (1) | Creating socket. | 2020-10-07 01:34:10.635
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:34:10.635
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:34:10.635
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:34:10.649
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:34:10.649
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:34:10.649
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:34:10.678
SC Data - All Services | Sending logon request message. | 2020-10-07 01:34:10.678
SC Data - All Services | Received logon response. | 2020-10-07 01:34:11.268
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:34:11.268
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:34:11.268
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:34:11.268
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:34:11.268
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:34:11.268
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:34:11.268
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:34:11.268
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:34:11.268
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:34:11.268
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:34:11.282
DTC Client socket (1) | Closed. | 2020-10-07 01:34:11.282
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:34:41.266
DTC Client socket (1) | Creating socket. | 2020-10-07 01:34:41.267
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:34:41.267
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:34:41.267
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:34:41.290
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:34:41.290
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:34:41.290
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:34:41.340
SC Data - All Services | Sending logon request message. | 2020-10-07 01:34:41.340
SC Data - All Services | Received logon response. | 2020-10-07 01:34:41.982
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:34:41.982
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:34:41.982
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:34:41.982
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:34:41.982
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:34:41.982
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:34:41.982
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:34:41.982
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:34:41.982
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:34:41.983
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:34:41.999
DTC Client socket (1) | Closed. | 2020-10-07 01:34:41.999
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:35:11.990
DTC Client socket (1) | Creating socket. | 2020-10-07 01:35:11.991
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:35:11.991
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:35:11.991
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:35:12.018
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:35:12.018
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:35:12.018
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:35:12.084
SC Data - All Services | Sending logon request message. | 2020-10-07 01:35:12.084
SC Data - All Services | Received logon response. | 2020-10-07 01:35:12.786
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:35:12.786
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:35:12.786
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:35:12.786
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:35:12.786
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:35:12.786
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:35:12.786
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:35:12.786
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:35:12.786
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:35:12.786
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:35:12.812
DTC Client socket (1) | Closed. | 2020-10-07 01:35:12.812
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:35:42.775
DTC Client socket (1) | Creating socket. | 2020-10-07 01:35:42.775
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:35:42.775
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:35:42.775
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:35:42.790
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:35:42.790
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:35:42.790
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:35:42.832
SC Data - All Services | Sending logon request message. | 2020-10-07 01:35:42.832
SC Data - All Services | Received logon response. | 2020-10-07 01:35:43.490
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:35:43.490
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:35:43.490
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:35:43.490
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:35:43.490
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:35:43.491
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:35:43.491
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:35:43.491
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:35:43.491
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:35:43.491
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:35:43.504
DTC Client socket (1) | Closed. | 2020-10-07 01:35:43.504
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:36:13.486
DTC Client socket (2) | Creating socket. | 2020-10-07 01:36:13.486
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 01:36:13.486
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:36:13.486
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:36:13.502
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:36:13.502
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:36:13.502
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:36:13.530
SC Data - All Services | Sending logon request message. | 2020-10-07 01:36:13.530
SC Data - All Services | Received logon response. | 2020-10-07 01:36:14.166
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:36:14.166
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:36:14.166
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:36:14.166
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:36:14.166
DTC Client socket (2) | CloseSocket call. | 2020-10-07 01:36:14.166
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:36:14.166
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:36:14.166
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:36:14.166
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:36:14.166
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 01:36:14.181
DTC Client socket (2) | Closed. | 2020-10-07 01:36:14.181
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:36:44.171
DTC Client socket (1) | Creating socket. | 2020-10-07 01:36:44.171
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:36:44.171
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:36:44.171
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:36:44.193
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:36:44.193
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:36:44.193
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:36:44.213
SC Data - All Services | Sending logon request message. | 2020-10-07 01:36:44.213
SC Data - All Services | Received logon response. | 2020-10-07 01:36:44.861
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:36:44.861
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:36:44.861
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:36:44.861
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:36:44.861
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:36:44.861
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:36:44.861
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:36:44.861
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:36:44.861
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:36:44.861
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:36:44.876
DTC Client socket (1) | Closed. | 2020-10-07 01:36:44.876
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:37:14.861
DTC Client socket (1) | Creating socket. | 2020-10-07 01:37:14.861
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:37:14.861
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:37:14.861
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:37:14.888
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:37:14.888
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:37:14.888
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:37:14.945
SC Data - All Services | Sending logon request message. | 2020-10-07 01:37:14.945
SC Data - All Services | Received logon response. | 2020-10-07 01:37:15.621
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:37:15.621
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:37:15.621
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:37:15.621
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:37:15.621
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:37:15.621
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:37:15.621
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:37:15.621
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:37:15.621
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:37:15.621
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:37:15.647
DTC Client socket (1) | Closed. | 2020-10-07 01:37:15.647
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:37:45.627
DTC Client socket (1) | Creating socket. | 2020-10-07 01:37:45.627
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:37:45.627
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:37:45.627
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:37:45.651
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:37:45.651
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:37:45.651
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:37:45.667
SC Data - All Services | Sending logon request message. | 2020-10-07 01:37:45.667
SC Data - All Services | Received logon response. | 2020-10-07 01:37:46.339
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:37:46.339
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:37:46.339
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:37:46.339
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:37:46.339
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:37:46.339
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:37:46.339
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:37:46.339
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:37:46.339
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:37:46.340
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:37:46.353
DTC Client socket (1) | Closed. | 2020-10-07 01:37:46.353
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:38:16.349
DTC Client socket (1) | Creating socket. | 2020-10-07 01:38:16.349
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:38:16.350
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:38:16.350
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:38:16.365
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:38:16.365
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:38:16.365
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:38:16.390
SC Data - All Services | Sending logon request message. | 2020-10-07 01:38:16.390
SC Data - All Services | Received logon response. | 2020-10-07 01:38:17.064
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:38:17.064
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:38:17.064
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:38:17.064
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:38:17.064
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:38:17.064
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:38:17.064
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:38:17.064
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:38:17.064
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:38:17.064
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:38:17.077
DTC Client socket (1) | Closed. | 2020-10-07 01:38:17.077
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:38:47.056
DTC Client socket (1) | Creating socket. | 2020-10-07 01:38:47.056
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:38:47.056
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:38:47.056
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:38:47.079
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:38:47.079
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:38:47.079
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:38:47.128
SC Data - All Services | Sending logon request message. | 2020-10-07 01:38:47.128
SC Data - All Services | Received logon response. | 2020-10-07 01:38:47.771
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:38:47.771
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:38:47.771
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:38:47.771
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:38:47.771
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:38:47.771
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:38:47.771
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:38:47.771
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:38:47.771
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:38:47.771
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:38:47.785
DTC Client socket (1) | Closed. | 2020-10-07 01:38:47.785
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:39:17.763
DTC Client socket (1) | Creating socket. | 2020-10-07 01:39:17.763
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:39:17.763
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:39:17.763
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:39:17.824
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:39:17.824
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:39:17.824
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:39:17.909
SC Data - All Services | Sending logon request message. | 2020-10-07 01:39:17.909
SC Data - All Services | Received logon response. | 2020-10-07 01:39:18.619
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:39:18.619
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:39:18.619
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:39:18.619
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:39:18.619
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:39:18.620
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:39:18.620
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:39:18.620
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:39:18.620
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:39:18.620
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:39:18.678
DTC Client socket (1) | Closed. | 2020-10-07 01:39:18.678
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:39:48.628
DTC Client socket (1) | Creating socket. | 2020-10-07 01:39:48.629
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:39:48.629
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:39:48.629
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:39:48.644
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:39:48.645
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:39:48.645
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:39:48.676
SC Data - All Services | Sending logon request message. | 2020-10-07 01:39:48.676
SC Data - All Services | Received logon response. | 2020-10-07 01:39:49.329
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:39:49.329
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:39:49.329
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:39:49.329
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:39:49.329
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:39:49.329
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:39:49.329
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:39:49.329
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:39:49.329
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:39:49.329
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:39:49.342
DTC Client socket (1) | Closed. | 2020-10-07 01:39:49.342
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:40:19.333
DTC Client socket (1) | Creating socket. | 2020-10-07 01:40:19.334
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:40:19.334
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:40:19.334
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:40:19.353
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:40:19.353
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:40:19.353
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:40:19.396
SC Data - All Services | Sending logon request message. | 2020-10-07 01:40:19.396
SC Data - All Services | Received logon response. | 2020-10-07 01:40:20.050
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:40:20.050
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:40:20.050
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:40:20.050
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:40:20.050
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:40:20.050
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:40:20.050
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:40:20.050
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:40:20.050
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:40:20.050
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:40:20.067
DTC Client socket (1) | Closed. | 2020-10-07 01:40:20.067
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:40:50.052
DTC Client socket (1) | Creating socket. | 2020-10-07 01:40:50.053
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:40:50.053
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:40:50.053
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:40:50.075
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:40:50.075
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:40:50.075
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:40:50.106
SC Data - All Services | Sending logon request message. | 2020-10-07 01:40:50.106
SC Data - All Services | Received logon response. | 2020-10-07 01:40:50.744
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:40:50.744
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:40:50.744
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:40:50.744
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:40:50.744
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:40:50.744
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:40:50.744
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:40:50.744
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:40:50.744
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:40:50.744
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:40:50.760
DTC Client socket (1) | Closed. | 2020-10-07 01:40:50.761
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:41:20.743
DTC Client socket (1) | Creating socket. | 2020-10-07 01:41:20.744
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:41:20.744
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:41:20.744
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:41:20.804
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:41:20.804
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:41:20.804
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:41:20.877
SC Data - All Services | Sending logon request message. | 2020-10-07 01:41:20.877
SC Data - All Services | Received logon response. | 2020-10-07 01:41:21.595
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:41:21.595
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:41:21.595
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:41:21.595
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:41:21.595
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:41:21.596
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:41:21.596
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:41:21.596
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:41:21.596
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:41:21.596
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:41:21.655
DTC Client socket (1) | Closed. | 2020-10-07 01:41:21.655
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:41:51.600
DTC Client socket (1) | Creating socket. | 2020-10-07 01:41:51.601
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:41:51.601
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:41:51.601
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:41:51.616
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:41:51.616
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:41:51.617
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:41:51.655
SC Data - All Services | Sending logon request message. | 2020-10-07 01:41:51.655
SC Data - All Services | Received logon response. | 2020-10-07 01:41:52.302
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:41:52.302
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:41:52.302
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:41:52.302
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:41:52.302
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:41:52.302
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:41:52.302
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:41:52.302
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:41:52.302
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:41:52.302
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:41:52.317
DTC Client socket (1) | Closed. | 2020-10-07 01:41:52.317
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:42:22.291
DTC Client socket (1) | Creating socket. | 2020-10-07 01:42:22.291
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:42:22.291
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:42:22.291
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:42:22.312
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:42:22.312
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:42:22.313
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:42:22.353
SC Data - All Services | Sending logon request message. | 2020-10-07 01:42:22.353
SC Data - All Services | Received logon response. | 2020-10-07 01:42:22.983
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:42:22.983
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:42:22.983
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:42:22.983
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:42:22.983
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:42:22.984
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:42:22.984
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:42:22.984
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:42:22.984
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:42:22.984
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:42:22.997
DTC Client socket (1) | Closed. | 2020-10-07 01:42:22.997
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1049 seconds. | 2020-10-07 01:42:25.913
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0448 seconds. | 2020-10-07 01:42:25.959
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:42:52.981
DTC Client socket (1) | Creating socket. | 2020-10-07 01:42:52.982
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:42:52.982
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:42:52.982
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:42:53.006
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:42:53.006
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:42:53.006
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:42:53.044
SC Data - All Services | Sending logon request message. | 2020-10-07 01:42:53.044
SC Data - All Services | Received logon response. | 2020-10-07 01:42:53.698
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:42:53.698
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:42:53.698
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:42:53.698
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:42:53.698
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:42:53.698
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:42:53.698
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:42:53.698
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:42:53.698
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:42:53.698
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:42:53.713
DTC Client socket (1) | Closed. | 2020-10-07 01:42:53.713
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:43:23.698
DTC Client socket (1) | Creating socket. | 2020-10-07 01:43:23.698
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:43:23.699
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:43:23.699
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:43:23.765
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:43:23.765
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:43:23.765
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:43:23.836
SC Data - All Services | Sending logon request message. | 2020-10-07 01:43:23.836
SC Data - All Services | Received logon response. | 2020-10-07 01:43:24.517
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:43:24.517
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:43:24.517
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:43:24.517
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:43:24.517
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:43:24.517
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:43:24.517
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:43:24.517
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:43:24.517
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:43:24.517
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:43:24.577
DTC Client socket (1) | Closed. | 2020-10-07 01:43:24.577
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:43:54.514
DTC Client socket (1) | Creating socket. | 2020-10-07 01:43:54.514
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:43:54.515
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:43:54.515
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:43:54.537
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:43:54.538
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:43:54.538
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:43:54.569
SC Data - All Services | Sending logon request message. | 2020-10-07 01:43:54.569
SC Data - All Services | Received logon response. | 2020-10-07 01:43:55.237
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:43:55.237
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:43:55.237
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:43:55.237
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:43:55.237
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:43:55.237
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:43:55.237
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:43:55.237
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:43:55.237
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:43:55.237
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:43:55.253
DTC Client socket (1) | Closed. | 2020-10-07 01:43:55.253
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:44:25.227
DTC Client socket (1) | Creating socket. | 2020-10-07 01:44:25.227
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:44:25.227
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:44:25.227
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:44:25.251
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:44:25.251
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:44:25.251
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:44:25.274
SC Data - All Services | Sending logon request message. | 2020-10-07 01:44:25.274
SC Data - All Services | Received logon response. | 2020-10-07 01:44:25.909
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:44:25.909
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:44:25.909
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:44:25.909
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:44:25.909
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:44:25.909
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:44:25.909
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:44:25.910
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:44:25.910
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:44:25.910
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:44:25.923
DTC Client socket (1) | Closed. | 2020-10-07 01:44:25.923
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:44:55.901
DTC Client socket (1) | Creating socket. | 2020-10-07 01:44:55.901
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:44:55.901
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:44:55.901
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:44:55.922
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:44:55.922
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:44:55.922
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:44:55.940
SC Data - All Services | Sending logon request message. | 2020-10-07 01:44:55.940
SC Data - All Services | Received logon response. | 2020-10-07 01:44:56.565
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:44:56.565
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:44:56.565
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:44:56.565
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:44:56.565
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:44:56.565
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:44:56.565
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:44:56.565
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:44:56.565
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:44:56.566
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:44:56.580
DTC Client socket (1) | Closed. | 2020-10-07 01:44:56.580
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:45:26.555
DTC Client socket (1) | Creating socket. | 2020-10-07 01:45:26.556
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:45:26.556
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:45:26.556
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:45:26.617
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:45:26.617
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:45:26.617
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:45:26.685
SC Data - All Services | Sending logon request message. | 2020-10-07 01:45:26.685
SC Data - All Services | Received logon response. | 2020-10-07 01:45:27.390
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:45:27.390
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:45:27.390
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:45:27.390
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:45:27.390
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:45:27.390
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:45:27.390
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:45:27.391
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:45:27.391
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:45:27.391
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:45:27.448
DTC Client socket (1) | Closed. | 2020-10-07 01:45:27.448
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:45:57.386
DTC Client socket (1) | Creating socket. | 2020-10-07 01:45:57.387
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:45:57.387
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:45:57.387
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:45:57.402
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:45:57.402
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:45:57.403
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:45:57.432
SC Data - All Services | Sending logon request message. | 2020-10-07 01:45:57.432
SC Data - All Services | Received logon response. | 2020-10-07 01:45:58.071
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:45:58.071
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:45:58.071
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:45:58.072
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:45:58.072
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:45:58.072
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:45:58.072
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:45:58.072
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:45:58.072
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:45:58.072
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:45:58.086
DTC Client socket (1) | Closed. | 2020-10-07 01:45:58.086
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:46:28.070
DTC Client socket (1) | Creating socket. | 2020-10-07 01:46:28.070
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:46:28.070
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:46:28.071
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:46:28.083
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:46:28.083
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:46:28.083
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:46:28.125
SC Data - All Services | Sending logon request message. | 2020-10-07 01:46:28.125
SC Data - All Services | Received logon response. | 2020-10-07 01:46:28.749
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:46:28.749
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:46:28.749
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:46:28.749
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:46:28.749
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:46:28.750
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:46:28.750
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:46:28.750
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:46:28.750
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:46:28.750
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:46:28.763
DTC Client socket (1) | Closed. | 2020-10-07 01:46:28.763
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:46:58.746
DTC Client socket (1) | Creating socket. | 2020-10-07 01:46:58.747
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:46:58.747
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:46:58.747
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:46:58.770
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:46:58.770
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:46:58.770
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:46:58.789
SC Data - All Services | Sending logon request message. | 2020-10-07 01:46:58.789
SC Data - All Services | Received logon response. | 2020-10-07 01:46:59.429
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:46:59.429
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:46:59.429
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:46:59.429
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:46:59.429
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:46:59.430
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:46:59.430
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:46:59.430
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:46:59.430
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:46:59.430
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:46:59.445
DTC Client socket (1) | Closed. | 2020-10-07 01:46:59.445
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:47:29.430
DTC Client socket (1) | Creating socket. | 2020-10-07 01:47:29.431
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:47:29.431
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:47:29.431
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:47:29.492
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:47:29.492
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:47:29.492
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:47:29.568
SC Data - All Services | Sending logon request message. | 2020-10-07 01:47:29.568
SC Data - All Services | Received logon response. | 2020-10-07 01:47:30.258
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:47:30.258
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:47:30.258
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:47:30.258
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:47:30.258
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:47:30.258
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:47:30.258
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:47:30.258
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:47:30.258
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:47:30.258
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:47:30.318
DTC Client socket (1) | Closed. | 2020-10-07 01:47:30.318
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:48:00.268
DTC Client socket (1) | Creating socket. | 2020-10-07 01:48:00.269
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:48:00.269
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:48:00.269
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:48:00.285
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:48:00.285
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:48:00.285
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:48:00.325
SC Data - All Services | Sending logon request message. | 2020-10-07 01:48:00.325
SC Data - All Services | Received logon response. | 2020-10-07 01:48:00.992
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:48:00.992
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:48:00.992
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:48:00.992
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:48:00.992
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:48:00.992
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:48:00.992
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:48:00.992
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:48:00.992
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:48:00.992
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:48:01.006
DTC Client socket (1) | Closed. | 2020-10-07 01:48:01.006
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:48:31.008
DTC Client socket (1) | Creating socket. | 2020-10-07 01:48:31.009
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:48:31.009
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:48:31.009
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:48:31.036
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:48:31.036
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:48:31.036
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:48:31.071
SC Data - All Services | Sending logon request message. | 2020-10-07 01:48:31.071
SC Data - All Services | Received logon response. | 2020-10-07 01:48:31.637
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:48:31.637
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:48:31.637
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:48:31.637
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:48:31.637
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:48:31.637
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:48:31.637
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:48:31.637
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:48:31.637
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:48:31.637
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:48:31.649
DTC Client socket (1) | Closed. | 2020-10-07 01:48:31.649
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:49:01.636
DTC Client socket (1) | Creating socket. | 2020-10-07 01:49:01.638
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:49:01.638
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:49:01.638
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:49:01.664
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:49:01.664
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:49:01.664
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:49:01.705
SC Data - All Services | Sending logon request message. | 2020-10-07 01:49:01.705
SC Data - All Services | Received logon response. | 2020-10-07 01:49:02.363
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:49:02.363
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:49:02.363
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:49:02.363
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:49:02.363
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:49:02.365
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:49:02.365
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:49:02.365
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:49:02.365
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:49:02.365
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:49:02.379
DTC Client socket (1) | Closed. | 2020-10-07 01:49:02.379
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:49:32.363
DTC Client socket (1) | Creating socket. | 2020-10-07 01:49:32.363
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:49:32.363
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:49:32.363
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:49:32.423
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:49:32.423
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:49:32.423
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:49:32.493
SC Data - All Services | Sending logon request message. | 2020-10-07 01:49:32.493
SC Data - All Services | Received logon response. | 2020-10-07 01:49:33.226
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:49:33.226
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:49:33.226
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:49:33.226
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:49:33.226
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:49:33.226
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:49:33.226
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:49:33.226
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:49:33.226
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:49:33.226
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:49:33.285
DTC Client socket (1) | Closed. | 2020-10-07 01:49:33.285
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:50:03.234
DTC Client socket (2) | Creating socket. | 2020-10-07 01:50:03.235
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 01:50:03.235
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:50:03.235
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:50:03.256
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:50:03.256
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:50:03.256
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:50:03.292
SC Data - All Services | Sending logon request message. | 2020-10-07 01:50:03.292
SC Data - All Services | Received logon response. | 2020-10-07 01:50:03.980
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:50:03.980
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:50:03.980
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:50:03.980
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:50:03.980
DTC Client socket (2) | CloseSocket call. | 2020-10-07 01:50:03.980
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:50:03.980
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:50:03.980
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:50:03.980
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:50:03.981
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 01:50:03.993
DTC Client socket (2) | Closed. | 2020-10-07 01:50:03.993
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:50:33.988
DTC Client socket (1) | Creating socket. | 2020-10-07 01:50:33.989
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:50:33.989
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:50:33.989
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:50:34.006
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:50:34.006
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:50:34.006
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:50:34.041
SC Data - All Services | Sending logon request message. | 2020-10-07 01:50:34.041
SC Data - All Services | Received logon response. | 2020-10-07 01:50:34.623
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:50:34.623
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:50:34.624
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:50:34.624
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:50:34.624
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:50:34.624
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:50:34.624
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:50:34.624
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:50:34.624
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:50:34.624
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:50:34.637
DTC Client socket (1) | Closed. | 2020-10-07 01:50:34.637
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:51:04.628
DTC Client socket (1) | Creating socket. | 2020-10-07 01:51:04.629
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:51:04.629
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:51:04.629
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:51:04.646
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:51:04.646
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:51:04.646
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:51:04.667
SC Data - All Services | Sending logon request message. | 2020-10-07 01:51:04.667
SC Data - All Services | Received logon response. | 2020-10-07 01:51:05.297
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:51:05.297
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:51:05.297
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:51:05.297
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:51:05.297
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:51:05.297
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:51:05.297
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:51:05.297
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:51:05.297
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:51:05.297
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:51:05.310
DTC Client socket (1) | Closed. | 2020-10-07 01:51:05.310
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:51:35.291
DTC Client socket (1) | Creating socket. | 2020-10-07 01:51:35.292
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:51:35.292
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:51:35.292
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:51:35.353
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:51:35.353
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:51:35.353
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:51:35.447
SC Data - All Services | Sending logon request message. | 2020-10-07 01:51:35.447
SC Data - All Services | Received logon response. | 2020-10-07 01:51:36.173
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:51:36.173
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:51:36.173
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:51:36.173
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:51:36.173
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:51:36.173
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:51:36.173
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:51:36.173
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:51:36.173
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:51:36.173
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:51:36.233
DTC Client socket (1) | Closed. | 2020-10-07 01:51:36.233
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:52:06.166
DTC Client socket (1) | Creating socket. | 2020-10-07 01:52:06.166
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:52:06.166
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:52:06.166
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:52:06.194
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:52:06.194
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:52:06.195
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:52:06.223
SC Data - All Services | Sending logon request message. | 2020-10-07 01:52:06.223
SC Data - All Services | Received logon response. | 2020-10-07 01:52:06.881
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:52:06.881
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:52:06.881
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:52:06.881
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:52:06.881
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:52:06.881
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:52:06.881
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:52:06.881
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:52:06.881
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:52:06.881
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:52:06.896
DTC Client socket (1) | Closed. | 2020-10-07 01:52:06.896
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:52:36.876
DTC Client socket (1) | Creating socket. | 2020-10-07 01:52:36.877
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:52:36.877
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:52:36.877
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:52:36.898
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:52:36.898
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:52:36.898
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:52:36.917
SC Data - All Services | Sending logon request message. | 2020-10-07 01:52:36.917
SC Data - All Services | Received logon response. | 2020-10-07 01:52:37.555
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:52:37.555
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:52:37.555
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:52:37.555
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:52:37.555
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:52:37.555
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:52:37.555
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:52:37.555
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:52:37.555
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:52:37.555
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:52:37.569
DTC Client socket (1) | Closed. | 2020-10-07 01:52:37.569
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:53:07.557
DTC Client socket (1) | Creating socket. | 2020-10-07 01:53:07.558
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:53:07.558
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:53:07.558
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:53:07.581
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:53:07.581
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:53:07.581
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:53:07.612
SC Data - All Services | Sending logon request message. | 2020-10-07 01:53:07.612
SC Data - All Services | Received logon response. | 2020-10-07 01:53:08.254
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:53:08.254
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:53:08.254
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:53:08.254
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:53:08.254
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:53:08.254
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:53:08.254
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:53:08.254
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:53:08.254
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:53:08.254
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:53:08.269
DTC Client socket (1) | Closed. | 2020-10-07 01:53:08.269
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:53:38.250
DTC Client socket (1) | Creating socket. | 2020-10-07 01:53:38.250
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:53:38.251
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:53:38.251
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:53:38.311
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:53:38.311
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:53:38.311
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:53:38.397
SC Data - All Services | Sending logon request message. | 2020-10-07 01:53:38.397
SC Data - All Services | Received logon response. | 2020-10-07 01:53:39.104
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:53:39.104
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:53:39.104
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:53:39.104
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:53:39.104
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:53:39.104
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:53:39.104
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:53:39.104
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:53:39.104
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:53:39.104
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:53:39.162
DTC Client socket (1) | Closed. | 2020-10-07 01:53:39.162
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:54:09.115
DTC Client socket (1) | Creating socket. | 2020-10-07 01:54:09.116
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:54:09.116
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:54:09.116
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:54:09.154
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:54:09.154
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:54:09.155
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:54:09.186
SC Data - All Services | Sending logon request message. | 2020-10-07 01:54:09.186
SC Data - All Services | Received logon response. | 2020-10-07 01:54:09.851
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:54:09.851
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:54:09.851
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:54:09.851
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:54:09.851
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:54:09.851
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:54:09.851
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:54:09.851
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:54:09.851
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:54:09.851
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:54:09.865
DTC Client socket (1) | Closed. | 2020-10-07 01:54:09.865
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:54:39.844
DTC Client socket (1) | Creating socket. | 2020-10-07 01:54:39.845
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:54:39.845
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:54:39.845
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:54:39.859
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:54:39.859
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:54:39.859
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:54:39.897
SC Data - All Services | Sending logon request message. | 2020-10-07 01:54:39.897
SC Data - All Services | Received logon response. | 2020-10-07 01:54:40.576
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:54:40.576
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:54:40.576
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:54:40.576
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:54:40.576
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:54:40.576
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:54:40.576
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:54:40.576
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:54:40.576
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:54:40.576
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:54:40.588
DTC Client socket (1) | Closed. | 2020-10-07 01:54:40.589
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:55:10.573
DTC Client socket (1) | Creating socket. | 2020-10-07 01:55:10.573
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:55:10.573
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:55:10.573
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:55:10.595
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:55:10.595
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:55:10.595
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:55:10.634
SC Data - All Services | Sending logon request message. | 2020-10-07 01:55:10.634
SC Data - All Services | Received logon response. | 2020-10-07 01:55:11.276
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:55:11.276
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:55:11.276
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:55:11.276
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:55:11.276
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:55:11.276
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:55:11.276
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:55:11.276
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:55:11.276
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:55:11.276
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:55:11.290
DTC Client socket (1) | Closed. | 2020-10-07 01:55:11.290
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:55:41.288
DTC Client socket (1) | Creating socket. | 2020-10-07 01:55:41.288
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:55:41.288
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:55:41.288
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:55:41.357
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:55:41.357
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:55:41.357
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:55:41.454
SC Data - All Services | Sending logon request message. | 2020-10-07 01:55:41.454
SC Data - All Services | Received logon response. | 2020-10-07 01:55:42.201
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:55:42.201
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:55:42.201
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:55:42.201
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:55:42.201
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:55:42.201
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:55:42.201
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:55:42.201
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:55:42.201
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:55:42.201
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:55:42.259
DTC Client socket (1) | Closed. | 2020-10-07 01:55:42.260
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:56:12.208
DTC Client socket (2) | Creating socket. | 2020-10-07 01:56:12.208
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 01:56:12.209
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:56:12.209
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:56:12.238
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:56:12.238
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:56:12.238
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:56:12.276
SC Data - All Services | Sending logon request message. | 2020-10-07 01:56:12.276
SC Data - All Services | Received logon response. | 2020-10-07 01:56:12.928
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:56:12.928
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:56:12.928
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:56:12.928
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:56:12.928
DTC Client socket (2) | CloseSocket call. | 2020-10-07 01:56:12.928
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:56:12.928
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:56:12.928
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:56:12.928
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:56:12.928
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 01:56:12.941
DTC Client socket (2) | Closed. | 2020-10-07 01:56:12.941
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:56:42.916
DTC Client socket (1) | Creating socket. | 2020-10-07 01:56:42.916
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:56:42.916
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:56:42.916
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:56:42.931
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:56:42.931
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:56:42.931
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:56:42.963
SC Data - All Services | Sending logon request message. | 2020-10-07 01:56:42.963
SC Data - All Services | Received logon response. | 2020-10-07 01:56:43.606
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:56:43.606
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:56:43.606
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:56:43.606
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:56:43.606
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:56:43.606
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:56:43.606
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:56:43.606
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:56:43.606
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:56:43.606
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:56:43.618
DTC Client socket (1) | Closed. | 2020-10-07 01:56:43.618
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:57:13.608
DTC Client socket (1) | Creating socket. | 2020-10-07 01:57:13.609
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:57:13.609
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:57:13.609
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:57:13.623
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:57:13.623
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:57:13.623
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:57:13.659
SC Data - All Services | Sending logon request message. | 2020-10-07 01:57:13.659
SC Data - All Services | Received logon response. | 2020-10-07 01:57:14.300
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:57:14.300
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:57:14.300
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:57:14.300
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:57:14.300
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:57:14.300
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:57:14.300
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:57:14.300
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:57:14.300
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:57:14.300
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:57:14.316
DTC Client socket (1) | Closed. | 2020-10-07 01:57:14.316
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1187 seconds. | 2020-10-07 01:57:26.075
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0435 seconds. | 2020-10-07 01:57:26.119
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:57:44.289
DTC Client socket (1) | Creating socket. | 2020-10-07 01:57:44.290
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:57:44.290
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:57:44.290
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:57:44.366
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:57:44.366
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:57:44.366
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:57:44.428
SC Data - All Services | Sending logon request message. | 2020-10-07 01:57:44.428
SC Data - All Services | Received logon response. | 2020-10-07 01:57:45.181
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:57:45.181
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:57:45.181
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:57:45.181
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:57:45.181
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:57:45.181
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:57:45.181
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:57:45.181
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:57:45.181
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:57:45.181
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:57:45.237
DTC Client socket (1) | Closed. | 2020-10-07 01:57:45.237
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 01:58:15.182
DTC Client socket (1) | Creating socket. | 2020-10-07 01:58:15.182
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:58:15.182
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 01:58:15.182
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:58:15.210
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:58:15.210
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:58:15.210
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:58:15.228
SC Data - All Services | Sending logon request message. | 2020-10-07 01:58:15.228
SC Data - All Services | Received logon response. | 2020-10-07 01:58:15.901
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:58:15.901
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:58:15.901
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:58:15.901
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:58:15.901
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:58:15.901
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:58:15.901
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:58:15.901
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:58:15.901
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:58:15.901
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:58:15.914
DTC Client socket (1) | Closed. | 2020-10-07 01:58:15.914
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 01:58:45.901
DTC Client socket (1) | Creating socket. | 2020-10-07 01:58:45.902
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:58:45.902
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 01:58:45.902
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:58:45.917
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:58:45.917
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:58:45.918
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:58:45.937
SC Data - All Services | Sending logon request message. | 2020-10-07 01:58:45.937
SC Data - All Services | Received logon response. | 2020-10-07 01:58:46.595
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:58:46.595
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:58:46.595
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:58:46.595
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:58:46.595
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:58:46.595
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:58:46.595
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:58:46.595
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:58:46.595
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:58:46.595
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:58:46.608
DTC Client socket (1) | Closed. | 2020-10-07 01:58:46.608
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 01:59:16.596
DTC Client socket (1) | Creating socket. | 2020-10-07 01:59:16.597
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:59:16.597
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 01:59:16.597
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:59:16.622
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:59:16.622
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:59:16.622
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:59:16.674
SC Data - All Services | Sending logon request message. | 2020-10-07 01:59:16.674
SC Data - All Services | Received logon response. | 2020-10-07 01:59:17.322
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:59:17.322
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:59:17.322
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:59:17.322
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:59:17.322
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:59:17.323
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:59:17.323
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:59:17.323
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:59:17.323
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:59:17.323
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:59:17.339
DTC Client socket (1) | Closed. | 2020-10-07 01:59:17.339
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 01:59:47.324
DTC Client socket (1) | Creating socket. | 2020-10-07 01:59:47.325
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 01:59:47.325
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 01:59:47.325
SC Data - All Services | Network connection to server complete. | 2020-10-07 01:59:47.385
SC Data - All Services | Starting socket receive thread. | 2020-10-07 01:59:47.385
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 01:59:47.385
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 01:59:47.456
SC Data - All Services | Sending logon request message. | 2020-10-07 01:59:47.456
SC Data - All Services | Received logon response. | 2020-10-07 01:59:48.177
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 01:59:48.177
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 01:59:48.177
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 01:59:48.177
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 01:59:48.177
DTC Client socket (1) | CloseSocket call. | 2020-10-07 01:59:48.177
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 01:59:48.177
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 01:59:48.177
SC Data - All Services | Disconnected from the server. | 2020-10-07 01:59:48.177
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 01:59:48.177
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 01:59:48.236
DTC Client socket (1) | Closed. | 2020-10-07 01:59:48.236
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:00:18.167
DTC Client socket (1) | Creating socket. | 2020-10-07 02:00:18.167
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:00:18.167
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:00:18.168
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:00:18.189
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:00:18.189
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:00:18.189
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:00:18.236
SC Data - All Services | Sending logon request message. | 2020-10-07 02:00:18.236
SC Data - All Services | Received logon response. | 2020-10-07 02:00:18.872
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:00:18.872
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:00:18.872
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:00:18.872
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:00:18.872
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:00:18.872
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:00:18.872
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:00:18.872
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:00:18.872
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:00:18.872
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:00:18.885
DTC Client socket (1) | Closed. | 2020-10-07 02:00:18.885
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:00:48.880
DTC Client socket (1) | Creating socket. | 2020-10-07 02:00:48.880
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:00:48.880
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:00:48.880
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:00:48.906
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:00:48.906
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:00:48.906
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:00:48.952
SC Data - All Services | Sending logon request message. | 2020-10-07 02:00:48.952
SC Data - All Services | Received logon response. | 2020-10-07 02:00:49.599
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:00:49.599
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:00:49.599
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:00:49.599
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:00:49.599
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:00:49.599
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:00:49.599
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:00:49.599
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:00:49.599
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:00:49.599
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:00:49.612
DTC Client socket (1) | Closed. | 2020-10-07 02:00:49.612
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:01:19.596
DTC Client socket (1) | Creating socket. | 2020-10-07 02:01:19.596
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:01:19.596
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:01:19.596
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:01:19.613
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:01:19.613
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:01:19.613
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:01:19.657
SC Data - All Services | Sending logon request message. | 2020-10-07 02:01:19.657
SC Data - All Services | Received logon response. | 2020-10-07 02:01:20.281
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:01:20.281
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:01:20.281
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:01:20.281
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:01:20.281
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:01:20.281
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:01:20.281
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:01:20.281
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:01:20.281
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:01:20.282
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:01:20.296
DTC Client socket (1) | Closed. | 2020-10-07 02:01:20.296
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:01:50.282
DTC Client socket (1) | Creating socket. | 2020-10-07 02:01:50.282
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:01:50.282
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:01:50.282
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:01:50.344
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:01:50.344
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:01:50.344
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:01:50.416
SC Data - All Services | Sending logon request message. | 2020-10-07 02:01:50.416
SC Data - All Services | Received logon response. | 2020-10-07 02:01:51.147
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:01:51.147
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:01:51.147
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:01:51.147
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:01:51.147
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:01:51.148
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:01:51.148
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:01:51.148
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:01:51.148
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:01:51.148
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:01:51.205
DTC Client socket (1) | Closed. | 2020-10-07 02:01:51.205
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:02:21.145
DTC Client socket (1) | Creating socket. | 2020-10-07 02:02:21.145
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:02:21.145
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:02:21.145
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:02:21.176
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:02:21.176
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:02:21.176
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:02:21.191
SC Data - All Services | Sending logon request message. | 2020-10-07 02:02:21.191
SC Data - All Services | Received logon response. | 2020-10-07 02:02:21.848
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:02:21.848
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:02:21.848
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:02:21.848
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:02:21.848
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:02:21.848
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:02:21.848
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:02:21.848
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:02:21.848
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:02:21.848
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:02:21.862
DTC Client socket (1) | Closed. | 2020-10-07 02:02:21.862
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:02:51.843
DTC Client socket (1) | Creating socket. | 2020-10-07 02:02:51.844
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:02:51.844
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:02:51.844
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:02:51.859
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:02:51.859
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:02:51.859
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:02:51.876
SC Data - All Services | Sending logon request message. | 2020-10-07 02:02:51.876
SC Data - All Services | Received logon response. | 2020-10-07 02:02:52.551
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:02:52.551
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:02:52.551
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:02:52.551
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:02:52.551
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:02:52.551
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:02:52.551
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:02:52.551
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:02:52.551
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:02:52.551
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:02:52.564
DTC Client socket (1) | Closed. | 2020-10-07 02:02:52.564
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:03:22.541
DTC Client socket (1) | Creating socket. | 2020-10-07 02:03:22.542
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:03:22.542
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:03:22.542
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:03:22.571
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:03:22.571
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:03:22.571
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:03:22.602
SC Data - All Services | Sending logon request message. | 2020-10-07 02:03:22.603
SC Data - All Services | Received logon response. | 2020-10-07 02:03:23.264
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:03:23.264
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:03:23.264
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:03:23.264
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:03:23.264
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:03:23.265
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:03:23.265
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:03:23.265
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:03:23.265
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:03:23.265
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:03:23.278
DTC Client socket (1) | Closed. | 2020-10-07 02:03:23.278
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:03:53.269
DTC Client socket (1) | Creating socket. | 2020-10-07 02:03:53.270
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:03:53.270
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:03:53.270
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:03:53.330
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:03:53.330
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:03:53.330
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:03:53.406
SC Data - All Services | Sending logon request message. | 2020-10-07 02:03:53.406
SC Data - All Services | Received logon response. | 2020-10-07 02:03:54.146
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:03:54.146
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:03:54.146
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:03:54.146
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:03:54.146
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:03:54.146
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:03:54.146
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:03:54.146
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:03:54.146
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:03:54.147
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:03:54.204
DTC Client socket (1) | Closed. | 2020-10-07 02:03:54.204
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:04:24.140
DTC Client socket (1) | Creating socket. | 2020-10-07 02:04:24.140
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:04:24.140
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:04:24.141
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:04:24.169
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:04:24.169
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:04:24.169
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:04:24.203
SC Data - All Services | Sending logon request message. | 2020-10-07 02:04:24.203
SC Data - All Services | Received logon response. | 2020-10-07 02:04:24.846
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:04:24.846
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:04:24.846
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:04:24.846
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:04:24.846
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:04:24.846
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:04:24.846
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:04:24.846
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:04:24.846
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:04:24.846
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:04:24.856
DTC Client socket (1) | Closed. | 2020-10-07 02:04:24.856
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:04:54.844
DTC Client socket (1) | Creating socket. | 2020-10-07 02:04:54.844
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:04:54.844
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:04:54.844
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:04:54.860
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:04:54.860
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:04:54.860
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:04:54.907
SC Data - All Services | Sending logon request message. | 2020-10-07 02:04:54.907
SC Data - All Services | Received logon response. | 2020-10-07 02:04:55.593
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:04:55.593
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:04:55.593
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:04:55.593
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:04:55.593
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:04:55.594
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:04:55.594
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:04:55.594
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:04:55.594
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:04:55.594
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:04:55.608
DTC Client socket (1) | Closed. | 2020-10-07 02:04:55.609
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:05:25.587
DTC Client socket (1) | Creating socket. | 2020-10-07 02:05:25.587
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:05:25.587
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:05:25.587
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:05:25.619
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:05:25.619
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:05:25.620
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:05:25.649
SC Data - All Services | Sending logon request message. | 2020-10-07 02:05:25.649
SC Data - All Services | Received logon response. | 2020-10-07 02:05:26.307
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:05:26.307
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:05:26.307
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:05:26.307
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:05:26.307
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:05:26.307
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:05:26.307
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:05:26.307
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:05:26.307
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:05:26.309
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:05:26.321
DTC Client socket (1) | Closed. | 2020-10-07 02:05:26.321
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:05:56.304
DTC Client socket (1) | Creating socket. | 2020-10-07 02:05:56.305
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:05:56.305
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:05:56.305
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:05:56.366
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:05:56.366
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:05:56.366
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:05:56.427
SC Data - All Services | Sending logon request message. | 2020-10-07 02:05:56.427
SC Data - All Services | Received logon response. | 2020-10-07 02:05:57.179
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:05:57.179
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:05:57.179
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:05:57.179
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:05:57.180
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:05:57.180
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:05:57.180
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:05:57.180
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:05:57.180
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:05:57.180
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:05:57.238
DTC Client socket (1) | Closed. | 2020-10-07 02:05:57.238
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:06:27.180
DTC Client socket (1) | Creating socket. | 2020-10-07 02:06:27.180
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:06:27.180
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:06:27.180
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:06:27.202
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:06:27.202
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:06:27.202
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:06:27.234
SC Data - All Services | Sending logon request message. | 2020-10-07 02:06:27.234
SC Data - All Services | Received logon response. | 2020-10-07 02:06:27.889
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:06:27.889
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:06:27.889
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:06:27.889
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:06:27.889
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:06:27.889
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:06:27.889
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:06:27.889
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:06:27.889
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:06:27.889
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:06:27.901
DTC Client socket (1) | Closed. | 2020-10-07 02:06:27.901
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:06:57.895
DTC Client socket (1) | Creating socket. | 2020-10-07 02:06:57.895
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:06:57.895
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:06:57.895
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:06:57.917
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:06:57.917
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:06:57.917
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:06:57.955
SC Data - All Services | Sending logon request message. | 2020-10-07 02:06:57.955
SC Data - All Services | Received logon response. | 2020-10-07 02:06:58.630
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:06:58.630
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:06:58.630
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:06:58.630
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:06:58.630
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:06:58.630
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:06:58.630
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:06:58.630
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:06:58.630
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:06:58.630
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:06:58.644
DTC Client socket (1) | Closed. | 2020-10-07 02:06:58.644
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:07:28.632
DTC Client socket (1) | Creating socket. | 2020-10-07 02:07:28.633
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:07:28.633
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:07:28.633
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:07:28.657
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:07:28.657
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:07:28.657
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:07:28.692
SC Data - All Services | Sending logon request message. | 2020-10-07 02:07:28.692
SC Data - All Services | Received logon response. | 2020-10-07 02:07:29.322
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:07:29.322
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:07:29.322
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:07:29.322
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:07:29.322
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:07:29.323
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:07:29.323
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:07:29.323
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:07:29.323
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:07:29.323
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:07:29.336
DTC Client socket (1) | Closed. | 2020-10-07 02:07:29.336
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:07:59.330
DTC Client socket (1) | Creating socket. | 2020-10-07 02:07:59.331
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:07:59.331
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:07:59.331
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:07:59.390
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:07:59.390
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:07:59.391
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:07:59.475
SC Data - All Services | Sending logon request message. | 2020-10-07 02:07:59.475
SC Data - All Services | Received logon response. | 2020-10-07 02:08:00.211
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:08:00.212
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:08:00.212
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:08:00.212
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:08:00.212
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:08:00.212
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:08:00.212
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:08:00.212
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:08:00.212
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:08:00.212
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:08:00.269
DTC Client socket (1) | Closed. | 2020-10-07 02:08:00.269
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:08:30.216
DTC Client socket (1) | Creating socket. | 2020-10-07 02:08:30.216
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:08:30.216
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:08:30.216
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:08:30.238
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:08:30.238
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:08:30.238
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:08:30.270
SC Data - All Services | Sending logon request message. | 2020-10-07 02:08:30.270
SC Data - All Services | Received logon response. | 2020-10-07 02:08:30.958
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:08:30.958
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:08:30.958
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:08:30.958
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:08:30.958
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:08:30.958
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:08:30.958
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:08:30.958
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:08:30.958
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:08:30.958
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:08:30.971
DTC Client socket (1) | Closed. | 2020-10-07 02:08:30.971
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:09:00.954
DTC Client socket (1) | Creating socket. | 2020-10-07 02:09:00.955
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:09:00.955
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:09:00.955
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:09:00.980
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:09:00.980
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:09:00.980
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:09:01.032
SC Data - All Services | Sending logon request message. | 2020-10-07 02:09:01.032
SC Data - All Services | Received logon response. | 2020-10-07 02:09:01.267
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:09:01.267
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:09:01.267
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:09:01.267
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:09:01.267
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:09:01.267
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:09:01.267
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:09:01.267
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:09:01.267
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:09:01.267
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:09:01.279
DTC Client socket (1) | Closed. | 2020-10-07 02:09:01.279
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:09:31.259
DTC Client socket (1) | Creating socket. | 2020-10-07 02:09:31.260
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:09:31.260
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:09:31.260
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:09:31.282
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:09:31.282
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:09:31.282
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:09:31.331
SC Data - All Services | Sending logon request message. | 2020-10-07 02:09:31.331
SC Data - All Services | Received logon response. | 2020-10-07 02:09:31.954
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:09:31.954
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:09:31.954
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:09:31.954
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:09:31.954
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:09:31.954
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:09:31.954
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:09:31.954
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:09:31.954
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:09:31.954
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:09:31.968
DTC Client socket (1) | Closed. | 2020-10-07 02:09:31.968
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:10:01.947
DTC Client socket (1) | Creating socket. | 2020-10-07 02:10:01.947
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:10:01.948
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:10:01.948
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:10:02.008
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:10:02.008
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:10:02.008
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:10:02.068
SC Data - All Services | Sending logon request message. | 2020-10-07 02:10:02.068
SC Data - All Services | Received logon response. | 2020-10-07 02:10:02.758
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:10:02.758
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:10:02.758
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:10:02.758
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:10:02.758
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:10:02.759
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:10:02.759
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:10:02.759
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:10:02.759
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:10:02.759
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:10:02.817
DTC Client socket (1) | Closed. | 2020-10-07 02:10:02.817
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:10:32.764
DTC Client socket (1) | Creating socket. | 2020-10-07 02:10:32.764
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:10:32.764
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:10:32.764
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:10:32.792
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:10:32.792
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:10:32.792
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:10:32.827
SC Data - All Services | Sending logon request message. | 2020-10-07 02:10:32.827
SC Data - All Services | Received logon response. | 2020-10-07 02:10:33.484
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:10:33.484
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:10:33.484
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:10:33.484
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:10:33.484
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:10:33.484
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:10:33.484
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:10:33.484
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:10:33.484
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:10:33.484
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:10:33.498
DTC Client socket (1) | Closed. | 2020-10-07 02:10:33.498
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:11:03.489
DTC Client socket (1) | Creating socket. | 2020-10-07 02:11:03.490
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:11:03.490
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:11:03.490
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:11:03.510
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:11:03.510
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:11:03.510
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:11:03.562
SC Data - All Services | Sending logon request message. | 2020-10-07 02:11:03.562
SC Data - All Services | Received logon response. | 2020-10-07 02:11:04.228
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:11:04.228
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:11:04.228
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:11:04.228
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:11:04.228
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:11:04.228
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:11:04.228
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:11:04.228
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:11:04.228
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:11:04.229
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:11:04.242
DTC Client socket (1) | Closed. | 2020-10-07 02:11:04.242
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:11:34.235
DTC Client socket (1) | Creating socket. | 2020-10-07 02:11:34.235
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:11:34.235
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:11:34.236
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:11:34.258
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:11:34.258
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:11:34.258
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:11:34.294
SC Data - All Services | Sending logon request message. | 2020-10-07 02:11:34.294
SC Data - All Services | Received logon response. | 2020-10-07 02:11:34.917
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:11:34.917
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:11:34.917
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:11:34.917
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:11:34.917
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:11:34.917
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:11:34.917
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:11:34.918
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:11:34.918
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:11:34.918
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:11:34.931
DTC Client socket (1) | Closed. | 2020-10-07 02:11:34.931
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:12:04.923
DTC Client socket (1) | Creating socket. | 2020-10-07 02:12:04.924
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:12:04.924
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:12:04.924
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:12:04.985
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:12:04.985
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:12:04.985
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:12:05.056
SC Data - All Services | Sending logon request message. | 2020-10-07 02:12:05.056
SC Data - All Services | Received logon response. | 2020-10-07 02:12:05.781
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:12:05.781
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:12:05.781
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:12:05.781
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:12:05.781
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:12:05.781
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:12:05.781
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:12:05.781
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:12:05.781
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:12:05.782
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:12:05.843
DTC Client socket (1) | Closed. | 2020-10-07 02:12:05.843
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1239 seconds. | 2020-10-07 02:12:26.254
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0345 seconds. | 2020-10-07 02:12:26.289
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:12:35.774
DTC Client socket (1) | Creating socket. | 2020-10-07 02:12:35.774
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:12:35.774
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:12:35.774
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:12:35.788
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:12:35.788
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:12:35.788
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:12:35.813
SC Data - All Services | Sending logon request message. | 2020-10-07 02:12:35.813
SC Data - All Services | Received logon response. | 2020-10-07 02:12:36.450
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:12:36.450
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:12:36.450
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:12:36.450
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:12:36.450
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:12:36.450
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:12:36.450
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:12:36.450
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:12:36.450
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:12:36.450
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:12:36.466
DTC Client socket (1) | Closed. | 2020-10-07 02:12:36.466
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:13:06.448
DTC Client socket (1) | Creating socket. | 2020-10-07 02:13:06.449
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:13:06.449
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:13:06.449
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:13:06.463
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:13:06.463
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:13:06.464
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:13:06.511
SC Data - All Services | Sending logon request message. | 2020-10-07 02:13:06.511
SC Data - All Services | Received logon response. | 2020-10-07 02:13:07.117
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:13:07.117
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:13:07.117
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:13:07.117
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:13:07.117
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:13:07.117
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:13:07.117
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:13:07.117
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:13:07.117
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:13:07.117
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:13:07.131
DTC Client socket (1) | Closed. | 2020-10-07 02:13:07.131
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:13:37.131
DTC Client socket (1) | Creating socket. | 2020-10-07 02:13:37.132
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:13:37.132
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:13:37.132
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:13:37.156
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:13:37.156
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:13:37.156
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:13:37.173
SC Data - All Services | Sending logon request message. | 2020-10-07 02:13:37.173
SC Data - All Services | Received logon response. | 2020-10-07 02:13:37.802
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:13:37.802
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:13:37.802
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:13:37.802
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:13:37.802
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:13:37.802
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:13:37.802
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:13:37.802
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:13:37.802
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:13:37.802
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:13:37.817
DTC Client socket (1) | Closed. | 2020-10-07 02:13:37.817
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:14:07.791
DTC Client socket (1) | Creating socket. | 2020-10-07 02:14:07.792
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:14:07.792
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:14:07.792
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:14:07.852
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:14:07.852
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:14:07.852
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:14:07.925
SC Data - All Services | Sending logon request message. | 2020-10-07 02:14:07.925
SC Data - All Services | Received logon response. | 2020-10-07 02:14:08.663
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:14:08.663
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:14:08.663
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:14:08.663
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:14:08.664
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:14:08.664
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:14:08.664
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:14:08.664
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:14:08.664
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:14:08.664
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:14:08.722
DTC Client socket (1) | Closed. | 2020-10-07 02:14:08.722
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:14:38.666
DTC Client socket (1) | Creating socket. | 2020-10-07 02:14:38.666
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:14:38.666
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:14:38.666
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:14:38.680
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:14:38.680
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:14:38.680
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:14:38.702
SC Data - All Services | Sending logon request message. | 2020-10-07 02:14:38.702
SC Data - All Services | Received logon response. | 2020-10-07 02:14:39.374
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:14:39.374
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:14:39.374
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:14:39.374
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:14:39.374
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:14:39.374
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:14:39.374
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:14:39.374
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:14:39.374
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:14:39.374
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:14:39.388
DTC Client socket (1) | Closed. | 2020-10-07 02:14:39.389
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:15:09.369
DTC Client socket (1) | Creating socket. | 2020-10-07 02:15:09.370
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:15:09.370
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:15:09.370
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:15:09.399
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:15:09.400
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:15:09.400
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:15:09.430
SC Data - All Services | Sending logon request message. | 2020-10-07 02:15:09.431
SC Data - All Services | Received logon response. | 2020-10-07 02:15:10.100
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:15:10.100
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:15:10.100
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:15:10.100
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:15:10.100
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:15:10.100
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:15:10.100
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:15:10.100
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:15:10.100
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:15:10.100
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:15:10.113
DTC Client socket (1) | Closed. | 2020-10-07 02:15:10.113
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:15:40.094
DTC Client socket (1) | Creating socket. | 2020-10-07 02:15:40.094
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:15:40.094
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:15:40.094
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:15:40.126
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:15:40.126
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:15:40.126
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:15:40.164
SC Data - All Services | Sending logon request message. | 2020-10-07 02:15:40.164
SC Data - All Services | Received logon response. | 2020-10-07 02:15:40.792
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:15:40.792
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:15:40.792
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:15:40.792
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:15:40.792
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:15:40.792
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:15:40.792
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:15:40.792
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:15:40.792
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:15:40.792
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:15:40.807
DTC Client socket (1) | Closed. | 2020-10-07 02:15:40.807
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:16:10.803
DTC Client socket (2) | Creating socket. | 2020-10-07 02:16:10.803
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 02:16:10.803
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:16:10.803
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:16:10.862
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:16:10.862
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:16:10.863
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:16:10.934
SC Data - All Services | Sending logon request message. | 2020-10-07 02:16:10.934
SC Data - All Services | Received logon response. | 2020-10-07 02:16:11.620
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:16:11.620
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:16:11.620
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:16:11.620
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:16:11.620
DTC Client socket (2) | CloseSocket call. | 2020-10-07 02:16:11.620
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:16:11.620
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:16:11.620
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:16:11.620
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:16:11.620
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 02:16:11.680
DTC Client socket (2) | Closed. | 2020-10-07 02:16:11.680
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:16:41.628
DTC Client socket (1) | Creating socket. | 2020-10-07 02:16:41.629
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:16:41.629
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:16:41.629
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:16:41.650
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:16:41.650
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:16:41.651
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:16:41.704
SC Data - All Services | Sending logon request message. | 2020-10-07 02:16:41.704
SC Data - All Services | Received logon response. | 2020-10-07 02:16:42.412
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:16:42.412
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:16:42.412
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:16:42.412
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:16:42.412
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:16:42.413
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:16:42.413
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:16:42.413
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:16:42.413
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:16:42.413
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:16:42.425
DTC Client socket (1) | Closed. | 2020-10-07 02:16:42.426
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:17:12.398
DTC Client socket (1) | Creating socket. | 2020-10-07 02:17:12.399
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:17:12.399
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:17:12.399
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:17:12.411
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:17:12.411
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:17:12.411
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:17:12.452
SC Data - All Services | Sending logon request message. | 2020-10-07 02:17:12.452
SC Data - All Services | Received logon response. | 2020-10-07 02:17:13.119
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:17:13.119
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:17:13.119
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:17:13.119
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:17:13.119
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:17:13.120
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:17:13.120
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:17:13.120
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:17:13.120
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:17:13.120
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:17:13.134
DTC Client socket (1) | Closed. | 2020-10-07 02:17:13.134
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:17:43.128
DTC Client socket (1) | Creating socket. | 2020-10-07 02:17:43.128
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:17:43.128
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:17:43.128
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:17:43.152
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:17:43.152
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:17:43.152
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:17:43.183
SC Data - All Services | Sending logon request message. | 2020-10-07 02:17:43.183
SC Data - All Services | Received logon response. | 2020-10-07 02:17:43.820
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:17:43.820
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:17:43.820
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:17:43.820
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:17:43.820
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:17:43.821
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:17:43.821
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:17:43.822
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:17:43.822
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:17:43.822
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:17:43.836
DTC Client socket (1) | Closed. | 2020-10-07 02:17:43.836
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:18:13.831
DTC Client socket (1) | Creating socket. | 2020-10-07 02:18:13.831
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:18:13.832
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:18:13.832
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:18:13.899
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:18:13.899
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:18:13.899
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:18:13.981
SC Data - All Services | Sending logon request message. | 2020-10-07 02:18:13.981
SC Data - All Services | Received logon response. | 2020-10-07 02:18:14.703
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:18:14.703
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:18:14.703
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:18:14.703
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:18:14.703
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:18:14.703
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:18:14.703
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:18:14.703
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:18:14.703
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:18:14.704
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:18:14.762
DTC Client socket (1) | Closed. | 2020-10-07 02:18:14.762
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:18:44.696
DTC Client socket (1) | Creating socket. | 2020-10-07 02:18:44.697
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:18:44.697
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:18:44.697
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:18:44.718
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:18:44.718
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:18:44.718
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:18:44.758
SC Data - All Services | Sending logon request message. | 2020-10-07 02:18:44.758
SC Data - All Services | Received logon response. | 2020-10-07 02:18:45.447
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:18:45.447
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:18:45.447
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:18:45.447
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:18:45.447
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:18:45.447
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:18:45.447
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:18:45.447
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:18:45.448
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:18:45.448
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:18:45.466
DTC Client socket (1) | Closed. | 2020-10-07 02:18:45.466
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:19:15.445
DTC Client socket (1) | Creating socket. | 2020-10-07 02:19:15.445
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:19:15.445
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:19:15.445
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:19:15.477
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:19:15.477
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:19:15.477
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:19:15.518
SC Data - All Services | Sending logon request message. | 2020-10-07 02:19:15.518
SC Data - All Services | Received logon response. | 2020-10-07 02:19:16.164
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:19:16.164
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:19:16.164
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:19:16.164
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:19:16.164
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:19:16.165
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:19:16.165
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:19:16.165
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:19:16.165
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:19:16.165
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:19:16.178
DTC Client socket (1) | Closed. | 2020-10-07 02:19:16.178
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:19:46.174
DTC Client socket (1) | Creating socket. | 2020-10-07 02:19:46.174
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:19:46.174
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:19:46.174
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:19:46.204
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:19:46.204
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:19:46.204
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:19:46.252
SC Data - All Services | Sending logon request message. | 2020-10-07 02:19:46.252
SC Data - All Services | Received logon response. | 2020-10-07 02:19:46.889
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:19:46.889
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:19:46.889
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:19:46.889
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:19:46.890
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:19:46.890
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:19:46.890
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:19:46.890
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:19:46.890
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:19:46.890
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:19:46.904
DTC Client socket (1) | Closed. | 2020-10-07 02:19:46.904
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:20:16.894
DTC Client socket (1) | Creating socket. | 2020-10-07 02:20:16.895
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:20:16.895
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:20:16.895
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:20:16.923
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:20:16.923
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:20:16.923
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:20:16.966
SC Data - All Services | Sending logon request message. | 2020-10-07 02:20:16.966
SC Data - All Services | Received logon response. | 2020-10-07 02:20:17.654
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:20:17.654
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:20:17.654
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:20:17.654
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:20:17.654
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:20:17.654
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:20:17.654
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:20:17.654
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:20:17.654
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:20:17.654
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:20:17.681
DTC Client socket (1) | Closed. | 2020-10-07 02:20:17.681
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:20:47.655
DTC Client socket (1) | Creating socket. | 2020-10-07 02:20:47.655
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:20:47.655
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:20:47.655
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:20:47.669
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:20:47.669
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:20:47.669
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:20:47.693
SC Data - All Services | Sending logon request message. | 2020-10-07 02:20:47.693
SC Data - All Services | Received logon response. | 2020-10-07 02:20:48.351
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:20:48.351
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:20:48.351
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:20:48.351
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:20:48.351
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:20:48.351
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:20:48.351
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:20:48.351
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:20:48.351
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:20:48.351
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:20:48.365
DTC Client socket (1) | Closed. | 2020-10-07 02:20:48.365
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:21:18.366
DTC Client socket (1) | Creating socket. | 2020-10-07 02:21:18.366
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:21:18.367
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:21:18.367
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:21:18.388
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:21:18.388
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:21:18.388
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:21:18.425
SC Data - All Services | Sending logon request message. | 2020-10-07 02:21:18.425
SC Data - All Services | Received logon response. | 2020-10-07 02:21:19.101
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:21:19.101
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:21:19.101
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:21:19.101
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:21:19.101
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:21:19.101
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:21:19.101
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:21:19.101
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:21:19.101
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:21:19.101
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:21:19.116
DTC Client socket (1) | Closed. | 2020-10-07 02:21:19.116
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:21:49.112
DTC Client socket (1) | Creating socket. | 2020-10-07 02:21:49.113
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:21:49.113
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:21:49.113
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:21:49.134
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:21:49.134
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:21:49.134
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:21:49.191
SC Data - All Services | Sending logon request message. | 2020-10-07 02:21:49.191
SC Data - All Services | Received logon response. | 2020-10-07 02:21:49.834
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:21:49.834
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:21:49.834
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:21:49.834
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:21:49.834
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:21:49.834
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:21:49.834
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:21:49.834
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:21:49.834
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:21:49.834
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:21:49.850
DTC Client socket (1) | Closed. | 2020-10-07 02:21:49.851
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:22:19.832
DTC Client socket (1) | Creating socket. | 2020-10-07 02:22:19.832
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:22:19.833
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:22:19.833
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:22:19.860
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:22:19.860
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:22:19.860
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:22:19.909
SC Data - All Services | Sending logon request message. | 2020-10-07 02:22:19.909
SC Data - All Services | Received logon response. | 2020-10-07 02:22:20.604
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:22:20.604
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:22:20.604
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:22:20.604
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:22:20.604
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:22:20.604
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:22:20.604
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:22:20.604
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:22:20.604
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:22:20.604
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:22:20.628
DTC Client socket (1) | Closed. | 2020-10-07 02:22:20.628
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:22:50.613
DTC Client socket (1) | Creating socket. | 2020-10-07 02:22:50.614
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:22:50.614
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:22:50.614
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:22:50.641
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:22:50.641
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:22:50.641
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:22:50.691
SC Data - All Services | Sending logon request message. | 2020-10-07 02:22:50.691
SC Data - All Services | Received logon response. | 2020-10-07 02:22:51.353
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:22:51.353
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:22:51.353
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:22:51.353
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:22:51.353
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:22:51.353
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:22:51.353
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:22:51.353
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:22:51.353
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:22:51.353
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:22:51.367
DTC Client socket (1) | Closed. | 2020-10-07 02:22:51.367
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:23:21.356
DTC Client socket (1) | Creating socket. | 2020-10-07 02:23:21.357
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:23:21.357
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:23:21.357
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:23:21.385
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:23:21.385
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:23:21.386
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:23:21.420
SC Data - All Services | Sending logon request message. | 2020-10-07 02:23:21.420
SC Data - All Services | Received logon response. | 2020-10-07 02:23:22.046
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:23:22.046
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:23:22.046
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:23:22.046
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:23:22.046
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:23:22.046
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:23:22.046
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:23:22.046
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:23:22.046
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:23:22.046
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:23:22.058
DTC Client socket (1) | Closed. | 2020-10-07 02:23:22.058
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:23:52.042
DTC Client socket (1) | Creating socket. | 2020-10-07 02:23:52.042
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:23:52.042
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:23:52.042
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:23:52.057
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:23:52.057
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:23:52.057
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:23:52.105
SC Data - All Services | Sending logon request message. | 2020-10-07 02:23:52.105
SC Data - All Services | Received logon response. | 2020-10-07 02:23:52.737
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:23:52.737
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:23:52.737
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:23:52.737
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:23:52.737
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:23:52.737
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:23:52.737
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:23:52.737
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:23:52.737
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:23:52.737
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:23:52.752
DTC Client socket (1) | Closed. | 2020-10-07 02:23:52.752
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:24:22.727
DTC Client socket (1) | Creating socket. | 2020-10-07 02:24:22.727
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:24:22.727
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:24:22.727
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:24:22.753
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:24:22.753
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:24:22.753
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:24:22.821
SC Data - All Services | Sending logon request message. | 2020-10-07 02:24:22.821
SC Data - All Services | Received logon response. | 2020-10-07 02:24:23.549
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:24:23.549
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:24:23.549
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:24:23.549
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:24:23.549
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:24:23.549
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:24:23.549
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:24:23.549
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:24:23.549
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:24:23.549
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:24:23.574
DTC Client socket (1) | Closed. | 2020-10-07 02:24:23.574
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:24:53.548
DTC Client socket (1) | Creating socket. | 2020-10-07 02:24:53.548
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:24:53.549
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:24:53.549
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:24:53.577
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:24:53.577
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:24:53.577
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:24:53.627
SC Data - All Services | Sending logon request message. | 2020-10-07 02:24:53.627
SC Data - All Services | Received logon response. | 2020-10-07 02:24:54.280
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:24:54.280
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:24:54.280
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:24:54.280
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:24:54.280
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:24:54.281
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:24:54.281
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:24:54.282
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:24:54.282
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:24:54.282
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:24:54.296
DTC Client socket (1) | Closed. | 2020-10-07 02:24:54.296
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:25:24.273
DTC Client socket (1) | Creating socket. | 2020-10-07 02:25:24.273
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:25:24.273
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:25:24.273
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:25:24.289
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:25:24.289
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:25:24.289
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:25:24.327
SC Data - All Services | Sending logon request message. | 2020-10-07 02:25:24.327
SC Data - All Services | Received logon response. | 2020-10-07 02:25:24.528
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:25:24.528
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:25:24.528
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:25:24.528
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:25:24.528
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:25:24.528
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:25:24.528
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:25:24.528
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:25:24.528
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:25:24.528
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:25:24.542
DTC Client socket (1) | Closed. | 2020-10-07 02:25:24.542
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:25:54.536
DTC Client socket (1) | Creating socket. | 2020-10-07 02:25:54.536
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:25:54.536
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:25:54.536
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:25:54.558
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:25:54.558
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:25:54.558
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:25:54.574
SC Data - All Services | Sending logon request message. | 2020-10-07 02:25:54.574
SC Data - All Services | Received logon response. | 2020-10-07 02:25:55.184
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:25:55.184
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:25:55.184
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:25:55.184
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:25:55.184
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:25:55.184
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:25:55.184
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:25:55.184
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:25:55.184
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:25:55.184
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:25:55.201
DTC Client socket (1) | Closed. | 2020-10-07 02:25:55.201
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:26:25.184
DTC Client socket (1) | Creating socket. | 2020-10-07 02:26:25.185
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:26:25.186
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:26:25.186
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:26:25.214
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:26:25.214
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:26:25.214
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:26:25.246
SC Data - All Services | Sending logon request message. | 2020-10-07 02:26:25.246
SC Data - All Services | Received logon response. | 2020-10-07 02:26:25.937
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:26:25.937
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:26:25.937
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:26:25.937
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:26:25.937
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:26:25.937
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:26:25.937
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:26:25.937
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:26:25.937
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:26:25.937
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:26:25.961
DTC Client socket (1) | Closed. | 2020-10-07 02:26:25.961
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:26:55.934
DTC Client socket (1) | Creating socket. | 2020-10-07 02:26:55.935
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:26:55.935
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:26:55.935
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:26:55.957
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:26:55.957
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:26:55.957
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:26:56.002
SC Data - All Services | Sending logon request message. | 2020-10-07 02:26:56.002
SC Data - All Services | Received logon response. | 2020-10-07 02:26:56.639
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:26:56.639
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:26:56.639
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:26:56.639
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:26:56.639
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:26:56.639
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:26:56.639
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:26:56.639
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:26:56.639
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:26:56.639
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:26:56.653
DTC Client socket (1) | Closed. | 2020-10-07 02:26:56.653
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.0955 seconds. | 2020-10-07 02:27:26.398
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0384 seconds. | 2020-10-07 02:27:26.438
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:27:26.644
DTC Client socket (1) | Creating socket. | 2020-10-07 02:27:26.644
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:27:26.644
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:27:26.644
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:27:26.659
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:27:26.659
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:27:26.659
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:27:26.687
SC Data - All Services | Sending logon request message. | 2020-10-07 02:27:26.687
SC Data - All Services | Received logon response. | 2020-10-07 02:27:27.330
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:27:27.330
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:27:27.330
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:27:27.330
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:27:27.330
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:27:27.330
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:27:27.330
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:27:27.330
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:27:27.330
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:27:27.330
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:27:27.342
DTC Client socket (1) | Closed. | 2020-10-07 02:27:27.342
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:27:57.334
DTC Client socket (1) | Creating socket. | 2020-10-07 02:27:57.335
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:27:57.335
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:27:57.335
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:27:57.366
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:27:57.366
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:27:57.366
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:27:57.390
SC Data - All Services | Sending logon request message. | 2020-10-07 02:27:57.390
SC Data - All Services | Received logon response. | 2020-10-07 02:27:58.048
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:27:58.048
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:27:58.048
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:27:58.048
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:27:58.048
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:27:58.049
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:27:58.049
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:27:58.049
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:27:58.049
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:27:58.049
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:27:58.064
DTC Client socket (1) | Closed. | 2020-10-07 02:27:58.064
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:28:28.047
DTC Client socket (1) | Creating socket. | 2020-10-07 02:28:28.047
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:28:28.047
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:28:28.047
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:28:28.074
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:28:28.074
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:28:28.074
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:28:28.132
SC Data - All Services | Sending logon request message. | 2020-10-07 02:28:28.132
SC Data - All Services | Received logon response. | 2020-10-07 02:28:28.825
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:28:28.825
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:28:28.825
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:28:28.825
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:28:28.825
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:28:28.825
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:28:28.825
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:28:28.825
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:28:28.825
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:28:28.825
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:28:28.854
DTC Client socket (1) | Closed. | 2020-10-07 02:28:28.854
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:28:58.829
DTC Client socket (1) | Creating socket. | 2020-10-07 02:28:58.830
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:28:58.830
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:28:58.830
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:28:58.858
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:28:58.858
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:28:58.858
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:28:58.895
SC Data - All Services | Sending logon request message. | 2020-10-07 02:28:58.895
SC Data - All Services | Received logon response. | 2020-10-07 02:28:59.539
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:28:59.539
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:28:59.539
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:28:59.539
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:28:59.539
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:28:59.539
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:28:59.539
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:28:59.539
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:28:59.539
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:28:59.539
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:28:59.552
DTC Client socket (1) | Closed. | 2020-10-07 02:28:59.552
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:29:29.552
DTC Client socket (1) | Creating socket. | 2020-10-07 02:29:29.553
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:29:29.553
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:29:29.553
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:29:29.577
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:29:29.577
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:29:29.578
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:29:29.610
SC Data - All Services | Sending logon request message. | 2020-10-07 02:29:29.610
SC Data - All Services | Received logon response. | 2020-10-07 02:29:30.180
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:29:30.180
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:29:30.180
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:29:30.180
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:29:30.181
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:29:30.181
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:29:30.181
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:29:30.181
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:29:30.181
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:29:30.181
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:29:30.194
DTC Client socket (1) | Closed. | 2020-10-07 02:29:30.195
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:30:00.193
DTC Client socket (1) | Creating socket. | 2020-10-07 02:30:00.193
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:30:00.193
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:30:00.193
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:30:00.215
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:30:00.215
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:30:00.215
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:30:00.267
SC Data - All Services | Sending logon request message. | 2020-10-07 02:30:00.267
SC Data - All Services | Received logon response. | 2020-10-07 02:30:00.897
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:30:00.897
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:30:00.897
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:30:00.897
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:30:00.897
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:30:00.897
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:30:00.897
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:30:00.897
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:30:00.897
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:30:00.897
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:30:00.912
DTC Client socket (1) | Closed. | 2020-10-07 02:30:00.912
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:30:30.882
DTC Client socket (1) | Creating socket. | 2020-10-07 02:30:30.883
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:30:30.883
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:30:30.883
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:30:30.911
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:30:30.911
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:30:30.911
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:30:30.952
SC Data - All Services | Sending logon request message. | 2020-10-07 02:30:30.952
SC Data - All Services | Received logon response. | 2020-10-07 02:30:31.606
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:30:31.606
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:30:31.606
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:30:31.606
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:30:31.606
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:30:31.606
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:30:31.606
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:30:31.606
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:30:31.606
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:30:31.606
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:30:31.632
DTC Client socket (1) | Closed. | 2020-10-07 02:30:31.632
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:31:01.603
DTC Client socket (1) | Creating socket. | 2020-10-07 02:31:01.603
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:31:01.603
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:31:01.603
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:31:01.626
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:31:01.626
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:31:01.626
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:31:01.659
SC Data - All Services | Sending logon request message. | 2020-10-07 02:31:01.659
SC Data - All Services | Received logon response. | 2020-10-07 02:31:02.332
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:31:02.332
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:31:02.332
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:31:02.332
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:31:02.332
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:31:02.333
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:31:02.333
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:31:02.333
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:31:02.333
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:31:02.333
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:31:02.347
DTC Client socket (1) | Closed. | 2020-10-07 02:31:02.347
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:31:32.325
DTC Client socket (1) | Creating socket. | 2020-10-07 02:31:32.325
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:31:32.325
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:31:32.325
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:31:32.357
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:31:32.357
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:31:32.357
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:31:32.387
SC Data - All Services | Sending logon request message. | 2020-10-07 02:31:32.387
SC Data - All Services | Received logon response. | 2020-10-07 02:31:32.985
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:31:32.985
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:31:32.985
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:31:32.985
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:31:32.985
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:31:32.986
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:31:32.986
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:31:32.986
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:31:32.986
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:31:32.986
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:31:32.999
DTC Client socket (1) | Closed. | 2020-10-07 02:31:32.999
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:32:02.981
DTC Client socket (2) | Creating socket. | 2020-10-07 02:32:02.981
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 02:32:02.981
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:32:02.981
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:32:03.004
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:32:03.004
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:32:03.005
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:32:03.025
SC Data - All Services | Sending logon request message. | 2020-10-07 02:32:03.025
SC Data - All Services | Received logon response. | 2020-10-07 02:32:03.638
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:32:03.638
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:32:03.638
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:32:03.638
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:32:03.638
DTC Client socket (2) | CloseSocket call. | 2020-10-07 02:32:03.638
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:32:03.638
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:32:03.638
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:32:03.638
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:32:03.638
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 02:32:03.651
DTC Client socket (2) | Closed. | 2020-10-07 02:32:03.651
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:32:33.644
DTC Client socket (1) | Creating socket. | 2020-10-07 02:32:33.645
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:32:33.645
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:32:33.645
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:32:33.673
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:32:33.673
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:32:33.673
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:32:33.737
SC Data - All Services | Sending logon request message. | 2020-10-07 02:32:33.737
SC Data - All Services | Received logon response. | 2020-10-07 02:32:34.448
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:32:34.448
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:32:34.448
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:32:34.448
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:32:34.448
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:32:34.448
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:32:34.448
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:32:34.448
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:32:34.449
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:32:34.449
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:32:34.475
DTC Client socket (1) | Closed. | 2020-10-07 02:32:34.475
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:33:04.458
DTC Client socket (1) | Creating socket. | 2020-10-07 02:33:04.459
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:33:04.459
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:33:04.459
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:33:04.480
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:33:04.480
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:33:04.480
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:33:04.512
SC Data - All Services | Sending logon request message. | 2020-10-07 02:33:04.512
SC Data - All Services | Received logon response. | 2020-10-07 02:33:05.194
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:33:05.194
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:33:05.194
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:33:05.194
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:33:05.194
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:33:05.194
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:33:05.194
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:33:05.194
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:33:05.194
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:33:05.195
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:33:05.208
DTC Client socket (1) | Closed. | 2020-10-07 02:33:05.208
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:33:35.186
DTC Client socket (1) | Creating socket. | 2020-10-07 02:33:35.186
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:33:35.186
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:33:35.186
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:33:35.200
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:33:35.200
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:33:35.200
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:33:35.234
SC Data - All Services | Sending logon request message. | 2020-10-07 02:33:35.234
SC Data - All Services | Received logon response. | 2020-10-07 02:33:35.847
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:33:35.847
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:33:35.847
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:33:35.847
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:33:35.847
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:33:35.847
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:33:35.847
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:33:35.848
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:33:35.848
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:33:35.848
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:33:35.862
DTC Client socket (1) | Closed. | 2020-10-07 02:33:35.862
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:34:05.840
DTC Client socket (1) | Creating socket. | 2020-10-07 02:34:05.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:34:05.840
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:34:05.840
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:34:05.862
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:34:05.862
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:34:05.862
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:34:05.895
SC Data - All Services | Sending logon request message. | 2020-10-07 02:34:05.895
SC Data - All Services | Received logon response. | 2020-10-07 02:34:06.534
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:34:06.534
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:34:06.534
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:34:06.534
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:34:06.534
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:34:06.535
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:34:06.535
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:34:06.535
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:34:06.535
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:34:06.535
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:34:06.551
DTC Client socket (1) | Closed. | 2020-10-07 02:34:06.551
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:34:36.528
DTC Client socket (1) | Creating socket. | 2020-10-07 02:34:36.528
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:34:36.528
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:34:36.528
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:34:36.558
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:34:36.558
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:34:36.558
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:34:36.589
SC Data - All Services | Sending logon request message. | 2020-10-07 02:34:36.589
SC Data - All Services | Received logon response. | 2020-10-07 02:34:37.294
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:34:37.294
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:34:37.294
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:34:37.294
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:34:37.294
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:34:37.294
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:34:37.294
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:34:37.294
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:34:37.294
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:34:37.294
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:34:37.320
DTC Client socket (1) | Closed. | 2020-10-07 02:34:37.320
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:35:07.297
DTC Client socket (1) | Creating socket. | 2020-10-07 02:35:07.298
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:35:07.298
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:35:07.298
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:35:07.325
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:35:07.325
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:35:07.325
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:35:07.351
SC Data - All Services | Sending logon request message. | 2020-10-07 02:35:07.351
SC Data - All Services | Received logon response. | 2020-10-07 02:35:08.025
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:35:08.025
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:35:08.025
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:35:08.025
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:35:08.025
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:35:08.025
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:35:08.025
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:35:08.025
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:35:08.026
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:35:08.026
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:35:08.039
DTC Client socket (1) | Closed. | 2020-10-07 02:35:08.039
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:35:38.028
DTC Client socket (1) | Creating socket. | 2020-10-07 02:35:38.029
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:35:38.029
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:35:38.029
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:35:38.060
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:35:38.060
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:35:38.060
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:35:38.099
SC Data - All Services | Sending logon request message. | 2020-10-07 02:35:38.099
SC Data - All Services | Received logon response. | 2020-10-07 02:35:38.677
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:35:38.677
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:35:38.677
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:35:38.677
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:35:38.677
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:35:38.677
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:35:38.677
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:35:38.677
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:35:38.677
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:35:38.677
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:35:38.691
DTC Client socket (1) | Closed. | 2020-10-07 02:35:38.691
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:36:08.676
DTC Client socket (2) | Creating socket. | 2020-10-07 02:36:08.676
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 02:36:08.676
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:36:08.676
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:36:08.701
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:36:08.701
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:36:08.701
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:36:08.732
SC Data - All Services | Sending logon request message. | 2020-10-07 02:36:08.732
SC Data - All Services | Received logon response. | 2020-10-07 02:36:09.357
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:36:09.357
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:36:09.357
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:36:09.357
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:36:09.357
DTC Client socket (2) | CloseSocket call. | 2020-10-07 02:36:09.357
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:36:09.357
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:36:09.357
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:36:09.357
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:36:09.357
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 02:36:09.372
DTC Client socket (2) | Closed. | 2020-10-07 02:36:09.372
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:36:39.360
DTC Client socket (1) | Creating socket. | 2020-10-07 02:36:39.361
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:36:39.361
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:36:39.361
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:36:39.391
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:36:39.391
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:36:39.391
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:36:39.431
SC Data - All Services | Sending logon request message. | 2020-10-07 02:36:39.431
SC Data - All Services | Received logon response. | 2020-10-07 02:36:40.136
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:36:40.136
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:36:40.136
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:36:40.136
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:36:40.136
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:36:40.136
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:36:40.136
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:36:40.136
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:36:40.136
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:36:40.136
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:36:40.163
DTC Client socket (1) | Closed. | 2020-10-07 02:36:40.163
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:37:10.140
DTC Client socket (1) | Creating socket. | 2020-10-07 02:37:10.140
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:37:10.140
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:37:10.140
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:37:10.161
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:37:10.161
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:37:10.161
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:37:10.197
SC Data - All Services | Sending logon request message. | 2020-10-07 02:37:10.197
SC Data - All Services | Received logon response. | 2020-10-07 02:37:10.850
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:37:10.850
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:37:10.850
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:37:10.850
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:37:10.850
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:37:10.850
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:37:10.850
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:37:10.850
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:37:10.850
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:37:10.850
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:37:10.865
DTC Client socket (1) | Closed. | 2020-10-07 02:37:10.865
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:37:40.840
DTC Client socket (1) | Creating socket. | 2020-10-07 02:37:40.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:37:40.840
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:37:40.840
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:37:40.849
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:37:40.849
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:37:40.849
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:37:40.902
SC Data - All Services | Sending logon request message. | 2020-10-07 02:37:40.902
SC Data - All Services | Received logon response. | 2020-10-07 02:37:41.492
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:37:41.492
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:37:41.492
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:37:41.492
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:37:41.492
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:37:41.493
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:37:41.493
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:37:41.493
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:37:41.493
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:37:41.493
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:37:41.506
DTC Client socket (1) | Closed. | 2020-10-07 02:37:41.506
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:38:11.497
DTC Client socket (1) | Creating socket. | 2020-10-07 02:38:11.497
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:38:11.497
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:38:11.497
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:38:11.526
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:38:11.526
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:38:11.526
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:38:11.571
SC Data - All Services | Sending logon request message. | 2020-10-07 02:38:11.571
SC Data - All Services | Received logon response. | 2020-10-07 02:38:12.208
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:38:12.208
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:38:12.208
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:38:12.208
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:38:12.208
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:38:12.208
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:38:12.208
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:38:12.209
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:38:12.209
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:38:12.209
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:38:12.221
DTC Client socket (1) | Closed. | 2020-10-07 02:38:12.222
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:38:42.202
DTC Client socket (1) | Creating socket. | 2020-10-07 02:38:42.202
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:38:42.202
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:38:42.202
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:38:42.230
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:38:42.230
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:38:42.230
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:38:42.276
SC Data - All Services | Sending logon request message. | 2020-10-07 02:38:42.277
SC Data - All Services | Received logon response. | 2020-10-07 02:38:42.930
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:38:42.930
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:38:42.930
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:38:42.930
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:38:42.930
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:38:42.931
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:38:42.931
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:38:42.931
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:38:42.931
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:38:42.931
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:38:42.961
DTC Client socket (1) | Closed. | 2020-10-07 02:38:42.961
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:39:12.940
DTC Client socket (1) | Creating socket. | 2020-10-07 02:39:12.940
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:39:12.940
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:39:12.940
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:39:12.957
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:39:12.957
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:39:12.957
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:39:12.995
SC Data - All Services | Sending logon request message. | 2020-10-07 02:39:12.996
SC Data - All Services | Received logon response. | 2020-10-07 02:39:13.650
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:39:13.650
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:39:13.650
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:39:13.650
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:39:13.650
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:39:13.650
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:39:13.650
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:39:13.650
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:39:13.650
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:39:13.650
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:39:13.664
DTC Client socket (1) | Closed. | 2020-10-07 02:39:13.664
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:39:43.659
DTC Client socket (1) | Creating socket. | 2020-10-07 02:39:43.659
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:39:43.659
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:39:43.659
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:39:43.681
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:39:43.681
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:39:43.681
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:39:43.697
SC Data - All Services | Sending logon request message. | 2020-10-07 02:39:43.697
SC Data - All Services | Received logon response. | 2020-10-07 02:39:44.295
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:39:44.295
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:39:44.295
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:39:44.295
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:39:44.295
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:39:44.295
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:39:44.295
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:39:44.295
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:39:44.295
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:39:44.295
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:39:44.308
DTC Client socket (1) | Closed. | 2020-10-07 02:39:44.308
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:40:14.293
DTC Client socket (1) | Creating socket. | 2020-10-07 02:40:14.293
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:40:14.293
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:40:14.293
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:40:14.317
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:40:14.317
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:40:14.317
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:40:14.360
SC Data - All Services | Sending logon request message. | 2020-10-07 02:40:14.360
SC Data - All Services | Received logon response. | 2020-10-07 02:40:14.996
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:40:14.996
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:40:14.996
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:40:14.996
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:40:14.996
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:40:14.997
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:40:14.997
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:40:14.997
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:40:14.997
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:40:14.997
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:40:15.011
DTC Client socket (1) | Closed. | 2020-10-07 02:40:15.011
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:40:44.998
DTC Client socket (1) | Creating socket. | 2020-10-07 02:40:44.999
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:40:44.999
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:40:44.999
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:40:45.033
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:40:45.033
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:40:45.033
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:40:45.081
SC Data - All Services | Sending logon request message. | 2020-10-07 02:40:45.081
SC Data - All Services | Received logon response. | 2020-10-07 02:40:45.771
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:40:45.771
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:40:45.771
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:40:45.771
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:40:45.771
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:40:45.771
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:40:45.771
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:40:45.771
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:40:45.771
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:40:45.771
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:40:45.799
DTC Client socket (1) | Closed. | 2020-10-07 02:40:45.800
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:41:15.767
DTC Client socket (1) | Creating socket. | 2020-10-07 02:41:15.767
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:41:15.767
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:41:15.767
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:41:15.796
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:41:15.796
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:41:15.796
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:41:15.850
SC Data - All Services | Sending logon request message. | 2020-10-07 02:41:15.850
SC Data - All Services | Received logon response. | 2020-10-07 02:41:16.503
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:41:16.503
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:41:16.503
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:41:16.503
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:41:16.503
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:41:16.503
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:41:16.503
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:41:16.503
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:41:16.503
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:41:16.503
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:41:16.516
DTC Client socket (1) | Closed. | 2020-10-07 02:41:16.516
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:41:46.497
DTC Client socket (1) | Creating socket. | 2020-10-07 02:41:46.498
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:41:46.498
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:41:46.498
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:41:46.522
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:41:46.522
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:41:46.522
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:41:46.558
SC Data - All Services | Sending logon request message. | 2020-10-07 02:41:46.558
SC Data - All Services | Received logon response. | 2020-10-07 02:41:47.159
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:41:47.159
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:41:47.159
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:41:47.159
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:41:47.159
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:41:47.159
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:41:47.159
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:41:47.159
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:41:47.159
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:41:47.159
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:41:47.172
DTC Client socket (1) | Closed. | 2020-10-07 02:41:47.172
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:42:17.158
DTC Client socket (1) | Creating socket. | 2020-10-07 02:42:17.158
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:42:17.158
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:42:17.158
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:42:17.186
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:42:17.186
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:42:17.186
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:42:17.200
SC Data - All Services | Sending logon request message. | 2020-10-07 02:42:17.200
SC Data - All Services | Received logon response. | 2020-10-07 02:42:17.830
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:42:17.830
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:42:17.830
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:42:17.830
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:42:17.830
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:42:17.830
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:42:17.830
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:42:17.831
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:42:17.831
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:42:17.831
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:42:17.844
DTC Client socket (1) | Closed. | 2020-10-07 02:42:17.844
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.0965 seconds. | 2020-10-07 02:42:26.528
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0448 seconds. | 2020-10-07 02:42:26.574
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:42:47.820
DTC Client socket (1) | Creating socket. | 2020-10-07 02:42:47.821
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:42:47.821
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:42:47.821
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:42:47.849
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:42:47.849
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:42:47.849
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:42:47.897
SC Data - All Services | Sending logon request message. | 2020-10-07 02:42:47.897
SC Data - All Services | Received logon response. | 2020-10-07 02:42:48.594
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:42:48.594
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:42:48.594
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:42:48.594
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:42:48.594
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:42:48.594
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:42:48.594
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:42:48.594
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:42:48.594
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:42:48.594
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:42:48.619
DTC Client socket (1) | Closed. | 2020-10-07 02:42:48.619
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:43:18.600
DTC Client socket (1) | Creating socket. | 2020-10-07 02:43:18.600
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:43:18.600
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:43:18.600
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:43:18.615
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:43:18.615
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:43:18.615
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:43:18.661
SC Data - All Services | Sending logon request message. | 2020-10-07 02:43:18.661
SC Data - All Services | Received logon response. | 2020-10-07 02:43:19.313
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:43:19.313
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:43:19.314
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:43:19.314
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:43:19.314
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:43:19.315
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:43:19.315
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:43:19.315
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:43:19.315
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:43:19.315
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:43:19.329
DTC Client socket (1) | Closed. | 2020-10-07 02:43:19.330
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:43:49.307
DTC Client socket (1) | Creating socket. | 2020-10-07 02:43:49.308
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:43:49.308
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:43:49.308
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:43:49.337
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:43:49.337
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:43:49.337
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:43:49.364
SC Data - All Services | Sending logon request message. | 2020-10-07 02:43:49.364
SC Data - All Services | Received logon response. | 2020-10-07 02:43:49.969
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:43:49.969
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:43:49.969
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:43:49.969
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:43:49.969
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:43:49.969
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:43:49.969
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:43:49.969
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:43:49.969
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:43:49.969
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:43:49.982
DTC Client socket (1) | Closed. | 2020-10-07 02:43:49.982
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:44:19.962
DTC Client socket (1) | Creating socket. | 2020-10-07 02:44:19.962
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:44:19.962
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:44:19.962
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:44:19.984
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:44:19.984
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:44:19.984
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:44:20.023
SC Data - All Services | Sending logon request message. | 2020-10-07 02:44:20.023
SC Data - All Services | Received logon response. | 2020-10-07 02:44:20.674
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:44:20.674
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:44:20.675
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:44:20.675
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:44:20.675
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:44:20.675
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:44:20.675
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:44:20.675
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:44:20.675
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:44:20.675
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:44:20.692
DTC Client socket (1) | Closed. | 2020-10-07 02:44:20.692
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:44:50.670
DTC Client socket (1) | Creating socket. | 2020-10-07 02:44:50.671
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:44:50.671
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:44:50.671
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:44:50.720
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:44:50.720
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:44:50.720
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:44:50.779
SC Data - All Services | Sending logon request message. | 2020-10-07 02:44:50.779
SC Data - All Services | Received logon response. | 2020-10-07 02:44:51.452
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:44:51.452
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:44:51.452
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:44:51.452
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:44:51.452
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:44:51.452
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:44:51.452
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:44:51.452
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:44:51.452
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:44:51.452
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:44:51.477
DTC Client socket (1) | Closed. | 2020-10-07 02:44:51.477
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:45:21.455
DTC Client socket (1) | Creating socket. | 2020-10-07 02:45:21.455
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:45:21.455
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:45:21.455
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:45:21.471
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:45:21.471
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:45:21.471
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:45:21.508
SC Data - All Services | Sending logon request message. | 2020-10-07 02:45:21.508
SC Data - All Services | Received logon response. | 2020-10-07 02:45:22.164
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:45:22.164
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:45:22.164
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:45:22.164
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:45:22.164
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:45:22.164
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:45:22.164
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:45:22.164
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:45:22.164
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:45:22.164
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:45:22.178
DTC Client socket (1) | Closed. | 2020-10-07 02:45:22.178
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:45:52.177
DTC Client socket (1) | Creating socket. | 2020-10-07 02:45:52.177
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:45:52.177
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:45:52.177
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:45:52.199
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:45:52.199
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:45:52.199
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:45:52.220
SC Data - All Services | Sending logon request message. | 2020-10-07 02:45:52.220
SC Data - All Services | Received logon response. | 2020-10-07 02:45:52.882
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:45:52.882
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:45:52.882
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:45:52.882
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:45:52.882
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:45:52.882
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:45:52.882
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:45:52.882
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:45:52.882
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:45:52.882
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:45:52.896
DTC Client socket (1) | Closed. | 2020-10-07 02:45:52.896
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:46:22.870
DTC Client socket (1) | Creating socket. | 2020-10-07 02:46:22.871
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:46:22.871
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:46:22.871
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:46:22.895
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:46:22.895
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:46:22.895
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:46:22.942
SC Data - All Services | Sending logon request message. | 2020-10-07 02:46:22.942
SC Data - All Services | Received logon response. | 2020-10-07 02:46:23.566
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:46:23.566
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:46:23.566
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:46:23.566
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:46:23.566
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:46:23.566
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:46:23.566
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:46:23.566
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:46:23.566
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:46:23.566
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:46:23.581
DTC Client socket (1) | Closed. | 2020-10-07 02:46:23.581
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:46:53.565
DTC Client socket (1) | Creating socket. | 2020-10-07 02:46:53.566
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:46:53.566
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:46:53.566
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:46:53.593
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:46:53.593
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:46:53.593
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:46:53.624
SC Data - All Services | Sending logon request message. | 2020-10-07 02:46:53.624
SC Data - All Services | Received logon response. | 2020-10-07 02:46:54.330
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:46:54.330
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:46:54.330
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:46:54.330
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:46:54.330
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:46:54.330
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:46:54.330
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:46:54.330
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:46:54.330
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:46:54.330
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:46:54.356
DTC Client socket (1) | Closed. | 2020-10-07 02:46:54.356
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:47:24.322
DTC Client socket (1) | Creating socket. | 2020-10-07 02:47:24.322
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:47:24.322
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:47:24.322
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:47:24.343
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:47:24.343
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:47:24.343
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:47:24.367
SC Data - All Services | Sending logon request message. | 2020-10-07 02:47:24.367
SC Data - All Services | Received logon response. | 2020-10-07 02:47:25.009
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:47:25.009
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:47:25.009
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:47:25.009
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:47:25.009
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:47:25.009
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:47:25.009
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:47:25.009
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:47:25.009
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:47:25.009
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:47:25.022
DTC Client socket (1) | Closed. | 2020-10-07 02:47:25.022
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:47:55.010
DTC Client socket (1) | Creating socket. | 2020-10-07 02:47:55.010
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:47:55.010
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:47:55.010
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:47:55.025
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:47:55.025
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:47:55.025
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:47:55.075
SC Data - All Services | Sending logon request message. | 2020-10-07 02:47:55.075
SC Data - All Services | Received logon response. | 2020-10-07 02:47:55.699
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:47:55.699
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:47:55.699
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:47:55.699
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:47:55.699
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:47:55.700
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:47:55.700
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:47:55.700
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:47:55.700
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:47:55.700
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:47:55.713
DTC Client socket (1) | Closed. | 2020-10-07 02:47:55.713
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:48:25.699
DTC Client socket (1) | Creating socket. | 2020-10-07 02:48:25.699
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:48:25.700
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:48:25.700
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:48:25.730
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:48:25.730
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:48:25.730
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:48:25.773
SC Data - All Services | Sending logon request message. | 2020-10-07 02:48:25.773
SC Data - All Services | Received logon response. | 2020-10-07 02:48:26.415
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:48:26.415
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:48:26.415
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:48:26.415
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:48:26.415
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:48:26.416
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:48:26.416
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:48:26.416
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:48:26.416
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:48:26.416
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:48:26.430
DTC Client socket (1) | Closed. | 2020-10-07 02:48:26.430
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:48:56.421
DTC Client socket (1) | Creating socket. | 2020-10-07 02:48:56.421
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:48:56.421
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:48:56.421
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:48:56.451
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:48:56.451
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:48:56.451
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:48:56.483
SC Data - All Services | Sending logon request message. | 2020-10-07 02:48:56.483
SC Data - All Services | Received logon response. | 2020-10-07 02:48:57.174
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:48:57.174
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:48:57.174
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:48:57.174
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:48:57.174
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:48:57.174
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:48:57.174
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:48:57.174
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:48:57.174
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:48:57.174
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:48:57.199
DTC Client socket (1) | Closed. | 2020-10-07 02:48:57.199
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:49:27.171
DTC Client socket (1) | Creating socket. | 2020-10-07 02:49:27.172
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:49:27.172
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:49:27.172
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:49:27.193
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:49:27.193
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:49:27.193
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:49:27.217
SC Data - All Services | Sending logon request message. | 2020-10-07 02:49:27.217
SC Data - All Services | Received logon response. | 2020-10-07 02:49:27.861
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:49:27.861
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:49:27.861
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:49:27.861
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:49:27.861
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:49:27.861
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:49:27.861
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:49:27.861
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:49:27.861
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:49:27.861
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:49:27.874
DTC Client socket (1) | Closed. | 2020-10-07 02:49:27.874
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:49:57.854
DTC Client socket (1) | Creating socket. | 2020-10-07 02:49:57.854
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:49:57.854
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:49:57.854
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:49:57.876
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:49:57.876
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:49:57.876
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:49:57.896
SC Data - All Services | Sending logon request message. | 2020-10-07 02:49:57.896
SC Data - All Services | Received logon response. | 2020-10-07 02:49:58.529
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:49:58.529
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:49:58.529
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:49:58.529
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:49:58.529
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:49:58.529
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:49:58.529
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:49:58.529
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:49:58.529
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:49:58.529
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:49:58.556
DTC Client socket (1) | Closed. | 2020-10-07 02:49:58.556
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:50:28.530
DTC Client socket (1) | Creating socket. | 2020-10-07 02:50:28.531
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:50:28.531
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:50:28.531
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:50:28.547
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:50:28.547
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:50:28.547
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:50:28.569
SC Data - All Services | Sending logon request message. | 2020-10-07 02:50:28.569
SC Data - All Services | Received logon response. | 2020-10-07 02:50:29.229
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:50:29.229
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:50:29.229
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:50:29.229
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:50:29.229
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:50:29.230
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:50:29.230
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:50:29.230
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:50:29.230
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:50:29.230
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:50:29.244
DTC Client socket (1) | Closed. | 2020-10-07 02:50:29.244
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:50:59.227
DTC Client socket (1) | Creating socket. | 2020-10-07 02:50:59.228
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:50:59.228
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:50:59.228
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:50:59.254
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:50:59.254
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:50:59.254
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:50:59.296
SC Data - All Services | Sending logon request message. | 2020-10-07 02:50:59.296
SC Data - All Services | Received logon response. | 2020-10-07 02:51:00.006
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:51:00.006
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:51:00.006
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:51:00.006
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:51:00.006
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:51:00.006
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:51:00.006
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:51:00.007
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:51:00.007
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:51:00.007
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:51:00.029
DTC Client socket (1) | Closed. | 2020-10-07 02:51:00.030
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:51:29.996
DTC Client socket (1) | Creating socket. | 2020-10-07 02:51:29.996
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:51:29.996
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:51:29.996
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:51:30.011
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:51:30.011
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:51:30.011
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:51:30.031
SC Data - All Services | Sending logon request message. | 2020-10-07 02:51:30.031
SC Data - All Services | Received logon response. | 2020-10-07 02:51:30.688
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:51:30.688
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:51:30.688
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:51:30.688
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:51:30.688
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:51:30.688
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:51:30.688
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:51:30.688
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:51:30.688
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:51:30.688
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:51:30.701
DTC Client socket (1) | Closed. | 2020-10-07 02:51:30.701
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:52:00.696
DTC Client socket (1) | Creating socket. | 2020-10-07 02:52:00.697
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:52:00.697
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:52:00.697
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:52:00.713
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:52:00.713
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:52:00.713
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:52:00.757
SC Data - All Services | Sending logon request message. | 2020-10-07 02:52:00.757
SC Data - All Services | Received logon response. | 2020-10-07 02:52:01.439
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:52:01.439
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:52:01.439
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:52:01.439
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:52:01.439
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:52:01.439
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:52:01.439
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:52:01.439
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:52:01.439
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:52:01.439
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:52:01.452
DTC Client socket (1) | Closed. | 2020-10-07 02:52:01.452
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:52:31.432
DTC Client socket (1) | Creating socket. | 2020-10-07 02:52:31.433
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:52:31.433
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:52:31.433
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:52:31.453
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:52:31.453
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:52:31.454
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:52:31.492
SC Data - All Services | Sending logon request message. | 2020-10-07 02:52:31.492
SC Data - All Services | Received logon response. | 2020-10-07 02:52:32.146
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:52:32.146
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:52:32.146
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:52:32.146
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:52:32.146
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:52:32.146
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:52:32.146
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:52:32.146
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:52:32.146
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:52:32.146
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:52:32.162
DTC Client socket (1) | Closed. | 2020-10-07 02:52:32.162
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:53:02.143
DTC Client socket (1) | Creating socket. | 2020-10-07 02:53:02.144
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:53:02.144
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:53:02.144
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:53:02.170
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:53:02.170
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:53:02.170
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:53:02.215
SC Data - All Services | Sending logon request message. | 2020-10-07 02:53:02.215
SC Data - All Services | Received logon response. | 2020-10-07 02:53:02.904
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:53:02.904
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:53:02.904
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:53:02.904
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:53:02.904
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:53:02.904
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:53:02.904
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:53:02.904
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:53:02.904
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:53:02.904
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:53:02.930
DTC Client socket (1) | Closed. | 2020-10-07 02:53:02.930
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:53:32.898
DTC Client socket (1) | Creating socket. | 2020-10-07 02:53:32.898
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:53:32.898
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:53:32.899
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:53:32.915
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:53:32.915
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:53:32.916
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:53:32.944
SC Data - All Services | Sending logon request message. | 2020-10-07 02:53:32.944
SC Data - All Services | Received logon response. | 2020-10-07 02:53:33.603
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:53:33.603
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:53:33.603
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:53:33.603
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:53:33.603
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:53:33.603
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:53:33.603
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:53:33.603
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:53:33.603
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:53:33.603
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:53:33.617
DTC Client socket (1) | Closed. | 2020-10-07 02:53:33.617
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:54:03.616
DTC Client socket (1) | Creating socket. | 2020-10-07 02:54:03.616
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:54:03.616
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:54:03.616
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:54:03.632
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:54:03.632
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:54:03.632
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:54:03.673
SC Data - All Services | Sending logon request message. | 2020-10-07 02:54:03.673
SC Data - All Services | Received logon response. | 2020-10-07 02:54:04.342
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:54:04.342
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:54:04.342
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:54:04.342
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:54:04.342
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:54:04.343
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:54:04.343
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:54:04.343
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:54:04.343
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:54:04.343
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:54:04.346
DTC Client socket (1) | Closed. | 2020-10-07 02:54:04.346
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:54:34.344
DTC Client socket (1) | Creating socket. | 2020-10-07 02:54:34.345
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:54:34.345
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:54:34.345
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:54:34.364
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:54:34.364
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:54:34.364
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:54:34.402
SC Data - All Services | Sending logon request message. | 2020-10-07 02:54:34.402
SC Data - All Services | Received logon response. | 2020-10-07 02:54:35.024
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:54:35.024
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:54:35.024
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:54:35.024
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:54:35.024
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:54:35.025
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:54:35.025
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:54:35.025
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:54:35.025
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:54:35.025
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:54:35.043
DTC Client socket (1) | Closed. | 2020-10-07 02:54:35.043
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:55:05.024
DTC Client socket (1) | Creating socket. | 2020-10-07 02:55:05.025
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:55:05.025
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:55:05.025
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:55:05.055
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:55:05.055
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:55:05.055
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:55:05.107
SC Data - All Services | Sending logon request message. | 2020-10-07 02:55:05.107
SC Data - All Services | Received logon response. | 2020-10-07 02:55:05.795
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:55:05.795
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:55:05.795
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:55:05.795
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:55:05.795
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:55:05.795
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:55:05.795
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:55:05.795
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:55:05.795
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:55:05.795
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:55:05.822
DTC Client socket (1) | Closed. | 2020-10-07 02:55:05.822
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:55:35.790
DTC Client socket (1) | Creating socket. | 2020-10-07 02:55:35.790
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:55:35.790
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:55:35.790
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:55:35.812
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:55:35.812
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:55:35.812
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:55:35.845
SC Data - All Services | Sending logon request message. | 2020-10-07 02:55:35.845
SC Data - All Services | Received logon response. | 2020-10-07 02:55:36.537
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:55:36.537
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:55:36.537
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:55:36.537
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:55:36.537
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:55:36.537
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:55:36.537
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:55:36.537
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:55:36.537
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:55:36.537
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:55:36.551
DTC Client socket (1) | Closed. | 2020-10-07 02:55:36.551
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:56:06.533
DTC Client socket (2) | Creating socket. | 2020-10-07 02:56:06.534
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 02:56:06.534
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:56:06.534
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:56:06.564
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:56:06.564
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:56:06.564
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:56:06.590
SC Data - All Services | Sending logon request message. | 2020-10-07 02:56:06.590
SC Data - All Services | Received logon response. | 2020-10-07 02:56:07.248
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:56:07.248
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:56:07.248
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:56:07.248
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:56:07.248
DTC Client socket (2) | CloseSocket call. | 2020-10-07 02:56:07.248
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:56:07.248
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:56:07.248
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:56:07.248
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:56:07.248
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 02:56:07.262
DTC Client socket (2) | Closed. | 2020-10-07 02:56:07.262
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:56:37.248
DTC Client socket (1) | Creating socket. | 2020-10-07 02:56:37.249
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:56:37.249
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:56:37.249
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:56:37.270
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:56:37.270
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:56:37.270
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:56:37.317
SC Data - All Services | Sending logon request message. | 2020-10-07 02:56:37.317
SC Data - All Services | Received logon response. | 2020-10-07 02:56:37.945
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:56:37.945
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:56:37.945
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:56:37.945
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:56:37.945
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:56:37.946
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:56:37.946
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:56:37.946
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:56:37.946
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:56:37.946
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:56:37.961
DTC Client socket (1) | Closed. | 2020-10-07 02:56:37.962
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:57:07.955
DTC Client socket (1) | Creating socket. | 2020-10-07 02:57:07.955
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:57:07.955
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:57:07.955
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:57:07.987
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:57:07.987
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:57:07.987
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:57:08.024
SC Data - All Services | Sending logon request message. | 2020-10-07 02:57:08.024
SC Data - All Services | Received logon response. | 2020-10-07 02:57:08.722
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:57:08.722
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:57:08.722
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:57:08.722
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:57:08.723
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:57:08.723
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:57:08.723
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:57:08.723
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:57:08.723
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:57:08.723
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:57:08.749
DTC Client socket (1) | Closed. | 2020-10-07 02:57:08.749
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1102 seconds. | 2020-10-07 02:57:26.688
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0413 seconds. | 2020-10-07 02:57:26.730
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:57:38.724
DTC Client socket (1) | Creating socket. | 2020-10-07 02:57:38.724
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:57:38.724
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:57:38.724
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:57:38.748
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:57:38.748
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:57:38.749
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:57:38.785
SC Data - All Services | Sending logon request message. | 2020-10-07 02:57:38.785
SC Data - All Services | Received logon response. | 2020-10-07 02:57:39.461
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:57:39.461
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:57:39.461
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:57:39.461
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:57:39.461
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:57:39.461
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:57:39.461
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:57:39.461
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:57:39.461
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:57:39.461
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:57:39.474
DTC Client socket (1) | Closed. | 2020-10-07 02:57:39.474
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 02:58:09.467
DTC Client socket (1) | Creating socket. | 2020-10-07 02:58:09.468
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:58:09.468
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 02:58:09.468
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:58:09.496
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:58:09.496
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:58:09.496
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:58:09.538
SC Data - All Services | Sending logon request message. | 2020-10-07 02:58:09.538
SC Data - All Services | Received logon response. | 2020-10-07 02:58:09.717
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:58:09.717
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:58:09.717
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:58:09.717
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:58:09.717
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:58:09.717
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:58:09.717
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:58:09.717
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:58:09.717
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:58:09.717
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:58:09.731
DTC Client socket (1) | Closed. | 2020-10-07 02:58:09.732
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 02:58:39.723
DTC Client socket (1) | Creating socket. | 2020-10-07 02:58:39.724
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:58:39.724
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 02:58:39.724
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:58:39.749
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:58:39.749
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:58:39.749
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:58:39.801
SC Data - All Services | Sending logon request message. | 2020-10-07 02:58:39.801
SC Data - All Services | Received logon response. | 2020-10-07 02:58:40.442
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:58:40.442
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:58:40.442
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:58:40.442
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:58:40.442
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:58:40.442
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:58:40.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:58:40.442
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:58:40.442
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:58:40.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:58:40.456
DTC Client socket (1) | Closed. | 2020-10-07 02:58:40.456
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 02:59:10.441
DTC Client socket (1) | Creating socket. | 2020-10-07 02:59:10.441
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:59:10.441
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 02:59:10.441
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:59:10.470
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:59:10.470
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:59:10.470
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:59:10.501
SC Data - All Services | Sending logon request message. | 2020-10-07 02:59:10.501
SC Data - All Services | Received logon response. | 2020-10-07 02:59:11.189
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:59:11.189
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:59:11.189
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:59:11.189
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:59:11.189
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:59:11.190
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:59:11.190
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:59:11.190
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:59:11.190
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:59:11.190
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:59:11.215
DTC Client socket (1) | Closed. | 2020-10-07 02:59:11.216
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 02:59:41.180
DTC Client socket (1) | Creating socket. | 2020-10-07 02:59:41.181
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 02:59:41.181
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 02:59:41.181
SC Data - All Services | Network connection to server complete. | 2020-10-07 02:59:41.191
SC Data - All Services | Starting socket receive thread. | 2020-10-07 02:59:41.191
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 02:59:41.191
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 02:59:41.238
SC Data - All Services | Sending logon request message. | 2020-10-07 02:59:41.238
SC Data - All Services | Received logon response. | 2020-10-07 02:59:41.878
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 02:59:41.878
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 02:59:41.878
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 02:59:41.878
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 02:59:41.878
DTC Client socket (1) | CloseSocket call. | 2020-10-07 02:59:41.878
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 02:59:41.879
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 02:59:41.879
SC Data - All Services | Disconnected from the server. | 2020-10-07 02:59:41.879
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 02:59:41.879
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 02:59:41.893
DTC Client socket (1) | Closed. | 2020-10-07 02:59:41.893
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:00:11.882
DTC Client socket (1) | Creating socket. | 2020-10-07 03:00:11.882
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:00:11.882
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:00:11.882
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:00:11.904
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:00:11.904
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:00:11.904
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:00:11.940
SC Data - All Services | Sending logon request message. | 2020-10-07 03:00:11.940
SC Data - All Services | Received logon response. | 2020-10-07 03:00:12.553
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:00:12.553
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:00:12.553
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:00:12.553
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:00:12.553
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:00:12.554
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:00:12.554
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:00:12.554
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:00:12.554
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:00:12.554
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:00:12.568
DTC Client socket (1) | Closed. | 2020-10-07 03:00:12.568
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:00:42.539
DTC Client socket (1) | Creating socket. | 2020-10-07 03:00:42.539
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:00:42.539
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:00:42.539
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:00:42.556
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:00:42.556
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:00:42.556
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:00:42.570
SC Data - All Services | Sending logon request message. | 2020-10-07 03:00:42.570
SC Data - All Services | Received logon response. | 2020-10-07 03:00:43.180
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:00:43.180
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:00:43.180
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:00:43.180
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:00:43.180
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:00:43.180
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:00:43.180
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:00:43.180
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:00:43.180
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:00:43.180
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:00:43.194
DTC Client socket (1) | Closed. | 2020-10-07 03:00:43.194
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:01:13.187
DTC Client socket (1) | Creating socket. | 2020-10-07 03:01:13.187
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:01:13.187
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:01:13.187
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:01:13.216
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:01:13.216
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:01:13.216
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:01:13.245
SC Data - All Services | Sending logon request message. | 2020-10-07 03:01:13.245
SC Data - All Services | Received logon response. | 2020-10-07 03:01:13.940
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:01:13.940
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:01:13.940
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:01:13.940
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:01:13.940
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:01:13.941
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:01:13.941
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:01:13.941
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:01:13.941
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:01:13.941
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:01:13.966
DTC Client socket (1) | Closed. | 2020-10-07 03:01:13.966
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:01:43.942
DTC Client socket (1) | Creating socket. | 2020-10-07 03:01:43.942
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:01:43.942
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:01:43.942
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:01:43.972
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:01:43.972
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:01:43.972
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:01:44.004
SC Data - All Services | Sending logon request message. | 2020-10-07 03:01:44.004
SC Data - All Services | Received logon response. | 2020-10-07 03:01:44.663
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:01:44.663
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:01:44.663
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:01:44.663
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:01:44.663
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:01:44.663
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:01:44.663
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:01:44.663
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:01:44.663
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:01:44.663
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:01:44.676
DTC Client socket (1) | Closed. | 2020-10-07 03:01:44.676
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:02:14.663
DTC Client socket (1) | Creating socket. | 2020-10-07 03:02:14.664
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:02:14.664
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:02:14.664
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:02:14.692
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:02:14.692
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:02:14.692
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:02:14.738
SC Data - All Services | Sending logon request message. | 2020-10-07 03:02:14.738
SC Data - All Services | Received logon response. | 2020-10-07 03:02:15.363
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:02:15.363
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:02:15.363
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:02:15.363
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:02:15.363
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:02:15.363
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:02:15.363
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:02:15.363
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:02:15.363
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:02:15.363
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:02:15.375
DTC Client socket (1) | Closed. | 2020-10-07 03:02:15.375
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:02:45.358
DTC Client socket (1) | Creating socket. | 2020-10-07 03:02:45.358
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:02:45.358
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:02:45.358
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:02:45.388
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:02:45.388
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:02:45.388
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:02:45.432
SC Data - All Services | Sending logon request message. | 2020-10-07 03:02:45.432
SC Data - All Services | Received logon response. | 2020-10-07 03:02:46.313
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:02:46.313
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:02:46.313
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:02:46.313
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:02:46.313
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:02:46.313
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:02:46.313
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:02:46.313
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:02:46.313
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:02:46.313
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:02:46.326
DTC Client socket (1) | Closed. | 2020-10-07 03:02:46.326
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:03:16.313
DTC Client socket (1) | Creating socket. | 2020-10-07 03:03:16.314
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:03:16.314
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:03:16.314
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:03:16.338
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:03:16.338
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:03:16.338
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:03:16.371
SC Data - All Services | Sending logon request message. | 2020-10-07 03:03:16.371
SC Data - All Services | Received logon response. | 2020-10-07 03:03:17.106
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:03:17.106
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:03:17.106
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:03:17.106
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:03:17.106
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:03:17.107
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:03:17.107
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:03:17.107
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:03:17.107
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:03:17.107
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:03:17.133
DTC Client socket (1) | Closed. | 2020-10-07 03:03:17.133
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:03:47.114
DTC Client socket (1) | Creating socket. | 2020-10-07 03:03:47.115
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:03:47.115
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:03:47.115
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:03:47.143
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:03:47.143
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:03:47.143
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:03:47.156
SC Data - All Services | Sending logon request message. | 2020-10-07 03:03:47.156
SC Data - All Services | Received logon response. | 2020-10-07 03:03:47.805
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:03:47.805
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:03:47.805
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:03:47.805
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:03:47.805
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:03:47.805
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:03:47.805
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:03:47.805
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:03:47.805
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:03:47.805
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:03:47.818
DTC Client socket (1) | Closed. | 2020-10-07 03:03:47.818
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:04:17.807
DTC Client socket (1) | Creating socket. | 2020-10-07 03:04:17.808
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:04:17.808
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:04:17.808
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:04:17.831
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:04:17.831
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:04:17.831
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:04:17.861
SC Data - All Services | Sending logon request message. | 2020-10-07 03:04:17.861
SC Data - All Services | Received logon response. | 2020-10-07 03:04:18.462
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:04:18.462
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:04:18.462
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:04:18.462
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:04:18.462
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:04:18.462
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:04:18.463
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:04:18.463
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:04:18.463
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:04:18.463
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:04:18.475
DTC Client socket (1) | Closed. | 2020-10-07 03:04:18.475
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:04:48.475
DTC Client socket (1) | Creating socket. | 2020-10-07 03:04:48.476
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:04:48.476
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:04:48.476
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:04:48.496
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:04:48.496
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:04:48.496
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:04:48.541
SC Data - All Services | Sending logon request message. | 2020-10-07 03:04:48.541
SC Data - All Services | Received logon response. | 2020-10-07 03:04:49.175
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:04:49.175
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:04:49.175
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:04:49.175
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:04:49.175
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:04:49.176
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:04:49.176
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:04:49.176
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:04:49.176
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:04:49.176
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:04:49.190
DTC Client socket (1) | Closed. | 2020-10-07 03:04:49.190
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:05:19.171
DTC Client socket (1) | Creating socket. | 2020-10-07 03:05:19.171
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:05:19.171
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:05:19.172
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:05:19.201
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:05:19.201
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:05:19.201
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:05:19.262
SC Data - All Services | Sending logon request message. | 2020-10-07 03:05:19.262
SC Data - All Services | Received logon response. | 2020-10-07 03:05:19.924
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:05:19.924
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:05:19.924
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:05:19.924
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:05:19.924
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:05:19.924
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:05:19.924
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:05:19.924
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:05:19.925
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:05:19.925
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:05:19.953
DTC Client socket (1) | Closed. | 2020-10-07 03:05:19.953
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:05:49.927
DTC Client socket (1) | Creating socket. | 2020-10-07 03:05:49.930
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:05:49.930
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:05:49.930
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:05:49.949
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:05:49.949
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:05:49.949
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:05:49.989
SC Data - All Services | Sending logon request message. | 2020-10-07 03:05:49.989
SC Data - All Services | Received logon response. | 2020-10-07 03:05:50.674
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:05:50.674
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:05:50.674
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:05:50.674
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:05:50.674
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:05:50.675
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:05:50.675
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:05:50.675
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:05:50.675
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:05:50.675
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:05:50.692
DTC Client socket (1) | Closed. | 2020-10-07 03:05:50.692
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:06:20.674
DTC Client socket (1) | Creating socket. | 2020-10-07 03:06:20.674
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:06:20.675
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:06:20.675
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:06:20.690
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:06:20.690
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:06:20.690
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:06:20.714
SC Data - All Services | Sending logon request message. | 2020-10-07 03:06:20.714
SC Data - All Services | Received logon response. | 2020-10-07 03:06:21.292
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:06:21.292
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:06:21.292
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:06:21.292
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:06:21.292
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:06:21.292
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:06:21.292
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:06:21.292
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:06:21.292
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:06:21.292
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:06:21.306
DTC Client socket (1) | Closed. | 2020-10-07 03:06:21.306
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:06:51.297
DTC Client socket (1) | Creating socket. | 2020-10-07 03:06:51.297
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:06:51.297
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:06:51.297
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:06:51.321
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:06:51.321
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:06:51.321
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:06:51.342
SC Data - All Services | Sending logon request message. | 2020-10-07 03:06:51.342
SC Data - All Services | Received logon response. | 2020-10-07 03:06:51.974
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:06:51.974
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:06:51.974
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:06:51.974
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:06:51.974
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:06:51.974
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:06:51.974
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:06:51.974
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:06:51.974
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:06:51.974
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:06:51.987
DTC Client socket (1) | Closed. | 2020-10-07 03:06:51.987
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:07:21.972
DTC Client socket (1) | Creating socket. | 2020-10-07 03:07:21.973
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:07:21.973
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:07:21.973
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:07:22.001
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:07:22.001
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:07:22.001
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:07:22.043
SC Data - All Services | Sending logon request message. | 2020-10-07 03:07:22.043
SC Data - All Services | Received logon response. | 2020-10-07 03:07:22.715
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:07:22.715
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:07:22.715
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:07:22.715
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:07:22.715
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:07:22.715
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:07:22.715
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:07:22.715
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:07:22.715
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:07:22.715
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:07:22.741
DTC Client socket (1) | Closed. | 2020-10-07 03:07:22.741
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:07:52.724
DTC Client socket (1) | Creating socket. | 2020-10-07 03:07:52.724
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:07:52.724
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:07:52.724
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:07:52.756
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:07:52.756
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:07:52.756
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:07:52.800
SC Data - All Services | Sending logon request message. | 2020-10-07 03:07:52.800
SC Data - All Services | Received logon response. | 2020-10-07 03:07:53.489
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:07:53.489
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:07:53.489
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:07:53.489
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:07:53.489
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:07:53.489
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:07:53.489
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:07:53.489
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:07:53.489
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:07:53.489
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:07:53.501
DTC Client socket (1) | Closed. | 2020-10-07 03:07:53.501
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:08:23.484
DTC Client socket (1) | Creating socket. | 2020-10-07 03:08:23.485
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:08:23.485
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:08:23.485
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:08:23.500
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:08:23.500
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:08:23.500
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:08:23.539
SC Data - All Services | Sending logon request message. | 2020-10-07 03:08:23.539
SC Data - All Services | Received logon response. | 2020-10-07 03:08:24.137
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:08:24.137
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:08:24.137
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:08:24.137
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:08:24.137
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:08:24.137
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:08:24.137
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:08:24.137
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:08:24.137
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:08:24.137
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:08:24.151
DTC Client socket (1) | Closed. | 2020-10-07 03:08:24.151
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:08:54.141
DTC Client socket (1) | Creating socket. | 2020-10-07 03:08:54.142
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:08:54.142
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:08:54.142
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:08:54.160
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:08:54.160
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:08:54.160
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:08:54.204
SC Data - All Services | Sending logon request message. | 2020-10-07 03:08:54.204
SC Data - All Services | Received logon response. | 2020-10-07 03:08:54.826
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:08:54.826
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:08:54.826
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:08:54.826
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:08:54.826
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:08:54.826
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:08:54.826
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:08:54.826
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:08:54.826
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:08:54.826
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:08:54.841
DTC Client socket (1) | Closed. | 2020-10-07 03:08:54.841
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:09:24.821
DTC Client socket (1) | Creating socket. | 2020-10-07 03:09:24.821
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:09:24.821
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:09:24.821
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:09:24.846
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:09:24.846
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:09:24.847
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:09:24.884
SC Data - All Services | Sending logon request message. | 2020-10-07 03:09:24.884
SC Data - All Services | Received logon response. | 2020-10-07 03:09:25.582
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:09:25.582
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:09:25.582
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:09:25.582
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:09:25.582
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:09:25.583
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:09:25.583
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:09:25.583
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:09:25.583
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:09:25.583
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:09:25.608
DTC Client socket (1) | Closed. | 2020-10-07 03:09:25.608
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:09:55.577
DTC Client socket (1) | Creating socket. | 2020-10-07 03:09:55.577
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:09:55.577
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:09:55.577
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:09:55.608
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:09:55.608
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:09:55.608
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:09:55.623
SC Data - All Services | Sending logon request message. | 2020-10-07 03:09:55.623
SC Data - All Services | Received logon response. | 2020-10-07 03:09:56.299
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:09:56.299
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:09:56.299
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:09:56.299
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:09:56.299
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:09:56.299
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:09:56.299
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:09:56.299
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:09:56.299
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:09:56.299
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:09:56.313
DTC Client socket (1) | Closed. | 2020-10-07 03:09:56.313
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:10:26.289
DTC Client socket (1) | Creating socket. | 2020-10-07 03:10:26.290
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:10:26.290
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:10:26.290
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:10:26.311
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:10:26.311
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:10:26.311
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:10:26.353
SC Data - All Services | Sending logon request message. | 2020-10-07 03:10:26.353
SC Data - All Services | Received logon response. | 2020-10-07 03:10:26.915
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:10:26.915
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:10:26.915
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:10:26.915
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:10:26.915
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:10:26.915
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:10:26.915
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:10:26.915
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:10:26.915
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:10:26.915
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:10:26.931
DTC Client socket (1) | Closed. | 2020-10-07 03:10:26.931
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:10:56.916
DTC Client socket (1) | Creating socket. | 2020-10-07 03:10:56.916
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:10:56.917
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:10:56.917
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:10:56.938
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:10:56.938
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:10:56.938
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:10:56.978
SC Data - All Services | Sending logon request message. | 2020-10-07 03:10:56.978
SC Data - All Services | Received logon response. | 2020-10-07 03:10:57.602
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:10:57.602
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:10:57.602
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:10:57.602
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:10:57.602
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:10:57.602
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:10:57.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:10:57.602
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:10:57.602
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:10:57.602
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:10:57.618
DTC Client socket (1) | Closed. | 2020-10-07 03:10:57.618
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:11:27.613
DTC Client socket (1) | Creating socket. | 2020-10-07 03:11:27.614
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:11:27.614
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:11:27.614
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:11:27.641
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:11:27.641
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:11:27.641
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:11:27.694
SC Data - All Services | Sending logon request message. | 2020-10-07 03:11:27.694
SC Data - All Services | Received logon response. | 2020-10-07 03:11:28.403
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:11:28.403
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:11:28.403
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:11:28.403
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:11:28.403
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:11:28.403
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:11:28.403
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:11:28.403
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:11:28.403
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:11:28.403
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:11:28.428
DTC Client socket (1) | Closed. | 2020-10-07 03:11:28.428
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:11:58.404
DTC Client socket (1) | Creating socket. | 2020-10-07 03:11:58.405
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:11:58.405
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:11:58.405
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:11:58.428
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:11:58.428
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:11:58.428
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:11:58.455
SC Data - All Services | Sending logon request message. | 2020-10-07 03:11:58.455
SC Data - All Services | Received logon response. | 2020-10-07 03:11:59.110
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:11:59.110
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:11:59.110
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:11:59.110
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:11:59.110
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:11:59.111
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:11:59.111
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:11:59.111
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:11:59.111
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:11:59.111
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:11:59.123
DTC Client socket (1) | Closed. | 2020-10-07 03:11:59.124
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1280 seconds. | 2020-10-07 03:12:26.857
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0410 seconds. | 2020-10-07 03:12:26.899
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:12:29.108
DTC Client socket (1) | Creating socket. | 2020-10-07 03:12:29.108
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:12:29.108
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:12:29.108
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:12:29.135
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:12:29.135
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:12:29.135
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:12:29.162
SC Data - All Services | Sending logon request message. | 2020-10-07 03:12:29.162
SC Data - All Services | Received logon response. | 2020-10-07 03:12:29.788
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:12:29.788
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:12:29.788
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:12:29.788
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:12:29.788
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:12:29.788
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:12:29.788
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:12:29.788
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:12:29.789
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:12:29.789
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:12:29.801
DTC Client socket (1) | Closed. | 2020-10-07 03:12:29.801
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:12:59.799
DTC Client socket (1) | Creating socket. | 2020-10-07 03:12:59.800
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:12:59.800
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:12:59.800
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:12:59.828
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:12:59.828
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:12:59.828
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:12:59.853
SC Data - All Services | Sending logon request message. | 2020-10-07 03:12:59.853
SC Data - All Services | Received logon response. | 2020-10-07 03:13:00.492
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:13:00.492
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:13:00.492
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:13:00.492
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:13:00.492
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:13:00.493
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:13:00.493
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:13:00.493
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:13:00.493
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:13:00.493
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:13:00.508
DTC Client socket (1) | Closed. | 2020-10-07 03:13:00.508
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:13:30.493
DTC Client socket (1) | Creating socket. | 2020-10-07 03:13:30.493
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:13:30.493
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:13:30.493
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:13:30.523
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:13:30.523
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:13:30.523
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:13:30.553
SC Data - All Services | Sending logon request message. | 2020-10-07 03:13:30.553
SC Data - All Services | Received logon response. | 2020-10-07 03:13:31.245
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:13:31.245
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:13:31.245
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:13:31.245
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:13:31.245
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:13:31.245
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:13:31.245
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:13:31.245
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:13:31.245
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:13:31.246
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:13:31.271
DTC Client socket (1) | Closed. | 2020-10-07 03:13:31.271
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:14:01.242
DTC Client socket (1) | Creating socket. | 2020-10-07 03:14:01.242
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:14:01.242
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:14:01.242
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:14:01.264
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:14:01.264
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:14:01.264
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:14:01.322
SC Data - All Services | Sending logon request message. | 2020-10-07 03:14:01.323
SC Data - All Services | Received logon response. | 2020-10-07 03:14:01.994
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:14:01.994
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:14:01.994
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:14:01.994
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:14:01.994
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:14:01.995
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:14:01.995
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:14:01.995
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:14:01.995
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:14:01.995
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:14:02.010
DTC Client socket (1) | Closed. | 2020-10-07 03:14:02.011
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:14:32.000
DTC Client socket (1) | Creating socket. | 2020-10-07 03:14:32.000
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:14:32.000
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:14:32.000
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:14:32.014
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:14:32.014
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:14:32.015
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:14:32.047
SC Data - All Services | Sending logon request message. | 2020-10-07 03:14:32.047
SC Data - All Services | Received logon response. | 2020-10-07 03:14:32.640
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:14:32.640
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:14:32.640
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:14:32.640
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:14:32.640
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:14:32.640
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:14:32.640
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:14:32.640
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:14:32.640
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:14:32.640
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:14:32.656
DTC Client socket (1) | Closed. | 2020-10-07 03:14:32.656
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:15:02.644
DTC Client socket (2) | Creating socket. | 2020-10-07 03:15:02.645
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 03:15:02.645
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:15:02.645
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:15:02.666
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:15:02.666
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:15:02.666
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:15:02.702
SC Data - All Services | Sending logon request message. | 2020-10-07 03:15:02.702
SC Data - All Services | Received logon response. | 2020-10-07 03:15:03.334
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:15:03.334
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:15:03.334
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:15:03.334
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:15:03.334
DTC Client socket (2) | CloseSocket call. | 2020-10-07 03:15:03.334
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:15:03.334
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:15:03.334
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:15:03.334
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:15:03.334
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 03:15:03.347
DTC Client socket (2) | Closed. | 2020-10-07 03:15:03.347
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:15:33.324
DTC Client socket (1) | Creating socket. | 2020-10-07 03:15:33.325
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:15:33.325
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:15:33.325
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:15:33.353
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:15:33.353
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:15:33.353
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:15:33.419
SC Data - All Services | Sending logon request message. | 2020-10-07 03:15:33.419
SC Data - All Services | Received logon response. | 2020-10-07 03:15:34.129
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:15:34.129
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:15:34.129
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:15:34.129
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:15:34.129
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:15:34.129
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:15:34.129
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:15:34.129
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:15:34.129
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:15:34.129
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:15:34.156
DTC Client socket (1) | Closed. | 2020-10-07 03:15:34.156
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:16:04.120
DTC Client socket (2) | Creating socket. | 2020-10-07 03:16:04.120
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 03:16:04.120
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:16:04.120
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:16:04.141
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:16:04.141
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:16:04.141
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:16:04.172
SC Data - All Services | Sending logon request message. | 2020-10-07 03:16:04.172
SC Data - All Services | Received logon response. | 2020-10-07 03:16:04.847
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:16:04.847
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:16:04.847
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:16:04.847
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:16:04.847
DTC Client socket (2) | CloseSocket call. | 2020-10-07 03:16:04.848
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:16:04.848
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:16:04.848
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:16:04.848
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:16:04.848
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 03:16:04.861
DTC Client socket (2) | Closed. | 2020-10-07 03:16:04.862
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:16:34.836
DTC Client socket (1) | Creating socket. | 2020-10-07 03:16:34.836
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:16:34.836
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:16:34.836
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:16:34.849
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:16:34.849
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:16:34.849
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:16:34.876
SC Data - All Services | Sending logon request message. | 2020-10-07 03:16:34.876
SC Data - All Services | Received logon response. | 2020-10-07 03:16:35.530
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:16:35.530
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:16:35.530
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:16:35.530
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:16:35.530
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:16:35.531
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:16:35.531
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:16:35.531
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:16:35.531
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:16:35.531
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:16:35.546
DTC Client socket (1) | Closed. | 2020-10-07 03:16:35.546
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:17:05.533
DTC Client socket (1) | Creating socket. | 2020-10-07 03:17:05.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:17:05.533
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:17:05.533
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:17:05.548
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:17:05.549
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:17:05.549
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:17:05.595
SC Data - All Services | Sending logon request message. | 2020-10-07 03:17:05.595
SC Data - All Services | Received logon response. | 2020-10-07 03:17:06.243
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:17:06.243
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:17:06.243
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:17:06.243
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:17:06.243
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:17:06.243
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:17:06.243
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:17:06.243
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:17:06.243
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:17:06.243
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:17:06.260
DTC Client socket (1) | Closed. | 2020-10-07 03:17:06.260
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:17:36.242
DTC Client socket (1) | Creating socket. | 2020-10-07 03:17:36.242
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:17:36.242
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:17:36.242
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:17:36.270
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:17:36.270
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:17:36.270
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:17:36.317
SC Data - All Services | Sending logon request message. | 2020-10-07 03:17:36.317
SC Data - All Services | Received logon response. | 2020-10-07 03:17:37.007
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:17:37.007
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:17:37.007
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:17:37.007
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:17:37.007
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:17:37.008
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:17:37.008
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:17:37.008
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:17:37.008
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:17:37.008
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:17:37.033
DTC Client socket (1) | Closed. | 2020-10-07 03:17:37.033
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:18:07.009
DTC Client socket (1) | Creating socket. | 2020-10-07 03:18:07.010
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:18:07.010
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:18:07.010
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:18:07.025
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:18:07.025
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:18:07.025
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:18:07.049
SC Data - All Services | Sending logon request message. | 2020-10-07 03:18:07.049
SC Data - All Services | Received logon response. | 2020-10-07 03:18:07.720
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:18:07.720
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:18:07.720
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:18:07.720
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:18:07.720
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:18:07.720
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:18:07.720
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:18:07.720
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:18:07.720
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:18:07.720
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:18:07.734
DTC Client socket (1) | Closed. | 2020-10-07 03:18:07.734
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:18:37.717
DTC Client socket (1) | Creating socket. | 2020-10-07 03:18:37.717
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:18:37.717
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:18:37.717
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:18:37.731
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:18:37.731
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:18:37.731
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:18:37.763
SC Data - All Services | Sending logon request message. | 2020-10-07 03:18:37.763
SC Data - All Services | Received logon response. | 2020-10-07 03:18:38.420
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:18:38.420
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:18:38.420
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:18:38.420
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:18:38.420
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:18:38.420
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:18:38.420
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:18:38.420
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:18:38.420
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:18:38.420
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:18:38.432
DTC Client socket (1) | Closed. | 2020-10-07 03:18:38.432
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:19:08.424
DTC Client socket (1) | Creating socket. | 2020-10-07 03:19:08.424
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:19:08.424
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:19:08.424
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:19:08.445
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:19:08.445
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:19:08.445
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:19:08.476
SC Data - All Services | Sending logon request message. | 2020-10-07 03:19:08.476
SC Data - All Services | Received logon response. | 2020-10-07 03:19:09.088
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:19:09.088
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:19:09.088
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:19:09.088
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:19:09.088
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:19:09.088
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:19:09.088
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:19:09.088
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:19:09.088
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:19:09.089
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:19:09.104
DTC Client socket (1) | Closed. | 2020-10-07 03:19:09.104
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:19:39.087
DTC Client socket (1) | Creating socket. | 2020-10-07 03:19:39.088
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:19:39.088
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:19:39.088
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:19:39.119
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:19:39.119
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:19:39.119
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:19:39.149
SC Data - All Services | Sending logon request message. | 2020-10-07 03:19:39.149
SC Data - All Services | Received logon response. | 2020-10-07 03:19:39.774
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:19:39.774
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:19:39.774
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:19:39.774
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:19:39.774
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:19:39.774
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:19:39.774
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:19:39.774
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:19:39.774
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:19:39.774
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:19:39.802
DTC Client socket (1) | Closed. | 2020-10-07 03:19:39.802
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:20:09.777
DTC Client socket (1) | Creating socket. | 2020-10-07 03:20:09.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:20:09.778
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:20:09.778
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:20:09.793
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:20:09.793
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:20:09.793
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:20:09.840
SC Data - All Services | Sending logon request message. | 2020-10-07 03:20:09.840
SC Data - All Services | Received logon response. | 2020-10-07 03:20:10.508
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:20:10.508
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:20:10.508
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:20:10.508
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:20:10.508
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:20:10.508
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:20:10.508
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:20:10.509
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:20:10.509
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:20:10.509
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:20:10.522
DTC Client socket (1) | Closed. | 2020-10-07 03:20:10.522
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:20:40.511
DTC Client socket (1) | Creating socket. | 2020-10-07 03:20:40.512
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:20:40.512
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:20:40.512
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:20:40.522
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:20:40.522
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:20:40.522
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:20:40.538
SC Data - All Services | Sending logon request message. | 2020-10-07 03:20:40.538
SC Data - All Services | Received logon response. | 2020-10-07 03:20:41.153
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:20:41.153
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:20:41.153
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:20:41.153
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:20:41.153
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:20:41.154
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:20:41.154
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:20:41.154
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:20:41.154
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:20:41.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:20:41.170
DTC Client socket (1) | Closed. | 2020-10-07 03:20:41.170
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:21:11.150
DTC Client socket (1) | Creating socket. | 2020-10-07 03:21:11.157
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:21:11.157
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:21:11.157
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:21:11.174
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:21:11.174
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:21:11.174
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:21:11.222
SC Data - All Services | Sending logon request message. | 2020-10-07 03:21:11.222
SC Data - All Services | Received logon response. | 2020-10-07 03:21:11.848
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:21:11.848
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:21:11.848
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:21:11.848
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:21:11.848
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:21:11.849
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:21:11.849
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:21:11.849
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:21:11.849
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:21:11.849
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:21:11.864
DTC Client socket (1) | Closed. | 2020-10-07 03:21:11.864
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:21:41.840
DTC Client socket (1) | Creating socket. | 2020-10-07 03:21:41.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:21:41.840
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:21:41.840
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:21:41.870
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:21:41.870
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:21:41.870
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:21:41.915
SC Data - All Services | Sending logon request message. | 2020-10-07 03:21:41.915
SC Data - All Services | Received logon response. | 2020-10-07 03:21:42.634
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:21:42.634
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:21:42.634
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:21:42.634
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:21:42.634
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:21:42.635
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:21:42.635
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:21:42.635
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:21:42.635
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:21:42.635
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:21:42.666
DTC Client socket (1) | Closed. | 2020-10-07 03:21:42.667
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:22:12.644
DTC Client socket (1) | Creating socket. | 2020-10-07 03:22:12.645
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:22:12.645
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:22:12.645
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:22:12.667
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:22:12.667
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:22:12.667
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:22:12.704
SC Data - All Services | Sending logon request message. | 2020-10-07 03:22:12.704
SC Data - All Services | Received logon response. | 2020-10-07 03:22:13.379
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:22:13.379
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:22:13.379
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:22:13.379
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:22:13.379
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:22:13.379
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:22:13.379
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:22:13.379
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:22:13.379
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:22:13.379
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:22:13.392
DTC Client socket (1) | Closed. | 2020-10-07 03:22:13.392
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:22:43.377
DTC Client socket (1) | Creating socket. | 2020-10-07 03:22:43.378
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:22:43.378
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:22:43.378
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:22:43.403
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:22:43.403
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:22:43.403
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:22:43.420
SC Data - All Services | Sending logon request message. | 2020-10-07 03:22:43.420
SC Data - All Services | Received logon response. | 2020-10-07 03:22:44.001
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:22:44.001
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:22:44.001
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:22:44.001
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:22:44.001
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:22:44.002
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:22:44.002
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:22:44.002
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:22:44.002
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:22:44.002
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:22:44.016
DTC Client socket (1) | Closed. | 2020-10-07 03:22:44.016
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:23:14.001
DTC Client socket (1) | Creating socket. | 2020-10-07 03:23:14.001
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:23:14.001
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:23:14.001
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:23:14.032
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:23:14.032
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:23:14.032
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:23:14.069
SC Data - All Services | Sending logon request message. | 2020-10-07 03:23:14.069
SC Data - All Services | Received logon response. | 2020-10-07 03:23:14.712
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:23:14.712
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:23:14.712
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:23:14.712
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:23:14.712
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:23:14.712
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:23:14.712
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:23:14.713
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:23:14.713
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:23:14.713
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:23:14.728
DTC Client socket (1) | Closed. | 2020-10-07 03:23:14.728
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:23:44.711
DTC Client socket (1) | Creating socket. | 2020-10-07 03:23:44.711
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:23:44.711
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:23:44.711
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:23:44.739
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:23:44.739
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:23:44.740
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:23:44.783
SC Data - All Services | Sending logon request message. | 2020-10-07 03:23:44.783
SC Data - All Services | Received logon response. | 2020-10-07 03:23:45.493
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:23:45.493
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:23:45.493
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:23:45.493
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:23:45.493
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:23:45.493
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:23:45.493
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:23:45.493
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:23:45.493
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:23:45.493
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:23:45.519
DTC Client socket (1) | Closed. | 2020-10-07 03:23:45.519
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:24:15.493
DTC Client socket (1) | Creating socket. | 2020-10-07 03:24:15.494
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:24:15.494
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:24:15.494
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:24:15.520
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:24:15.520
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:24:15.520
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:24:15.564
SC Data - All Services | Sending logon request message. | 2020-10-07 03:24:15.564
SC Data - All Services | Received logon response. | 2020-10-07 03:24:16.257
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:24:16.257
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:24:16.257
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:24:16.257
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:24:16.257
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:24:16.258
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:24:16.258
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:24:16.258
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:24:16.258
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:24:16.258
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:24:16.271
DTC Client socket (1) | Closed. | 2020-10-07 03:24:16.271
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:24:46.269
DTC Client socket (1) | Creating socket. | 2020-10-07 03:24:46.270
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:24:46.270
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:24:46.270
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:24:46.285
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:24:46.285
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:24:46.285
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:24:46.316
SC Data - All Services | Sending logon request message. | 2020-10-07 03:24:46.316
SC Data - All Services | Received logon response. | 2020-10-07 03:24:46.972
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:24:46.972
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:24:46.972
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:24:46.972
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:24:46.972
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:24:46.972
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:24:46.972
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:24:46.972
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:24:46.972
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:24:46.972
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:24:46.988
DTC Client socket (1) | Closed. | 2020-10-07 03:24:46.988
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:25:16.964
DTC Client socket (1) | Creating socket. | 2020-10-07 03:25:16.964
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:25:16.964
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:25:16.964
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:25:16.981
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:25:16.981
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:25:16.981
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:25:17.023
SC Data - All Services | Sending logon request message. | 2020-10-07 03:25:17.023
SC Data - All Services | Received logon response. | 2020-10-07 03:25:17.674
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:25:17.674
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:25:17.674
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:25:17.674
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:25:17.674
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:25:17.674
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:25:17.674
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:25:17.674
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:25:17.674
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:25:17.674
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:25:17.689
DTC Client socket (1) | Closed. | 2020-10-07 03:25:17.689
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:25:47.666
DTC Client socket (1) | Creating socket. | 2020-10-07 03:25:47.667
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:25:47.667
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:25:47.667
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:25:47.704
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:25:47.704
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:25:47.704
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:25:47.762
SC Data - All Services | Sending logon request message. | 2020-10-07 03:25:47.762
SC Data - All Services | Received logon response. | 2020-10-07 03:25:48.458
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:25:48.458
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:25:48.458
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:25:48.458
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:25:48.458
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:25:48.458
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:25:48.458
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:25:48.458
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:25:48.458
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:25:48.458
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:25:48.484
DTC Client socket (1) | Closed. | 2020-10-07 03:25:48.484
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:26:18.449
DTC Client socket (1) | Creating socket. | 2020-10-07 03:26:18.449
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:26:18.449
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:26:18.449
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:26:18.471
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:26:18.471
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:26:18.471
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:26:18.502
SC Data - All Services | Sending logon request message. | 2020-10-07 03:26:18.502
SC Data - All Services | Received logon response. | 2020-10-07 03:26:19.193
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:26:19.193
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:26:19.193
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:26:19.193
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:26:19.193
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:26:19.194
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:26:19.194
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:26:19.194
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:26:19.194
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:26:19.194
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:26:19.207
DTC Client socket (1) | Closed. | 2020-10-07 03:26:19.207
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:26:49.183
DTC Client socket (1) | Creating socket. | 2020-10-07 03:26:49.183
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:26:49.183
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:26:49.183
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:26:49.204
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:26:49.204
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:26:49.204
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:26:49.251
SC Data - All Services | Sending logon request message. | 2020-10-07 03:26:49.251
SC Data - All Services | Received logon response. | 2020-10-07 03:26:49.907
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:26:49.907
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:26:49.907
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:26:49.907
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:26:49.907
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:26:49.907
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:26:49.907
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:26:49.907
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:26:49.907
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:26:49.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:26:49.921
DTC Client socket (1) | Closed. | 2020-10-07 03:26:49.921
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:27:19.902
DTC Client socket (1) | Creating socket. | 2020-10-07 03:27:19.902
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:27:19.902
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:27:19.902
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:27:19.917
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:27:19.917
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:27:19.917
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:27:19.942
SC Data - All Services | Sending logon request message. | 2020-10-07 03:27:19.942
SC Data - All Services | Received logon response. | 2020-10-07 03:27:20.584
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:27:20.584
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:27:20.584
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:27:20.584
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:27:20.584
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:27:20.584
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:27:20.584
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:27:20.584
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:27:20.584
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:27:20.584
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:27:20.598
DTC Client socket (1) | Closed. | 2020-10-07 03:27:20.598
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1519 seconds. | 2020-10-07 03:27:27.061
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0399 seconds. | 2020-10-07 03:27:27.102
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:27:50.576
DTC Client socket (1) | Creating socket. | 2020-10-07 03:27:50.576
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:27:50.576
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:27:50.577
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:27:50.607
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:27:50.607
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:27:50.607
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:27:50.649
SC Data - All Services | Sending logon request message. | 2020-10-07 03:27:50.649
SC Data - All Services | Received logon response. | 2020-10-07 03:27:51.336
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:27:51.336
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:27:51.336
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:27:51.336
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:27:51.336
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:27:51.336
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:27:51.337
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:27:51.337
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:27:51.337
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:27:51.337
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:27:51.363
DTC Client socket (1) | Closed. | 2020-10-07 03:27:51.363
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:28:21.340
DTC Client socket (1) | Creating socket. | 2020-10-07 03:28:21.340
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:28:21.340
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:28:21.340
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:28:21.355
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:28:21.355
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:28:21.355
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:28:21.395
SC Data - All Services | Sending logon request message. | 2020-10-07 03:28:21.395
SC Data - All Services | Received logon response. | 2020-10-07 03:28:22.039
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:28:22.040
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:28:22.040
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:28:22.040
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:28:22.040
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:28:22.040
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:28:22.040
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:28:22.040
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:28:22.040
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:28:22.040
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:28:22.057
DTC Client socket (1) | Closed. | 2020-10-07 03:28:22.057
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:28:52.044
DTC Client socket (1) | Creating socket. | 2020-10-07 03:28:52.045
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:28:52.045
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:28:52.045
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:28:52.070
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:28:52.070
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:28:52.070
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:28:52.118
SC Data - All Services | Sending logon request message. | 2020-10-07 03:28:52.118
SC Data - All Services | Received logon response. | 2020-10-07 03:28:52.780
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:28:52.780
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:28:52.780
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:28:52.780
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:28:52.780
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:28:52.780
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:28:52.780
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:28:52.780
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:28:52.780
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:28:52.780
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:28:52.792
DTC Client socket (1) | Closed. | 2020-10-07 03:28:52.792
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:29:22.773
DTC Client socket (1) | Creating socket. | 2020-10-07 03:29:22.774
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:29:22.774
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:29:22.774
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:29:22.796
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:29:22.796
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:29:22.796
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:29:22.850
SC Data - All Services | Sending logon request message. | 2020-10-07 03:29:22.850
SC Data - All Services | Received logon response. | 2020-10-07 03:29:23.505
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:29:23.505
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:29:23.505
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:29:23.505
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:29:23.505
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:29:23.505
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:29:23.505
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:29:23.505
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:29:23.505
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:29:23.505
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:29:23.520
DTC Client socket (1) | Closed. | 2020-10-07 03:29:23.520
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:29:53.501
DTC Client socket (1) | Creating socket. | 2020-10-07 03:29:53.501
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:29:53.501
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:29:53.501
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:29:53.528
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:29:53.528
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:29:53.528
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:29:53.577
SC Data - All Services | Sending logon request message. | 2020-10-07 03:29:53.577
SC Data - All Services | Received logon response. | 2020-10-07 03:29:54.270
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:29:54.271
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:29:54.271
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:29:54.271
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:29:54.271
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:29:54.272
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:29:54.272
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:29:54.272
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:29:54.272
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:29:54.272
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:29:54.297
DTC Client socket (1) | Closed. | 2020-10-07 03:29:54.297
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:30:24.264
DTC Client socket (1) | Creating socket. | 2020-10-07 03:30:24.265
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:30:24.265
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:30:24.265
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:30:24.292
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:30:24.292
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:30:24.292
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:30:24.318
SC Data - All Services | Sending logon request message. | 2020-10-07 03:30:24.318
SC Data - All Services | Received logon response. | 2020-10-07 03:30:24.982
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:30:24.982
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:30:24.982
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:30:24.982
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:30:24.982
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:30:24.983
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:30:24.983
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:30:24.983
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:30:24.983
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:30:24.983
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:30:24.997
DTC Client socket (1) | Closed. | 2020-10-07 03:30:24.997
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:30:54.993
DTC Client socket (1) | Creating socket. | 2020-10-07 03:30:54.993
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:30:54.993
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:30:54.993
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:30:55.008
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:30:55.008
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:30:55.008
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:30:55.022
SC Data - All Services | Sending logon request message. | 2020-10-07 03:30:55.022
SC Data - All Services | Received logon response. | 2020-10-07 03:30:55.702
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:30:55.702
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:30:55.702
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:30:55.702
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:30:55.702
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:30:55.702
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:30:55.702
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:30:55.702
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:30:55.702
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:30:55.702
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:30:55.716
DTC Client socket (1) | Closed. | 2020-10-07 03:30:55.717
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:31:25.700
DTC Client socket (1) | Creating socket. | 2020-10-07 03:31:25.700
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:31:25.700
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:31:25.700
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:31:25.720
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:31:25.720
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:31:25.720
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:31:25.751
SC Data - All Services | Sending logon request message. | 2020-10-07 03:31:25.751
SC Data - All Services | Received logon response. | 2020-10-07 03:31:26.375
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:31:26.375
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:31:26.375
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:31:26.375
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:31:26.375
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:31:26.375
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:31:26.375
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:31:26.375
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:31:26.375
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:31:26.375
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:31:26.390
DTC Client socket (1) | Closed. | 2020-10-07 03:31:26.390
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:31:56.379
DTC Client socket (1) | Creating socket. | 2020-10-07 03:31:56.380
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:31:56.380
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:31:56.380
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:31:56.410
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:31:56.410
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:31:56.410
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:31:56.466
SC Data - All Services | Sending logon request message. | 2020-10-07 03:31:56.466
SC Data - All Services | Received logon response. | 2020-10-07 03:31:57.170
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:31:57.170
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:31:57.170
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:31:57.170
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:31:57.170
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:31:57.170
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:31:57.170
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:31:57.171
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:31:57.171
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:31:57.171
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:31:57.196
DTC Client socket (1) | Closed. | 2020-10-07 03:31:57.196
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:32:27.164
DTC Client socket (1) | Creating socket. | 2020-10-07 03:32:27.164
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:32:27.164
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:32:27.164
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:32:27.178
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:32:27.178
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:32:27.178
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:32:27.204
SC Data - All Services | Sending logon request message. | 2020-10-07 03:32:27.204
SC Data - All Services | Received logon response. | 2020-10-07 03:32:27.854
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:32:27.854
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:32:27.854
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:32:27.854
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:32:27.854
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:32:27.854
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:32:27.854
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:32:27.855
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:32:27.855
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:32:27.855
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:32:27.868
DTC Client socket (1) | Closed. | 2020-10-07 03:32:27.868
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:32:57.866
DTC Client socket (1) | Creating socket. | 2020-10-07 03:32:57.866
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:32:57.867
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:32:57.867
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:32:57.884
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:32:57.884
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:32:57.884
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:32:57.914
SC Data - All Services | Sending logon request message. | 2020-10-07 03:32:57.914
SC Data - All Services | Received logon response. | 2020-10-07 03:32:58.496
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:32:58.496
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:32:58.496
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:32:58.496
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:32:58.496
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:32:58.496
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:32:58.496
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:32:58.496
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:32:58.496
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:32:58.496
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:32:58.510
DTC Client socket (1) | Closed. | 2020-10-07 03:32:58.510
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:33:28.491
DTC Client socket (1) | Creating socket. | 2020-10-07 03:33:28.492
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:33:28.492
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:33:28.492
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:33:28.508
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:33:28.508
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:33:28.508
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:33:28.570
SC Data - All Services | Sending logon request message. | 2020-10-07 03:33:28.570
SC Data - All Services | Received logon response. | 2020-10-07 03:33:29.196
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:33:29.196
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:33:29.196
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:33:29.196
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:33:29.196
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:33:29.196
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:33:29.196
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:33:29.196
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:33:29.196
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:33:29.196
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:33:29.210
DTC Client socket (1) | Closed. | 2020-10-07 03:33:29.210
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:33:59.204
DTC Client socket (1) | Creating socket. | 2020-10-07 03:33:59.204
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:33:59.204
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:33:59.204
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:33:59.232
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:33:59.232
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:33:59.232
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:33:59.281
SC Data - All Services | Sending logon request message. | 2020-10-07 03:33:59.281
SC Data - All Services | Received logon response. | 2020-10-07 03:33:59.973
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:33:59.973
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:33:59.973
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:33:59.973
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:33:59.973
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:33:59.973
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:33:59.973
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:33:59.973
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:33:59.973
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:33:59.974
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:34:00.000
DTC Client socket (1) | Closed. | 2020-10-07 03:34:00.000
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:34:29.974
DTC Client socket (1) | Creating socket. | 2020-10-07 03:34:29.975
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:34:29.975
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:34:29.975
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:34:29.990
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:34:29.990
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:34:29.990
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:34:30.032
SC Data - All Services | Sending logon request message. | 2020-10-07 03:34:30.032
SC Data - All Services | Received logon response. | 2020-10-07 03:34:30.673
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:34:30.673
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:34:30.673
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:34:30.673
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:34:30.673
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:34:30.673
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:34:30.673
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:34:30.673
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:34:30.673
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:34:30.675
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:34:30.686
DTC Client socket (1) | Closed. | 2020-10-07 03:34:30.686
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:35:00.678
DTC Client socket (1) | Creating socket. | 2020-10-07 03:35:00.678
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:35:00.678
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:35:00.678
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:35:00.699
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:35:00.699
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:35:00.699
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:35:00.722
SC Data - All Services | Sending logon request message. | 2020-10-07 03:35:00.722
SC Data - All Services | Received logon response. | 2020-10-07 03:35:01.364
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:35:01.364
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:35:01.364
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:35:01.364
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:35:01.364
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:35:01.365
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:35:01.365
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:35:01.365
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:35:01.365
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:35:01.365
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:35:01.378
DTC Client socket (1) | Closed. | 2020-10-07 03:35:01.378
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:35:31.361
DTC Client socket (1) | Creating socket. | 2020-10-07 03:35:31.361
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:35:31.361
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:35:31.361
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:35:31.376
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:35:31.376
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:35:31.376
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:35:31.402
SC Data - All Services | Sending logon request message. | 2020-10-07 03:35:31.402
SC Data - All Services | Received logon response. | 2020-10-07 03:35:32.046
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:35:32.046
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:35:32.046
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:35:32.046
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:35:32.046
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:35:32.047
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:35:32.047
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:35:32.047
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:35:32.047
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:35:32.048
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:35:32.066
DTC Client socket (1) | Closed. | 2020-10-07 03:35:32.066
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:36:02.042
DTC Client socket (1) | Creating socket. | 2020-10-07 03:36:02.042
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:36:02.042
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:36:02.042
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:36:02.071
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:36:02.071
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:36:02.071
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:36:02.104
SC Data - All Services | Sending logon request message. | 2020-10-07 03:36:02.104
SC Data - All Services | Received logon response. | 2020-10-07 03:36:02.832
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:36:02.832
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:36:02.832
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:36:02.832
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:36:02.832
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:36:02.832
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:36:02.832
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:36:02.832
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:36:02.832
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:36:02.832
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:36:02.859
DTC Client socket (1) | Closed. | 2020-10-07 03:36:02.859
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:36:32.825
DTC Client socket (1) | Creating socket. | 2020-10-07 03:36:32.826
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:36:32.826
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:36:32.826
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:36:32.840
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:36:32.840
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:36:32.840
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:36:32.870
SC Data - All Services | Sending logon request message. | 2020-10-07 03:36:32.870
SC Data - All Services | Received logon response. | 2020-10-07 03:36:33.518
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:36:33.518
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:36:33.518
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:36:33.518
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:36:33.518
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:36:33.518
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:36:33.518
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:36:33.518
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:36:33.518
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:36:33.518
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:36:33.532
DTC Client socket (1) | Closed. | 2020-10-07 03:36:33.532
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:37:03.509
DTC Client socket (1) | Creating socket. | 2020-10-07 03:37:03.509
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:37:03.509
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:37:03.509
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:37:03.525
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:37:03.525
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:37:03.525
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:37:03.557
SC Data - All Services | Sending logon request message. | 2020-10-07 03:37:03.557
SC Data - All Services | Received logon response. | 2020-10-07 03:37:04.214
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:37:04.214
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:37:04.214
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:37:04.214
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:37:04.214
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:37:04.215
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:37:04.215
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:37:04.215
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:37:04.215
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:37:04.215
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:37:04.232
DTC Client socket (1) | Closed. | 2020-10-07 03:37:04.232
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:37:34.225
DTC Client socket (1) | Creating socket. | 2020-10-07 03:37:34.226
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:37:34.226
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:37:34.226
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:37:34.253
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:37:34.253
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:37:34.253
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:37:34.286
SC Data - All Services | Sending logon request message. | 2020-10-07 03:37:34.287
SC Data - All Services | Received logon response. | 2020-10-07 03:37:34.927
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:37:34.927
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:37:34.927
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:37:34.927
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:37:34.927
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:37:34.928
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:37:34.928
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:37:34.928
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:37:34.928
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:37:34.928
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:37:34.943
DTC Client socket (1) | Closed. | 2020-10-07 03:37:34.943
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:38:04.917
DTC Client socket (1) | Creating socket. | 2020-10-07 03:38:04.918
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:38:04.918
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:38:04.918
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:38:04.962
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:38:04.962
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:38:04.962
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:38:05.020
SC Data - All Services | Sending logon request message. | 2020-10-07 03:38:05.020
SC Data - All Services | Received logon response. | 2020-10-07 03:38:05.727
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:38:05.727
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:38:05.727
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:38:05.727
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:38:05.727
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:38:05.728
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:38:05.728
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:38:05.728
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:38:05.728
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:38:05.728
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:38:05.756
DTC Client socket (1) | Closed. | 2020-10-07 03:38:05.756
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:38:35.727
DTC Client socket (1) | Creating socket. | 2020-10-07 03:38:35.727
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:38:35.727
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:38:35.727
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:38:35.742
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:38:35.742
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:38:35.742
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:38:35.765
SC Data - All Services | Sending logon request message. | 2020-10-07 03:38:35.765
SC Data - All Services | Received logon response. | 2020-10-07 03:38:36.442
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:38:36.442
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:38:36.442
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:38:36.442
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:38:36.442
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:38:36.442
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:38:36.442
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:38:36.442
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:38:36.442
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:38:36.442
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:38:36.454
DTC Client socket (1) | Closed. | 2020-10-07 03:38:36.454
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:39:06.442
DTC Client socket (1) | Creating socket. | 2020-10-07 03:39:06.442
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:39:06.442
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:39:06.442
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:39:06.470
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:39:06.470
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:39:06.470
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:39:06.516
SC Data - All Services | Sending logon request message. | 2020-10-07 03:39:06.516
SC Data - All Services | Received logon response. | 2020-10-07 03:39:07.165
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:39:07.165
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:39:07.165
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:39:07.165
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:39:07.165
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:39:07.166
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:39:07.166
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:39:07.166
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:39:07.166
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:39:07.166
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:39:07.181
DTC Client socket (1) | Closed. | 2020-10-07 03:39:07.181
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:39:37.178
DTC Client socket (1) | Creating socket. | 2020-10-07 03:39:37.178
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:39:37.178
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:39:37.178
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:39:37.203
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:39:37.203
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:39:37.203
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:39:37.244
SC Data - All Services | Sending logon request message. | 2020-10-07 03:39:37.244
SC Data - All Services | Received logon response. | 2020-10-07 03:39:37.890
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:39:37.890
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:39:37.890
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:39:37.890
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:39:37.890
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:39:37.890
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:39:37.890
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:39:37.890
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:39:37.890
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:39:37.890
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:39:37.904
DTC Client socket (1) | Closed. | 2020-10-07 03:39:37.904
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:40:07.885
DTC Client socket (1) | Creating socket. | 2020-10-07 03:40:07.885
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:40:07.885
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:40:07.885
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:40:07.912
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:40:07.912
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:40:07.912
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:40:07.950
SC Data - All Services | Sending logon request message. | 2020-10-07 03:40:07.950
SC Data - All Services | Received logon response. | 2020-10-07 03:40:08.651
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:40:08.651
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:40:08.651
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:40:08.651
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:40:08.651
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:40:08.651
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:40:08.651
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:40:08.651
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:40:08.651
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:40:08.651
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:40:08.675
DTC Client socket (1) | Closed. | 2020-10-07 03:40:08.675
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:40:38.666
DTC Client socket (1) | Creating socket. | 2020-10-07 03:40:38.666
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:40:38.666
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:40:38.666
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:40:38.688
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:40:38.688
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:40:38.688
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:40:38.719
SC Data - All Services | Sending logon request message. | 2020-10-07 03:40:38.719
SC Data - All Services | Received logon response. | 2020-10-07 03:40:39.387
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:40:39.387
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:40:39.387
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:40:39.387
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:40:39.387
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:40:39.387
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:40:39.387
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:40:39.387
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:40:39.387
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:40:39.387
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:40:39.401
DTC Client socket (1) | Closed. | 2020-10-07 03:40:39.401
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:41:09.383
DTC Client socket (1) | Creating socket. | 2020-10-07 03:41:09.384
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:41:09.384
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:41:09.384
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:41:09.399
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:41:09.399
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:41:09.399
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:41:09.443
SC Data - All Services | Sending logon request message. | 2020-10-07 03:41:09.443
SC Data - All Services | Received logon response. | 2020-10-07 03:41:10.069
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:41:10.069
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:41:10.069
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:41:10.069
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:41:10.069
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:41:10.069
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:41:10.069
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:41:10.069
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:41:10.069
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:41:10.069
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:41:10.083
DTC Client socket (1) | Closed. | 2020-10-07 03:41:10.083
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:41:40.067
DTC Client socket (1) | Creating socket. | 2020-10-07 03:41:40.068
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:41:40.068
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:41:40.068
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:41:40.097
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:41:40.097
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:41:40.097
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:41:40.128
SC Data - All Services | Sending logon request message. | 2020-10-07 03:41:40.128
SC Data - All Services | Received logon response. | 2020-10-07 03:41:40.755
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:41:40.755
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:41:40.755
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:41:40.755
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:41:40.755
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:41:40.755
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:41:40.755
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:41:40.755
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:41:40.755
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:41:40.755
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:41:40.771
DTC Client socket (1) | Closed. | 2020-10-07 03:41:40.771
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:42:10.758
DTC Client socket (1) | Creating socket. | 2020-10-07 03:42:10.759
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:42:10.759
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:42:10.759
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:42:10.786
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:42:10.786
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:42:10.786
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:42:10.836
SC Data - All Services | Sending logon request message. | 2020-10-07 03:42:10.837
SC Data - All Services | Received logon response. | 2020-10-07 03:42:11.533
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:42:11.533
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:42:11.533
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:42:11.533
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:42:11.533
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:42:11.533
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:42:11.533
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:42:11.533
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:42:11.533
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:42:11.533
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:42:11.560
DTC Client socket (1) | Closed. | 2020-10-07 03:42:11.560
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1216 seconds. | 2020-10-07 03:42:27.235
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0381 seconds. | 2020-10-07 03:42:27.275
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:42:41.536
DTC Client socket (1) | Creating socket. | 2020-10-07 03:42:41.537
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:42:41.537
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:42:41.537
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:42:41.563
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:42:41.563
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:42:41.563
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:42:41.605
SC Data - All Services | Sending logon request message. | 2020-10-07 03:42:41.605
SC Data - All Services | Received logon response. | 2020-10-07 03:42:42.287
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:42:42.287
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:42:42.287
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:42:42.287
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:42:42.287
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:42:42.287
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:42:42.287
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:42:42.287
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:42:42.287
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:42:42.287
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:42:42.299
DTC Client socket (1) | Closed. | 2020-10-07 03:42:42.299
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:43:12.276
DTC Client socket (1) | Creating socket. | 2020-10-07 03:43:12.276
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:43:12.276
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:43:12.276
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:43:12.308
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:43:12.308
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:43:12.308
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:43:12.345
SC Data - All Services | Sending logon request message. | 2020-10-07 03:43:12.346
SC Data - All Services | Received logon response. | 2020-10-07 03:43:12.472
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:43:12.472
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:43:12.472
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:43:12.472
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:43:12.472
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:43:12.472
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:43:12.472
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:43:12.472
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:43:12.472
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:43:12.472
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:43:12.483
DTC Client socket (1) | Closed. | 2020-10-07 03:43:12.483
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:43:42.468
DTC Client socket (1) | Creating socket. | 2020-10-07 03:43:42.468
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:43:42.468
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:43:42.468
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:43:42.484
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:43:42.484
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:43:42.484
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:43:42.529
SC Data - All Services | Sending logon request message. | 2020-10-07 03:43:42.529
SC Data - All Services | Received logon response. | 2020-10-07 03:43:43.178
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:43:43.178
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:43:43.178
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:43:43.178
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:43:43.178
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:43:43.178
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:43:43.178
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:43:43.178
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:43:43.178
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:43:43.178
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:43:43.193
DTC Client socket (1) | Closed. | 2020-10-07 03:43:43.193
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:44:13.177
DTC Client socket (1) | Creating socket. | 2020-10-07 03:44:13.177
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:44:13.177
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:44:13.177
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:44:13.204
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:44:13.204
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:44:13.204
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:44:13.254
SC Data - All Services | Sending logon request message. | 2020-10-07 03:44:13.254
SC Data - All Services | Received logon response. | 2020-10-07 03:44:13.962
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:44:13.962
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:44:13.962
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:44:13.962
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:44:13.962
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:44:13.962
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:44:13.962
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:44:13.962
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:44:13.962
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:44:13.962
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:44:13.989
DTC Client socket (1) | Closed. | 2020-10-07 03:44:13.989
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:44:43.961
DTC Client socket (1) | Creating socket. | 2020-10-07 03:44:43.962
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:44:43.962
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:44:43.962
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:44:43.989
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:44:43.989
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:44:43.989
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:44:44.049
SC Data - All Services | Sending logon request message. | 2020-10-07 03:44:44.049
SC Data - All Services | Received logon response. | 2020-10-07 03:44:44.711
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:44:44.711
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:44:44.711
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:44:44.711
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:44:44.711
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:44:44.711
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:44:44.711
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:44:44.711
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:44:44.711
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:44:44.711
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:44:44.728
DTC Client socket (1) | Closed. | 2020-10-07 03:44:44.728
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:45:14.726
DTC Client socket (1) | Creating socket. | 2020-10-07 03:45:14.726
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:45:14.726
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:45:14.726
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:45:14.741
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:45:14.741
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:45:14.741
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:45:14.781
SC Data - All Services | Sending logon request message. | 2020-10-07 03:45:14.781
SC Data - All Services | Received logon response. | 2020-10-07 03:45:15.431
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:45:15.431
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:45:15.431
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:45:15.431
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:45:15.431
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:45:15.432
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:45:15.432
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:45:15.432
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:45:15.432
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:45:15.432
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:45:15.446
DTC Client socket (1) | Closed. | 2020-10-07 03:45:15.446
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:45:45.442
DTC Client socket (1) | Creating socket. | 2020-10-07 03:45:45.442
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:45:45.442
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:45:45.442
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:45:45.457
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:45:45.457
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:45:45.457
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:45:45.474
SC Data - All Services | Sending logon request message. | 2020-10-07 03:45:45.474
SC Data - All Services | Received logon response. | 2020-10-07 03:45:46.118
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:45:46.118
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:45:46.118
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:45:46.118
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:45:46.118
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:45:46.118
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:45:46.118
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:45:46.118
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:45:46.118
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:45:46.118
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:45:46.130
DTC Client socket (1) | Closed. | 2020-10-07 03:45:46.130
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:46:16.122
DTC Client socket (1) | Creating socket. | 2020-10-07 03:46:16.122
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:46:16.122
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:46:16.122
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:46:16.162
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:46:16.162
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:46:16.162
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:46:16.227
SC Data - All Services | Sending logon request message. | 2020-10-07 03:46:16.227
SC Data - All Services | Received logon response. | 2020-10-07 03:46:16.896
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:46:16.896
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:46:16.896
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:46:16.896
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:46:16.896
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:46:16.896
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:46:16.896
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:46:16.896
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:46:16.896
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:46:16.896
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:46:17.062
DTC Client socket (1) | Closed. | 2020-10-07 03:46:17.062
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:46:46.891
DTC Client socket (1) | Creating socket. | 2020-10-07 03:46:46.891
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:46:46.891
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:46:46.891
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:46:46.913
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:46:46.913
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:46:46.913
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:46:46.929
SC Data - All Services | Sending logon request message. | 2020-10-07 03:46:46.929
SC Data - All Services | Received logon response. | 2020-10-07 03:46:47.557
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:46:47.557
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:46:47.557
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:46:47.557
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:46:47.557
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:46:47.557
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:46:47.557
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:46:47.557
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:46:47.557
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:46:47.557
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:46:47.572
DTC Client socket (1) | Closed. | 2020-10-07 03:46:47.572
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:47:17.555
DTC Client socket (1) | Creating socket. | 2020-10-07 03:47:17.555
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:47:17.555
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:47:17.555
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:47:17.581
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:47:17.581
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:47:17.581
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:47:17.618
SC Data - All Services | Sending logon request message. | 2020-10-07 03:47:17.619
SC Data - All Services | Received logon response. | 2020-10-07 03:47:18.218
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:47:18.218
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:47:18.218
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:47:18.218
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:47:18.218
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:47:18.218
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:47:18.218
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:47:18.218
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:47:18.218
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:47:18.218
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:47:18.236
DTC Client socket (1) | Closed. | 2020-10-07 03:47:18.236
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:47:48.223
DTC Client socket (1) | Creating socket. | 2020-10-07 03:47:48.224
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:47:48.224
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:47:48.224
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:47:48.253
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:47:48.253
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:47:48.253
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:47:48.277
SC Data - All Services | Sending logon request message. | 2020-10-07 03:47:48.277
SC Data - All Services | Received logon response. | 2020-10-07 03:47:48.907
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:47:48.907
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:47:48.907
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:47:48.907
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:47:48.907
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:47:48.907
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:47:48.907
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:47:48.907
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:47:48.907
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:47:48.907
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:47:48.922
DTC Client socket (1) | Closed. | 2020-10-07 03:47:48.922
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:48:18.901
DTC Client socket (1) | Creating socket. | 2020-10-07 03:48:18.902
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:48:18.902
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:48:18.902
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:48:18.932
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:48:18.932
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:48:18.932
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:48:18.991
SC Data - All Services | Sending logon request message. | 2020-10-07 03:48:18.991
SC Data - All Services | Received logon response. | 2020-10-07 03:48:19.676
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:48:19.676
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:48:19.676
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:48:19.676
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:48:19.676
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:48:19.676
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:48:19.676
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:48:19.676
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:48:19.676
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:48:19.676
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:48:19.700
DTC Client socket (1) | Closed. | 2020-10-07 03:48:19.700
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:48:49.665
DTC Client socket (1) | Creating socket. | 2020-10-07 03:48:49.666
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:48:49.666
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:48:49.666
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:48:49.692
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:48:49.692
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:48:49.692
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:48:49.720
SC Data - All Services | Sending logon request message. | 2020-10-07 03:48:49.720
SC Data - All Services | Received logon response. | 2020-10-07 03:48:50.359
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:48:50.359
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:48:50.359
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:48:50.359
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:48:50.359
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:48:50.359
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:48:50.359
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:48:50.359
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:48:50.359
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:48:50.359
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:48:50.378
DTC Client socket (1) | Closed. | 2020-10-07 03:48:50.378
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:49:20.360
DTC Client socket (1) | Creating socket. | 2020-10-07 03:49:20.360
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:49:20.361
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:49:20.361
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:49:20.393
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:49:20.393
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:49:20.393
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:49:20.419
SC Data - All Services | Sending logon request message. | 2020-10-07 03:49:20.419
SC Data - All Services | Received logon response. | 2020-10-07 03:49:21.045
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:49:21.045
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:49:21.045
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:49:21.045
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:49:21.045
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:49:21.045
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:49:21.045
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:49:21.045
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:49:21.045
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:49:21.045
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:49:21.059
DTC Client socket (1) | Closed. | 2020-10-07 03:49:21.059
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:49:51.046
DTC Client socket (1) | Creating socket. | 2020-10-07 03:49:51.046
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:49:51.046
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:49:51.046
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:49:51.079
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:49:51.079
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:49:51.079
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:49:51.117
SC Data - All Services | Sending logon request message. | 2020-10-07 03:49:51.117
SC Data - All Services | Received logon response. | 2020-10-07 03:49:51.758
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:49:51.758
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:49:51.758
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:49:51.758
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:49:51.758
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:49:51.759
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:49:51.759
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:49:51.759
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:49:51.759
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:49:51.759
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:49:51.772
DTC Client socket (1) | Closed. | 2020-10-07 03:49:51.772
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:50:21.763
DTC Client socket (1) | Creating socket. | 2020-10-07 03:50:21.763
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:50:21.764
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:50:21.764
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:50:21.793
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:50:21.793
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:50:21.793
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:50:21.863
SC Data - All Services | Sending logon request message. | 2020-10-07 03:50:21.863
SC Data - All Services | Received logon response. | 2020-10-07 03:50:22.518
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:50:22.518
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:50:22.518
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:50:22.519
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:50:22.519
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:50:22.519
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:50:22.519
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:50:22.519
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:50:22.519
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:50:22.519
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:50:22.543
DTC Client socket (1) | Closed. | 2020-10-07 03:50:22.543
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:50:52.511
DTC Client socket (1) | Creating socket. | 2020-10-07 03:50:52.511
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:50:52.511
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:50:52.511
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:50:52.525
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:50:52.525
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:50:52.525
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:50:52.570
SC Data - All Services | Sending logon request message. | 2020-10-07 03:50:52.570
SC Data - All Services | Received logon response. | 2020-10-07 03:50:53.245
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:50:53.245
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:50:53.245
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:50:53.245
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:50:53.245
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:50:53.245
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:50:53.245
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:50:53.245
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:50:53.245
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:50:53.245
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:50:53.262
DTC Client socket (1) | Closed. | 2020-10-07 03:50:53.262
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:51:23.254
DTC Client socket (1) | Creating socket. | 2020-10-07 03:51:23.255
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:51:23.255
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:51:23.255
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:51:23.269
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:51:23.269
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:51:23.269
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:51:23.302
SC Data - All Services | Sending logon request message. | 2020-10-07 03:51:23.302
SC Data - All Services | Received logon response. | 2020-10-07 03:51:23.897
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:51:23.897
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:51:23.897
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:51:23.897
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:51:23.897
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:51:23.897
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:51:23.897
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:51:23.897
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:51:23.897
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:51:23.897
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:51:23.910
DTC Client socket (1) | Closed. | 2020-10-07 03:51:23.910
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:51:53.897
DTC Client socket (1) | Creating socket. | 2020-10-07 03:51:53.903
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:51:53.903
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:51:53.903
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:51:53.923
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:51:53.923
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:51:53.924
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:51:53.969
SC Data - All Services | Sending logon request message. | 2020-10-07 03:51:53.969
SC Data - All Services | Received logon response. | 2020-10-07 03:51:54.590
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:51:54.590
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:51:54.590
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:51:54.590
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:51:54.590
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:51:54.591
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:51:54.591
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:51:54.591
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:51:54.591
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:51:54.591
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:51:54.606
DTC Client socket (1) | Closed. | 2020-10-07 03:51:54.606
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:52:24.596
DTC Client socket (1) | Creating socket. | 2020-10-07 03:52:24.597
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:52:24.597
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:52:24.597
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:52:24.628
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:52:24.628
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:52:24.628
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:52:24.665
SC Data - All Services | Sending logon request message. | 2020-10-07 03:52:24.665
SC Data - All Services | Received logon response. | 2020-10-07 03:52:25.328
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:52:25.328
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:52:25.328
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:52:25.328
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:52:25.328
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:52:25.329
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:52:25.329
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:52:25.329
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:52:25.329
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:52:25.329
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:52:25.355
DTC Client socket (1) | Closed. | 2020-10-07 03:52:25.355
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:52:55.320
DTC Client socket (1) | Creating socket. | 2020-10-07 03:52:55.320
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:52:55.320
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:52:55.320
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:52:55.344
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:52:55.344
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:52:55.344
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:52:55.374
SC Data - All Services | Sending logon request message. | 2020-10-07 03:52:55.374
SC Data - All Services | Received logon response. | 2020-10-07 03:52:56.065
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:52:56.065
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:52:56.065
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:52:56.065
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:52:56.065
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:52:56.065
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:52:56.065
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:52:56.065
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:52:56.065
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:52:56.065
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:52:56.078
DTC Client socket (1) | Closed. | 2020-10-07 03:52:56.078
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:53:26.057
DTC Client socket (1) | Creating socket. | 2020-10-07 03:53:26.058
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:53:26.058
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:53:26.058
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:53:26.086
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:53:26.086
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:53:26.086
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:53:26.125
SC Data - All Services | Sending logon request message. | 2020-10-07 03:53:26.125
SC Data - All Services | Received logon response. | 2020-10-07 03:53:26.769
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:53:26.769
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:53:26.769
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:53:26.769
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:53:26.769
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:53:26.769
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:53:26.769
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:53:26.769
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:53:26.769
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:53:26.769
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:53:26.786
DTC Client socket (1) | Closed. | 2020-10-07 03:53:26.786
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:53:56.772
DTC Client socket (1) | Creating socket. | 2020-10-07 03:53:56.772
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:53:56.772
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:53:56.772
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:53:56.793
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:53:56.793
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:53:56.793
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:53:56.811
SC Data - All Services | Sending logon request message. | 2020-10-07 03:53:56.811
SC Data - All Services | Received logon response. | 2020-10-07 03:53:57.440
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:53:57.440
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:53:57.440
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:53:57.440
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:53:57.440
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:53:57.440
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:53:57.440
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:53:57.440
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:53:57.440
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:53:57.440
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:53:57.454
DTC Client socket (1) | Closed. | 2020-10-07 03:53:57.454
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:54:27.430
DTC Client socket (1) | Creating socket. | 2020-10-07 03:54:27.431
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:54:27.431
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:54:27.431
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:54:27.461
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:54:27.461
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:54:27.461
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:54:27.496
SC Data - All Services | Sending logon request message. | 2020-10-07 03:54:27.496
SC Data - All Services | Received logon response. | 2020-10-07 03:54:28.168
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:54:28.168
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:54:28.168
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:54:28.168
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:54:28.168
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:54:28.168
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:54:28.168
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:54:28.168
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:54:28.168
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:54:28.168
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:54:28.192
DTC Client socket (1) | Closed. | 2020-10-07 03:54:28.192
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:54:58.164
DTC Client socket (1) | Creating socket. | 2020-10-07 03:54:58.164
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:54:58.164
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:54:58.164
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:54:58.179
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:54:58.179
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:54:58.179
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:54:58.211
SC Data - All Services | Sending logon request message. | 2020-10-07 03:54:58.211
SC Data - All Services | Received logon response. | 2020-10-07 03:54:58.866
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:54:58.866
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:54:58.866
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:54:58.866
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:54:58.866
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:54:58.867
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:54:58.867
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:54:58.867
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:54:58.867
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:54:58.867
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:54:58.884
DTC Client socket (1) | Closed. | 2020-10-07 03:54:58.884
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:55:28.871
DTC Client socket (1) | Creating socket. | 2020-10-07 03:55:28.871
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:55:28.871
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:55:28.871
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:55:28.886
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:55:28.886
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:55:28.886
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:55:28.918
SC Data - All Services | Sending logon request message. | 2020-10-07 03:55:28.918
SC Data - All Services | Received logon response. | 2020-10-07 03:55:29.501
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:55:29.501
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:55:29.501
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:55:29.501
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:55:29.501
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:55:29.501
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:55:29.501
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:55:29.501
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:55:29.501
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:55:29.501
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:55:29.514
DTC Client socket (1) | Closed. | 2020-10-07 03:55:29.514
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:55:59.495
DTC Client socket (1) | Creating socket. | 2020-10-07 03:55:59.496
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:55:59.496
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:55:59.496
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:55:59.517
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:55:59.517
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:55:59.517
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:55:59.556
SC Data - All Services | Sending logon request message. | 2020-10-07 03:55:59.556
SC Data - All Services | Received logon response. | 2020-10-07 03:56:00.183
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:56:00.183
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:56:00.183
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:56:00.183
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:56:00.183
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:56:00.183
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:56:00.183
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:56:00.183
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:56:00.183
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:56:00.183
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:56:00.196
DTC Client socket (1) | Closed. | 2020-10-07 03:56:00.196
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:56:30.190
DTC Client socket (1) | Creating socket. | 2020-10-07 03:56:30.191
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:56:30.191
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:56:30.191
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:56:30.221
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:56:30.221
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:56:30.221
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:56:30.267
SC Data - All Services | Sending logon request message. | 2020-10-07 03:56:30.267
SC Data - All Services | Received logon response. | 2020-10-07 03:56:30.919
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:56:30.919
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:56:30.919
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:56:30.919
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:56:30.919
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:56:30.920
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:56:30.920
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:56:30.920
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:56:30.920
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:56:30.920
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:56:30.951
DTC Client socket (1) | Closed. | 2020-10-07 03:56:30.951
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:57:00.924
DTC Client socket (1) | Creating socket. | 2020-10-07 03:57:00.925
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:57:00.925
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:57:00.925
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:57:00.956
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:57:00.956
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:57:00.956
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:57:00.979
SC Data - All Services | Sending logon request message. | 2020-10-07 03:57:00.979
SC Data - All Services | Received logon response. | 2020-10-07 03:57:01.647
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:57:01.647
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:57:01.647
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:57:01.647
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:57:01.647
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:57:01.649
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:57:01.649
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:57:01.649
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:57:01.649
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:57:01.649
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:57:01.663
DTC Client socket (1) | Closed. | 2020-10-07 03:57:01.663
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.0905 seconds. | 2020-10-07 03:57:27.369
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0344 seconds. | 2020-10-07 03:57:27.404
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:57:31.651
DTC Client socket (1) | Creating socket. | 2020-10-07 03:57:31.651
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:57:31.651
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:57:31.651
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:57:31.666
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:57:31.666
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:57:31.666
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:57:31.694
SC Data - All Services | Sending logon request message. | 2020-10-07 03:57:31.694
SC Data - All Services | Received logon response. | 2020-10-07 03:57:32.271
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:57:32.271
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:57:32.271
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:57:32.271
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:57:32.271
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:57:32.271
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:57:32.271
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:57:32.271
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:57:32.271
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:57:32.271
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:57:32.284
DTC Client socket (1) | Closed. | 2020-10-07 03:57:32.284
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 03:58:02.272
DTC Client socket (1) | Creating socket. | 2020-10-07 03:58:02.272
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:58:02.273
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 03:58:02.273
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:58:02.305
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:58:02.305
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:58:02.305
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:58:02.326
SC Data - All Services | Sending logon request message. | 2020-10-07 03:58:02.326
SC Data - All Services | Received logon response. | 2020-10-07 03:58:02.953
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:58:02.953
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:58:02.953
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:58:02.953
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:58:02.953
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:58:02.953
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:58:02.953
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:58:02.953
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:58:02.953
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:58:02.953
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:58:02.973
DTC Client socket (1) | Closed. | 2020-10-07 03:58:02.973
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 03:58:32.947
DTC Client socket (1) | Creating socket. | 2020-10-07 03:58:32.948
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:58:32.948
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 03:58:32.948
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:58:32.977
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:58:32.977
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:58:32.977
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:58:33.006
SC Data - All Services | Sending logon request message. | 2020-10-07 03:58:33.006
SC Data - All Services | Received logon response. | 2020-10-07 03:58:33.725
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:58:33.725
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:58:33.725
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:58:33.725
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:58:33.725
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:58:33.726
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:58:33.726
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:58:33.726
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:58:33.726
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:58:33.726
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:58:33.752
DTC Client socket (1) | Closed. | 2020-10-07 03:58:33.752
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 03:59:03.717
DTC Client socket (1) | Creating socket. | 2020-10-07 03:59:03.717
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:59:03.718
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 03:59:03.718
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:59:03.732
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:59:03.732
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:59:03.732
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:59:03.755
SC Data - All Services | Sending logon request message. | 2020-10-07 03:59:03.755
SC Data - All Services | Received logon response. | 2020-10-07 03:59:04.379
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:59:04.379
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:59:04.379
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:59:04.379
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:59:04.379
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:59:04.379
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:59:04.379
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:59:04.379
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:59:04.379
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:59:04.379
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:59:04.394
DTC Client socket (1) | Closed. | 2020-10-07 03:59:04.395
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 03:59:34.368
DTC Client socket (1) | Creating socket. | 2020-10-07 03:59:34.368
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 03:59:34.369
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 03:59:34.369
SC Data - All Services | Network connection to server complete. | 2020-10-07 03:59:34.393
SC Data - All Services | Starting socket receive thread. | 2020-10-07 03:59:34.393
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 03:59:34.393
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 03:59:34.424
SC Data - All Services | Sending logon request message. | 2020-10-07 03:59:34.424
SC Data - All Services | Received logon response. | 2020-10-07 03:59:35.052
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 03:59:35.052
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 03:59:35.052
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 03:59:35.052
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 03:59:35.052
DTC Client socket (1) | CloseSocket call. | 2020-10-07 03:59:35.052
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 03:59:35.052
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 03:59:35.052
SC Data - All Services | Disconnected from the server. | 2020-10-07 03:59:35.052
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 03:59:35.052
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 03:59:35.068
DTC Client socket (1) | Closed. | 2020-10-07 03:59:35.068
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:00:05.043
DTC Client socket (1) | Creating socket. | 2020-10-07 04:00:05.044
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:00:05.044
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:00:05.044
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:00:05.067
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:00:05.067
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:00:05.067
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:00:05.103
SC Data - All Services | Sending logon request message. | 2020-10-07 04:00:05.103
SC Data - All Services | Received logon response. | 2020-10-07 04:00:05.745
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:00:05.745
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:00:05.745
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:00:05.745
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:00:05.745
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:00:05.745
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:00:05.745
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:00:05.745
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:00:05.745
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:00:05.745
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:00:05.758
DTC Client socket (1) | Closed. | 2020-10-07 04:00:05.758
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:00:35.744
DTC Client socket (1) | Creating socket. | 2020-10-07 04:00:35.744
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:00:35.744
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:00:35.744
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:00:35.770
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:00:35.770
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:00:35.770
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:00:35.819
SC Data - All Services | Sending logon request message. | 2020-10-07 04:00:35.819
SC Data - All Services | Received logon response. | 2020-10-07 04:00:36.554
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:00:36.554
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:00:36.554
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:00:36.554
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:00:36.554
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:00:36.554
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:00:36.554
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:00:36.554
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:00:36.554
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:00:36.555
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:00:36.582
DTC Client socket (1) | Closed. | 2020-10-07 04:00:36.582
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:01:06.555
DTC Client socket (1) | Creating socket. | 2020-10-07 04:01:06.555
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:01:06.555
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:01:06.555
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:01:06.573
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:01:06.573
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:01:06.573
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:01:06.598
SC Data - All Services | Sending logon request message. | 2020-10-07 04:01:06.598
SC Data - All Services | Received logon response. | 2020-10-07 04:01:07.230
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:01:07.230
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:01:07.230
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:01:07.230
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:01:07.230
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:01:07.230
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:01:07.230
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:01:07.230
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:01:07.230
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:01:07.230
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:01:07.245
DTC Client socket (1) | Closed. | 2020-10-07 04:01:07.245
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:01:37.237
DTC Client socket (1) | Creating socket. | 2020-10-07 04:01:37.238
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:01:37.238
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:01:37.238
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:01:37.261
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:01:37.261
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:01:37.261
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:01:37.294
SC Data - All Services | Sending logon request message. | 2020-10-07 04:01:37.294
SC Data - All Services | Received logon response. | 2020-10-07 04:01:37.891
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:01:37.891
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:01:37.891
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:01:37.891
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:01:37.891
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:01:37.891
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:01:37.891
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:01:37.891
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:01:37.891
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:01:37.891
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:01:37.904
DTC Client socket (1) | Closed. | 2020-10-07 04:01:37.904
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:02:07.884
DTC Client socket (1) | Creating socket. | 2020-10-07 04:02:07.885
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:02:07.885
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:02:07.885
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:02:07.914
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:02:07.914
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:02:07.914
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:02:07.946
SC Data - All Services | Sending logon request message. | 2020-10-07 04:02:07.946
SC Data - All Services | Received logon response. | 2020-10-07 04:02:08.577
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:02:08.577
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:02:08.577
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:02:08.577
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:02:08.577
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:02:08.577
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:02:08.577
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:02:08.577
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:02:08.577
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:02:08.577
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:02:08.590
DTC Client socket (1) | Closed. | 2020-10-07 04:02:08.590
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:02:38.576
DTC Client socket (1) | Creating socket. | 2020-10-07 04:02:38.576
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:02:38.576
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:02:38.576
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:02:38.608
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:02:38.608
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:02:38.608
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:02:38.650
SC Data - All Services | Sending logon request message. | 2020-10-07 04:02:38.650
SC Data - All Services | Received logon response. | 2020-10-07 04:02:39.335
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:02:39.335
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:02:39.335
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:02:39.335
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:02:39.335
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:02:39.336
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:02:39.336
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:02:39.336
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:02:39.336
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:02:39.336
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:02:39.363
DTC Client socket (1) | Closed. | 2020-10-07 04:02:39.363
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:03:09.337
DTC Client socket (1) | Creating socket. | 2020-10-07 04:03:09.337
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:03:09.337
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:03:09.337
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:03:09.369
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:03:09.369
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:03:09.370
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:03:09.413
SC Data - All Services | Sending logon request message. | 2020-10-07 04:03:09.413
SC Data - All Services | Received logon response. | 2020-10-07 04:03:10.067
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:03:10.067
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:03:10.067
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:03:10.067
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:03:10.067
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:03:10.067
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:03:10.067
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:03:10.067
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:03:10.067
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:03:10.067
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:03:10.080
DTC Client socket (1) | Closed. | 2020-10-07 04:03:10.080
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:03:40.057
DTC Client socket (1) | Creating socket. | 2020-10-07 04:03:40.057
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:03:40.057
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:03:40.057
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:03:40.088
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:03:40.088
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:03:40.088
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:03:40.111
SC Data - All Services | Sending logon request message. | 2020-10-07 04:03:40.111
SC Data - All Services | Received logon response. | 2020-10-07 04:03:40.706
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:03:40.706
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:03:40.706
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:03:40.706
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:03:40.706
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:03:40.706
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:03:40.706
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:03:40.707
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:03:40.707
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:03:40.707
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:03:40.719
DTC Client socket (1) | Closed. | 2020-10-07 04:03:40.719
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:04:10.703
DTC Client socket (1) | Creating socket. | 2020-10-07 04:04:10.704
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:04:10.704
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:04:10.704
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:04:10.725
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:04:10.725
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:04:10.725
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:04:10.739
SC Data - All Services | Sending logon request message. | 2020-10-07 04:04:10.739
SC Data - All Services | Received logon response. | 2020-10-07 04:04:11.385
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:04:11.385
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:04:11.385
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:04:11.385
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:04:11.386
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:04:11.386
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:04:11.386
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:04:11.386
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:04:11.386
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:04:11.386
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:04:11.404
DTC Client socket (1) | Closed. | 2020-10-07 04:04:11.404
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:04:41.387
DTC Client socket (1) | Creating socket. | 2020-10-07 04:04:41.387
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:04:41.387
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:04:41.387
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:04:41.417
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:04:41.417
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:04:41.417
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:04:41.457
SC Data - All Services | Sending logon request message. | 2020-10-07 04:04:41.457
SC Data - All Services | Received logon response. | 2020-10-07 04:04:42.149
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:04:42.149
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:04:42.149
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:04:42.149
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:04:42.149
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:04:42.149
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:04:42.149
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:04:42.150
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:04:42.150
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:04:42.150
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:04:42.176
DTC Client socket (1) | Closed. | 2020-10-07 04:04:42.176
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:05:12.158
DTC Client socket (1) | Creating socket. | 2020-10-07 04:05:12.158
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:05:12.158
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:05:12.158
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:05:12.186
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:05:12.186
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:05:12.186
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:05:12.227
SC Data - All Services | Sending logon request message. | 2020-10-07 04:05:12.227
SC Data - All Services | Received logon response. | 2020-10-07 04:05:12.886
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:05:12.886
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:05:12.886
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:05:12.886
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:05:12.886
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:05:12.886
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:05:12.886
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:05:12.886
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:05:12.886
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:05:12.886
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:05:12.900
DTC Client socket (1) | Closed. | 2020-10-07 04:05:12.900
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:05:42.886
DTC Client socket (1) | Creating socket. | 2020-10-07 04:05:42.887
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:05:42.887
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:05:42.887
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:05:42.915
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:05:42.915
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:05:42.915
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:05:42.940
SC Data - All Services | Sending logon request message. | 2020-10-07 04:05:42.940
SC Data - All Services | Received logon response. | 2020-10-07 04:05:43.536
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:05:43.536
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:05:43.536
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:05:43.536
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:05:43.536
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:05:43.536
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:05:43.536
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:05:43.536
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:05:43.536
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:05:43.536
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:05:43.555
DTC Client socket (1) | Closed. | 2020-10-07 04:05:43.555
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:06:13.537
DTC Client socket (1) | Creating socket. | 2020-10-07 04:06:13.538
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:06:13.538
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:06:13.538
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:06:13.559
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:06:13.559
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:06:13.559
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:06:13.598
SC Data - All Services | Sending logon request message. | 2020-10-07 04:06:13.598
SC Data - All Services | Received logon response. | 2020-10-07 04:06:14.239
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:06:14.239
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:06:14.239
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:06:14.239
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:06:14.239
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:06:14.240
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:06:14.240
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:06:14.240
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:06:14.240
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:06:14.240
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:06:14.256
DTC Client socket (1) | Closed. | 2020-10-07 04:06:14.256
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:06:44.236
DTC Client socket (1) | Creating socket. | 2020-10-07 04:06:44.236
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:06:44.236
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:06:44.237
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:06:44.265
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:06:44.265
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:06:44.265
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:06:44.324
SC Data - All Services | Sending logon request message. | 2020-10-07 04:06:44.324
SC Data - All Services | Received logon response. | 2020-10-07 04:06:45.074
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:06:45.074
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:06:45.074
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:06:45.074
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:06:45.074
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:06:45.074
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:06:45.074
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:06:45.074
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:06:45.074
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:06:45.074
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:06:45.099
DTC Client socket (1) | Closed. | 2020-10-07 04:06:45.099
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:07:15.083
DTC Client socket (1) | Creating socket. | 2020-10-07 04:07:15.083
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:07:15.083
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:07:15.083
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:07:15.107
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:07:15.107
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:07:15.107
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:07:15.162
SC Data - All Services | Sending logon request message. | 2020-10-07 04:07:15.162
SC Data - All Services | Received logon response. | 2020-10-07 04:07:15.815
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:07:15.815
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:07:15.815
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:07:15.815
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:07:15.815
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:07:15.815
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:07:15.815
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:07:15.815
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:07:15.815
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:07:15.815
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:07:15.830
DTC Client socket (1) | Closed. | 2020-10-07 04:07:15.830
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:07:45.809
DTC Client socket (1) | Creating socket. | 2020-10-07 04:07:45.810
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:07:45.810
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:07:45.810
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:07:45.825
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:07:45.825
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:07:45.825
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:07:45.865
SC Data - All Services | Sending logon request message. | 2020-10-07 04:07:45.865
SC Data - All Services | Received logon response. | 2020-10-07 04:07:46.466
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:07:46.466
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:07:46.466
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:07:46.466
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:07:46.466
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:07:46.466
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:07:46.466
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:07:46.467
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:07:46.467
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:07:46.467
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:07:46.480
DTC Client socket (1) | Closed. | 2020-10-07 04:07:46.480
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:08:16.461
DTC Client socket (1) | Creating socket. | 2020-10-07 04:08:16.462
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:08:16.462
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:08:16.462
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:08:16.484
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:08:16.484
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:08:16.484
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:08:16.523
SC Data - All Services | Sending logon request message. | 2020-10-07 04:08:16.523
SC Data - All Services | Received logon response. | 2020-10-07 04:08:17.154
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:08:17.154
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:08:17.154
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:08:17.154
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:08:17.154
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:08:17.154
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:08:17.154
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:08:17.155
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:08:17.155
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:08:17.155
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:08:17.168
DTC Client socket (1) | Closed. | 2020-10-07 04:08:17.168
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:08:47.156
DTC Client socket (1) | Creating socket. | 2020-10-07 04:08:47.157
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:08:47.157
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:08:47.157
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:08:47.185
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:08:47.185
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:08:47.186
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:08:47.245
SC Data - All Services | Sending logon request message. | 2020-10-07 04:08:47.245
SC Data - All Services | Received logon response. | 2020-10-07 04:08:47.947
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:08:47.947
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:08:47.947
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:08:47.947
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:08:47.947
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:08:47.947
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:08:47.947
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:08:47.947
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:08:47.947
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:08:47.947
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:08:47.972
DTC Client socket (1) | Closed. | 2020-10-07 04:08:47.972
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:09:17.949
DTC Client socket (1) | Creating socket. | 2020-10-07 04:09:17.949
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:09:17.949
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:09:17.949
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:09:17.963
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:09:17.963
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:09:17.963
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:09:18.003
SC Data - All Services | Sending logon request message. | 2020-10-07 04:09:18.003
SC Data - All Services | Received logon response. | 2020-10-07 04:09:18.668
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:09:18.668
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:09:18.668
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:09:18.668
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:09:18.668
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:09:18.668
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:09:18.668
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:09:18.668
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:09:18.668
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:09:18.668
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:09:18.680
DTC Client socket (1) | Closed. | 2020-10-07 04:09:18.680
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:09:48.671
DTC Client socket (1) | Creating socket. | 2020-10-07 04:09:48.671
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:09:48.671
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:09:48.671
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:09:48.686
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:09:48.686
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:09:48.687
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:09:48.709
SC Data - All Services | Sending logon request message. | 2020-10-07 04:09:48.709
SC Data - All Services | Received logon response. | 2020-10-07 04:09:49.297
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:09:49.297
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:09:49.297
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:09:49.297
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:09:49.297
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:09:49.297
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:09:49.297
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:09:49.297
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:09:49.297
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:09:49.297
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:09:49.310
DTC Client socket (1) | Closed. | 2020-10-07 04:09:49.310
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:10:19.302
DTC Client socket (1) | Creating socket. | 2020-10-07 04:10:19.302
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:10:19.302
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:10:19.302
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:10:19.332
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:10:19.332
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:10:19.332
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:10:19.372
SC Data - All Services | Sending logon request message. | 2020-10-07 04:10:19.372
SC Data - All Services | Received logon response. | 2020-10-07 04:10:19.967
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:10:19.967
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:10:19.967
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:10:19.967
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:10:19.967
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:10:19.968
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:10:19.968
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:10:19.968
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:10:19.968
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:10:19.968
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:10:19.982
DTC Client socket (1) | Closed. | 2020-10-07 04:10:19.982
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:10:49.966
DTC Client socket (1) | Creating socket. | 2020-10-07 04:10:49.967
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:10:49.967
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:10:49.967
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:10:49.995
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:10:49.995
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:10:49.995
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:10:50.041
SC Data - All Services | Sending logon request message. | 2020-10-07 04:10:50.041
SC Data - All Services | Received logon response. | 2020-10-07 04:10:50.760
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:10:50.760
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:10:50.760
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:10:50.760
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:10:50.760
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:10:50.761
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:10:50.761
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:10:50.761
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:10:50.761
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:10:50.761
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:10:50.787
DTC Client socket (1) | Closed. | 2020-10-07 04:10:50.787
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:11:20.764
DTC Client socket (1) | Creating socket. | 2020-10-07 04:11:20.765
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:11:20.765
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:11:20.765
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:11:20.785
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:11:20.785
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:11:20.785
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:11:20.818
SC Data - All Services | Sending logon request message. | 2020-10-07 04:11:20.818
SC Data - All Services | Received logon response. | 2020-10-07 04:11:21.485
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:11:21.485
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:11:21.485
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:11:21.485
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:11:21.485
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:11:21.485
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:11:21.485
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:11:21.485
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:11:21.485
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:11:21.485
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:11:21.500
DTC Client socket (1) | Closed. | 2020-10-07 04:11:21.500
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:11:51.484
DTC Client socket (1) | Creating socket. | 2020-10-07 04:11:51.485
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:11:51.485
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:11:51.485
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:11:51.510
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:11:51.510
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:11:51.511
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:11:51.527
SC Data - All Services | Sending logon request message. | 2020-10-07 04:11:51.527
SC Data - All Services | Received logon response. | 2020-10-07 04:11:52.141
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:11:52.141
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:11:52.141
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:11:52.141
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:11:52.142
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:11:52.142
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:11:52.142
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:11:52.142
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:11:52.142
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:11:52.142
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:11:52.156
DTC Client socket (1) | Closed. | 2020-10-07 04:11:52.156
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:12:22.142
DTC Client socket (1) | Creating socket. | 2020-10-07 04:12:22.143
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:12:22.143
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:12:22.143
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:12:22.164
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:12:22.164
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:12:22.164
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:12:22.200
SC Data - All Services | Sending logon request message. | 2020-10-07 04:12:22.200
SC Data - All Services | Received logon response. | 2020-10-07 04:12:22.825
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:12:22.825
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:12:22.825
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:12:22.825
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:12:22.825
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:12:22.825
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:12:22.825
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:12:22.825
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:12:22.825
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:12:22.825
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:12:22.839
DTC Client socket (1) | Closed. | 2020-10-07 04:12:22.839
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1436 seconds. | 2020-10-07 04:12:27.549
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0510 seconds. | 2020-10-07 04:12:27.603
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:12:52.828
DTC Client socket (1) | Creating socket. | 2020-10-07 04:12:52.828
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:12:52.828
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:12:52.828
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:12:52.857
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:12:52.857
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:12:52.857
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:12:52.900
SC Data - All Services | Sending logon request message. | 2020-10-07 04:12:52.900
SC Data - All Services | Received logon response. | 2020-10-07 04:12:53.620
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:12:53.620
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:12:53.620
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:12:53.620
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:12:53.620
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:12:53.620
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:12:53.620
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:12:53.620
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:12:53.620
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:12:53.620
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:12:53.647
DTC Client socket (1) | Closed. | 2020-10-07 04:12:53.647
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:13:23.617
DTC Client socket (1) | Creating socket. | 2020-10-07 04:13:23.617
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:13:23.618
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:13:23.618
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:13:23.643
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:13:23.643
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:13:23.643
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:13:23.661
SC Data - All Services | Sending logon request message. | 2020-10-07 04:13:23.661
SC Data - All Services | Received logon response. | 2020-10-07 04:13:24.321
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:13:24.321
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:13:24.321
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:13:24.321
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:13:24.321
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:13:24.321
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:13:24.321
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:13:24.321
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:13:24.321
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:13:24.321
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:13:24.334
DTC Client socket (1) | Closed. | 2020-10-07 04:13:24.334
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:13:54.321
DTC Client socket (1) | Creating socket. | 2020-10-07 04:13:54.322
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:13:54.322
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:13:54.322
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:13:54.352
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:13:54.352
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:13:54.352
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:13:54.382
SC Data - All Services | Sending logon request message. | 2020-10-07 04:13:54.382
SC Data - All Services | Received logon response. | 2020-10-07 04:13:55.055
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:13:55.056
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:13:55.056
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:13:55.056
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:13:55.056
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:13:55.056
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:13:55.056
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:13:55.056
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:13:55.056
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:13:55.056
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:13:55.070
DTC Client socket (1) | Closed. | 2020-10-07 04:13:55.070
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:14:25.055
DTC Client socket (1) | Creating socket. | 2020-10-07 04:14:25.056
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:14:25.056
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:14:25.056
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:14:25.077
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:14:25.077
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:14:25.077
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:14:25.093
SC Data - All Services | Sending logon request message. | 2020-10-07 04:14:25.093
SC Data - All Services | Received logon response. | 2020-10-07 04:14:25.722
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:14:25.722
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:14:25.722
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:14:25.722
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:14:25.722
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:14:25.723
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:14:25.723
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:14:25.723
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:14:25.723
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:14:25.724
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:14:25.737
DTC Client socket (1) | Closed. | 2020-10-07 04:14:25.738
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:14:55.721
DTC Client socket (1) | Creating socket. | 2020-10-07 04:14:55.721
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:14:55.721
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:14:55.721
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:14:55.766
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:14:55.766
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:14:55.766
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:14:55.820
SC Data - All Services | Sending logon request message. | 2020-10-07 04:14:55.820
SC Data - All Services | Received logon response. | 2020-10-07 04:14:56.528
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:14:56.528
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:14:56.528
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:14:56.528
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:14:56.528
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:14:56.528
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:14:56.528
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:14:56.528
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:14:56.528
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:14:56.528
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:14:56.554
DTC Client socket (1) | Closed. | 2020-10-07 04:14:56.554
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:15:26.526
DTC Client socket (1) | Creating socket. | 2020-10-07 04:15:26.526
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:15:26.526
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:15:26.526
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:15:26.542
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:15:26.542
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:15:26.542
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:15:26.570
SC Data - All Services | Sending logon request message. | 2020-10-07 04:15:26.570
SC Data - All Services | Received logon response. | 2020-10-07 04:15:27.222
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:15:27.222
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:15:27.222
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:15:27.222
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:15:27.222
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:15:27.222
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:15:27.222
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:15:27.222
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:15:27.222
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:15:27.222
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:15:27.235
DTC Client socket (1) | Closed. | 2020-10-07 04:15:27.235
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:15:57.220
DTC Client socket (1) | Creating socket. | 2020-10-07 04:15:57.221
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:15:57.221
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:15:57.221
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:15:57.236
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:15:57.236
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:15:57.236
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:15:57.275
SC Data - All Services | Sending logon request message. | 2020-10-07 04:15:57.275
SC Data - All Services | Received logon response. | 2020-10-07 04:15:57.903
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:15:57.903
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:15:57.903
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:15:57.903
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:15:57.903
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:15:57.903
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:15:57.903
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:15:57.903
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:15:57.903
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:15:57.903
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:15:57.917
DTC Client socket (1) | Closed. | 2020-10-07 04:15:57.917
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:16:27.899
DTC Client socket (1) | Creating socket. | 2020-10-07 04:16:27.899
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:16:27.899
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:16:27.899
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:16:27.926
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:16:27.926
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:16:27.926
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:16:27.953
SC Data - All Services | Sending logon request message. | 2020-10-07 04:16:27.953
SC Data - All Services | Received logon response. | 2020-10-07 04:16:28.556
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:16:28.556
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:16:28.556
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:16:28.556
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:16:28.556
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:16:28.556
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:16:28.556
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:16:28.556
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:16:28.556
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:16:28.556
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:16:28.570
DTC Client socket (1) | Closed. | 2020-10-07 04:16:28.570
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:16:58.569
DTC Client socket (1) | Creating socket. | 2020-10-07 04:16:58.569
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:16:58.569
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:16:58.569
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:16:58.599
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:16:58.599
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:16:58.600
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:16:58.656
SC Data - All Services | Sending logon request message. | 2020-10-07 04:16:58.656
SC Data - All Services | Received logon response. | 2020-10-07 04:16:59.326
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:16:59.326
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:16:59.326
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:16:59.326
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:16:59.326
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:16:59.327
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:16:59.327
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:16:59.327
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:16:59.327
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:16:59.327
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:16:59.351
DTC Client socket (1) | Closed. | 2020-10-07 04:16:59.351
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:17:29.335
DTC Client socket (1) | Creating socket. | 2020-10-07 04:17:29.335
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:17:29.335
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:17:29.335
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:17:29.361
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:17:29.361
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:17:29.361
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:17:29.383
SC Data - All Services | Sending logon request message. | 2020-10-07 04:17:29.383
SC Data - All Services | Received logon response. | 2020-10-07 04:17:30.044
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:17:30.044
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:17:30.044
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:17:30.044
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:17:30.044
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:17:30.044
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:17:30.044
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:17:30.044
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:17:30.044
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:17:30.044
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:17:30.058
DTC Client socket (1) | Closed. | 2020-10-07 04:17:30.058
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:18:00.044
DTC Client socket (1) | Creating socket. | 2020-10-07 04:18:00.044
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:18:00.044
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:18:00.044
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:18:00.081
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:18:00.081
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:18:00.081
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:18:00.119
SC Data - All Services | Sending logon request message. | 2020-10-07 04:18:00.119
SC Data - All Services | Received logon response. | 2020-10-07 04:18:00.747
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:18:00.747
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:18:00.747
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:18:00.747
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:18:00.747
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:18:00.747
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:18:00.747
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:18:00.747
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:18:00.747
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:18:00.747
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:18:00.760
DTC Client socket (1) | Closed. | 2020-10-07 04:18:00.760
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:18:30.750
DTC Client socket (1) | Creating socket. | 2020-10-07 04:18:30.750
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:18:30.750
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:18:30.750
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:18:30.774
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:18:30.774
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:18:30.774
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:18:30.827
SC Data - All Services | Sending logon request message. | 2020-10-07 04:18:30.827
SC Data - All Services | Received logon response. | 2020-10-07 04:18:31.454
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:18:31.454
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:18:31.454
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:18:31.454
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:18:31.454
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:18:31.454
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:18:31.454
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:18:31.454
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:18:31.454
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:18:31.454
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:18:31.467
DTC Client socket (1) | Closed. | 2020-10-07 04:18:31.467
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:19:01.461
DTC Client socket (1) | Creating socket. | 2020-10-07 04:19:01.461
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:19:01.461
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:19:01.461
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:19:01.498
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:19:01.498
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:19:01.498
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:19:01.529
SC Data - All Services | Sending logon request message. | 2020-10-07 04:19:01.529
SC Data - All Services | Received logon response. | 2020-10-07 04:19:02.235
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:19:02.235
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:19:02.235
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:19:02.235
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:19:02.235
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:19:02.235
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:19:02.235
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:19:02.235
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:19:02.235
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:19:02.235
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:19:02.262
DTC Client socket (1) | Closed. | 2020-10-07 04:19:02.262
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:19:32.233
DTC Client socket (1) | Creating socket. | 2020-10-07 04:19:32.233
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:19:32.234
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:19:32.234
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:19:32.255
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:19:32.255
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:19:32.255
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:19:32.277
SC Data - All Services | Sending logon request message. | 2020-10-07 04:19:32.277
SC Data - All Services | Received logon response. | 2020-10-07 04:19:32.938
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:19:32.938
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:19:32.938
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:19:32.938
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:19:32.938
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:19:32.938
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:19:32.938
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:19:32.938
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:19:32.938
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:19:32.938
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:19:32.951
DTC Client socket (1) | Closed. | 2020-10-07 04:19:32.951
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:20:02.938
DTC Client socket (2) | Creating socket. | 2020-10-07 04:20:02.939
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 04:20:02.939
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:20:02.939
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:20:02.968
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:20:02.968
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:20:02.968
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:20:03.017
SC Data - All Services | Sending logon request message. | 2020-10-07 04:20:03.017
SC Data - All Services | Received logon response. | 2020-10-07 04:20:03.602
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:20:03.602
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:20:03.602
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:20:03.602
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:20:03.602
DTC Client socket (2) | CloseSocket call. | 2020-10-07 04:20:03.602
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:20:03.602
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:20:03.602
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:20:03.602
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:20:03.602
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 04:20:03.616
DTC Client socket (2) | Closed. | 2020-10-07 04:20:03.616
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:20:33.610
DTC Client socket (1) | Creating socket. | 2020-10-07 04:20:33.610
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:20:33.610
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:20:33.610
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:20:33.625
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:20:33.625
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:20:33.625
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:20:33.657
SC Data - All Services | Sending logon request message. | 2020-10-07 04:20:33.657
SC Data - All Services | Received logon response. | 2020-10-07 04:20:34.302
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:20:34.302
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:20:34.302
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:20:34.302
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:20:34.302
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:20:34.302
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:20:34.302
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:20:34.302
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:20:34.302
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:20:34.302
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:20:34.315
DTC Client socket (1) | Closed. | 2020-10-07 04:20:34.315
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:21:04.300
DTC Client socket (1) | Creating socket. | 2020-10-07 04:21:04.301
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:21:04.301
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:21:04.301
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:21:04.329
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:21:04.329
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:21:04.329
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:21:04.358
SC Data - All Services | Sending logon request message. | 2020-10-07 04:21:04.358
SC Data - All Services | Received logon response. | 2020-10-07 04:21:05.081
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:21:05.081
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:21:05.081
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:21:05.081
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:21:05.081
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:21:05.082
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:21:05.082
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:21:05.082
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:21:05.082
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:21:05.082
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:21:05.107
DTC Client socket (1) | Closed. | 2020-10-07 04:21:05.107
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:21:35.083
DTC Client socket (1) | Creating socket. | 2020-10-07 04:21:35.084
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:21:35.084
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:21:35.084
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:21:35.111
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:21:35.111
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:21:35.111
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:21:35.127
SC Data - All Services | Sending logon request message. | 2020-10-07 04:21:35.127
SC Data - All Services | Received logon response. | 2020-10-07 04:21:35.782
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:21:35.782
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:21:35.782
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:21:35.782
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:21:35.782
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:21:35.782
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:21:35.782
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:21:35.782
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:21:35.782
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:21:35.782
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:21:35.795
DTC Client socket (1) | Closed. | 2020-10-07 04:21:35.795
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:22:05.774
DTC Client socket (1) | Creating socket. | 2020-10-07 04:22:05.775
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:22:05.775
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:22:05.775
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:22:05.790
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:22:05.790
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:22:05.790
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:22:05.834
SC Data - All Services | Sending logon request message. | 2020-10-07 04:22:05.834
SC Data - All Services | Received logon response. | 2020-10-07 04:22:06.460
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:22:06.460
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:22:06.460
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:22:06.460
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:22:06.460
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:22:06.460
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:22:06.460
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:22:06.460
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:22:06.460
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:22:06.460
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:22:06.477
DTC Client socket (1) | Closed. | 2020-10-07 04:22:06.477
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:22:36.457
DTC Client socket (1) | Creating socket. | 2020-10-07 04:22:36.463
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:22:36.463
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:22:36.463
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:22:36.490
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:22:36.490
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:22:36.490
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:22:36.515
SC Data - All Services | Sending logon request message. | 2020-10-07 04:22:36.515
SC Data - All Services | Received logon response. | 2020-10-07 04:22:37.147
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:22:37.147
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:22:37.147
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:22:37.147
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:22:37.147
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:22:37.147
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:22:37.147
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:22:37.147
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:22:37.147
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:22:37.148
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:22:37.162
DTC Client socket (1) | Closed. | 2020-10-07 04:22:37.162
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:23:07.146
DTC Client socket (1) | Creating socket. | 2020-10-07 04:23:07.147
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:23:07.147
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:23:07.147
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:23:07.173
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:23:07.173
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:23:07.173
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:23:07.240
SC Data - All Services | Sending logon request message. | 2020-10-07 04:23:07.240
SC Data - All Services | Received logon response. | 2020-10-07 04:23:07.933
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:23:07.933
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:23:07.933
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:23:07.933
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:23:07.933
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:23:07.933
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:23:07.933
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:23:07.933
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:23:07.934
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:23:07.934
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:23:07.960
DTC Client socket (1) | Closed. | 2020-10-07 04:23:07.960
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:23:37.940
DTC Client socket (1) | Creating socket. | 2020-10-07 04:23:37.940
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:23:37.940
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:23:37.940
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:23:37.962
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:23:37.962
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:23:37.962
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:23:37.998
SC Data - All Services | Sending logon request message. | 2020-10-07 04:23:37.999
SC Data - All Services | Received logon response. | 2020-10-07 04:23:38.670
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:23:38.670
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:23:38.670
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:23:38.670
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:23:38.670
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:23:38.670
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:23:38.670
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:23:38.670
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:23:38.670
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:23:38.670
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:23:38.683
DTC Client socket (1) | Closed. | 2020-10-07 04:23:38.683
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:24:08.674
DTC Client socket (1) | Creating socket. | 2020-10-07 04:24:08.675
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:24:08.675
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:24:08.675
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:24:08.697
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:24:08.697
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:24:08.697
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:24:08.713
SC Data - All Services | Sending logon request message. | 2020-10-07 04:24:08.713
SC Data - All Services | Received logon response. | 2020-10-07 04:24:09.310
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:24:09.311
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:24:09.311
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:24:09.311
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:24:09.311
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:24:09.311
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:24:09.311
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:24:09.311
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:24:09.311
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:24:09.311
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:24:09.325
DTC Client socket (1) | Closed. | 2020-10-07 04:24:09.325
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:24:39.313
DTC Client socket (1) | Creating socket. | 2020-10-07 04:24:39.314
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:24:39.314
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:24:39.314
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:24:39.341
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:24:39.341
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:24:39.341
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:24:39.366
SC Data - All Services | Sending logon request message. | 2020-10-07 04:24:39.366
SC Data - All Services | Received logon response. | 2020-10-07 04:24:40.000
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:24:40.000
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:24:40.000
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:24:40.000
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:24:40.000
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:24:40.000
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:24:40.000
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:24:40.000
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:24:40.000
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:24:40.000
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:24:40.014
DTC Client socket (1) | Closed. | 2020-10-07 04:24:40.014
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:25:10.007
DTC Client socket (1) | Creating socket. | 2020-10-07 04:25:10.007
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:25:10.007
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:25:10.007
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:25:10.034
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:25:10.034
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:25:10.035
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:25:10.082
SC Data - All Services | Sending logon request message. | 2020-10-07 04:25:10.082
SC Data - All Services | Received logon response. | 2020-10-07 04:25:10.800
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:25:10.800
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:25:10.800
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:25:10.800
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:25:10.800
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:25:10.801
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:25:10.801
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:25:10.801
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:25:10.801
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:25:10.801
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:25:10.826
DTC Client socket (1) | Closed. | 2020-10-07 04:25:10.826
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:25:40.794
DTC Client socket (1) | Creating socket. | 2020-10-07 04:25:40.795
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:25:40.795
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:25:40.795
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:25:40.818
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:25:40.818
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:25:40.818
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:25:40.864
SC Data - All Services | Sending logon request message. | 2020-10-07 04:25:40.864
SC Data - All Services | Received logon response. | 2020-10-07 04:25:41.530
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:25:41.530
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:25:41.530
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:25:41.530
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:25:41.530
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:25:41.530
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:25:41.530
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:25:41.530
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:25:41.530
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:25:41.530
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:25:41.542
DTC Client socket (1) | Closed. | 2020-10-07 04:25:41.542
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:26:11.527
DTC Client socket (1) | Creating socket. | 2020-10-07 04:26:11.528
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:26:11.528
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:26:11.529
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:26:11.545
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:26:11.545
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:26:11.545
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:26:11.576
SC Data - All Services | Sending logon request message. | 2020-10-07 04:26:11.576
SC Data - All Services | Received logon response. | 2020-10-07 04:26:12.218
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:26:12.218
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:26:12.218
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:26:12.218
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:26:12.218
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:26:12.219
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:26:12.219
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:26:12.219
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:26:12.219
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:26:12.219
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:26:12.233
DTC Client socket (1) | Closed. | 2020-10-07 04:26:12.233
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:26:42.215
DTC Client socket (1) | Creating socket. | 2020-10-07 04:26:42.215
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:26:42.215
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:26:42.215
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:26:42.242
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:26:42.242
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:26:42.243
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:26:42.287
SC Data - All Services | Sending logon request message. | 2020-10-07 04:26:42.287
SC Data - All Services | Received logon response. | 2020-10-07 04:26:42.892
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:26:42.892
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:26:42.892
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:26:42.892
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:26:42.892
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:26:42.892
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:26:42.892
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:26:42.892
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:26:42.892
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:26:42.892
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:26:42.907
DTC Client socket (1) | Closed. | 2020-10-07 04:26:42.907
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:27:12.886
DTC Client socket (1) | Creating socket. | 2020-10-07 04:27:12.887
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:27:12.887
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:27:12.887
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:27:12.914
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:27:12.914
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:27:12.914
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:27:12.945
SC Data - All Services | Sending logon request message. | 2020-10-07 04:27:12.945
SC Data - All Services | Received logon response. | 2020-10-07 04:27:13.622
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:27:13.622
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:27:13.622
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:27:13.622
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:27:13.622
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:27:13.622
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:27:13.622
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:27:13.622
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:27:13.622
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:27:13.622
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:27:13.648
DTC Client socket (1) | Closed. | 2020-10-07 04:27:13.648
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1129 seconds. | 2020-10-07 04:27:27.725
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0441 seconds. | 2020-10-07 04:27:27.771
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:27:43.625
DTC Client socket (1) | Creating socket. | 2020-10-07 04:27:43.625
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:27:43.626
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:27:43.626
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:27:43.647
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:27:43.647
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:27:43.647
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:27:43.678
SC Data - All Services | Sending logon request message. | 2020-10-07 04:27:43.678
SC Data - All Services | Received logon response. | 2020-10-07 04:27:44.333
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:27:44.333
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:27:44.333
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:27:44.333
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:27:44.333
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:27:44.333
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:27:44.333
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:27:44.333
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:27:44.333
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:27:44.333
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:27:44.347
DTC Client socket (1) | Closed. | 2020-10-07 04:27:44.347
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:28:14.329
DTC Client socket (1) | Creating socket. | 2020-10-07 04:28:14.330
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:28:14.330
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:28:14.330
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:28:14.351
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:28:14.351
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:28:14.351
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:28:14.393
SC Data - All Services | Sending logon request message. | 2020-10-07 04:28:14.393
SC Data - All Services | Received logon response. | 2020-10-07 04:28:14.976
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:28:14.976
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:28:14.976
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:28:14.976
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:28:14.976
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:28:14.976
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:28:14.976
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:28:14.976
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:28:14.976
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:28:14.976
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:28:14.990
DTC Client socket (1) | Closed. | 2020-10-07 04:28:14.990
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:28:44.960
DTC Client socket (1) | Creating socket. | 2020-10-07 04:28:44.961
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:28:44.961
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:28:44.961
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:28:44.985
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:28:44.985
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:28:44.985
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:28:45.030
SC Data - All Services | Sending logon request message. | 2020-10-07 04:28:45.030
SC Data - All Services | Received logon response. | 2020-10-07 04:28:45.637
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:28:45.637
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:28:45.637
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:28:45.637
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:28:45.637
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:28:45.637
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:28:45.637
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:28:45.637
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:28:45.637
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:28:45.637
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:28:45.651
DTC Client socket (1) | Closed. | 2020-10-07 04:28:45.651
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:29:15.649
DTC Client socket (1) | Creating socket. | 2020-10-07 04:29:15.650
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:29:15.650
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:29:15.650
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:29:15.680
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:29:15.680
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:29:15.680
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:29:15.717
SC Data - All Services | Sending logon request message. | 2020-10-07 04:29:15.717
SC Data - All Services | Received logon response. | 2020-10-07 04:29:16.434
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:29:16.434
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:29:16.434
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:29:16.434
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:29:16.434
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:29:16.434
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:29:16.434
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:29:16.434
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:29:16.434
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:29:16.434
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:29:16.458
DTC Client socket (1) | Closed. | 2020-10-07 04:29:16.458
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:29:46.438
DTC Client socket (1) | Creating socket. | 2020-10-07 04:29:46.438
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:29:46.438
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:29:46.438
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:29:46.473
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:29:46.473
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:29:46.473
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:29:46.509
SC Data - All Services | Sending logon request message. | 2020-10-07 04:29:46.509
SC Data - All Services | Received logon response. | 2020-10-07 04:29:47.174
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:29:47.174
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:29:47.174
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:29:47.174
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:29:47.174
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:29:47.175
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:29:47.175
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:29:47.175
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:29:47.175
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:29:47.175
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:29:47.191
DTC Client socket (1) | Closed. | 2020-10-07 04:29:47.192
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:30:17.173
DTC Client socket (1) | Creating socket. | 2020-10-07 04:30:17.174
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:30:17.174
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:30:17.174
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:30:17.188
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:30:17.188
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:30:17.189
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:30:17.215
SC Data - All Services | Sending logon request message. | 2020-10-07 04:30:17.216
SC Data - All Services | Received logon response. | 2020-10-07 04:30:17.884
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:30:17.884
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:30:17.884
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:30:17.884
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:30:17.884
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:30:17.884
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:30:17.884
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:30:17.884
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:30:17.884
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:30:17.884
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:30:17.898
DTC Client socket (1) | Closed. | 2020-10-07 04:30:17.898
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:30:47.890
DTC Client socket (1) | Creating socket. | 2020-10-07 04:30:47.890
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:30:47.890
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:30:47.890
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:30:47.920
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:30:47.920
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:30:47.920
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:30:47.963
SC Data - All Services | Sending logon request message. | 2020-10-07 04:30:47.963
SC Data - All Services | Received logon response. | 2020-10-07 04:30:48.600
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:30:48.600
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:30:48.600
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:30:48.600
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:30:48.600
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:30:48.600
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:30:48.600
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:30:48.600
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:30:48.601
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:30:48.601
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:30:48.616
DTC Client socket (1) | Closed. | 2020-10-07 04:30:48.616
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:31:18.589
DTC Client socket (1) | Creating socket. | 2020-10-07 04:31:18.589
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:31:18.589
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:31:18.589
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:31:18.616
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:31:18.616
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:31:18.617
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:31:18.663
SC Data - All Services | Sending logon request message. | 2020-10-07 04:31:18.663
SC Data - All Services | Received logon response. | 2020-10-07 04:31:19.316
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:31:19.316
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:31:19.316
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:31:19.316
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:31:19.316
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:31:19.317
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:31:19.317
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:31:19.317
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:31:19.317
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:31:19.317
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:31:19.344
DTC Client socket (1) | Closed. | 2020-10-07 04:31:19.344
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:31:49.318
DTC Client socket (1) | Creating socket. | 2020-10-07 04:31:49.319
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:31:49.319
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:31:49.319
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:31:49.341
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:31:49.341
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:31:49.341
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:31:49.364
SC Data - All Services | Sending logon request message. | 2020-10-07 04:31:49.364
SC Data - All Services | Received logon response. | 2020-10-07 04:31:50.020
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:31:50.020
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:31:50.020
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:31:50.020
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:31:50.020
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:31:50.020
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:31:50.020
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:31:50.020
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:31:50.020
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:31:50.021
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:31:50.034
DTC Client socket (1) | Closed. | 2020-10-07 04:31:50.034
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:32:20.016
DTC Client socket (1) | Creating socket. | 2020-10-07 04:32:20.016
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:32:20.017
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:32:20.017
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:32:20.030
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:32:20.030
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:32:20.031
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:32:20.062
SC Data - All Services | Sending logon request message. | 2020-10-07 04:32:20.062
SC Data - All Services | Received logon response. | 2020-10-07 04:32:20.724
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:32:20.724
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:32:20.724
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:32:20.724
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:32:20.724
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:32:20.724
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:32:20.724
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:32:20.724
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:32:20.724
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:32:20.724
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:32:20.737
DTC Client socket (1) | Closed. | 2020-10-07 04:32:20.737
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:32:50.715
DTC Client socket (1) | Creating socket. | 2020-10-07 04:32:50.716
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:32:50.716
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:32:50.716
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:32:50.738
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:32:50.738
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:32:50.738
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:32:50.775
SC Data - All Services | Sending logon request message. | 2020-10-07 04:32:50.775
SC Data - All Services | Received logon response. | 2020-10-07 04:32:51.411
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:32:51.411
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:32:51.411
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:32:51.411
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:32:51.411
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:32:51.411
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:32:51.411
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:32:51.411
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:32:51.411
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:32:51.411
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:32:51.425
DTC Client socket (1) | Closed. | 2020-10-07 04:32:51.425
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:33:21.411
DTC Client socket (1) | Creating socket. | 2020-10-07 04:33:21.412
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:33:21.412
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:33:21.412
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:33:21.439
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:33:21.439
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:33:21.439
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:33:21.481
SC Data - All Services | Sending logon request message. | 2020-10-07 04:33:21.481
SC Data - All Services | Received logon response. | 2020-10-07 04:33:22.176
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:33:22.176
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:33:22.176
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:33:22.176
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:33:22.176
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:33:22.177
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:33:22.177
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:33:22.177
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:33:22.177
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:33:22.177
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:33:22.202
DTC Client socket (1) | Closed. | 2020-10-07 04:33:22.202
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:33:52.175
DTC Client socket (1) | Creating socket. | 2020-10-07 04:33:52.175
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:33:52.175
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:33:52.175
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:33:52.197
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:33:52.197
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:33:52.197
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:33:52.219
SC Data - All Services | Sending logon request message. | 2020-10-07 04:33:52.219
SC Data - All Services | Received logon response. | 2020-10-07 04:33:52.890
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:33:52.890
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:33:52.890
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:33:52.890
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:33:52.890
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:33:52.890
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:33:52.890
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:33:52.890
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:33:52.890
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:33:52.890
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:33:52.903
DTC Client socket (1) | Closed. | 2020-10-07 04:33:52.903
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:34:22.896
DTC Client socket (1) | Creating socket. | 2020-10-07 04:34:22.896
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:34:22.896
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:34:22.896
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:34:22.911
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:34:22.911
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:34:22.911
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:34:22.934
SC Data - All Services | Sending logon request message. | 2020-10-07 04:34:22.934
SC Data - All Services | Received logon response. | 2020-10-07 04:34:23.559
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:34:23.559
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:34:23.559
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:34:23.559
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:34:23.559
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:34:23.559
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:34:23.559
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:34:23.559
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:34:23.559
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:34:23.559
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:34:23.573
DTC Client socket (1) | Closed. | 2020-10-07 04:34:23.573
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:34:53.562
DTC Client socket (1) | Creating socket. | 2020-10-07 04:34:53.563
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:34:53.563
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:34:53.563
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:34:53.591
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:34:53.591
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:34:53.591
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:34:53.635
SC Data - All Services | Sending logon request message. | 2020-10-07 04:34:53.635
SC Data - All Services | Received logon response. | 2020-10-07 04:34:54.279
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:34:54.279
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:34:54.279
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:34:54.279
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:34:54.279
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:34:54.279
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:34:54.279
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:34:54.279
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:34:54.279
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:34:54.279
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:34:54.294
DTC Client socket (1) | Closed. | 2020-10-07 04:34:54.294
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:35:24.281
DTC Client socket (1) | Creating socket. | 2020-10-07 04:35:24.282
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:35:24.282
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:35:24.282
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:35:24.311
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:35:24.311
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:35:24.311
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:35:24.354
SC Data - All Services | Sending logon request message. | 2020-10-07 04:35:24.354
SC Data - All Services | Received logon response. | 2020-10-07 04:35:25.047
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:35:25.047
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:35:25.047
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:35:25.047
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:35:25.047
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:35:25.047
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:35:25.047
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:35:25.047
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:35:25.047
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:35:25.047
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:35:25.077
DTC Client socket (1) | Closed. | 2020-10-07 04:35:25.077
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:35:55.053
DTC Client socket (1) | Creating socket. | 2020-10-07 04:35:55.053
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:35:55.053
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:35:55.053
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:35:55.068
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:35:55.068
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:35:55.068
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:35:55.100
SC Data - All Services | Sending logon request message. | 2020-10-07 04:35:55.100
SC Data - All Services | Received logon response. | 2020-10-07 04:35:55.772
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:35:55.772
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:35:55.772
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:35:55.772
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:35:55.772
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:35:55.772
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:35:55.772
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:35:55.772
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:35:55.773
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:35:55.773
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:35:55.790
DTC Client socket (1) | Closed. | 2020-10-07 04:35:55.790
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:36:25.762
DTC Client socket (1) | Creating socket. | 2020-10-07 04:36:25.763
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:36:25.763
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:36:25.763
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:36:25.783
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:36:25.783
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:36:25.783
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:36:25.818
SC Data - All Services | Sending logon request message. | 2020-10-07 04:36:25.818
SC Data - All Services | Received logon response. | 2020-10-07 04:36:26.426
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:36:26.426
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:36:26.426
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:36:26.426
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:36:26.426
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:36:26.426
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:36:26.426
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:36:26.426
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:36:26.426
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:36:26.426
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:36:26.438
DTC Client socket (1) | Closed. | 2020-10-07 04:36:26.438
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:36:56.425
DTC Client socket (1) | Creating socket. | 2020-10-07 04:36:56.426
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:36:56.426
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:36:56.426
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:36:56.448
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:36:56.448
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:36:56.448
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:36:56.488
SC Data - All Services | Sending logon request message. | 2020-10-07 04:36:56.488
SC Data - All Services | Received logon response. | 2020-10-07 04:36:57.110
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:36:57.110
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:36:57.110
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:36:57.110
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:36:57.110
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:36:57.111
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:36:57.111
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:36:57.111
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:36:57.111
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:36:57.111
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:36:57.127
DTC Client socket (1) | Closed. | 2020-10-07 04:36:57.127
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:37:27.111
DTC Client socket (1) | Creating socket. | 2020-10-07 04:37:27.111
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:37:27.111
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:37:27.111
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:37:27.139
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:37:27.139
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:37:27.139
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:37:27.200
SC Data - All Services | Sending logon request message. | 2020-10-07 04:37:27.200
SC Data - All Services | Received logon response. | 2020-10-07 04:37:27.858
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:37:27.858
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:37:27.858
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:37:27.858
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:37:27.858
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:37:27.858
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:37:27.858
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:37:27.859
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:37:27.859
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:37:27.859
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:37:27.884
DTC Client socket (1) | Closed. | 2020-10-07 04:37:27.884
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:37:57.866
DTC Client socket (1) | Creating socket. | 2020-10-07 04:37:57.870
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:37:57.870
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:37:57.870
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:37:57.889
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:37:57.889
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:37:57.889
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:37:57.934
SC Data - All Services | Sending logon request message. | 2020-10-07 04:37:57.934
SC Data - All Services | Received logon response. | 2020-10-07 04:37:58.605
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:37:58.605
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:37:58.605
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:37:58.605
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:37:58.605
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:37:58.605
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:37:58.605
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:37:58.605
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:37:58.605
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:37:58.605
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:37:58.620
DTC Client socket (1) | Closed. | 2020-10-07 04:37:58.620
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:38:28.613
DTC Client socket (1) | Creating socket. | 2020-10-07 04:38:28.613
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:38:28.613
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:38:28.613
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:38:28.628
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:38:28.628
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:38:28.628
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:38:28.651
SC Data - All Services | Sending logon request message. | 2020-10-07 04:38:28.651
SC Data - All Services | Received logon response. | 2020-10-07 04:38:29.230
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:38:29.230
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:38:29.230
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:38:29.230
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:38:29.230
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:38:29.230
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:38:29.230
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:38:29.230
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:38:29.230
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:38:29.230
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:38:29.245
DTC Client socket (1) | Closed. | 2020-10-07 04:38:29.245
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:38:59.234
DTC Client socket (1) | Creating socket. | 2020-10-07 04:38:59.234
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:38:59.234
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:38:59.234
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:38:59.263
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:38:59.264
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:38:59.264
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:38:59.294
SC Data - All Services | Sending logon request message. | 2020-10-07 04:38:59.294
SC Data - All Services | Received logon response. | 2020-10-07 04:38:59.951
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:38:59.951
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:38:59.951
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:38:59.951
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:38:59.951
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:38:59.951
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:38:59.951
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:38:59.951
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:38:59.951
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:38:59.951
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:38:59.965
DTC Client socket (1) | Closed. | 2020-10-07 04:38:59.965
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:39:29.956
DTC Client socket (1) | Creating socket. | 2020-10-07 04:39:29.956
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:39:29.956
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:39:29.956
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:39:29.986
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:39:29.986
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:39:29.986
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:39:30.044
SC Data - All Services | Sending logon request message. | 2020-10-07 04:39:30.044
SC Data - All Services | Received logon response. | 2020-10-07 04:39:30.712
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:39:30.712
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:39:30.712
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:39:30.712
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:39:30.712
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:39:30.712
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:39:30.712
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:39:30.712
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:39:30.712
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:39:30.712
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:39:30.737
DTC Client socket (1) | Closed. | 2020-10-07 04:39:30.737
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:40:00.715
DTC Client socket (1) | Creating socket. | 2020-10-07 04:40:00.716
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:40:00.716
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:40:00.716
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:40:00.747
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:40:00.747
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:40:00.747
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:40:00.774
SC Data - All Services | Sending logon request message. | 2020-10-07 04:40:00.774
SC Data - All Services | Received logon response. | 2020-10-07 04:40:01.430
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:40:01.430
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:40:01.430
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:40:01.430
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:40:01.430
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:40:01.430
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:40:01.430
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:40:01.430
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:40:01.430
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:40:01.430
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:40:01.445
DTC Client socket (1) | Closed. | 2020-10-07 04:40:01.445
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:40:31.438
DTC Client socket (1) | Creating socket. | 2020-10-07 04:40:31.439
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:40:31.439
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:40:31.439
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:40:31.469
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:40:31.469
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:40:31.470
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:40:31.528
SC Data - All Services | Sending logon request message. | 2020-10-07 04:40:31.528
SC Data - All Services | Received logon response. | 2020-10-07 04:40:32.194
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:40:32.194
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:40:32.194
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:40:32.194
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:40:32.194
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:40:32.194
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:40:32.194
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:40:32.194
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:40:32.194
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:40:32.194
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:40:32.208
DTC Client socket (1) | Closed. | 2020-10-07 04:40:32.208
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:41:02.206
DTC Client socket (1) | Creating socket. | 2020-10-07 04:41:02.206
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:41:02.206
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:41:02.206
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:41:02.230
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:41:02.230
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:41:02.230
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:41:02.247
SC Data - All Services | Sending logon request message. | 2020-10-07 04:41:02.247
SC Data - All Services | Received logon response. | 2020-10-07 04:41:02.875
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:41:02.875
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:41:02.875
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:41:02.875
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:41:02.875
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:41:02.875
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:41:02.875
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:41:02.875
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:41:02.875
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:41:02.875
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:41:02.886
DTC Client socket (1) | Closed. | 2020-10-07 04:41:02.886
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:41:32.868
DTC Client socket (1) | Creating socket. | 2020-10-07 04:41:32.869
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:41:32.869
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:41:32.869
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:41:32.897
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:41:32.897
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:41:32.897
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:41:32.929
SC Data - All Services | Sending logon request message. | 2020-10-07 04:41:32.929
SC Data - All Services | Received logon response. | 2020-10-07 04:41:33.584
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:41:33.584
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:41:33.584
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:41:33.584
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:41:33.584
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:41:33.584
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:41:33.584
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:41:33.584
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:41:33.584
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:41:33.584
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:41:33.611
DTC Client socket (1) | Closed. | 2020-10-07 04:41:33.611
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:42:03.583
DTC Client socket (1) | Creating socket. | 2020-10-07 04:42:03.584
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:42:03.584
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:42:03.584
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:42:03.599
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:42:03.599
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:42:03.599
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:42:03.622
SC Data - All Services | Sending logon request message. | 2020-10-07 04:42:03.622
SC Data - All Services | Received logon response. | 2020-10-07 04:42:04.251
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:42:04.251
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:42:04.251
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:42:04.251
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:42:04.251
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:42:04.251
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:42:04.251
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:42:04.251
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:42:04.251
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:42:04.252
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:42:04.265
DTC Client socket (1) | Closed. | 2020-10-07 04:42:04.265
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1339 seconds. | 2020-10-07 04:42:27.897
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0416 seconds. | 2020-10-07 04:42:27.939
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:42:34.244
DTC Client socket (1) | Creating socket. | 2020-10-07 04:42:34.245
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:42:34.245
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:42:34.245
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:42:34.260
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:42:34.260
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:42:34.260
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:42:34.306
SC Data - All Services | Sending logon request message. | 2020-10-07 04:42:34.306
SC Data - All Services | Received logon response. | 2020-10-07 04:42:34.963
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:42:34.963
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:42:34.963
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:42:34.963
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:42:34.963
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:42:34.963
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:42:34.963
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:42:34.963
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:42:34.963
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:42:34.963
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:42:34.977
DTC Client socket (1) | Closed. | 2020-10-07 04:42:34.977
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:43:04.966
DTC Client socket (1) | Creating socket. | 2020-10-07 04:43:04.966
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:43:04.966
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:43:04.966
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:43:04.996
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:43:04.996
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:43:04.996
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:43:05.032
SC Data - All Services | Sending logon request message. | 2020-10-07 04:43:05.032
SC Data - All Services | Received logon response. | 2020-10-07 04:43:05.669
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:43:05.669
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:43:05.669
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:43:05.669
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:43:05.669
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:43:05.669
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:43:05.669
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:43:05.669
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:43:05.669
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:43:05.669
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:43:05.683
DTC Client socket (1) | Closed. | 2020-10-07 04:43:05.683
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:43:35.673
DTC Client socket (1) | Creating socket. | 2020-10-07 04:43:35.674
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:43:35.674
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:43:35.674
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:43:35.700
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:43:35.700
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:43:35.700
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:43:35.731
SC Data - All Services | Sending logon request message. | 2020-10-07 04:43:35.731
SC Data - All Services | Received logon response. | 2020-10-07 04:43:36.392
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:43:36.392
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:43:36.392
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:43:36.392
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:43:36.392
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:43:36.393
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:43:36.393
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:43:36.393
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:43:36.393
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:43:36.393
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:43:36.417
DTC Client socket (1) | Closed. | 2020-10-07 04:43:36.417
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:44:06.389
DTC Client socket (1) | Creating socket. | 2020-10-07 04:44:06.389
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:44:06.389
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:44:06.390
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:44:06.405
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:44:06.405
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:44:06.405
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:44:06.420
SC Data - All Services | Sending logon request message. | 2020-10-07 04:44:06.420
SC Data - All Services | Received logon response. | 2020-10-07 04:44:07.093
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:44:07.093
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:44:07.093
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:44:07.093
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:44:07.093
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:44:07.093
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:44:07.093
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:44:07.093
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:44:07.093
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:44:07.093
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:44:07.107
DTC Client socket (1) | Closed. | 2020-10-07 04:44:07.107
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:44:37.092
DTC Client socket (1) | Creating socket. | 2020-10-07 04:44:37.093
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:44:37.093
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:44:37.093
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:44:37.110
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:44:37.110
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:44:37.110
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:44:37.135
SC Data - All Services | Sending logon request message. | 2020-10-07 04:44:37.135
SC Data - All Services | Received logon response. | 2020-10-07 04:44:37.756
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:44:37.756
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:44:37.756
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:44:37.756
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:44:37.756
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:44:37.757
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:44:37.757
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:44:37.757
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:44:37.757
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:44:37.757
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:44:37.773
DTC Client socket (1) | Closed. | 2020-10-07 04:44:37.773
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:45:07.755
DTC Client socket (1) | Creating socket. | 2020-10-07 04:45:07.756
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:45:07.756
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:45:07.756
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:45:07.785
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:45:07.785
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:45:07.786
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:45:07.817
SC Data - All Services | Sending logon request message. | 2020-10-07 04:45:07.817
SC Data - All Services | Received logon response. | 2020-10-07 04:45:08.434
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:45:08.434
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:45:08.434
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:45:08.434
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:45:08.434
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:45:08.434
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:45:08.434
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:45:08.434
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:45:08.434
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:45:08.434
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:45:08.449
DTC Client socket (1) | Closed. | 2020-10-07 04:45:08.449
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:45:38.430
DTC Client socket (1) | Creating socket. | 2020-10-07 04:45:38.431
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:45:38.431
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:45:38.431
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:45:38.463
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:45:38.463
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:45:38.463
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:45:38.500
SC Data - All Services | Sending logon request message. | 2020-10-07 04:45:38.500
SC Data - All Services | Received logon response. | 2020-10-07 04:45:39.205
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:45:39.205
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:45:39.205
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:45:39.205
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:45:39.205
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:45:39.205
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:45:39.205
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:45:39.205
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:45:39.205
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:45:39.205
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:45:39.233
DTC Client socket (1) | Closed. | 2020-10-07 04:45:39.233
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:46:09.209
DTC Client socket (1) | Creating socket. | 2020-10-07 04:46:09.209
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:46:09.209
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:46:09.209
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:46:09.236
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:46:09.236
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:46:09.236
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:46:09.263
SC Data - All Services | Sending logon request message. | 2020-10-07 04:46:09.263
SC Data - All Services | Received logon response. | 2020-10-07 04:46:09.922
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:46:09.922
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:46:09.922
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:46:09.922
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:46:09.922
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:46:09.922
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:46:09.922
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:46:09.922
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:46:09.922
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:46:09.922
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:46:09.939
DTC Client socket (1) | Closed. | 2020-10-07 04:46:09.939
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:46:39.921
DTC Client socket (1) | Creating socket. | 2020-10-07 04:46:39.921
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:46:39.921
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:46:39.921
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:46:39.935
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:46:39.935
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:46:39.935
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:46:39.961
SC Data - All Services | Sending logon request message. | 2020-10-07 04:46:39.961
SC Data - All Services | Received logon response. | 2020-10-07 04:46:40.610
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:46:40.610
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:46:40.610
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:46:40.610
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:46:40.610
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:46:40.611
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:46:40.611
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:46:40.611
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:46:40.611
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:46:40.611
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:46:40.623
DTC Client socket (1) | Closed. | 2020-10-07 04:46:40.623
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:47:10.609
DTC Client socket (1) | Creating socket. | 2020-10-07 04:47:10.610
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:47:10.610
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:47:10.610
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:47:10.626
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:47:10.626
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:47:10.626
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:47:10.663
SC Data - All Services | Sending logon request message. | 2020-10-07 04:47:10.663
SC Data - All Services | Received logon response. | 2020-10-07 04:47:11.289
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:47:11.289
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:47:11.289
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:47:11.289
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:47:11.289
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:47:11.289
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:47:11.289
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:47:11.289
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:47:11.289
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:47:11.289
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:47:11.303
DTC Client socket (1) | Closed. | 2020-10-07 04:47:11.304
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:47:41.299
DTC Client socket (1) | Creating socket. | 2020-10-07 04:47:41.299
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:47:41.299
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:47:41.299
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:47:41.327
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:47:41.327
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:47:41.328
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:47:41.391
SC Data - All Services | Sending logon request message. | 2020-10-07 04:47:41.391
SC Data - All Services | Received logon response. | 2020-10-07 04:47:42.096
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:47:42.096
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:47:42.096
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:47:42.096
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:47:42.096
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:47:42.096
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:47:42.096
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:47:42.096
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:47:42.096
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:47:42.096
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:47:42.122
DTC Client socket (1) | Closed. | 2020-10-07 04:47:42.122
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:48:12.098
DTC Client socket (1) | Creating socket. | 2020-10-07 04:48:12.099
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:48:12.099
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:48:12.099
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:48:12.114
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:48:12.114
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:48:12.114
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:48:12.139
SC Data - All Services | Sending logon request message. | 2020-10-07 04:48:12.139
SC Data - All Services | Received logon response. | 2020-10-07 04:48:12.831
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:48:12.831
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:48:12.831
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:48:12.831
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:48:12.831
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:48:12.831
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:48:12.831
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:48:12.831
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:48:12.831
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:48:12.831
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:48:12.843
DTC Client socket (1) | Closed. | 2020-10-07 04:48:12.843
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:48:42.831
DTC Client socket (1) | Creating socket. | 2020-10-07 04:48:42.831
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:48:42.831
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:48:42.831
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:48:42.855
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:48:42.855
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:48:42.855
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:48:42.884
SC Data - All Services | Sending logon request message. | 2020-10-07 04:48:42.884
SC Data - All Services | Received logon response. | 2020-10-07 04:48:43.523
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:48:43.523
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:48:43.523
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:48:43.523
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:48:43.523
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:48:43.523
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:48:43.523
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:48:43.523
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:48:43.523
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:48:43.523
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:48:43.536
DTC Client socket (1) | Closed. | 2020-10-07 04:48:43.536
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:49:13.529
DTC Client socket (1) | Creating socket. | 2020-10-07 04:49:13.529
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:49:13.529
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:49:13.529
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:49:13.545
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:49:13.545
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:49:13.545
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:49:13.572
SC Data - All Services | Sending logon request message. | 2020-10-07 04:49:13.572
SC Data - All Services | Received logon response. | 2020-10-07 04:49:14.202
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:49:14.202
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:49:14.202
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:49:14.202
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:49:14.202
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:49:14.203
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:49:14.203
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:49:14.203
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:49:14.203
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:49:14.203
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:49:14.215
DTC Client socket (1) | Closed. | 2020-10-07 04:49:14.215
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:49:44.198
DTC Client socket (1) | Creating socket. | 2020-10-07 04:49:44.199
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:49:44.199
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:49:44.199
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:49:44.226
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:49:44.226
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:49:44.226
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:49:44.279
SC Data - All Services | Sending logon request message. | 2020-10-07 04:49:44.279
SC Data - All Services | Received logon response. | 2020-10-07 04:49:44.979
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:49:44.979
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:49:44.979
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:49:44.979
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:49:44.979
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:49:44.980
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:49:44.980
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:49:44.980
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:49:44.980
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:49:44.980
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:49:45.006
DTC Client socket (1) | Closed. | 2020-10-07 04:49:45.006
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:50:14.982
DTC Client socket (1) | Creating socket. | 2020-10-07 04:50:14.982
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:50:14.982
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:50:14.982
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:50:15.012
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:50:15.012
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:50:15.012
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:50:15.045
SC Data - All Services | Sending logon request message. | 2020-10-07 04:50:15.045
SC Data - All Services | Received logon response. | 2020-10-07 04:50:15.714
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:50:15.714
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:50:15.714
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:50:15.714
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:50:15.714
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:50:15.715
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:50:15.715
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:50:15.715
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:50:15.715
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:50:15.715
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:50:15.732
DTC Client socket (1) | Closed. | 2020-10-07 04:50:15.732
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:50:45.711
DTC Client socket (1) | Creating socket. | 2020-10-07 04:50:45.711
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:50:45.711
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:50:45.711
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:50:45.733
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:50:45.733
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:50:45.733
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:50:45.758
SC Data - All Services | Sending logon request message. | 2020-10-07 04:50:45.758
SC Data - All Services | Received logon response. | 2020-10-07 04:50:46.368
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:50:46.368
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:50:46.368
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:50:46.368
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:50:46.368
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:50:46.368
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:50:46.368
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:50:46.368
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:50:46.368
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:50:46.368
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:50:46.380
DTC Client socket (1) | Closed. | 2020-10-07 04:50:46.381
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:51:16.380
DTC Client socket (1) | Creating socket. | 2020-10-07 04:51:16.381
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:51:16.381
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:51:16.381
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:51:16.403
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:51:16.403
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:51:16.403
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:51:16.433
SC Data - All Services | Sending logon request message. | 2020-10-07 04:51:16.433
SC Data - All Services | Received logon response. | 2020-10-07 04:51:17.079
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:51:17.079
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:51:17.079
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:51:17.079
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:51:17.079
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:51:17.079
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:51:17.079
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:51:17.079
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:51:17.079
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:51:17.079
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:51:17.094
DTC Client socket (1) | Closed. | 2020-10-07 04:51:17.094
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:51:47.073
DTC Client socket (1) | Creating socket. | 2020-10-07 04:51:47.073
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:51:47.073
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:51:47.073
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:51:47.102
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:51:47.102
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:51:47.102
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:51:47.143
SC Data - All Services | Sending logon request message. | 2020-10-07 04:51:47.143
SC Data - All Services | Received logon response. | 2020-10-07 04:51:47.817
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:51:47.817
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:51:47.817
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:51:47.817
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:51:47.817
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:51:47.817
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:51:47.817
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:51:47.817
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:51:47.817
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:51:47.817
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:51:47.847
DTC Client socket (1) | Closed. | 2020-10-07 04:51:47.847
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:52:17.807
DTC Client socket (1) | Creating socket. | 2020-10-07 04:52:17.808
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:52:17.808
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:52:17.808
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:52:17.835
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:52:17.835
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:52:17.835
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:52:17.844
SC Data - All Services | Sending logon request message. | 2020-10-07 04:52:17.844
SC Data - All Services | Received logon response. | 2020-10-07 04:52:18.504
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:52:18.504
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:52:18.504
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:52:18.504
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:52:18.504
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:52:18.504
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:52:18.504
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:52:18.504
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:52:18.504
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:52:18.505
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:52:18.518
DTC Client socket (1) | Closed. | 2020-10-07 04:52:18.518
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:52:48.499
DTC Client socket (1) | Creating socket. | 2020-10-07 04:52:48.499
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:52:48.499
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:52:48.499
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:52:48.521
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:52:48.521
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:52:48.521
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:52:48.544
SC Data - All Services | Sending logon request message. | 2020-10-07 04:52:48.544
SC Data - All Services | Received logon response. | 2020-10-07 04:52:49.189
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:52:49.189
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:52:49.189
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:52:49.189
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:52:49.189
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:52:49.189
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:52:49.189
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:52:49.189
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:52:49.189
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:52:49.189
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:52:49.201
DTC Client socket (1) | Closed. | 2020-10-07 04:52:49.201
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:53:19.190
DTC Client socket (1) | Creating socket. | 2020-10-07 04:53:19.193
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:53:19.193
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:53:19.193
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:53:19.212
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:53:19.212
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:53:19.212
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:53:19.242
SC Data - All Services | Sending logon request message. | 2020-10-07 04:53:19.242
SC Data - All Services | Received logon response. | 2020-10-07 04:53:19.884
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:53:19.884
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:53:19.884
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:53:19.884
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:53:19.884
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:53:19.884
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:53:19.884
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:53:19.885
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:53:19.885
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:53:19.885
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:53:19.900
DTC Client socket (1) | Closed. | 2020-10-07 04:53:19.900
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:53:49.885
DTC Client socket (1) | Creating socket. | 2020-10-07 04:53:49.885
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:53:49.885
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:53:49.885
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:53:49.913
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:53:49.913
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:53:49.913
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:53:49.963
SC Data - All Services | Sending logon request message. | 2020-10-07 04:53:49.963
SC Data - All Services | Received logon response. | 2020-10-07 04:53:50.640
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:53:50.640
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:53:50.640
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:53:50.640
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:53:50.640
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:53:50.640
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:53:50.640
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:53:50.640
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:53:50.640
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:53:50.641
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:53:50.668
DTC Client socket (1) | Closed. | 2020-10-07 04:53:50.668
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:54:20.643
DTC Client socket (1) | Creating socket. | 2020-10-07 04:54:20.643
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:54:20.643
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:54:20.643
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:54:20.668
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:54:20.668
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:54:20.668
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:54:20.712
SC Data - All Services | Sending logon request message. | 2020-10-07 04:54:20.712
SC Data - All Services | Received logon response. | 2020-10-07 04:54:21.357
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:54:21.357
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:54:21.357
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:54:21.357
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:54:21.357
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:54:21.357
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:54:21.357
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:54:21.357
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:54:21.357
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:54:21.357
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:54:21.370
DTC Client socket (1) | Closed. | 2020-10-07 04:54:21.370
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:54:51.361
DTC Client socket (1) | Creating socket. | 2020-10-07 04:54:51.362
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:54:51.362
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:54:51.362
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:54:51.377
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:54:51.377
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:54:51.377
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:54:51.432
SC Data - All Services | Sending logon request message. | 2020-10-07 04:54:51.432
SC Data - All Services | Received logon response. | 2020-10-07 04:54:52.046
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:54:52.046
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:54:52.046
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:54:52.046
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:54:52.046
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:54:52.046
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:54:52.046
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:54:52.046
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:54:52.046
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:54:52.046
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:54:52.059
DTC Client socket (1) | Closed. | 2020-10-07 04:54:52.059
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:55:22.049
DTC Client socket (1) | Creating socket. | 2020-10-07 04:55:22.050
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:55:22.050
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:55:22.050
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:55:22.072
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:55:22.072
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:55:22.072
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:55:22.096
SC Data - All Services | Sending logon request message. | 2020-10-07 04:55:22.096
SC Data - All Services | Received logon response. | 2020-10-07 04:55:22.723
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:55:22.723
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:55:22.723
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:55:22.723
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:55:22.723
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:55:22.723
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:55:22.723
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:55:22.723
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:55:22.723
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:55:22.723
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:55:22.737
DTC Client socket (1) | Closed. | 2020-10-07 04:55:22.737
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:55:52.720
DTC Client socket (1) | Creating socket. | 2020-10-07 04:55:52.720
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:55:52.720
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:55:52.720
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:55:52.747
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:55:52.747
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:55:52.747
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:55:52.789
SC Data - All Services | Sending logon request message. | 2020-10-07 04:55:52.789
SC Data - All Services | Received logon response. | 2020-10-07 04:55:53.483
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:55:53.483
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:55:53.483
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:55:53.483
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:55:53.483
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:55:53.484
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:55:53.484
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:55:53.484
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:55:53.484
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:55:53.484
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:55:53.509
DTC Client socket (1) | Closed. | 2020-10-07 04:55:53.509
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:56:23.479
DTC Client socket (1) | Creating socket. | 2020-10-07 04:56:23.480
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:56:23.480
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:56:23.480
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:56:23.495
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:56:23.495
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:56:23.495
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:56:23.516
SC Data - All Services | Sending logon request message. | 2020-10-07 04:56:23.516
SC Data - All Services | Received logon response. | 2020-10-07 04:56:24.144
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:56:24.144
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:56:24.144
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:56:24.144
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:56:24.144
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:56:24.144
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:56:24.144
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:56:24.144
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:56:24.144
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:56:24.144
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:56:24.161
DTC Client socket (1) | Closed. | 2020-10-07 04:56:24.161
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:56:54.138
DTC Client socket (1) | Creating socket. | 2020-10-07 04:56:54.140
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:56:54.140
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:56:54.140
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:56:54.154
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:56:54.154
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:56:54.154
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:56:54.195
SC Data - All Services | Sending logon request message. | 2020-10-07 04:56:54.195
SC Data - All Services | Received logon response. | 2020-10-07 04:56:54.849
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:56:54.849
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:56:54.849
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:56:54.849
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:56:54.849
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:56:54.849
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:56:54.849
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:56:54.849
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:56:54.849
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:56:54.849
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:56:54.865
DTC Client socket (1) | Closed. | 2020-10-07 04:56:54.865
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:57:24.844
DTC Client socket (1) | Creating socket. | 2020-10-07 04:57:24.844
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:57:24.844
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:57:24.845
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:57:24.866
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:57:24.866
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:57:24.866
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:57:24.905
SC Data - All Services | Sending logon request message. | 2020-10-07 04:57:24.905
SC Data - All Services | Received logon response. | 2020-10-07 04:57:25.563
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:57:25.563
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:57:25.563
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:57:25.563
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:57:25.563
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:57:25.563
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:57:25.564
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:57:25.564
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:57:25.564
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:57:25.564
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:57:25.578
DTC Client socket (1) | Closed. | 2020-10-07 04:57:25.578
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1062 seconds. | 2020-10-07 04:57:28.047
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0412 seconds. | 2020-10-07 04:57:28.090
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:57:55.555
DTC Client socket (1) | Creating socket. | 2020-10-07 04:57:55.556
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:57:55.556
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:57:55.556
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:57:55.585
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:57:55.585
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:57:55.585
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:57:55.647
SC Data - All Services | Sending logon request message. | 2020-10-07 04:57:55.647
SC Data - All Services | Received logon response. | 2020-10-07 04:57:56.335
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:57:56.335
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:57:56.335
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:57:56.335
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:57:56.335
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:57:56.336
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:57:56.336
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:57:56.336
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:57:56.336
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:57:56.336
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:57:56.369
DTC Client socket (1) | Closed. | 2020-10-07 04:57:56.369
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 04:58:26.350
DTC Client socket (1) | Creating socket. | 2020-10-07 04:58:26.350
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:58:26.350
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 04:58:26.350
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:58:26.377
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:58:26.377
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:58:26.377
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:58:26.406
SC Data - All Services | Sending logon request message. | 2020-10-07 04:58:26.406
SC Data - All Services | Received logon response. | 2020-10-07 04:58:27.082
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:58:27.082
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:58:27.082
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:58:27.082
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:58:27.082
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:58:27.082
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:58:27.082
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:58:27.082
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:58:27.083
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:58:27.083
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:58:27.097
DTC Client socket (1) | Closed. | 2020-10-07 04:58:27.097
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 04:58:57.084
DTC Client socket (1) | Creating socket. | 2020-10-07 04:58:57.084
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:58:57.084
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 04:58:57.084
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:58:57.105
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:58:57.105
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:58:57.105
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:58:57.123
SC Data - All Services | Sending logon request message. | 2020-10-07 04:58:57.124
SC Data - All Services | Received logon response. | 2020-10-07 04:58:57.737
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:58:57.737
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:58:57.737
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:58:57.737
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:58:57.737
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:58:57.738
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:58:57.738
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:58:57.738
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:58:57.738
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:58:57.738
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:58:57.751
DTC Client socket (1) | Closed. | 2020-10-07 04:58:57.751
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 04:59:27.738
DTC Client socket (1) | Creating socket. | 2020-10-07 04:59:27.738
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:59:27.739
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 04:59:27.739
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:59:27.762
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:59:27.762
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:59:27.762
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:59:27.784
SC Data - All Services | Sending logon request message. | 2020-10-07 04:59:27.785
SC Data - All Services | Received logon response. | 2020-10-07 04:59:28.383
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:59:28.383
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:59:28.383
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:59:28.383
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:59:28.383
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:59:28.383
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:59:28.383
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:59:28.383
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:59:28.383
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:59:28.384
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:59:28.398
DTC Client socket (1) | Closed. | 2020-10-07 04:59:28.398
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 04:59:58.391
DTC Client socket (1) | Creating socket. | 2020-10-07 04:59:58.392
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 04:59:58.392
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 04:59:58.392
SC Data - All Services | Network connection to server complete. | 2020-10-07 04:59:58.418
SC Data - All Services | Starting socket receive thread. | 2020-10-07 04:59:58.418
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 04:59:58.418
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 04:59:58.471
SC Data - All Services | Sending logon request message. | 2020-10-07 04:59:58.471
SC Data - All Services | Received logon response. | 2020-10-07 04:59:59.145
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 04:59:59.145
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 04:59:59.145
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 04:59:59.145
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 04:59:59.145
DTC Client socket (1) | CloseSocket call. | 2020-10-07 04:59:59.146
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 04:59:59.146
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 04:59:59.146
SC Data - All Services | Disconnected from the server. | 2020-10-07 04:59:59.146
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 04:59:59.146
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 04:59:59.172
DTC Client socket (1) | Closed. | 2020-10-07 04:59:59.172
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:00:29.146
DTC Client socket (1) | Creating socket. | 2020-10-07 05:00:29.147
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:00:29.147
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:00:29.147
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:00:29.161
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:00:29.161
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:00:29.161
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:00:29.183
SC Data - All Services | Sending logon request message. | 2020-10-07 05:00:29.183
SC Data - All Services | Received logon response. | 2020-10-07 05:00:29.882
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:00:29.882
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:00:29.882
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:00:29.882
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:00:29.882
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:00:29.882
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:00:29.882
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:00:29.882
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:00:29.882
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:00:29.882
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:00:29.896
DTC Client socket (1) | Closed. | 2020-10-07 05:00:29.896
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:00:59.876
DTC Client socket (1) | Creating socket. | 2020-10-07 05:00:59.876
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:00:59.876
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:00:59.876
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:00:59.892
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:00:59.892
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:00:59.892
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:00:59.942
SC Data - All Services | Sending logon request message. | 2020-10-07 05:00:59.942
SC Data - All Services | Received logon response. | 2020-10-07 05:01:00.578
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:01:00.578
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:01:00.578
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:01:00.578
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:01:00.578
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:01:00.579
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:01:00.579
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:01:00.579
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:01:00.579
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:01:00.579
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:01:00.594
DTC Client socket (1) | Closed. | 2020-10-07 05:01:00.594
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:01:30.575
DTC Client socket (1) | Creating socket. | 2020-10-07 05:01:30.575
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:01:30.575
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:01:30.575
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:01:30.597
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:01:30.597
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:01:30.598
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:01:30.619
SC Data - All Services | Sending logon request message. | 2020-10-07 05:01:30.619
SC Data - All Services | Received logon response. | 2020-10-07 05:01:31.262
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:01:31.262
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:01:31.262
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:01:31.262
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:01:31.262
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:01:31.263
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:01:31.263
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:01:31.263
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:01:31.263
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:01:31.263
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:01:31.277
DTC Client socket (1) | Closed. | 2020-10-07 05:01:31.277
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:02:01.262
DTC Client socket (1) | Creating socket. | 2020-10-07 05:02:01.262
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:02:01.262
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:02:01.262
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:02:01.290
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:02:01.290
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:02:01.290
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:02:01.331
SC Data - All Services | Sending logon request message. | 2020-10-07 05:02:01.332
SC Data - All Services | Received logon response. | 2020-10-07 05:02:02.037
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:02:02.037
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:02:02.037
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:02:02.037
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:02:02.037
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:02:02.038
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:02:02.038
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:02:02.038
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:02:02.038
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:02:02.038
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:02:02.065
DTC Client socket (1) | Closed. | 2020-10-07 05:02:02.065
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:02:32.032
DTC Client socket (1) | Creating socket. | 2020-10-07 05:02:32.032
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:02:32.032
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:02:32.032
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:02:32.054
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:02:32.054
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:02:32.054
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:02:32.101
SC Data - All Services | Sending logon request message. | 2020-10-07 05:02:32.101
SC Data - All Services | Received logon response. | 2020-10-07 05:02:32.754
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:02:32.754
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:02:32.754
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:02:32.754
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:02:32.754
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:02:32.754
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:02:32.754
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:02:32.754
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:02:32.754
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:02:32.754
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:02:32.767
DTC Client socket (1) | Closed. | 2020-10-07 05:02:32.767
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:03:02.756
DTC Client socket (2) | Creating socket. | 2020-10-07 05:03:02.756
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 05:03:02.756
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:03:02.756
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:03:02.783
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:03:02.783
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:03:02.783
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:03:02.830
SC Data - All Services | Sending logon request message. | 2020-10-07 05:03:02.830
SC Data - All Services | Received logon response. | 2020-10-07 05:03:03.443
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:03:03.443
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:03:03.443
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:03:03.443
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:03:03.443
DTC Client socket (2) | CloseSocket call. | 2020-10-07 05:03:03.443
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:03:03.443
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:03:03.443
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:03:03.443
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:03:03.447
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 05:03:03.457
DTC Client socket (2) | Closed. | 2020-10-07 05:03:03.457
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:03:33.446
DTC Client socket (1) | Creating socket. | 2020-10-07 05:03:33.447
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:03:33.447
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:03:33.447
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:03:33.469
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:03:33.469
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:03:33.469
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:03:33.514
SC Data - All Services | Sending logon request message. | 2020-10-07 05:03:33.514
SC Data - All Services | Received logon response. | 2020-10-07 05:03:34.251
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:03:34.251
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:03:34.251
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:03:34.251
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:03:34.251
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:03:34.251
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:03:34.251
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:03:34.251
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:03:34.252
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:03:34.252
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:03:34.266
DTC Client socket (1) | Closed. | 2020-10-07 05:03:34.266
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:04:04.253
DTC Client socket (1) | Creating socket. | 2020-10-07 05:04:04.253
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:04:04.253
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:04:04.253
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:04:04.280
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:04:04.280
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:04:04.280
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:04:04.321
SC Data - All Services | Sending logon request message. | 2020-10-07 05:04:04.321
SC Data - All Services | Received logon response. | 2020-10-07 05:04:05.026
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:04:05.026
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:04:05.026
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:04:05.026
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:04:05.026
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:04:05.026
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:04:05.026
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:04:05.026
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:04:05.026
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:04:05.026
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:04:05.053
DTC Client socket (1) | Closed. | 2020-10-07 05:04:05.053
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:04:35.033
DTC Client socket (1) | Creating socket. | 2020-10-07 05:04:35.033
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:04:35.033
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:04:35.033
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:04:35.054
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:04:35.054
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:04:35.054
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:04:35.085
SC Data - All Services | Sending logon request message. | 2020-10-07 05:04:35.085
SC Data - All Services | Received logon response. | 2020-10-07 05:04:35.775
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:04:35.775
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:04:35.775
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:04:35.775
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:04:35.775
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:04:35.776
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:04:35.776
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:04:35.776
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:04:35.776
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:04:35.777
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:04:35.789
DTC Client socket (1) | Closed. | 2020-10-07 05:04:35.790
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:05:05.774
DTC Client socket (1) | Creating socket. | 2020-10-07 05:05:05.775
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:05:05.775
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:05:05.775
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:05:05.790
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:05:05.790
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:05:05.790
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:05:05.832
SC Data - All Services | Sending logon request message. | 2020-10-07 05:05:05.832
SC Data - All Services | Received logon response. | 2020-10-07 05:05:06.426
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:05:06.426
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:05:06.426
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:05:06.426
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:05:06.426
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:05:06.426
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:05:06.426
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:05:06.426
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:05:06.426
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:05:06.426
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:05:06.440
DTC Client socket (1) | Closed. | 2020-10-07 05:05:06.440
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:05:36.427
DTC Client socket (1) | Creating socket. | 2020-10-07 05:05:36.427
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:05:36.427
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:05:36.427
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:05:36.447
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:05:36.447
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:05:36.447
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:05:36.467
SC Data - All Services | Sending logon request message. | 2020-10-07 05:05:36.467
SC Data - All Services | Received logon response. | 2020-10-07 05:05:37.096
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:05:37.096
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:05:37.096
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:05:37.096
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:05:37.096
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:05:37.096
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:05:37.096
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:05:37.096
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:05:37.096
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:05:37.097
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:05:37.111
DTC Client socket (1) | Closed. | 2020-10-07 05:05:37.111
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:06:07.088
DTC Client socket (1) | Creating socket. | 2020-10-07 05:06:07.088
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:06:07.088
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:06:07.088
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:06:07.120
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:06:07.120
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:06:07.120
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:06:07.174
SC Data - All Services | Sending logon request message. | 2020-10-07 05:06:07.174
SC Data - All Services | Received logon response. | 2020-10-07 05:06:07.880
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:06:07.880
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:06:07.880
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:06:07.880
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:06:07.880
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:06:07.880
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:06:07.880
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:06:07.880
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:06:07.880
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:06:07.880
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:06:07.906
DTC Client socket (1) | Closed. | 2020-10-07 05:06:07.906
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:06:37.880
DTC Client socket (1) | Creating socket. | 2020-10-07 05:06:37.880
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:06:37.881
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:06:37.881
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:06:37.910
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:06:37.910
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:06:37.910
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:06:37.949
SC Data - All Services | Sending logon request message. | 2020-10-07 05:06:37.949
SC Data - All Services | Received logon response. | 2020-10-07 05:06:38.600
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:06:38.600
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:06:38.600
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:06:38.600
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:06:38.600
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:06:38.600
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:06:38.600
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:06:38.600
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:06:38.600
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:06:38.600
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:06:38.613
DTC Client socket (1) | Closed. | 2020-10-07 05:06:38.613
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:07:08.599
DTC Client socket (1) | Creating socket. | 2020-10-07 05:07:08.599
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:07:08.599
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:07:08.599
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:07:08.614
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:07:08.614
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:07:08.614
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:07:08.637
SC Data - All Services | Sending logon request message. | 2020-10-07 05:07:08.637
SC Data - All Services | Received logon response. | 2020-10-07 05:07:09.276
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:07:09.276
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:07:09.276
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:07:09.276
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:07:09.276
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:07:09.276
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:07:09.276
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:07:09.276
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:07:09.276
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:07:09.277
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:07:09.288
DTC Client socket (1) | Closed. | 2020-10-07 05:07:09.288
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:07:39.284
DTC Client socket (1) | Creating socket. | 2020-10-07 05:07:39.285
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:07:39.285
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:07:39.285
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:07:39.310
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:07:39.310
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:07:39.310
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:07:39.329
SC Data - All Services | Sending logon request message. | 2020-10-07 05:07:39.329
SC Data - All Services | Received logon response. | 2020-10-07 05:07:39.965
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:07:39.965
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:07:39.965
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:07:39.965
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:07:39.965
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:07:39.965
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:07:39.965
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:07:39.965
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:07:39.965
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:07:39.965
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:07:39.980
DTC Client socket (1) | Closed. | 2020-10-07 05:07:39.980
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:08:09.962
DTC Client socket (1) | Creating socket. | 2020-10-07 05:08:09.963
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:08:09.963
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:08:09.963
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:08:09.992
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:08:09.992
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:08:09.992
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:08:10.040
SC Data - All Services | Sending logon request message. | 2020-10-07 05:08:10.040
SC Data - All Services | Received logon response. | 2020-10-07 05:08:10.730
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:08:10.730
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:08:10.730
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:08:10.730
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:08:10.730
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:08:10.730
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:08:10.730
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:08:10.730
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:08:10.730
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:08:10.730
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:08:10.758
DTC Client socket (1) | Closed. | 2020-10-07 05:08:10.758
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:08:40.739
DTC Client socket (1) | Creating socket. | 2020-10-07 05:08:40.742
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:08:40.742
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:08:40.742
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:08:40.764
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:08:40.764
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:08:40.764
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:08:40.811
SC Data - All Services | Sending logon request message. | 2020-10-07 05:08:40.811
SC Data - All Services | Received logon response. | 2020-10-07 05:08:41.483
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:08:41.483
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:08:41.483
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:08:41.483
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:08:41.483
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:08:41.484
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:08:41.484
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:08:41.484
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:08:41.484
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:08:41.484
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:08:41.496
DTC Client socket (1) | Closed. | 2020-10-07 05:08:41.496
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:09:11.490
DTC Client socket (1) | Creating socket. | 2020-10-07 05:09:11.490
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:09:11.490
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:09:11.490
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:09:11.521
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:09:11.521
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:09:11.521
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:09:11.545
SC Data - All Services | Sending logon request message. | 2020-10-07 05:09:11.545
SC Data - All Services | Received logon response. | 2020-10-07 05:09:12.132
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:09:12.132
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:09:12.132
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:09:12.132
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:09:12.132
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:09:12.132
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:09:12.132
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:09:12.132
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:09:12.132
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:09:12.132
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:09:12.146
DTC Client socket (1) | Closed. | 2020-10-07 05:09:12.146
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:09:42.123
DTC Client socket (1) | Creating socket. | 2020-10-07 05:09:42.123
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:09:42.123
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:09:42.123
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:09:42.152
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:09:42.152
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:09:42.152
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:09:42.179
SC Data - All Services | Sending logon request message. | 2020-10-07 05:09:42.179
SC Data - All Services | Received logon response. | 2020-10-07 05:09:42.802
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:09:42.802
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:09:42.802
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:09:42.802
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:09:42.802
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:09:42.803
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:09:42.803
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:09:42.803
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:09:42.803
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:09:42.803
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:09:42.819
DTC Client socket (1) | Closed. | 2020-10-07 05:09:42.819
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:10:12.788
DTC Client socket (1) | Creating socket. | 2020-10-07 05:10:12.789
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:10:12.789
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:10:12.789
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:10:12.815
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:10:12.815
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:10:12.815
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:10:12.867
SC Data - All Services | Sending logon request message. | 2020-10-07 05:10:12.867
SC Data - All Services | Received logon response. | 2020-10-07 05:10:13.565
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:10:13.565
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:10:13.565
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:10:13.565
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:10:13.565
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:10:13.566
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:10:13.566
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:10:13.566
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:10:13.566
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:10:13.566
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:10:13.594
DTC Client socket (1) | Closed. | 2020-10-07 05:10:13.594
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:10:43.564
DTC Client socket (1) | Creating socket. | 2020-10-07 05:10:43.564
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:10:43.564
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:10:43.564
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:10:43.591
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:10:43.591
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:10:43.591
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:10:43.608
SC Data - All Services | Sending logon request message. | 2020-10-07 05:10:43.608
SC Data - All Services | Received logon response. | 2020-10-07 05:10:44.295
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:10:44.295
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:10:44.295
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:10:44.295
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:10:44.295
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:10:44.296
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:10:44.296
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:10:44.296
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:10:44.296
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:10:44.296
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:10:44.310
DTC Client socket (1) | Closed. | 2020-10-07 05:10:44.310
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:11:14.292
DTC Client socket (1) | Creating socket. | 2020-10-07 05:11:14.292
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:11:14.292
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:11:14.292
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:11:14.310
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:11:14.310
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:11:14.310
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:11:14.338
SC Data - All Services | Sending logon request message. | 2020-10-07 05:11:14.338
SC Data - All Services | Received logon response. | 2020-10-07 05:11:14.940
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:11:14.940
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:11:14.940
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:11:14.940
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:11:14.940
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:11:14.940
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:11:14.940
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:11:14.940
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:11:14.940
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:11:14.940
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:11:14.953
DTC Client socket (1) | Closed. | 2020-10-07 05:11:14.953
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:11:44.942
DTC Client socket (1) | Creating socket. | 2020-10-07 05:11:44.943
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:11:44.943
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:11:44.943
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:11:44.966
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:11:44.966
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:11:44.966
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:11:44.988
SC Data - All Services | Sending logon request message. | 2020-10-07 05:11:44.988
SC Data - All Services | Received logon response. | 2020-10-07 05:11:45.633
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:11:45.633
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:11:45.633
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:11:45.633
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:11:45.633
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:11:45.634
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:11:45.634
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:11:45.634
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:11:45.634
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:11:45.634
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:11:45.648
DTC Client socket (1) | Closed. | 2020-10-07 05:11:45.648
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:12:15.643
DTC Client socket (1) | Creating socket. | 2020-10-07 05:12:15.644
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:12:15.644
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:12:15.644
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:12:15.674
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:12:15.674
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:12:15.674
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:12:15.733
SC Data - All Services | Sending logon request message. | 2020-10-07 05:12:15.733
SC Data - All Services | Received logon response. | 2020-10-07 05:12:16.426
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:12:16.426
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:12:16.426
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:12:16.426
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:12:16.426
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:12:16.427
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:12:16.427
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:12:16.427
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:12:16.427
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:12:16.427
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:12:16.453
DTC Client socket (1) | Closed. | 2020-10-07 05:12:16.453
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1180 seconds. | 2020-10-07 05:12:28.217
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0339 seconds. | 2020-10-07 05:12:28.252
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:12:46.429
DTC Client socket (1) | Creating socket. | 2020-10-07 05:12:46.430
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:12:46.430
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:12:46.430
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:12:46.461
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:12:46.461
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:12:46.461
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:12:46.487
SC Data - All Services | Sending logon request message. | 2020-10-07 05:12:46.487
SC Data - All Services | Received logon response. | 2020-10-07 05:12:47.145
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:12:47.145
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:12:47.145
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:12:47.146
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:12:47.146
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:12:47.146
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:12:47.146
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:12:47.146
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:12:47.146
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:12:47.146
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:12:47.161
DTC Client socket (1) | Closed. | 2020-10-07 05:12:47.161
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:13:17.138
DTC Client socket (1) | Creating socket. | 2020-10-07 05:13:17.138
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:13:17.138
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:13:17.138
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:13:17.167
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:13:17.167
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:13:17.167
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:13:17.198
SC Data - All Services | Sending logon request message. | 2020-10-07 05:13:17.198
SC Data - All Services | Received logon response. | 2020-10-07 05:13:17.835
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:13:17.835
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:13:17.835
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:13:17.835
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:13:17.835
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:13:17.835
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:13:17.835
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:13:17.835
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:13:17.835
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:13:17.835
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:13:17.850
DTC Client socket (1) | Closed. | 2020-10-07 05:13:17.850
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:13:47.836
DTC Client socket (1) | Creating socket. | 2020-10-07 05:13:47.836
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:13:47.836
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:13:47.836
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:13:47.867
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:13:47.867
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:13:47.867
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:13:47.916
SC Data - All Services | Sending logon request message. | 2020-10-07 05:13:47.916
SC Data - All Services | Received logon response. | 2020-10-07 05:13:48.525
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:13:48.525
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:13:48.525
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:13:48.525
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:13:48.525
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:13:48.527
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:13:48.527
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:13:48.527
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:13:48.527
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:13:48.527
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:13:48.540
DTC Client socket (1) | Closed. | 2020-10-07 05:13:48.540
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:14:18.534
DTC Client socket (1) | Creating socket. | 2020-10-07 05:14:18.534
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:14:18.534
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:14:18.534
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:14:18.564
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:14:18.564
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:14:18.564
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:14:18.604
SC Data - All Services | Sending logon request message. | 2020-10-07 05:14:18.605
SC Data - All Services | Received logon response. | 2020-10-07 05:14:19.308
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:14:19.308
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:14:19.308
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:14:19.308
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:14:19.308
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:14:19.309
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:14:19.309
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:14:19.309
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:14:19.309
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:14:19.309
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:14:19.336
DTC Client socket (1) | Closed. | 2020-10-07 05:14:19.337
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:14:49.309
DTC Client socket (1) | Creating socket. | 2020-10-07 05:14:49.309
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:14:49.309
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:14:49.309
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:14:49.339
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:14:49.339
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:14:49.339
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:14:49.378
SC Data - All Services | Sending logon request message. | 2020-10-07 05:14:49.378
SC Data - All Services | Received logon response. | 2020-10-07 05:14:50.030
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:14:50.030
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:14:50.030
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:14:50.030
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:14:50.030
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:14:50.030
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:14:50.030
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:14:50.030
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:14:50.030
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:14:50.030
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:14:50.043
DTC Client socket (1) | Closed. | 2020-10-07 05:14:50.043
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:15:20.025
DTC Client socket (1) | Creating socket. | 2020-10-07 05:15:20.026
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:15:20.026
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:15:20.026
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:15:20.040
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:15:20.040
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:15:20.040
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:15:20.081
SC Data - All Services | Sending logon request message. | 2020-10-07 05:15:20.081
SC Data - All Services | Received logon response. | 2020-10-07 05:15:20.707
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:15:20.707
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:15:20.707
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:15:20.707
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:15:20.707
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:15:20.707
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:15:20.707
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:15:20.707
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:15:20.708
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:15:20.708
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:15:20.722
DTC Client socket (1) | Closed. | 2020-10-07 05:15:20.722
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:15:50.704
DTC Client socket (1) | Creating socket. | 2020-10-07 05:15:50.705
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:15:50.705
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:15:50.705
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:15:50.726
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:15:50.726
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:15:50.726
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:15:50.761
SC Data - All Services | Sending logon request message. | 2020-10-07 05:15:50.761
SC Data - All Services | Received logon response. | 2020-10-07 05:15:51.405
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:15:51.405
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:15:51.405
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:15:51.405
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:15:51.405
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:15:51.405
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:15:51.405
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:15:51.405
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:15:51.405
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:15:51.405
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:15:51.424
DTC Client socket (1) | Closed. | 2020-10-07 05:15:51.424
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:16:21.412
DTC Client socket (2) | Creating socket. | 2020-10-07 05:16:21.412
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 05:16:21.412
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:16:21.412
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:16:21.441
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:16:21.441
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:16:21.441
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:16:21.517
SC Data - All Services | Sending logon request message. | 2020-10-07 05:16:21.517
SC Data - All Services | Received logon response. | 2020-10-07 05:16:22.204
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:16:22.204
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:16:22.204
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:16:22.204
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:16:22.204
DTC Client socket (2) | CloseSocket call. | 2020-10-07 05:16:22.204
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:16:22.204
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:16:22.204
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:16:22.204
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:16:22.204
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 05:16:22.231
DTC Client socket (2) | Closed. | 2020-10-07 05:16:22.231
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:16:52.197
DTC Client socket (1) | Creating socket. | 2020-10-07 05:16:52.198
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:16:52.198
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:16:52.198
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:16:52.227
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:16:52.227
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:16:52.227
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:16:52.251
SC Data - All Services | Sending logon request message. | 2020-10-07 05:16:52.251
SC Data - All Services | Received logon response. | 2020-10-07 05:16:52.897
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:16:52.897
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:16:52.897
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:16:52.897
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:16:52.897
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:16:52.899
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:16:52.899
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:16:52.899
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:16:52.899
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:16:52.899
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:16:52.915
DTC Client socket (1) | Closed. | 2020-10-07 05:16:52.915
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:17:22.907
DTC Client socket (1) | Creating socket. | 2020-10-07 05:17:22.907
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:17:22.907
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:17:22.907
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:17:22.924
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:17:22.924
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:17:22.924
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:17:22.964
SC Data - All Services | Sending logon request message. | 2020-10-07 05:17:22.964
SC Data - All Services | Received logon response. | 2020-10-07 05:17:23.592
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:17:23.592
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:17:23.592
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:17:23.592
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:17:23.592
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:17:23.593
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:17:23.593
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:17:23.593
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:17:23.593
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:17:23.593
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:17:23.608
DTC Client socket (1) | Closed. | 2020-10-07 05:17:23.608
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:17:53.599
DTC Client socket (1) | Creating socket. | 2020-10-07 05:17:53.600
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:17:53.600
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:17:53.600
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:17:53.628
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:17:53.628
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:17:53.628
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:17:53.677
SC Data - All Services | Sending logon request message. | 2020-10-07 05:17:53.677
SC Data - All Services | Received logon response. | 2020-10-07 05:17:54.302
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:17:54.302
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:17:54.302
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:17:54.302
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:17:54.302
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:17:54.302
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:17:54.302
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:17:54.302
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:17:54.302
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:17:54.303
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:17:54.317
DTC Client socket (1) | Closed. | 2020-10-07 05:17:54.317
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:18:24.298
DTC Client socket (1) | Creating socket. | 2020-10-07 05:18:24.298
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:18:24.298
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:18:24.298
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:18:24.325
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:18:24.325
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:18:24.325
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:18:24.392
SC Data - All Services | Sending logon request message. | 2020-10-07 05:18:24.392
SC Data - All Services | Received logon response. | 2020-10-07 05:18:25.095
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:18:25.095
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:18:25.095
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:18:25.095
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:18:25.095
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:18:25.095
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:18:25.095
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:18:25.095
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:18:25.095
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:18:25.095
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:18:25.120
DTC Client socket (1) | Closed. | 2020-10-07 05:18:25.120
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:18:55.093
DTC Client socket (1) | Creating socket. | 2020-10-07 05:18:55.094
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:18:55.094
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:18:55.094
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:18:55.117
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:18:55.117
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:18:55.117
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:18:55.162
SC Data - All Services | Sending logon request message. | 2020-10-07 05:18:55.162
SC Data - All Services | Received logon response. | 2020-10-07 05:18:55.841
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:18:55.841
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:18:55.841
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:18:55.841
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:18:55.841
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:18:55.841
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:18:55.841
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:18:55.841
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:18:55.841
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:18:55.841
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:18:55.854
DTC Client socket (1) | Closed. | 2020-10-07 05:18:55.854
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:19:25.837
DTC Client socket (1) | Creating socket. | 2020-10-07 05:19:25.838
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:19:25.838
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:19:25.838
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:19:25.851
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:19:25.851
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:19:25.851
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:19:25.883
SC Data - All Services | Sending logon request message. | 2020-10-07 05:19:25.883
SC Data - All Services | Received logon response. | 2020-10-07 05:19:26.491
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:19:26.491
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:19:26.491
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:19:26.491
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:19:26.491
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:19:26.492
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:19:26.492
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:19:26.492
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:19:26.492
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:19:26.492
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:19:26.506
DTC Client socket (1) | Closed. | 2020-10-07 05:19:26.506
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:19:56.493
DTC Client socket (1) | Creating socket. | 2020-10-07 05:19:56.493
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:19:56.493
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:19:56.493
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:19:56.517
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:19:56.517
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:19:56.517
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:19:56.562
SC Data - All Services | Sending logon request message. | 2020-10-07 05:19:56.562
SC Data - All Services | Received logon response. | 2020-10-07 05:19:57.221
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:19:57.221
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:19:57.221
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:19:57.221
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:19:57.221
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:19:57.221
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:19:57.221
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:19:57.221
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:19:57.221
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:19:57.221
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:19:57.234
DTC Client socket (1) | Closed. | 2020-10-07 05:19:57.234
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:20:27.217
DTC Client socket (1) | Creating socket. | 2020-10-07 05:20:27.218
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:20:27.218
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:20:27.218
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:20:27.246
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:20:27.246
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:20:27.246
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:20:27.296
SC Data - All Services | Sending logon request message. | 2020-10-07 05:20:27.296
SC Data - All Services | Received logon response. | 2020-10-07 05:20:27.957
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:20:27.957
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:20:27.957
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:20:27.957
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:20:27.957
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:20:27.957
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:20:27.957
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:20:27.957
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:20:27.957
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:20:27.957
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:20:27.984
DTC Client socket (1) | Closed. | 2020-10-07 05:20:27.984
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:20:57.956
DTC Client socket (1) | Creating socket. | 2020-10-07 05:20:57.956
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:20:57.956
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:20:57.956
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:20:57.970
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:20:57.970
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:20:57.970
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:20:58.010
SC Data - All Services | Sending logon request message. | 2020-10-07 05:20:58.010
SC Data - All Services | Received logon response. | 2020-10-07 05:20:58.662
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:20:58.662
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:20:58.662
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:20:58.662
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:20:58.662
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:20:58.663
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:20:58.663
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:20:58.663
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:20:58.663
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:20:58.663
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:20:58.677
DTC Client socket (1) | Closed. | 2020-10-07 05:20:58.677
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:21:28.659
DTC Client socket (1) | Creating socket. | 2020-10-07 05:21:28.660
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:21:28.660
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:21:28.660
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:21:28.674
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:21:28.674
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:21:28.674
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:21:28.698
SC Data - All Services | Sending logon request message. | 2020-10-07 05:21:28.698
SC Data - All Services | Received logon response. | 2020-10-07 05:21:29.361
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:21:29.361
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:21:29.361
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:21:29.361
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:21:29.361
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:21:29.361
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:21:29.361
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:21:29.361
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:21:29.361
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:21:29.361
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:21:29.375
DTC Client socket (1) | Closed. | 2020-10-07 05:21:29.375
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:21:59.367
DTC Client socket (1) | Creating socket. | 2020-10-07 05:21:59.368
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:21:59.368
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:21:59.368
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:21:59.391
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:21:59.391
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:21:59.391
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:21:59.439
SC Data - All Services | Sending logon request message. | 2020-10-07 05:21:59.439
SC Data - All Services | Received logon response. | 2020-10-07 05:22:00.048
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:22:00.048
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:22:00.048
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:22:00.048
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:22:00.048
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:22:00.048
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:22:00.048
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:22:00.048
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:22:00.048
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:22:00.048
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:22:00.069
DTC Client socket (1) | Closed. | 2020-10-07 05:22:00.069
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:22:30.051
DTC Client socket (1) | Creating socket. | 2020-10-07 05:22:30.052
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:22:30.052
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:22:30.052
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:22:30.081
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:22:30.081
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:22:30.081
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:22:30.146
SC Data - All Services | Sending logon request message. | 2020-10-07 05:22:30.146
SC Data - All Services | Received logon response. | 2020-10-07 05:22:30.829
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:22:30.829
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:22:30.829
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:22:30.829
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:22:30.829
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:22:30.830
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:22:30.830
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:22:30.830
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:22:30.830
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:22:30.830
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:22:30.855
DTC Client socket (1) | Closed. | 2020-10-07 05:22:30.855
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:23:00.829
DTC Client socket (1) | Creating socket. | 2020-10-07 05:23:00.829
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:23:00.829
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:23:00.829
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:23:00.853
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:23:00.853
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:23:00.853
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:23:00.872
SC Data - All Services | Sending logon request message. | 2020-10-07 05:23:00.872
SC Data - All Services | Received logon response. | 2020-10-07 05:23:01.564
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:23:01.564
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:23:01.564
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:23:01.564
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:23:01.564
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:23:01.564
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:23:01.564
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:23:01.564
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:23:01.564
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:23:01.564
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:23:01.577
DTC Client socket (1) | Closed. | 2020-10-07 05:23:01.577
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:23:31.563
DTC Client socket (1) | Creating socket. | 2020-10-07 05:23:31.564
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:23:31.564
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:23:31.564
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:23:31.593
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:23:31.594
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:23:31.594
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:23:31.622
SC Data - All Services | Sending logon request message. | 2020-10-07 05:23:31.622
SC Data - All Services | Received logon response. | 2020-10-07 05:23:32.204
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:23:32.204
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:23:32.204
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:23:32.204
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:23:32.204
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:23:32.204
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:23:32.204
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:23:32.204
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:23:32.204
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:23:32.204
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:23:32.222
DTC Client socket (1) | Closed. | 2020-10-07 05:23:32.222
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:24:02.202
DTC Client socket (1) | Creating socket. | 2020-10-07 05:24:02.203
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:24:02.203
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:24:02.203
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:24:02.229
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:24:02.229
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:24:02.230
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:24:02.262
SC Data - All Services | Sending logon request message. | 2020-10-07 05:24:02.262
SC Data - All Services | Received logon response. | 2020-10-07 05:24:02.901
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:24:02.901
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:24:02.901
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:24:02.901
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:24:02.901
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:24:02.901
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:24:02.901
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:24:02.901
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:24:02.901
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:24:02.901
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:24:02.916
DTC Client socket (1) | Closed. | 2020-10-07 05:24:02.916
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:24:32.902
DTC Client socket (1) | Creating socket. | 2020-10-07 05:24:32.903
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:24:32.903
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:24:32.903
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:24:32.931
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:24:32.931
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:24:32.931
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:24:32.998
SC Data - All Services | Sending logon request message. | 2020-10-07 05:24:32.998
SC Data - All Services | Received logon response. | 2020-10-07 05:24:33.712
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:24:33.712
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:24:33.712
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:24:33.712
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:24:33.712
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:24:33.712
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:24:33.712
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:24:33.712
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:24:33.712
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:24:33.712
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:24:33.737
DTC Client socket (1) | Closed. | 2020-10-07 05:24:33.737
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:25:03.715
DTC Client socket (1) | Creating socket. | 2020-10-07 05:25:03.715
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:25:03.715
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:25:03.715
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:25:03.743
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:25:03.743
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:25:03.743
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:25:03.777
SC Data - All Services | Sending logon request message. | 2020-10-07 05:25:03.777
SC Data - All Services | Received logon response. | 2020-10-07 05:25:04.453
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:25:04.453
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:25:04.453
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:25:04.453
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:25:04.453
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:25:04.453
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:25:04.453
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:25:04.453
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:25:04.453
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:25:04.453
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:25:04.467
DTC Client socket (1) | Closed. | 2020-10-07 05:25:04.467
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:25:34.449
DTC Client socket (1) | Creating socket. | 2020-10-07 05:25:34.449
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:25:34.450
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:25:34.450
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:25:34.463
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:25:34.463
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:25:34.463
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:25:34.489
SC Data - All Services | Sending logon request message. | 2020-10-07 05:25:34.489
SC Data - All Services | Received logon response. | 2020-10-07 05:25:35.101
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:25:35.101
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:25:35.101
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:25:35.101
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:25:35.101
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:25:35.102
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:25:35.102
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:25:35.102
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:25:35.102
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:25:35.102
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:25:35.117
DTC Client socket (1) | Closed. | 2020-10-07 05:25:35.117
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:26:05.108
DTC Client socket (1) | Creating socket. | 2020-10-07 05:26:05.108
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:26:05.108
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:26:05.108
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:26:05.142
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:26:05.142
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:26:05.142
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:26:05.172
SC Data - All Services | Sending logon request message. | 2020-10-07 05:26:05.172
SC Data - All Services | Received logon response. | 2020-10-07 05:26:05.828
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:26:05.828
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:26:05.828
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:26:05.828
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:26:05.828
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:26:05.828
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:26:05.828
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:26:05.828
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:26:05.828
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:26:05.828
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:26:05.840
DTC Client socket (1) | Closed. | 2020-10-07 05:26:05.840
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:26:35.829
DTC Client socket (1) | Creating socket. | 2020-10-07 05:26:35.830
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:26:35.831
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:26:35.831
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:26:35.860
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:26:35.860
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:26:35.860
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:26:35.921
SC Data - All Services | Sending logon request message. | 2020-10-07 05:26:35.921
SC Data - All Services | Received logon response. | 2020-10-07 05:26:36.599
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:26:36.599
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:26:36.599
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:26:36.599
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:26:36.599
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:26:36.599
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:26:36.599
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:26:36.599
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:26:36.599
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:26:36.599
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:26:36.625
DTC Client socket (1) | Closed. | 2020-10-07 05:26:36.625
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:27:06.596
DTC Client socket (1) | Creating socket. | 2020-10-07 05:27:06.596
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:27:06.596
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:27:06.596
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:27:06.618
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:27:06.618
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:27:06.618
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:27:06.638
SC Data - All Services | Sending logon request message. | 2020-10-07 05:27:06.638
SC Data - All Services | Received logon response. | 2020-10-07 05:27:07.287
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:27:07.287
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:27:07.287
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:27:07.287
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:27:07.287
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:27:07.288
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:27:07.288
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:27:07.288
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:27:07.288
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:27:07.288
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:27:07.303
DTC Client socket (1) | Closed. | 2020-10-07 05:27:07.303
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1404 seconds. | 2020-10-07 05:27:28.386
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0420 seconds. | 2020-10-07 05:27:28.429
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:27:37.275
DTC Client socket (1) | Creating socket. | 2020-10-07 05:27:37.276
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:27:37.276
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:27:37.276
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:27:37.302
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:27:37.302
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:27:37.302
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:27:37.330
SC Data - All Services | Sending logon request message. | 2020-10-07 05:27:37.330
SC Data - All Services | Received logon response. | 2020-10-07 05:27:37.968
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:27:37.968
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:27:37.968
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:27:37.968
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:27:37.968
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:27:37.969
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:27:37.969
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:27:37.969
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:27:37.969
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:27:37.969
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:27:37.982
DTC Client socket (1) | Closed. | 2020-10-07 05:27:37.982
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:28:07.964
DTC Client socket (1) | Creating socket. | 2020-10-07 05:28:07.964
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:28:07.964
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:28:07.964
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:28:07.996
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:28:07.996
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:28:07.996
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:28:08.032
SC Data - All Services | Sending logon request message. | 2020-10-07 05:28:08.032
SC Data - All Services | Received logon response. | 2020-10-07 05:28:08.663
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:28:08.663
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:28:08.663
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:28:08.663
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:28:08.663
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:28:08.664
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:28:08.664
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:28:08.664
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:28:08.664
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:28:08.664
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:28:08.676
DTC Client socket (1) | Closed. | 2020-10-07 05:28:08.676
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:28:38.677
DTC Client socket (1) | Creating socket. | 2020-10-07 05:28:38.677
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:28:38.677
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:28:38.677
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:28:38.704
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:28:38.704
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:28:38.704
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:28:38.751
SC Data - All Services | Sending logon request message. | 2020-10-07 05:28:38.751
SC Data - All Services | Received logon response. | 2020-10-07 05:28:39.406
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:28:39.406
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:28:39.406
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:28:39.406
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:28:39.406
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:28:39.406
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:28:39.406
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:28:39.406
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:28:39.406
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:28:39.406
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:28:39.433
DTC Client socket (1) | Closed. | 2020-10-07 05:28:39.433
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:29:09.415
DTC Client socket (1) | Creating socket. | 2020-10-07 05:29:09.415
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:29:09.416
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:29:09.416
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:29:09.445
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:29:09.446
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:29:09.446
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:29:09.491
SC Data - All Services | Sending logon request message. | 2020-10-07 05:29:09.491
SC Data - All Services | Received logon response. | 2020-10-07 05:29:10.154
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:29:10.154
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:29:10.154
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:29:10.154
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:29:10.154
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:29:10.154
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:29:10.154
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:29:10.154
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:29:10.154
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:29:10.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:29:10.168
DTC Client socket (1) | Closed. | 2020-10-07 05:29:10.168
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:29:40.160
DTC Client socket (1) | Creating socket. | 2020-10-07 05:29:40.161
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:29:40.161
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:29:40.161
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:29:40.178
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:29:40.178
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:29:40.178
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:29:40.214
SC Data - All Services | Sending logon request message. | 2020-10-07 05:29:40.214
SC Data - All Services | Received logon response. | 2020-10-07 05:29:40.884
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:29:40.884
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:29:40.884
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:29:40.884
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:29:40.884
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:29:40.885
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:29:40.885
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:29:40.885
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:29:40.885
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:29:40.885
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:29:40.902
DTC Client socket (1) | Closed. | 2020-10-07 05:29:40.903
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:30:10.892
DTC Client socket (1) | Creating socket. | 2020-10-07 05:30:10.892
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:30:10.892
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:30:10.892
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:30:10.907
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:30:10.907
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:30:10.908
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:30:10.949
SC Data - All Services | Sending logon request message. | 2020-10-07 05:30:10.949
SC Data - All Services | Received logon response. | 2020-10-07 05:30:11.604
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:30:11.604
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:30:11.604
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:30:11.604
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:30:11.604
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:30:11.604
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:30:11.604
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:30:11.604
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:30:11.604
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:30:11.604
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:30:11.619
DTC Client socket (1) | Closed. | 2020-10-07 05:30:11.619
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:30:41.610
DTC Client socket (1) | Creating socket. | 2020-10-07 05:30:41.610
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:30:41.610
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:30:41.610
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:30:41.641
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:30:41.641
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:30:41.641
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:30:41.682
SC Data - All Services | Sending logon request message. | 2020-10-07 05:30:41.682
SC Data - All Services | Received logon response. | 2020-10-07 05:30:42.413
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:30:42.413
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:30:42.413
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:30:42.413
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:30:42.413
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:30:42.413
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:30:42.413
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:30:42.413
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:30:42.413
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:30:42.413
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:30:42.439
DTC Client socket (1) | Closed. | 2020-10-07 05:30:42.439
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:31:12.404
DTC Client socket (1) | Creating socket. | 2020-10-07 05:31:12.404
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:31:12.405
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:31:12.405
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:31:12.426
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:31:12.426
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:31:12.426
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:31:12.462
SC Data - All Services | Sending logon request message. | 2020-10-07 05:31:12.462
SC Data - All Services | Received logon response. | 2020-10-07 05:31:13.128
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:31:13.128
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:31:13.128
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:31:13.128
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:31:13.128
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:31:13.128
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:31:13.128
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:31:13.128
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:31:13.128
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:31:13.128
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:31:13.141
DTC Client socket (1) | Closed. | 2020-10-07 05:31:13.141
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:31:43.126
DTC Client socket (1) | Creating socket. | 2020-10-07 05:31:43.127
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:31:43.127
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:31:43.127
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:31:43.141
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:31:43.141
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:31:43.141
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:31:43.172
SC Data - All Services | Sending logon request message. | 2020-10-07 05:31:43.172
SC Data - All Services | Received logon response. | 2020-10-07 05:31:43.814
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:31:43.814
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:31:43.814
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:31:43.814
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:31:43.814
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:31:43.814
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:31:43.814
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:31:43.814
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:31:43.815
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:31:43.815
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:31:43.827
DTC Client socket (1) | Closed. | 2020-10-07 05:31:43.828
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:32:13.806
DTC Client socket (1) | Creating socket. | 2020-10-07 05:32:13.807
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:32:13.807
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:32:13.807
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:32:13.828
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:32:13.828
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:32:13.828
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:32:13.868
SC Data - All Services | Sending logon request message. | 2020-10-07 05:32:13.868
SC Data - All Services | Received logon response. | 2020-10-07 05:32:14.525
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:32:14.525
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:32:14.525
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:32:14.525
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:32:14.525
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:32:14.525
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:32:14.525
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:32:14.525
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:32:14.525
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:32:14.525
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:32:14.539
DTC Client socket (1) | Closed. | 2020-10-07 05:32:14.539
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:32:44.533
DTC Client socket (1) | Creating socket. | 2020-10-07 05:32:44.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:32:44.533
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:32:44.534
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:32:44.561
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:32:44.561
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:32:44.561
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:32:44.610
SC Data - All Services | Sending logon request message. | 2020-10-07 05:32:44.610
SC Data - All Services | Received logon response. | 2020-10-07 05:32:45.300
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:32:45.300
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:32:45.300
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:32:45.300
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:32:45.300
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:32:45.300
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:32:45.300
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:32:45.300
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:32:45.300
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:32:45.300
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:32:45.325
DTC Client socket (1) | Closed. | 2020-10-07 05:32:45.325
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:33:15.297
DTC Client socket (1) | Creating socket. | 2020-10-07 05:33:15.298
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:33:15.298
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:33:15.298
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:33:15.311
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:33:15.311
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:33:15.311
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:33:15.335
SC Data - All Services | Sending logon request message. | 2020-10-07 05:33:15.335
SC Data - All Services | Received logon response. | 2020-10-07 05:33:15.997
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:33:15.997
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:33:15.997
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:33:15.997
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:33:15.997
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:33:15.997
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:33:15.997
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:33:15.997
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:33:15.997
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:33:15.997
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:33:16.010
DTC Client socket (1) | Closed. | 2020-10-07 05:33:16.010
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:33:46.005
DTC Client socket (1) | Creating socket. | 2020-10-07 05:33:46.005
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:33:46.005
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:33:46.006
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:33:46.026
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:33:46.026
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:33:46.026
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:33:46.050
SC Data - All Services | Sending logon request message. | 2020-10-07 05:33:46.050
SC Data - All Services | Received logon response. | 2020-10-07 05:33:46.702
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:33:46.702
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:33:46.702
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:33:46.702
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:33:46.703
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:33:46.703
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:33:46.703
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:33:46.703
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:33:46.703
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:33:46.703
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:33:46.717
DTC Client socket (1) | Closed. | 2020-10-07 05:33:46.717
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:34:16.703
DTC Client socket (1) | Creating socket. | 2020-10-07 05:34:16.704
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:34:16.704
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:34:16.704
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:34:16.734
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:34:16.734
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:34:16.734
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:34:16.762
SC Data - All Services | Sending logon request message. | 2020-10-07 05:34:16.762
SC Data - All Services | Received logon response. | 2020-10-07 05:34:17.423
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:34:17.423
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:34:17.423
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:34:17.423
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:34:17.423
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:34:17.423
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:34:17.423
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:34:17.423
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:34:17.423
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:34:17.423
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:34:17.439
DTC Client socket (1) | Closed. | 2020-10-07 05:34:17.439
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:34:47.414
DTC Client socket (1) | Creating socket. | 2020-10-07 05:34:47.414
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:34:47.414
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:34:47.414
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:34:47.445
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:34:47.445
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:34:47.445
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:34:47.501
SC Data - All Services | Sending logon request message. | 2020-10-07 05:34:47.501
SC Data - All Services | Received logon response. | 2020-10-07 05:34:48.221
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:34:48.221
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:34:48.221
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:34:48.221
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:34:48.221
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:34:48.221
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:34:48.221
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:34:48.221
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:34:48.221
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:34:48.221
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:34:48.249
DTC Client socket (1) | Closed. | 2020-10-07 05:34:48.249
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:35:18.215
DTC Client socket (1) | Creating socket. | 2020-10-07 05:35:18.215
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:35:18.215
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:35:18.215
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:35:18.230
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:35:18.230
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:35:18.230
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:35:18.278
SC Data - All Services | Sending logon request message. | 2020-10-07 05:35:18.278
SC Data - All Services | Received logon response. | 2020-10-07 05:35:18.953
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:35:18.953
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:35:18.953
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:35:18.953
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:35:18.953
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:35:18.953
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:35:18.953
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:35:18.954
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:35:18.954
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:35:18.954
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:35:18.969
DTC Client socket (1) | Closed. | 2020-10-07 05:35:18.969
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:35:48.951
DTC Client socket (1) | Creating socket. | 2020-10-07 05:35:48.951
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:35:48.951
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:35:48.951
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:35:48.974
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:35:48.974
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:35:48.974
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:35:48.993
SC Data - All Services | Sending logon request message. | 2020-10-07 05:35:48.993
SC Data - All Services | Received logon response. | 2020-10-07 05:35:49.665
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:35:49.665
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:35:49.665
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:35:49.665
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:35:49.665
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:35:49.665
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:35:49.665
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:35:49.665
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:35:49.665
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:35:49.665
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:35:49.677
DTC Client socket (1) | Closed. | 2020-10-07 05:35:49.678
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:36:19.666
DTC Client socket (2) | Creating socket. | 2020-10-07 05:36:19.667
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 05:36:19.667
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:36:19.667
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:36:19.690
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:36:19.690
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:36:19.690
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:36:19.736
SC Data - All Services | Sending logon request message. | 2020-10-07 05:36:19.736
SC Data - All Services | Received logon response. | 2020-10-07 05:36:20.367
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:36:20.367
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:36:20.367
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:36:20.367
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:36:20.367
DTC Client socket (2) | CloseSocket call. | 2020-10-07 05:36:20.367
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:36:20.367
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:36:20.367
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:36:20.367
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:36:20.368
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 05:36:20.382
DTC Client socket (2) | Closed. | 2020-10-07 05:36:20.382
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:36:50.376
DTC Client socket (1) | Creating socket. | 2020-10-07 05:36:50.376
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:36:50.376
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:36:50.376
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:36:50.404
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:36:50.404
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:36:50.404
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:36:50.430
SC Data - All Services | Sending logon request message. | 2020-10-07 05:36:50.430
SC Data - All Services | Received logon response. | 2020-10-07 05:36:51.139
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:36:51.139
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:36:51.139
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:36:51.139
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:36:51.139
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:36:51.139
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:36:51.139
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:36:51.140
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:36:51.140
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:36:51.140
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:36:51.166
DTC Client socket (1) | Closed. | 2020-10-07 05:36:51.166
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:37:21.134
DTC Client socket (1) | Creating socket. | 2020-10-07 05:37:21.134
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:37:21.134
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:37:21.135
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:37:21.156
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:37:21.156
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:37:21.156
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:37:21.195
SC Data - All Services | Sending logon request message. | 2020-10-07 05:37:21.195
SC Data - All Services | Received logon response. | 2020-10-07 05:37:21.855
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:37:21.855
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:37:21.855
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:37:21.855
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:37:21.855
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:37:21.855
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:37:21.855
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:37:21.855
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:37:21.855
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:37:21.855
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:37:21.867
DTC Client socket (1) | Closed. | 2020-10-07 05:37:21.868
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:37:51.866
DTC Client socket (1) | Creating socket. | 2020-10-07 05:37:51.867
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:37:51.867
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:37:51.867
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:37:51.882
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:37:51.882
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:37:51.883
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:37:51.903
SC Data - All Services | Sending logon request message. | 2020-10-07 05:37:51.903
SC Data - All Services | Received logon response. | 2020-10-07 05:37:52.545
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:37:52.545
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:37:52.545
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:37:52.545
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:37:52.545
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:37:52.545
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:37:52.545
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:37:52.545
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:37:52.545
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:37:52.545
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:37:52.558
DTC Client socket (1) | Closed. | 2020-10-07 05:37:52.558
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:38:22.538
DTC Client socket (1) | Creating socket. | 2020-10-07 05:38:22.539
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:38:22.539
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:38:22.539
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:38:22.557
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:38:22.557
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:38:22.557
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:38:22.609
SC Data - All Services | Sending logon request message. | 2020-10-07 05:38:22.609
SC Data - All Services | Received logon response. | 2020-10-07 05:38:23.245
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:38:23.245
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:38:23.245
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:38:23.245
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:38:23.245
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:38:23.246
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:38:23.246
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:38:23.246
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:38:23.246
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:38:23.246
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:38:23.259
DTC Client socket (1) | Closed. | 2020-10-07 05:38:23.259
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:38:53.242
DTC Client socket (1) | Creating socket. | 2020-10-07 05:38:53.242
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:38:53.242
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:38:53.242
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:38:53.273
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:38:53.273
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:38:53.273
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:38:53.332
SC Data - All Services | Sending logon request message. | 2020-10-07 05:38:53.332
SC Data - All Services | Received logon response. | 2020-10-07 05:38:54.031
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:38:54.031
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:38:54.031
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:38:54.031
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:38:54.031
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:38:54.031
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:38:54.031
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:38:54.031
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:38:54.031
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:38:54.031
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:38:54.057
DTC Client socket (1) | Closed. | 2020-10-07 05:38:54.057
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:39:24.037
DTC Client socket (1) | Creating socket. | 2020-10-07 05:39:24.038
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:39:24.038
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:39:24.038
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:39:24.064
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:39:24.064
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:39:24.064
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:39:24.116
SC Data - All Services | Sending logon request message. | 2020-10-07 05:39:24.116
SC Data - All Services | Received logon response. | 2020-10-07 05:39:24.776
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:39:24.776
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:39:24.777
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:39:24.777
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:39:24.777
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:39:24.778
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:39:24.778
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:39:24.778
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:39:24.778
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:39:24.778
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:39:24.793
DTC Client socket (1) | Closed. | 2020-10-07 05:39:24.793
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:39:54.783
DTC Client socket (1) | Creating socket. | 2020-10-07 05:39:54.784
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:39:54.784
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:39:54.784
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:39:54.811
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:39:54.811
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:39:54.811
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:39:54.845
SC Data - All Services | Sending logon request message. | 2020-10-07 05:39:54.845
SC Data - All Services | Received logon response. | 2020-10-07 05:39:55.016
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:39:55.016
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:39:55.016
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:39:55.016
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:39:55.016
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:39:55.016
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:39:55.016
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:39:55.016
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:39:55.016
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:39:55.016
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:39:55.030
DTC Client socket (1) | Closed. | 2020-10-07 05:39:55.030
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:40:25.015
DTC Client socket (1) | Creating socket. | 2020-10-07 05:40:25.015
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:40:25.015
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:40:25.015
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:40:25.038
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:40:25.038
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:40:25.038
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:40:25.060
SC Data - All Services | Sending logon request message. | 2020-10-07 05:40:25.060
SC Data - All Services | Received logon response. | 2020-10-07 05:40:25.697
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:40:25.697
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:40:25.697
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:40:25.697
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:40:25.697
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:40:25.697
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:40:25.697
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:40:25.697
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:40:25.697
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:40:25.697
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:40:25.710
DTC Client socket (1) | Closed. | 2020-10-07 05:40:25.710
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:40:55.707
DTC Client socket (1) | Creating socket. | 2020-10-07 05:40:55.708
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:40:55.708
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:40:55.708
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:40:55.735
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:40:55.735
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:40:55.735
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:40:55.777
SC Data - All Services | Sending logon request message. | 2020-10-07 05:40:55.777
SC Data - All Services | Received logon response. | 2020-10-07 05:40:56.469
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:40:56.469
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:40:56.469
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:40:56.469
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:40:56.469
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:40:56.469
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:40:56.469
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:40:56.469
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:40:56.470
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:40:56.470
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:40:56.495
DTC Client socket (1) | Closed. | 2020-10-07 05:40:56.495
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:41:26.476
DTC Client socket (1) | Creating socket. | 2020-10-07 05:41:26.476
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:41:26.476
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:41:26.476
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:41:26.492
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:41:26.492
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:41:26.492
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:41:26.538
SC Data - All Services | Sending logon request message. | 2020-10-07 05:41:26.538
SC Data - All Services | Received logon response. | 2020-10-07 05:41:27.199
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:41:27.199
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:41:27.199
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:41:27.199
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:41:27.199
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:41:27.199
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:41:27.199
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:41:27.199
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:41:27.199
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:41:27.199
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:41:27.211
DTC Client socket (1) | Closed. | 2020-10-07 05:41:27.211
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:41:57.208
DTC Client socket (1) | Creating socket. | 2020-10-07 05:41:57.209
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:41:57.209
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:41:57.209
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:41:57.231
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:41:57.231
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:41:57.231
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:41:57.272
SC Data - All Services | Sending logon request message. | 2020-10-07 05:41:57.272
SC Data - All Services | Received logon response. | 2020-10-07 05:41:57.854
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:41:57.854
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:41:57.854
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:41:57.854
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:41:57.854
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:41:57.854
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:41:57.854
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:41:57.854
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:41:57.854
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:41:57.854
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:41:57.870
DTC Client socket (1) | Closed. | 2020-10-07 05:41:57.870
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:42:27.858
DTC Client socket (1) | Creating socket. | 2020-10-07 05:42:27.858
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:42:27.858
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:42:27.858
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:42:27.880
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:42:27.880
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:42:27.880
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:42:27.893
SC Data - All Services | Sending logon request message. | 2020-10-07 05:42:27.893
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1087 seconds. | 2020-10-07 05:42:28.543
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0438 seconds. | 2020-10-07 05:42:28.587
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:42:28.595
SC Data - All Services | Received logon response. | 2020-10-07 05:42:28.596
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:42:28.596
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:42:28.597
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:42:28.597
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:42:28.597
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:42:28.597
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:42:28.597
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:42:28.597
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:42:28.597
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-10-07 05:42:28.597
DTC Client socket (1) | Closed. | 2020-10-07 05:42:28.597
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:42:58.587
DTC Client socket (1) | Creating socket. | 2020-10-07 05:42:58.587
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:42:58.587
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:42:58.587
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:42:58.618
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:42:58.618
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:42:58.618
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:42:58.680
SC Data - All Services | Sending logon request message. | 2020-10-07 05:42:58.680
SC Data - All Services | Received logon response. | 2020-10-07 05:42:59.382
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:42:59.382
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:42:59.382
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:42:59.382
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:42:59.382
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:42:59.382
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:42:59.382
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:42:59.382
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:42:59.382
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:42:59.382
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:42:59.408
DTC Client socket (1) | Closed. | 2020-10-07 05:42:59.408
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:43:29.368
DTC Client socket (1) | Creating socket. | 2020-10-07 05:43:29.369
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:43:29.369
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:43:29.369
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:43:29.385
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:43:29.385
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:43:29.385
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:43:29.411
SC Data - All Services | Sending logon request message. | 2020-10-07 05:43:29.411
SC Data - All Services | Received logon response. | 2020-10-07 05:43:30.052
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:43:30.052
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:43:30.052
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:43:30.052
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:43:30.052
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:43:30.052
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:43:30.052
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:43:30.052
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:43:30.052
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:43:30.052
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:43:30.067
DTC Client socket (1) | Closed. | 2020-10-07 05:43:30.067
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:44:00.047
DTC Client socket (1) | Creating socket. | 2020-10-07 05:44:00.048
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:44:00.048
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:44:00.048
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:44:00.069
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:44:00.069
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:44:00.069
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:44:00.100
SC Data - All Services | Sending logon request message. | 2020-10-07 05:44:00.100
SC Data - All Services | Received logon response. | 2020-10-07 05:44:00.777
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:44:00.777
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:44:00.777
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:44:00.777
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:44:00.777
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:44:00.778
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:44:00.778
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:44:00.778
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:44:00.778
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:44:00.778
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:44:00.793
DTC Client socket (1) | Closed. | 2020-10-07 05:44:00.793
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:44:30.775
DTC Client socket (1) | Creating socket. | 2020-10-07 05:44:30.775
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:44:30.775
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:44:30.775
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:44:30.803
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:44:30.803
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:44:30.803
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:44:30.821
SC Data - All Services | Sending logon request message. | 2020-10-07 05:44:30.821
SC Data - All Services | Received logon response. | 2020-10-07 05:44:31.447
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:44:31.447
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:44:31.447
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:44:31.447
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:44:31.447
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:44:31.447
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:44:31.447
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:44:31.447
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:44:31.447
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:44:31.447
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:44:31.461
DTC Client socket (1) | Closed. | 2020-10-07 05:44:31.462
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:45:01.448
DTC Client socket (1) | Creating socket. | 2020-10-07 05:45:01.449
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:45:01.449
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:45:01.449
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:45:01.479
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:45:01.479
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:45:01.479
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:45:01.535
SC Data - All Services | Sending logon request message. | 2020-10-07 05:45:01.535
SC Data - All Services | Received logon response. | 2020-10-07 05:45:02.256
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:45:02.256
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:45:02.256
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:45:02.256
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:45:02.256
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:45:02.256
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:45:02.256
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:45:02.256
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:45:02.256
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:45:02.256
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:45:02.286
DTC Client socket (1) | Closed. | 2020-10-07 05:45:02.286
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:45:32.248
DTC Client socket (1) | Creating socket. | 2020-10-07 05:45:32.248
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:45:32.249
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:45:32.249
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:45:32.280
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:45:32.280
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:45:32.281
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:45:32.322
SC Data - All Services | Sending logon request message. | 2020-10-07 05:45:32.322
SC Data - All Services | Received logon response. | 2020-10-07 05:45:32.996
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:45:32.996
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:45:32.996
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:45:32.996
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:45:32.996
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:45:32.997
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:45:32.997
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:45:32.997
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:45:32.997
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:45:32.997
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:45:33.012
DTC Client socket (1) | Closed. | 2020-10-07 05:45:33.012
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:46:03.006
DTC Client socket (2) | Creating socket. | 2020-10-07 05:46:03.007
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 05:46:03.007
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:46:03.007
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:46:03.028
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:46:03.028
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:46:03.028
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:46:03.057
SC Data - All Services | Sending logon request message. | 2020-10-07 05:46:03.057
SC Data - All Services | Received logon response. | 2020-10-07 05:46:03.668
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:46:03.668
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:46:03.668
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:46:03.668
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:46:03.668
DTC Client socket (2) | CloseSocket call. | 2020-10-07 05:46:03.668
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:46:03.668
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:46:03.668
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:46:03.668
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:46:03.668
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 05:46:03.684
DTC Client socket (2) | Closed. | 2020-10-07 05:46:03.684
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:46:33.675
DTC Client socket (1) | Creating socket. | 2020-10-07 05:46:33.676
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:46:33.676
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:46:33.676
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:46:33.699
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:46:33.699
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:46:33.700
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:46:33.745
SC Data - All Services | Sending logon request message. | 2020-10-07 05:46:33.745
SC Data - All Services | Received logon response. | 2020-10-07 05:46:34.378
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:46:34.378
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:46:34.378
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:46:34.378
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:46:34.378
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:46:34.379
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:46:34.379
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:46:34.379
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:46:34.379
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:46:34.379
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:46:34.394
DTC Client socket (1) | Closed. | 2020-10-07 05:46:34.394
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:47:04.375
DTC Client socket (1) | Creating socket. | 2020-10-07 05:47:04.375
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:47:04.375
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:47:04.375
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:47:04.403
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:47:04.403
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:47:04.403
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:47:04.464
SC Data - All Services | Sending logon request message. | 2020-10-07 05:47:04.464
SC Data - All Services | Received logon response. | 2020-10-07 05:47:05.171
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:47:05.172
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:47:05.172
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:47:05.172
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:47:05.172
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:47:05.172
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:47:05.172
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:47:05.172
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:47:05.172
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:47:05.172
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:47:05.198
DTC Client socket (1) | Closed. | 2020-10-07 05:47:05.198
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:47:35.178
DTC Client socket (1) | Creating socket. | 2020-10-07 05:47:35.179
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:47:35.179
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:47:35.179
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:47:35.205
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:47:35.205
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:47:35.205
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:47:35.232
SC Data - All Services | Sending logon request message. | 2020-10-07 05:47:35.232
SC Data - All Services | Received logon response. | 2020-10-07 05:47:35.882
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:47:35.882
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:47:35.882
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:47:35.882
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:47:35.882
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:47:35.883
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:47:35.883
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:47:35.883
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:47:35.883
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:47:35.883
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:47:35.896
DTC Client socket (1) | Closed. | 2020-10-07 05:47:35.897
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:48:05.892
DTC Client socket (1) | Creating socket. | 2020-10-07 05:48:05.892
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:48:05.892
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:48:05.892
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:48:05.905
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:48:05.905
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:48:05.906
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:48:05.947
SC Data - All Services | Sending logon request message. | 2020-10-07 05:48:05.947
SC Data - All Services | Received logon response. | 2020-10-07 05:48:06.527
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:48:06.527
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:48:06.527
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:48:06.527
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:48:06.527
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:48:06.527
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:48:06.527
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:48:06.527
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:48:06.527
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:48:06.527
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:48:06.540
DTC Client socket (1) | Closed. | 2020-10-07 05:48:06.540
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:48:36.524
DTC Client socket (1) | Creating socket. | 2020-10-07 05:48:36.524
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:48:36.524
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:48:36.524
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:48:36.554
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:48:36.554
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:48:36.554
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:48:36.592
SC Data - All Services | Sending logon request message. | 2020-10-07 05:48:36.592
SC Data - All Services | Received logon response. | 2020-10-07 05:48:37.248
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:48:37.248
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:48:37.248
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:48:37.248
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:48:37.248
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:48:37.248
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:48:37.248
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:48:37.248
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:48:37.248
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:48:37.248
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:48:37.262
DTC Client socket (1) | Closed. | 2020-10-07 05:48:37.262
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:49:07.253
DTC Client socket (1) | Creating socket. | 2020-10-07 05:49:07.253
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:49:07.253
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:49:07.253
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:49:07.282
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:49:07.283
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:49:07.283
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:49:07.337
SC Data - All Services | Sending logon request message. | 2020-10-07 05:49:07.337
SC Data - All Services | Received logon response. | 2020-10-07 05:49:07.991
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:49:07.991
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:49:07.991
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:49:07.991
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:49:07.991
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:49:07.991
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:49:07.991
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:49:07.991
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:49:07.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:49:07.991
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:49:08.016
DTC Client socket (1) | Closed. | 2020-10-07 05:49:08.016
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:49:37.988
DTC Client socket (1) | Creating socket. | 2020-10-07 05:49:37.988
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:49:37.988
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:49:37.988
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:49:38.003
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:49:38.003
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:49:38.003
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:49:38.051
SC Data - All Services | Sending logon request message. | 2020-10-07 05:49:38.051
SC Data - All Services | Received logon response. | 2020-10-07 05:49:38.695
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:49:38.695
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:49:38.695
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:49:38.695
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:49:38.695
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:49:38.695
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:49:38.695
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:49:38.695
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:49:38.695
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:49:38.695
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:49:38.708
DTC Client socket (1) | Closed. | 2020-10-07 05:49:38.708
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:50:08.699
DTC Client socket (1) | Creating socket. | 2020-10-07 05:50:08.699
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:50:08.699
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:50:08.699
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:50:08.724
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:50:08.724
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:50:08.724
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:50:08.760
SC Data - All Services | Sending logon request message. | 2020-10-07 05:50:08.760
SC Data - All Services | Received logon response. | 2020-10-07 05:50:09.571
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:50:09.571
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:50:09.571
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:50:09.571
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:50:09.571
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:50:09.571
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:50:09.571
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:50:09.571
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:50:09.571
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:50:09.571
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:50:09.585
DTC Client socket (1) | Closed. | 2020-10-07 05:50:09.585
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:50:39.574
DTC Client socket (1) | Creating socket. | 2020-10-07 05:50:39.574
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:50:39.574
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:50:39.574
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:50:39.590
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:50:39.590
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:50:39.590
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:50:39.633
SC Data - All Services | Sending logon request message. | 2020-10-07 05:50:39.633
SC Data - All Services | Received logon response. | 2020-10-07 05:50:40.291
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:50:40.291
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:50:40.291
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:50:40.291
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:50:40.291
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:50:40.291
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:50:40.291
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:50:40.291
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:50:40.291
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:50:40.292
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:50:40.306
DTC Client socket (1) | Closed. | 2020-10-07 05:50:40.306
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:51:10.289
DTC Client socket (1) | Creating socket. | 2020-10-07 05:51:10.290
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:51:10.290
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:51:10.290
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:51:10.323
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:51:10.323
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:51:10.323
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:51:10.362
SC Data - All Services | Sending logon request message. | 2020-10-07 05:51:10.362
SC Data - All Services | Received logon response. | 2020-10-07 05:51:11.067
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:51:11.067
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:51:11.067
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:51:11.067
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:51:11.067
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:51:11.067
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:51:11.067
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:51:11.068
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:51:11.068
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:51:11.068
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:51:11.093
DTC Client socket (1) | Closed. | 2020-10-07 05:51:11.093
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:51:41.063
DTC Client socket (1) | Creating socket. | 2020-10-07 05:51:41.063
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:51:41.063
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:51:41.063
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:51:41.086
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:51:41.086
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:51:41.086
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:51:41.135
SC Data - All Services | Sending logon request message. | 2020-10-07 05:51:41.135
SC Data - All Services | Received logon response. | 2020-10-07 05:51:41.792
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:51:41.792
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:51:41.792
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:51:41.792
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:51:41.792
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:51:41.792
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:51:41.792
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:51:41.792
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:51:41.792
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:51:41.792
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:51:41.806
DTC Client socket (1) | Closed. | 2020-10-07 05:51:41.807
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:52:11.790
DTC Client socket (1) | Creating socket. | 2020-10-07 05:52:11.790
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:52:11.790
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:52:11.790
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:52:11.805
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:52:11.805
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:52:11.806
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:52:11.838
SC Data - All Services | Sending logon request message. | 2020-10-07 05:52:11.838
SC Data - All Services | Received logon response. | 2020-10-07 05:52:12.436
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:52:12.436
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:52:12.436
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:52:12.436
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:52:12.436
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:52:12.437
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:52:12.437
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:52:12.437
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:52:12.437
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:52:12.437
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:52:12.452
DTC Client socket (1) | Closed. | 2020-10-07 05:52:12.452
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:52:42.432
DTC Client socket (1) | Creating socket. | 2020-10-07 05:52:42.433
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:52:42.433
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:52:42.433
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:52:42.459
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:52:42.459
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:52:42.459
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:52:42.476
SC Data - All Services | Sending logon request message. | 2020-10-07 05:52:42.476
SC Data - All Services | Received logon response. | 2020-10-07 05:52:43.101
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:52:43.101
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:52:43.101
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:52:43.101
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:52:43.101
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:52:43.101
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:52:43.101
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:52:43.101
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:52:43.101
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:52:43.101
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:52:43.118
DTC Client socket (1) | Closed. | 2020-10-07 05:52:43.118
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:53:13.116
DTC Client socket (1) | Creating socket. | 2020-10-07 05:53:13.116
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:53:13.116
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:53:13.116
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:53:13.145
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:53:13.145
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:53:13.145
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:53:13.184
SC Data - All Services | Sending logon request message. | 2020-10-07 05:53:13.184
SC Data - All Services | Received logon response. | 2020-10-07 05:53:13.893
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:53:13.893
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:53:13.893
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:53:13.893
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:53:13.893
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:53:13.893
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:53:13.893
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:53:13.893
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:53:13.893
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:53:13.893
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:53:13.922
DTC Client socket (1) | Closed. | 2020-10-07 05:53:13.922
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:53:43.889
DTC Client socket (1) | Creating socket. | 2020-10-07 05:53:43.889
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:53:43.890
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:53:43.890
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:53:43.911
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:53:43.911
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:53:43.911
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:53:43.947
SC Data - All Services | Sending logon request message. | 2020-10-07 05:53:43.947
SC Data - All Services | Received logon response. | 2020-10-07 05:53:44.587
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:53:44.587
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:53:44.587
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:53:44.587
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:53:44.587
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:53:44.587
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:53:44.587
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:53:44.587
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:53:44.587
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:53:44.587
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:53:44.600
DTC Client socket (1) | Closed. | 2020-10-07 05:53:44.600
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:54:14.586
DTC Client socket (1) | Creating socket. | 2020-10-07 05:54:14.587
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:54:14.587
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:54:14.587
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:54:14.603
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:54:14.603
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:54:14.603
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:54:14.636
SC Data - All Services | Sending logon request message. | 2020-10-07 05:54:14.636
SC Data - All Services | Received logon response. | 2020-10-07 05:54:15.298
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:54:15.298
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:54:15.298
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:54:15.298
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:54:15.298
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:54:15.298
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:54:15.298
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:54:15.298
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:54:15.298
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:54:15.298
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:54:15.313
DTC Client socket (1) | Closed. | 2020-10-07 05:54:15.313
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:54:45.291
DTC Client socket (1) | Creating socket. | 2020-10-07 05:54:45.292
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:54:45.292
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:54:45.292
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:54:45.313
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:54:45.313
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:54:45.313
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:54:45.333
SC Data - All Services | Sending logon request message. | 2020-10-07 05:54:45.333
SC Data - All Services | Received logon response. | 2020-10-07 05:54:45.961
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:54:45.961
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:54:45.961
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:54:45.961
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:54:45.961
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:54:45.961
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:54:45.961
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:54:45.961
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:54:45.961
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:54:45.961
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:54:45.979
DTC Client socket (1) | Closed. | 2020-10-07 05:54:45.979
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:55:15.966
DTC Client socket (1) | Creating socket. | 2020-10-07 05:55:15.966
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:55:15.966
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:55:15.966
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:55:15.992
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:55:15.992
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:55:15.992
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:55:16.034
SC Data - All Services | Sending logon request message. | 2020-10-07 05:55:16.034
SC Data - All Services | Received logon response. | 2020-10-07 05:55:16.754
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:55:16.754
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:55:16.754
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:55:16.754
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:55:16.754
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:55:16.754
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:55:16.754
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:55:16.754
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:55:16.754
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:55:16.754
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:55:16.778
DTC Client socket (1) | Closed. | 2020-10-07 05:55:16.778
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:55:46.752
DTC Client socket (1) | Creating socket. | 2020-10-07 05:55:46.752
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:55:46.752
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:55:46.752
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:55:46.768
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:55:46.768
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:55:46.768
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:55:46.808
SC Data - All Services | Sending logon request message. | 2020-10-07 05:55:46.808
SC Data - All Services | Received logon response. | 2020-10-07 05:55:47.469
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:55:47.469
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:55:47.469
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:55:47.469
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:55:47.469
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:55:47.469
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:55:47.469
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:55:47.469
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:55:47.469
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:55:47.469
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:55:47.483
DTC Client socket (1) | Closed. | 2020-10-07 05:55:47.483
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:56:17.466
DTC Client socket (2) | Creating socket. | 2020-10-07 05:56:17.466
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 05:56:17.466
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:56:17.466
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:56:17.490
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:56:17.490
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:56:17.490
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:56:17.530
SC Data - All Services | Sending logon request message. | 2020-10-07 05:56:17.530
SC Data - All Services | Received logon response. | 2020-10-07 05:56:18.147
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:56:18.147
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:56:18.147
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:56:18.147
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:56:18.147
DTC Client socket (2) | CloseSocket call. | 2020-10-07 05:56:18.147
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:56:18.147
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:56:18.147
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:56:18.147
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:56:18.148
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 05:56:18.161
DTC Client socket (2) | Closed. | 2020-10-07 05:56:18.161
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:56:48.132
DTC Client socket (1) | Creating socket. | 2020-10-07 05:56:48.133
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:56:48.133
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:56:48.133
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:56:48.157
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:56:48.157
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:56:48.158
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:56:48.189
SC Data - All Services | Sending logon request message. | 2020-10-07 05:56:48.189
SC Data - All Services | Received logon response. | 2020-10-07 05:56:48.807
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:56:48.807
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:56:48.807
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:56:48.807
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:56:48.807
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:56:48.807
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:56:48.807
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:56:48.807
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:56:48.807
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:56:48.807
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:56:48.821
DTC Client socket (1) | Closed. | 2020-10-07 05:56:48.821
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:57:18.815
DTC Client socket (1) | Creating socket. | 2020-10-07 05:57:18.815
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:57:18.815
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:57:18.815
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:57:18.844
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:57:18.844
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:57:18.844
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:57:18.876
SC Data - All Services | Sending logon request message. | 2020-10-07 05:57:18.876
SC Data - All Services | Received logon response. | 2020-10-07 05:57:19.574
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:57:19.574
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:57:19.574
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:57:19.574
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:57:19.574
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:57:19.574
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:57:19.574
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:57:19.574
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:57:19.574
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:57:19.574
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:57:19.602
DTC Client socket (1) | Closed. | 2020-10-07 05:57:19.602
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1062 seconds. | 2020-10-07 05:57:28.704
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0353 seconds. | 2020-10-07 05:57:28.740
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:57:49.581
DTC Client socket (1) | Creating socket. | 2020-10-07 05:57:49.581
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:57:49.581
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:57:49.581
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:57:49.595
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:57:49.595
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:57:49.595
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:57:49.638
SC Data - All Services | Sending logon request message. | 2020-10-07 05:57:49.638
SC Data - All Services | Received logon response. | 2020-10-07 05:57:50.271
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:57:50.271
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:57:50.271
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:57:50.271
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:57:50.271
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:57:50.272
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:57:50.272
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:57:50.272
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:57:50.272
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:57:50.272
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:57:50.286
DTC Client socket (1) | Closed. | 2020-10-07 05:57:50.286
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 05:58:20.271
DTC Client socket (1) | Creating socket. | 2020-10-07 05:58:20.272
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:58:20.272
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 05:58:20.272
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:58:20.287
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:58:20.287
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:58:20.287
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:58:20.324
SC Data - All Services | Sending logon request message. | 2020-10-07 05:58:20.324
SC Data - All Services | Received logon response. | 2020-10-07 05:58:20.995
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:58:20.995
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:58:20.995
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:58:20.995
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:58:20.995
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:58:20.996
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:58:20.996
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:58:20.996
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:58:20.996
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:58:20.996
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:58:21.010
DTC Client socket (1) | Closed. | 2020-10-07 05:58:21.010
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 05:58:50.994
DTC Client socket (1) | Creating socket. | 2020-10-07 05:58:50.994
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:58:50.994
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 05:58:50.994
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:58:51.019
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:58:51.019
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:58:51.019
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:58:51.037
SC Data - All Services | Sending logon request message. | 2020-10-07 05:58:51.037
SC Data - All Services | Received logon response. | 2020-10-07 05:58:51.675
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:58:51.675
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:58:51.675
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:58:51.675
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:58:51.675
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:58:51.675
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:58:51.675
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:58:51.676
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:58:51.676
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:58:51.676
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:58:51.691
DTC Client socket (1) | Closed. | 2020-10-07 05:58:51.691
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 05:59:21.671
DTC Client socket (1) | Creating socket. | 2020-10-07 05:59:21.671
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:59:21.671
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 05:59:21.671
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:59:21.708
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:59:21.708
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:59:21.708
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:59:21.749
SC Data - All Services | Sending logon request message. | 2020-10-07 05:59:21.749
SC Data - All Services | Received logon response. | 2020-10-07 05:59:22.453
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:59:22.453
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:59:22.453
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:59:22.453
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:59:22.453
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:59:22.453
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:59:22.453
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:59:22.453
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:59:22.453
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:59:22.453
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:59:22.479
DTC Client socket (1) | Closed. | 2020-10-07 05:59:22.479
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 05:59:52.456
DTC Client socket (1) | Creating socket. | 2020-10-07 05:59:52.457
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 05:59:52.457
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 05:59:52.457
SC Data - All Services | Network connection to server complete. | 2020-10-07 05:59:52.478
SC Data - All Services | Starting socket receive thread. | 2020-10-07 05:59:52.478
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 05:59:52.478
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 05:59:52.509
SC Data - All Services | Sending logon request message. | 2020-10-07 05:59:52.509
SC Data - All Services | Received logon response. | 2020-10-07 05:59:53.149
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 05:59:53.149
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 05:59:53.149
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 05:59:53.149
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 05:59:53.149
DTC Client socket (1) | CloseSocket call. | 2020-10-07 05:59:53.149
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 05:59:53.149
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 05:59:53.149
SC Data - All Services | Disconnected from the server. | 2020-10-07 05:59:53.149
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 05:59:53.149
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 05:59:53.164
DTC Client socket (1) | Closed. | 2020-10-07 05:59:53.164
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:00:23.161
DTC Client socket (1) | Creating socket. | 2020-10-07 06:00:23.161
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:00:23.161
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:00:23.161
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:00:23.191
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:00:23.191
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:00:23.191
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:00:23.213
SC Data - All Services | Sending logon request message. | 2020-10-07 06:00:23.213
SC Data - All Services | Received logon response. | 2020-10-07 06:00:23.834
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:00:23.834
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:00:23.834
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:00:23.834
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:00:23.835
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:00:23.835
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:00:23.835
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:00:23.835
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:00:23.835
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:00:23.835
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:00:23.848
DTC Client socket (1) | Closed. | 2020-10-07 06:00:23.848
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:00:53.833
DTC Client socket (1) | Creating socket. | 2020-10-07 06:00:53.834
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:00:53.834
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:00:53.834
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:00:53.849
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:00:53.849
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:00:53.849
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:00:53.881
SC Data - All Services | Sending logon request message. | 2020-10-07 06:00:53.881
SC Data - All Services | Received logon response. | 2020-10-07 06:00:54.509
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:00:54.509
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:00:54.509
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:00:54.509
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:00:54.509
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:00:54.509
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:00:54.509
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:00:54.509
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:00:54.509
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:00:54.510
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:00:54.525
DTC Client socket (1) | Closed. | 2020-10-07 06:00:54.525
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:01:24.511
DTC Client socket (1) | Creating socket. | 2020-10-07 06:01:24.511
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:01:24.511
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:01:24.511
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:01:24.539
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:01:24.539
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:01:24.539
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:01:24.580
SC Data - All Services | Sending logon request message. | 2020-10-07 06:01:24.580
SC Data - All Services | Received logon response. | 2020-10-07 06:01:25.276
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:01:25.276
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:01:25.276
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:01:25.276
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:01:25.276
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:01:25.277
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:01:25.277
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:01:25.277
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:01:25.277
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:01:25.277
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:01:25.302
DTC Client socket (1) | Closed. | 2020-10-07 06:01:25.302
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:01:55.277
DTC Client socket (1) | Creating socket. | 2020-10-07 06:01:55.277
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:01:55.277
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:01:55.277
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:01:55.297
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:01:55.297
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:01:55.297
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:01:55.319
SC Data - All Services | Sending logon request message. | 2020-10-07 06:01:55.319
SC Data - All Services | Received logon response. | 2020-10-07 06:01:56.004
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:01:56.004
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:01:56.004
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:01:56.004
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:01:56.004
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:01:56.004
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:01:56.004
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:01:56.004
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:01:56.004
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:01:56.005
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:01:56.018
DTC Client socket (1) | Closed. | 2020-10-07 06:01:56.018
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:02:25.995
DTC Client socket (1) | Creating socket. | 2020-10-07 06:02:25.996
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:02:25.996
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:02:25.996
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:02:26.018
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:02:26.018
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:02:26.018
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:02:26.058
SC Data - All Services | Sending logon request message. | 2020-10-07 06:02:26.058
SC Data - All Services | Received logon response. | 2020-10-07 06:02:26.714
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:02:26.714
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:02:26.714
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:02:26.714
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:02:26.714
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:02:26.714
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:02:26.714
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:02:26.714
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:02:26.714
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:02:26.714
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:02:26.727
DTC Client socket (1) | Closed. | 2020-10-07 06:02:26.727
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:02:56.713
DTC Client socket (1) | Creating socket. | 2020-10-07 06:02:56.713
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:02:56.713
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:02:56.713
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:02:56.734
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:02:56.734
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:02:56.734
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:02:56.774
SC Data - All Services | Sending logon request message. | 2020-10-07 06:02:56.774
SC Data - All Services | Received logon response. | 2020-10-07 06:02:57.422
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:02:57.422
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:02:57.422
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:02:57.422
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:02:57.422
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:02:57.422
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:02:57.422
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:02:57.422
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:02:57.422
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:02:57.422
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:02:57.438
DTC Client socket (1) | Closed. | 2020-10-07 06:02:57.439
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:03:27.420
DTC Client socket (1) | Creating socket. | 2020-10-07 06:03:27.420
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:03:27.420
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:03:27.420
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:03:27.447
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:03:27.447
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:03:27.448
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:03:27.481
SC Data - All Services | Sending logon request message. | 2020-10-07 06:03:27.481
SC Data - All Services | Received logon response. | 2020-10-07 06:03:28.181
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:03:28.181
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:03:28.181
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:03:28.181
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:03:28.181
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:03:28.182
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:03:28.182
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:03:28.182
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:03:28.182
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:03:28.182
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:03:28.207
DTC Client socket (1) | Closed. | 2020-10-07 06:03:28.207
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:03:58.182
DTC Client socket (1) | Creating socket. | 2020-10-07 06:03:58.182
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:03:58.182
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:03:58.182
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:03:58.213
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:03:58.213
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:03:58.213
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:03:58.238
SC Data - All Services | Sending logon request message. | 2020-10-07 06:03:58.238
SC Data - All Services | Received logon response. | 2020-10-07 06:03:58.919
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:03:58.919
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:03:58.919
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:03:58.919
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:03:58.919
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:03:58.920
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:03:58.920
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:03:58.920
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:03:58.920
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:03:58.920
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:03:58.933
DTC Client socket (1) | Closed. | 2020-10-07 06:03:58.933
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:04:28.915
DTC Client socket (1) | Creating socket. | 2020-10-07 06:04:28.916
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:04:28.916
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:04:28.916
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:04:28.938
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:04:28.938
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:04:28.938
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:04:28.971
SC Data - All Services | Sending logon request message. | 2020-10-07 06:04:28.971
SC Data - All Services | Received logon response. | 2020-10-07 06:04:29.555
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:04:29.555
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:04:29.555
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:04:29.555
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:04:29.555
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:04:29.555
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:04:29.555
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:04:29.555
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:04:29.555
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:04:29.555
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:04:29.568
DTC Client socket (1) | Closed. | 2020-10-07 06:04:29.568
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:04:59.559
DTC Client socket (1) | Creating socket. | 2020-10-07 06:04:59.559
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:04:59.559
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:04:59.559
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:04:59.583
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:04:59.583
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:04:59.583
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:04:59.602
SC Data - All Services | Sending logon request message. | 2020-10-07 06:04:59.602
SC Data - All Services | Received logon response. | 2020-10-07 06:05:00.215
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:05:00.215
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:05:00.215
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:05:00.215
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:05:00.215
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:05:00.216
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:05:00.216
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:05:00.216
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:05:00.216
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:05:00.216
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:05:00.232
DTC Client socket (1) | Closed. | 2020-10-07 06:05:00.232
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:05:30.224
DTC Client socket (1) | Creating socket. | 2020-10-07 06:05:30.224
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:05:30.224
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:05:30.224
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:05:30.253
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:05:30.253
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:05:30.253
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:05:30.301
SC Data - All Services | Sending logon request message. | 2020-10-07 06:05:30.301
SC Data - All Services | Received logon response. | 2020-10-07 06:05:31.020
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:05:31.020
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:05:31.020
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:05:31.020
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:05:31.020
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:05:31.020
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:05:31.020
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:05:31.020
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:05:31.020
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:05:31.021
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:05:31.049
DTC Client socket (1) | Closed. | 2020-10-07 06:05:31.049
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:06:01.018
DTC Client socket (1) | Creating socket. | 2020-10-07 06:06:01.018
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:06:01.018
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:06:01.018
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:06:01.040
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:06:01.040
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:06:01.040
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:06:01.072
SC Data - All Services | Sending logon request message. | 2020-10-07 06:06:01.072
SC Data - All Services | Received logon response. | 2020-10-07 06:06:01.718
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:06:01.718
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:06:01.718
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:06:01.718
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:06:01.718
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:06:01.718
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:06:01.718
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:06:01.719
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:06:01.719
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:06:01.719
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:06:01.732
DTC Client socket (1) | Closed. | 2020-10-07 06:06:01.732
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:06:31.711
DTC Client socket (1) | Creating socket. | 2020-10-07 06:06:31.712
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:06:31.712
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:06:31.712
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:06:31.726
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:06:31.726
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:06:31.726
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:06:31.758
SC Data - All Services | Sending logon request message. | 2020-10-07 06:06:31.758
SC Data - All Services | Received logon response. | 2020-10-07 06:06:32.406
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:06:32.406
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:06:32.406
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:06:32.406
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:06:32.406
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:06:32.406
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:06:32.406
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:06:32.406
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:06:32.406
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:06:32.406
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:06:32.419
DTC Client socket (1) | Closed. | 2020-10-07 06:06:32.419
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:07:02.407
DTC Client socket (1) | Creating socket. | 2020-10-07 06:07:02.408
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:07:02.408
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:07:02.408
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:07:02.429
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:07:02.429
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:07:02.429
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:07:02.461
SC Data - All Services | Sending logon request message. | 2020-10-07 06:07:02.461
SC Data - All Services | Received logon response. | 2020-10-07 06:07:03.102
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:07:03.102
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:07:03.102
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:07:03.102
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:07:03.102
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:07:03.102
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:07:03.102
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:07:03.102
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:07:03.102
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:07:03.102
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:07:03.118
DTC Client socket (1) | Closed. | 2020-10-07 06:07:03.118
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:07:33.118
DTC Client socket (1) | Creating socket. | 2020-10-07 06:07:33.119
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:07:33.119
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:07:33.119
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:07:33.147
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:07:33.147
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:07:33.147
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:07:33.189
SC Data - All Services | Sending logon request message. | 2020-10-07 06:07:33.189
SC Data - All Services | Received logon response. | 2020-10-07 06:07:33.881
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:07:33.881
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:07:33.881
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:07:33.881
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:07:33.881
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:07:33.881
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:07:33.881
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:07:33.881
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:07:33.881
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:07:33.882
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:07:33.906
DTC Client socket (1) | Closed. | 2020-10-07 06:07:33.906
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:08:03.871
DTC Client socket (1) | Creating socket. | 2020-10-07 06:08:03.871
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:08:03.871
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:08:03.871
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:08:03.886
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:08:03.886
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:08:03.886
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:08:03.932
SC Data - All Services | Sending logon request message. | 2020-10-07 06:08:03.932
SC Data - All Services | Received logon response. | 2020-10-07 06:08:04.616
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:08:04.616
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:08:04.616
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:08:04.616
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:08:04.616
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:08:04.617
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:08:04.617
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:08:04.617
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:08:04.617
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:08:04.617
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:08:04.629
DTC Client socket (1) | Closed. | 2020-10-07 06:08:04.630
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:08:34.620
DTC Client socket (1) | Creating socket. | 2020-10-07 06:08:34.620
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:08:34.620
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:08:34.620
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:08:34.634
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:08:34.635
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:08:34.635
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:08:34.648
SC Data - All Services | Sending logon request message. | 2020-10-07 06:08:34.648
SC Data - All Services | Received logon response. | 2020-10-07 06:08:35.287
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:08:35.287
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:08:35.287
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:08:35.287
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:08:35.287
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:08:35.287
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:08:35.287
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:08:35.287
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:08:35.287
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:08:35.287
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:08:35.302
DTC Client socket (1) | Closed. | 2020-10-07 06:08:35.302
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:09:05.286
DTC Client socket (1) | Creating socket. | 2020-10-07 06:09:05.287
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:09:05.287
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:09:05.287
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:09:05.313
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:09:05.313
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:09:05.313
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:09:05.350
SC Data - All Services | Sending logon request message. | 2020-10-07 06:09:05.350
SC Data - All Services | Received logon response. | 2020-10-07 06:09:05.991
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:09:05.991
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:09:05.991
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:09:05.991
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:09:05.991
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:09:05.991
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:09:05.991
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:09:05.991
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:09:05.991
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:09:05.991
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:09:06.009
DTC Client socket (1) | Closed. | 2020-10-07 06:09:06.009
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:09:35.991
DTC Client socket (1) | Creating socket. | 2020-10-07 06:09:35.992
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:09:35.992
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:09:35.992
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:09:36.035
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:09:36.035
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:09:36.035
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:09:36.106
SC Data - All Services | Sending logon request message. | 2020-10-07 06:09:36.106
SC Data - All Services | Received logon response. | 2020-10-07 06:09:36.783
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:09:36.783
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:09:36.783
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:09:36.783
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:09:36.783
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:09:36.783
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:09:36.783
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:09:36.783
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:09:36.783
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:09:36.783
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:09:36.811
DTC Client socket (1) | Closed. | 2020-10-07 06:09:36.811
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:10:06.779
DTC Client socket (1) | Creating socket. | 2020-10-07 06:10:06.779
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:10:06.779
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:10:06.779
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:10:06.804
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:10:06.804
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:10:06.804
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:10:06.852
SC Data - All Services | Sending logon request message. | 2020-10-07 06:10:06.852
SC Data - All Services | Received logon response. | 2020-10-07 06:10:07.523
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:10:07.523
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:10:07.523
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:10:07.523
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:10:07.523
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:10:07.523
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:10:07.523
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:10:07.523
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:10:07.523
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:10:07.523
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:10:07.537
DTC Client socket (1) | Closed. | 2020-10-07 06:10:07.537
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:10:37.509
DTC Client socket (1) | Creating socket. | 2020-10-07 06:10:37.509
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:10:37.509
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:10:37.509
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:10:37.535
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:10:37.535
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:10:37.535
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:10:37.578
SC Data - All Services | Sending logon request message. | 2020-10-07 06:10:37.578
SC Data - All Services | Received logon response. | 2020-10-07 06:10:38.155
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:10:38.155
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:10:38.155
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:10:38.155
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:10:38.155
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:10:38.155
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:10:38.155
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:10:38.155
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:10:38.155
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:10:38.156
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:10:38.170
DTC Client socket (1) | Closed. | 2020-10-07 06:10:38.170
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:11:08.148
DTC Client socket (1) | Creating socket. | 2020-10-07 06:11:08.149
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:11:08.149
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:11:08.149
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:11:08.165
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:11:08.165
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:11:08.165
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:11:08.212
SC Data - All Services | Sending logon request message. | 2020-10-07 06:11:08.212
SC Data - All Services | Received logon response. | 2020-10-07 06:11:08.827
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:11:08.827
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:11:08.827
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:11:08.827
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:11:08.827
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:11:08.827
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:11:08.827
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:11:08.827
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:11:08.827
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:11:08.827
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:11:08.842
DTC Client socket (1) | Closed. | 2020-10-07 06:11:08.842
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:11:38.834
DTC Client socket (1) | Creating socket. | 2020-10-07 06:11:38.834
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:11:38.834
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:11:38.834
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:11:38.865
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:11:38.865
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:11:38.865
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:11:38.928
SC Data - All Services | Sending logon request message. | 2020-10-07 06:11:38.928
SC Data - All Services | Received logon response. | 2020-10-07 06:11:39.605
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:11:39.605
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:11:39.605
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:11:39.605
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:11:39.605
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:11:39.605
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:11:39.605
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:11:39.605
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:11:39.605
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:11:39.605
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:11:39.629
DTC Client socket (1) | Closed. | 2020-10-07 06:11:39.629
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:12:09.606
DTC Client socket (1) | Creating socket. | 2020-10-07 06:12:09.606
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:12:09.606
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:12:09.606
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:12:09.628
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:12:09.628
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:12:09.628
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:12:09.668
SC Data - All Services | Sending logon request message. | 2020-10-07 06:12:09.668
SC Data - All Services | Received logon response. | 2020-10-07 06:12:10.360
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:12:10.360
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:12:10.360
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:12:10.360
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:12:10.360
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:12:10.360
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:12:10.360
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:12:10.360
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:12:10.360
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:12:10.360
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:12:10.372
DTC Client socket (1) | Closed. | 2020-10-07 06:12:10.372
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1020 seconds. | 2020-10-07 06:12:28.837
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0429 seconds. | 2020-10-07 06:12:28.881
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:12:40.351
DTC Client socket (1) | Creating socket. | 2020-10-07 06:12:40.351
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:12:40.351
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:12:40.351
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:12:40.366
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:12:40.366
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:12:40.366
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:12:40.389
SC Data - All Services | Sending logon request message. | 2020-10-07 06:12:40.389
SC Data - All Services | Received logon response. | 2020-10-07 06:12:40.992
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:12:40.992
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:12:40.992
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:12:40.992
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:12:40.992
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:12:40.992
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:12:40.992
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:12:40.992
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:12:40.992
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:12:40.992
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:12:41.007
DTC Client socket (1) | Closed. | 2020-10-07 06:12:41.007
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:13:10.994
DTC Client socket (1) | Creating socket. | 2020-10-07 06:13:10.994
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:13:10.994
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:13:10.994
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:13:11.024
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:13:11.024
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:13:11.024
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:13:11.066
SC Data - All Services | Sending logon request message. | 2020-10-07 06:13:11.066
SC Data - All Services | Received logon response. | 2020-10-07 06:13:11.712
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:13:11.712
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:13:11.712
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:13:11.712
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:13:11.712
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:13:11.713
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:13:11.713
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:13:11.713
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:13:11.713
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:13:11.713
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:13:11.727
DTC Client socket (1) | Closed. | 2020-10-07 06:13:11.727
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:13:41.718
DTC Client socket (1) | Creating socket. | 2020-10-07 06:13:41.718
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:13:41.718
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:13:41.718
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:13:41.744
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:13:41.744
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:13:41.744
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:13:41.792
SC Data - All Services | Sending logon request message. | 2020-10-07 06:13:41.792
SC Data - All Services | Received logon response. | 2020-10-07 06:13:42.484
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:13:42.484
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:13:42.484
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:13:42.484
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:13:42.484
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:13:42.484
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:13:42.484
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:13:42.484
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:13:42.484
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:13:42.484
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:13:42.512
DTC Client socket (1) | Closed. | 2020-10-07 06:13:42.512
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:14:12.480
DTC Client socket (1) | Creating socket. | 2020-10-07 06:14:12.481
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:14:12.481
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:14:12.481
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:14:12.501
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:14:12.501
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:14:12.501
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:14:12.536
SC Data - All Services | Sending logon request message. | 2020-10-07 06:14:12.536
SC Data - All Services | Received logon response. | 2020-10-07 06:14:13.176
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:14:13.176
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:14:13.176
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:14:13.176
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:14:13.176
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:14:13.176
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:14:13.176
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:14:13.177
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:14:13.177
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:14:13.177
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:14:13.193
DTC Client socket (1) | Closed. | 2020-10-07 06:14:13.193
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:14:43.176
DTC Client socket (1) | Creating socket. | 2020-10-07 06:14:43.176
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:14:43.176
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:14:43.176
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:14:43.198
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:14:43.198
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:14:43.198
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:14:43.218
SC Data - All Services | Sending logon request message. | 2020-10-07 06:14:43.218
SC Data - All Services | Received logon response. | 2020-10-07 06:14:43.878
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:14:43.878
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:14:43.878
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:14:43.878
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:14:43.878
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:14:43.878
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:14:43.878
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:14:43.878
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:14:43.878
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:14:43.878
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:14:43.903
DTC Client socket (1) | Closed. | 2020-10-07 06:14:43.903
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:15:13.867
DTC Client socket (1) | Creating socket. | 2020-10-07 06:15:13.868
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:15:13.868
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:15:13.868
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:15:13.896
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:15:13.896
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:15:13.896
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:15:13.951
SC Data - All Services | Sending logon request message. | 2020-10-07 06:15:13.951
SC Data - All Services | Received logon response. | 2020-10-07 06:15:14.586
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:15:14.586
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:15:14.586
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:15:14.586
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:15:14.586
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:15:14.586
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:15:14.586
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:15:14.587
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:15:14.587
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:15:14.587
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:15:14.602
DTC Client socket (1) | Closed. | 2020-10-07 06:15:14.602
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:15:44.588
DTC Client socket (1) | Creating socket. | 2020-10-07 06:15:44.588
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:15:44.588
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:15:44.588
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:15:44.615
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:15:44.615
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:15:44.615
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:15:44.657
SC Data - All Services | Sending logon request message. | 2020-10-07 06:15:44.657
SC Data - All Services | Received logon response. | 2020-10-07 06:15:45.350
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:15:45.350
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:15:45.350
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:15:45.350
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:15:45.350
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:15:45.350
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:15:45.350
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:15:45.350
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:15:45.350
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:15:45.350
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:15:45.375
DTC Client socket (1) | Closed. | 2020-10-07 06:15:45.375
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:16:15.336
DTC Client socket (2) | Creating socket. | 2020-10-07 06:16:15.336
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 06:16:15.336
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:16:15.336
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:16:15.367
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:16:15.367
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:16:15.367
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:16:15.392
SC Data - All Services | Sending logon request message. | 2020-10-07 06:16:15.392
SC Data - All Services | Received logon response. | 2020-10-07 06:16:16.046
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:16:16.046
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:16:16.046
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:16:16.046
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:16:16.046
DTC Client socket (2) | CloseSocket call. | 2020-10-07 06:16:16.046
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:16:16.046
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:16:16.046
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:16:16.046
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:16:16.046
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 06:16:16.063
DTC Client socket (2) | Closed. | 2020-10-07 06:16:16.063
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:16:46.046
DTC Client socket (1) | Creating socket. | 2020-10-07 06:16:46.046
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:16:46.046
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:16:46.046
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:16:46.062
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:16:46.062
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:16:46.062
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:16:46.089
SC Data - All Services | Sending logon request message. | 2020-10-07 06:16:46.089
SC Data - All Services | Received logon response. | 2020-10-07 06:16:46.673
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:16:46.673
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:16:46.673
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:16:46.673
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:16:46.673
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:16:46.673
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:16:46.673
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:16:46.673
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:16:46.673
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:16:46.673
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:16:46.687
DTC Client socket (1) | Closed. | 2020-10-07 06:16:46.687
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:17:16.673
DTC Client socket (1) | Creating socket. | 2020-10-07 06:17:16.674
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:17:16.674
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:17:16.674
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:17:16.701
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:17:16.701
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:17:16.702
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:17:16.729
SC Data - All Services | Sending logon request message. | 2020-10-07 06:17:16.729
SC Data - All Services | Received logon response. | 2020-10-07 06:17:17.362
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:17:17.362
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:17:17.362
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:17:17.362
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:17:17.362
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:17:17.363
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:17:17.363
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:17:17.363
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:17:17.363
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:17:17.363
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:17:17.378
DTC Client socket (1) | Closed. | 2020-10-07 06:17:17.378
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:17:47.356
DTC Client socket (1) | Creating socket. | 2020-10-07 06:17:47.356
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:17:47.357
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:17:47.357
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:17:47.387
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:17:47.387
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:17:47.387
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:17:47.426
SC Data - All Services | Sending logon request message. | 2020-10-07 06:17:47.426
SC Data - All Services | Received logon response. | 2020-10-07 06:17:48.127
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:17:48.127
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:17:48.127
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:17:48.127
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:17:48.127
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:17:48.127
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:17:48.127
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:17:48.127
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:17:48.127
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:17:48.127
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:17:48.153
DTC Client socket (1) | Closed. | 2020-10-07 06:17:48.153
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:18:18.122
DTC Client socket (1) | Creating socket. | 2020-10-07 06:18:18.122
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:18:18.122
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:18:18.122
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:18:18.145
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:18:18.145
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:18:18.145
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:18:18.176
SC Data - All Services | Sending logon request message. | 2020-10-07 06:18:18.176
SC Data - All Services | Received logon response. | 2020-10-07 06:18:18.846
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:18:18.846
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:18:18.846
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:18:18.846
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:18:18.846
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:18:18.846
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:18:18.846
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:18:18.846
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:18:18.846
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:18:18.846
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:18:18.860
DTC Client socket (1) | Closed. | 2020-10-07 06:18:18.861
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:18:48.846
DTC Client socket (1) | Creating socket. | 2020-10-07 06:18:48.846
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:18:48.846
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:18:48.846
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:18:48.860
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:18:48.861
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:18:48.861
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:18:48.907
SC Data - All Services | Sending logon request message. | 2020-10-07 06:18:48.907
SC Data - All Services | Received logon response. | 2020-10-07 06:18:49.602
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:18:49.602
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:18:49.602
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:18:49.602
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:18:49.602
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:18:49.602
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:18:49.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:18:49.602
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:18:49.602
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:18:49.602
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:18:49.616
DTC Client socket (1) | Closed. | 2020-10-07 06:18:49.617
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:19:19.602
DTC Client socket (1) | Creating socket. | 2020-10-07 06:19:19.602
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:19:19.602
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:19:19.602
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:19:19.618
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:19:19.618
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:19:19.618
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:19:19.650
SC Data - All Services | Sending logon request message. | 2020-10-07 06:19:19.650
SC Data - All Services | Received logon response. | 2020-10-07 06:19:20.282
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:19:20.282
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:19:20.282
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:19:20.282
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:19:20.282
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:19:20.282
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:19:20.282
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:19:20.282
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:19:20.282
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:19:20.282
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:19:20.298
DTC Client socket (1) | Closed. | 2020-10-07 06:19:20.298
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:19:50.273
DTC Client socket (1) | Creating socket. | 2020-10-07 06:19:50.274
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:19:50.274
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:19:50.274
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:19:50.303
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:19:50.303
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:19:50.303
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:19:50.365
SC Data - All Services | Sending logon request message. | 2020-10-07 06:19:50.365
SC Data - All Services | Received logon response. | 2020-10-07 06:19:51.058
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:19:51.058
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:19:51.058
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:19:51.058
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:19:51.058
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:19:51.059
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:19:51.059
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:19:51.059
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:19:51.059
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:19:51.059
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:19:51.083
DTC Client socket (1) | Closed. | 2020-10-07 06:19:51.084
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:20:21.058
DTC Client socket (1) | Creating socket. | 2020-10-07 06:20:21.059
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:20:21.059
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:20:21.059
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:20:21.091
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:20:21.091
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:20:21.091
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:20:21.114
SC Data - All Services | Sending logon request message. | 2020-10-07 06:20:21.114
SC Data - All Services | Received logon response. | 2020-10-07 06:20:21.756
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:20:21.756
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:20:21.756
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:20:21.756
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:20:21.756
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:20:21.757
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:20:21.757
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:20:21.757
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:20:21.757
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:20:21.757
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:20:21.769
DTC Client socket (1) | Closed. | 2020-10-07 06:20:21.769
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:20:51.764
DTC Client socket (1) | Creating socket. | 2020-10-07 06:20:51.765
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:20:51.765
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:20:51.765
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:20:51.780
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:20:51.780
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:20:51.780
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:20:51.799
SC Data - All Services | Sending logon request message. | 2020-10-07 06:20:51.799
SC Data - All Services | Received logon response. | 2020-10-07 06:20:52.366
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:20:52.366
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:20:52.366
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:20:52.366
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:20:52.366
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:20:52.366
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:20:52.366
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:20:52.366
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:20:52.366
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:20:52.366
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:20:52.378
DTC Client socket (1) | Closed. | 2020-10-07 06:20:52.378
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:21:22.351
DTC Client socket (1) | Creating socket. | 2020-10-07 06:21:22.351
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:21:22.351
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:21:22.351
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:21:22.367
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:21:22.367
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:21:22.367
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:21:22.412
SC Data - All Services | Sending logon request message. | 2020-10-07 06:21:22.412
SC Data - All Services | Received logon response. | 2020-10-07 06:21:23.031
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:21:23.031
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:21:23.031
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:21:23.031
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:21:23.031
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:21:23.031
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:21:23.031
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:21:23.031
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:21:23.031
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:21:23.031
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:21:23.047
DTC Client socket (1) | Closed. | 2020-10-07 06:21:23.047
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:21:53.029
DTC Client socket (1) | Creating socket. | 2020-10-07 06:21:53.029
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:21:53.029
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:21:53.029
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:21:53.057
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:21:53.057
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:21:53.057
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:21:53.117
SC Data - All Services | Sending logon request message. | 2020-10-07 06:21:53.117
SC Data - All Services | Received logon response. | 2020-10-07 06:21:53.822
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:21:53.822
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:21:53.822
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:21:53.822
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:21:53.822
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:21:53.822
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:21:53.822
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:21:53.822
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:21:53.822
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:21:53.822
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:21:53.846
DTC Client socket (1) | Closed. | 2020-10-07 06:21:53.847
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:22:23.824
DTC Client socket (1) | Creating socket. | 2020-10-07 06:22:23.825
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:22:23.825
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:22:23.825
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:22:23.847
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:22:23.847
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:22:23.847
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:22:23.893
SC Data - All Services | Sending logon request message. | 2020-10-07 06:22:23.893
SC Data - All Services | Received logon response. | 2020-10-07 06:22:24.565
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:22:24.565
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:22:24.565
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:22:24.565
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:22:24.565
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:22:24.565
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:22:24.565
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:22:24.565
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:22:24.565
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:22:24.565
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:22:24.579
DTC Client socket (1) | Closed. | 2020-10-07 06:22:24.579
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:22:54.558
DTC Client socket (1) | Creating socket. | 2020-10-07 06:22:54.558
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:22:54.558
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:22:54.558
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:22:54.573
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:22:54.573
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:22:54.573
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:22:54.611
SC Data - All Services | Sending logon request message. | 2020-10-07 06:22:54.611
SC Data - All Services | Received logon response. | 2020-10-07 06:22:55.177
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:22:55.177
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:22:55.177
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:22:55.177
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:22:55.177
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:22:55.177
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:22:55.177
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:22:55.177
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:22:55.177
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:22:55.177
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:22:55.189
DTC Client socket (1) | Closed. | 2020-10-07 06:22:55.190
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:23:25.166
DTC Client socket (1) | Creating socket. | 2020-10-07 06:23:25.166
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:23:25.166
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:23:25.166
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:23:25.181
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:23:25.181
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:23:25.181
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:23:25.220
SC Data - All Services | Sending logon request message. | 2020-10-07 06:23:25.220
SC Data - All Services | Received logon response. | 2020-10-07 06:23:25.829
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:23:25.829
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:23:25.829
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:23:25.829
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:23:25.829
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:23:25.829
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:23:25.829
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:23:25.829
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:23:25.829
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:23:25.829
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:23:25.843
DTC Client socket (1) | Closed. | 2020-10-07 06:23:25.843
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:23:55.827
DTC Client socket (1) | Creating socket. | 2020-10-07 06:23:55.828
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:23:55.828
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:23:55.828
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:23:55.859
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:23:55.859
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:23:55.859
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:23:55.897
SC Data - All Services | Sending logon request message. | 2020-10-07 06:23:55.897
SC Data - All Services | Received logon response. | 2020-10-07 06:23:56.601
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:23:56.601
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:23:56.601
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:23:56.601
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:23:56.601
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:23:56.601
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:23:56.601
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:23:56.601
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:23:56.601
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:23:56.601
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:23:56.628
DTC Client socket (1) | Closed. | 2020-10-07 06:23:56.628
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:24:26.600
DTC Client socket (1) | Creating socket. | 2020-10-07 06:24:26.600
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:24:26.600
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:24:26.600
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:24:26.627
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:24:26.627
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:24:26.627
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:24:26.674
SC Data - All Services | Sending logon request message. | 2020-10-07 06:24:26.674
SC Data - All Services | Received logon response. | 2020-10-07 06:24:27.334
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:24:27.334
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:24:27.334
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:24:27.334
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:24:27.334
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:24:27.334
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:24:27.334
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:24:27.334
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:24:27.334
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:24:27.334
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:24:27.348
DTC Client socket (1) | Closed. | 2020-10-07 06:24:27.348
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:24:57.320
DTC Client socket (1) | Creating socket. | 2020-10-07 06:24:57.321
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:24:57.321
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:24:57.321
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:24:57.338
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:24:57.338
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:24:57.338
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:24:57.370
SC Data - All Services | Sending logon request message. | 2020-10-07 06:24:57.370
SC Data - All Services | Received logon response. | 2020-10-07 06:24:57.949
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:24:57.949
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:24:57.949
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:24:57.949
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:24:57.949
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:24:57.949
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:24:57.949
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:24:57.949
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:24:57.949
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:24:57.949
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:24:57.963
DTC Client socket (1) | Closed. | 2020-10-07 06:24:57.963
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:25:27.950
DTC Client socket (1) | Creating socket. | 2020-10-07 06:25:27.950
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:25:27.950
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:25:27.950
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:25:27.966
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:25:27.966
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:25:27.966
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:25:27.982
SC Data - All Services | Sending logon request message. | 2020-10-07 06:25:27.982
SC Data - All Services | Received logon response. | 2020-10-07 06:25:28.633
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:25:28.633
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:25:28.633
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:25:28.633
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:25:28.633
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:25:28.633
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:25:28.633
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:25:28.633
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:25:28.633
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:25:28.634
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:25:28.650
DTC Client socket (1) | Closed. | 2020-10-07 06:25:28.650
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:25:58.644
DTC Client socket (1) | Creating socket. | 2020-10-07 06:25:58.644
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:25:58.644
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:25:58.644
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:25:58.673
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:25:58.673
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:25:58.673
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:25:58.717
SC Data - All Services | Sending logon request message. | 2020-10-07 06:25:58.717
SC Data - All Services | Received logon response. | 2020-10-07 06:25:59.374
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:25:59.374
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:25:59.374
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:25:59.374
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:25:59.374
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:25:59.374
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:25:59.374
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:25:59.374
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:25:59.374
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:25:59.374
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:25:59.401
DTC Client socket (1) | Closed. | 2020-10-07 06:25:59.401
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:26:29.368
DTC Client socket (1) | Creating socket. | 2020-10-07 06:26:29.368
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:26:29.368
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:26:29.368
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:26:29.392
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:26:29.392
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:26:29.392
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:26:29.431
SC Data - All Services | Sending logon request message. | 2020-10-07 06:26:29.431
SC Data - All Services | Received logon response. | 2020-10-07 06:26:30.089
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:26:30.090
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:26:30.090
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:26:30.090
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:26:30.090
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:26:30.090
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:26:30.090
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:26:30.090
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:26:30.090
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:26:30.090
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:26:30.103
DTC Client socket (1) | Closed. | 2020-10-07 06:26:30.103
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:27:00.095
DTC Client socket (1) | Creating socket. | 2020-10-07 06:27:00.095
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:27:00.095
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:27:00.095
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:27:00.111
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:27:00.111
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:27:00.111
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:27:00.156
SC Data - All Services | Sending logon request message. | 2020-10-07 06:27:00.156
SC Data - All Services | Received logon response. | 2020-10-07 06:27:00.821
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:27:00.821
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:27:00.821
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:27:00.821
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:27:00.821
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:27:00.821
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:27:00.821
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:27:00.821
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:27:00.821
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:27:00.821
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:27:00.837
DTC Client socket (1) | Closed. | 2020-10-07 06:27:00.837
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1058 seconds. | 2020-10-07 06:27:28.983
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0340 seconds. | 2020-10-07 06:27:29.018
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:27:30.831
DTC Client socket (1) | Creating socket. | 2020-10-07 06:27:30.832
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:27:30.832
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:27:30.832
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:27:30.849
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:27:30.849
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:27:30.849
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:27:30.872
SC Data - All Services | Sending logon request message. | 2020-10-07 06:27:30.872
SC Data - All Services | Received logon response. | 2020-10-07 06:27:31.514
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:27:31.514
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:27:31.514
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:27:31.514
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:27:31.514
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:27:31.514
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:27:31.514
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:27:31.514
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:27:31.514
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:27:31.514
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:27:31.528
DTC Client socket (1) | Closed. | 2020-10-07 06:27:31.528
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:28:01.513
DTC Client socket (1) | Creating socket. | 2020-10-07 06:28:01.513
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:28:01.513
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:28:01.513
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:28:01.543
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:28:01.543
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:28:01.543
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:28:01.581
SC Data - All Services | Sending logon request message. | 2020-10-07 06:28:01.581
SC Data - All Services | Received logon response. | 2020-10-07 06:28:02.285
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:28:02.285
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:28:02.285
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:28:02.285
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:28:02.285
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:28:02.285
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:28:02.285
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:28:02.285
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:28:02.285
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:28:02.285
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:28:02.311
DTC Client socket (1) | Closed. | 2020-10-07 06:28:02.311
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:28:32.277
DTC Client socket (1) | Creating socket. | 2020-10-07 06:28:32.277
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:28:32.277
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:28:32.277
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:28:32.298
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:28:32.298
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:28:32.298
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:28:32.321
SC Data - All Services | Sending logon request message. | 2020-10-07 06:28:32.321
SC Data - All Services | Received logon response. | 2020-10-07 06:28:32.983
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:28:32.983
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:28:32.983
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:28:32.983
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:28:32.983
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:28:32.984
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:28:32.984
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:28:32.984
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:28:32.984
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:28:32.984
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:28:32.998
DTC Client socket (1) | Closed. | 2020-10-07 06:28:32.998
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:29:02.979
DTC Client socket (2) | Creating socket. | 2020-10-07 06:29:02.980
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 06:29:02.980
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:29:02.980
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:29:03.002
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:29:03.002
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:29:03.002
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:29:03.034
SC Data - All Services | Sending logon request message. | 2020-10-07 06:29:03.034
SC Data - All Services | Received logon response. | 2020-10-07 06:29:03.626
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:29:03.626
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:29:03.626
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:29:03.626
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:29:03.626
DTC Client socket (2) | CloseSocket call. | 2020-10-07 06:29:03.627
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:29:03.627
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:29:03.628
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:29:03.628
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:29:03.628
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 06:29:03.641
DTC Client socket (2) | Closed. | 2020-10-07 06:29:03.641
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:29:33.628
DTC Client socket (1) | Creating socket. | 2020-10-07 06:29:33.628
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:29:33.628
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:29:33.628
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:29:33.650
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:29:33.650
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:29:33.650
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:29:33.681
SC Data - All Services | Sending logon request message. | 2020-10-07 06:29:33.681
SC Data - All Services | Received logon response. | 2020-10-07 06:29:34.323
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:29:34.323
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:29:34.323
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:29:34.323
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:29:34.323
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:29:34.323
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:29:34.323
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:29:34.323
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:29:34.323
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:29:34.323
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:29:34.337
DTC Client socket (1) | Closed. | 2020-10-07 06:29:34.337
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:30:04.327
DTC Client socket (2) | Creating socket. | 2020-10-07 06:30:04.327
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 06:30:04.327
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:30:04.327
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:30:04.354
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:30:04.354
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:30:04.354
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:30:04.387
SC Data - All Services | Sending logon request message. | 2020-10-07 06:30:04.387
SC Data - All Services | Received logon response. | 2020-10-07 06:30:05.102
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:30:05.102
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:30:05.102
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:30:05.102
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:30:05.102
DTC Client socket (2) | CloseSocket call. | 2020-10-07 06:30:05.102
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:30:05.102
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:30:05.102
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:30:05.102
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:30:05.103
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 06:30:05.129
DTC Client socket (2) | Closed. | 2020-10-07 06:30:05.129
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:30:35.102
DTC Client socket (1) | Creating socket. | 2020-10-07 06:30:35.103
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:30:35.103
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:30:35.103
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:30:35.125
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:30:35.125
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:30:35.125
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:30:35.158
SC Data - All Services | Sending logon request message. | 2020-10-07 06:30:35.158
SC Data - All Services | Received logon response. | 2020-10-07 06:30:35.817
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:30:35.817
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:30:35.817
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:30:35.817
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:30:35.817
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:30:35.817
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:30:35.817
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:30:35.817
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:30:35.817
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:30:35.817
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:30:35.831
DTC Client socket (1) | Closed. | 2020-10-07 06:30:35.831
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:31:05.812
DTC Client socket (1) | Creating socket. | 2020-10-07 06:31:05.813
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:31:05.813
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:31:05.813
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:31:05.838
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:31:05.838
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:31:05.838
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:31:05.889
SC Data - All Services | Sending logon request message. | 2020-10-07 06:31:05.889
SC Data - All Services | Received logon response. | 2020-10-07 06:31:06.492
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:31:06.492
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:31:06.492
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:31:06.492
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:31:06.492
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:31:06.492
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:31:06.492
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:31:06.493
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:31:06.493
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:31:06.493
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:31:06.506
DTC Client socket (1) | Closed. | 2020-10-07 06:31:06.506
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:31:36.500
DTC Client socket (1) | Creating socket. | 2020-10-07 06:31:36.500
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:31:36.500
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:31:36.500
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:31:36.523
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:31:36.523
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:31:36.523
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:31:36.568
SC Data - All Services | Sending logon request message. | 2020-10-07 06:31:36.568
SC Data - All Services | Received logon response. | 2020-10-07 06:31:37.208
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:31:37.208
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:31:37.208
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:31:37.208
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:31:37.208
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:31:37.209
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:31:37.209
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:31:37.209
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:31:37.209
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:31:37.209
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:31:37.222
DTC Client socket (1) | Closed. | 2020-10-07 06:31:37.222
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:32:08.086
DTC Client socket (1) | Creating socket. | 2020-10-07 06:32:08.086
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:32:08.086
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:32:08.086
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:32:08.115
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:32:08.115
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:32:08.115
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:32:08.164
SC Data - All Services | Sending logon request message. | 2020-10-07 06:32:08.164
SC Data - All Services | Received logon response. | 2020-10-07 06:32:08.377
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:32:08.377
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:32:08.377
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:32:08.377
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:32:08.377
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:32:08.377
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:32:08.377
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:32:08.377
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:32:08.377
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:32:08.377
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:32:08.405
DTC Client socket (1) | Closed. | 2020-10-07 06:32:08.405
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:32:38.377
DTC Client socket (1) | Creating socket. | 2020-10-07 06:32:38.377
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:32:38.377
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:32:38.378
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:32:38.394
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:32:38.394
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:32:38.394
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:32:38.438
SC Data - All Services | Sending logon request message. | 2020-10-07 06:32:38.438
SC Data - All Services | Received logon response. | 2020-10-07 06:32:39.112
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:32:39.112
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:32:39.112
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:32:39.112
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:32:39.112
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:32:39.113
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:32:39.113
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:32:39.113
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:32:39.113
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:32:39.113
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:32:39.126
DTC Client socket (1) | Closed. | 2020-10-07 06:32:39.126
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:33:09.104
DTC Client socket (1) | Creating socket. | 2020-10-07 06:33:09.105
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:33:09.105
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:33:09.105
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:33:09.128
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:33:09.128
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:33:09.128
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:33:09.147
SC Data - All Services | Sending logon request message. | 2020-10-07 06:33:09.147
SC Data - All Services | Received logon response. | 2020-10-07 06:33:09.808
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:33:09.808
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:33:09.808
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:33:09.808
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:33:09.808
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:33:09.808
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:33:09.808
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:33:09.808
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:33:09.808
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:33:09.808
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:33:09.822
DTC Client socket (1) | Closed. | 2020-10-07 06:33:09.822
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:33:39.813
DTC Client socket (1) | Creating socket. | 2020-10-07 06:33:39.813
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:33:39.813
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:33:39.813
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:33:39.835
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:33:39.835
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:33:39.835
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:33:39.857
SC Data - All Services | Sending logon request message. | 2020-10-07 06:33:39.857
SC Data - All Services | Received logon response. | 2020-10-07 06:33:40.473
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:33:40.473
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:33:40.473
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:33:40.473
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:33:40.473
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:33:40.473
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:33:40.473
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:33:40.473
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:33:40.473
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:33:40.473
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:33:40.489
DTC Client socket (1) | Closed. | 2020-10-07 06:33:40.489
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:34:10.462
DTC Client socket (1) | Creating socket. | 2020-10-07 06:34:10.462
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:34:10.462
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:34:10.462
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:34:10.489
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:34:10.489
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:34:10.489
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:34:10.530
SC Data - All Services | Sending logon request message. | 2020-10-07 06:34:10.530
SC Data - All Services | Received logon response. | 2020-10-07 06:34:11.245
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:34:11.245
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:34:11.245
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:34:11.245
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:34:11.245
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:34:11.245
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:34:11.245
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:34:11.245
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:34:11.245
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:34:11.245
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:34:11.273
DTC Client socket (1) | Closed. | 2020-10-07 06:34:11.273
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:34:41.256
DTC Client socket (1) | Creating socket. | 2020-10-07 06:34:41.256
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:34:41.256
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:34:41.256
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:34:41.275
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:34:41.275
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:34:41.275
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:34:41.322
SC Data - All Services | Sending logon request message. | 2020-10-07 06:34:41.322
SC Data - All Services | Received logon response. | 2020-10-07 06:34:41.986
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:34:41.986
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:34:41.986
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:34:41.986
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:34:41.986
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:34:41.986
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:34:41.986
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:34:41.986
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:34:41.986
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:34:41.986
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:34:42.002
DTC Client socket (1) | Closed. | 2020-10-07 06:34:42.003
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:35:11.981
DTC Client socket (1) | Creating socket. | 2020-10-07 06:35:11.981
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:35:11.981
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:35:11.981
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:35:11.996
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:35:11.996
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:35:11.996
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:35:12.016
SC Data - All Services | Sending logon request message. | 2020-10-07 06:35:12.016
SC Data - All Services | Received logon response. | 2020-10-07 06:35:12.680
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:35:12.680
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:35:12.680
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:35:12.680
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:35:12.680
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:35:12.684
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:35:12.684
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:35:12.684
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:35:12.684
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:35:12.684
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:35:12.698
DTC Client socket (1) | Closed. | 2020-10-07 06:35:12.698
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:35:42.681
DTC Client socket (1) | Creating socket. | 2020-10-07 06:35:42.682
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:35:42.682
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:35:42.682
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:35:42.703
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:35:42.703
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:35:42.703
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:35:42.725
SC Data - All Services | Sending logon request message. | 2020-10-07 06:35:42.725
SC Data - All Services | Received logon response. | 2020-10-07 06:35:43.362
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:35:43.362
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:35:43.362
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:35:43.362
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:35:43.362
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:35:43.363
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:35:43.363
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:35:43.363
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:35:43.363
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:35:43.363
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:35:43.378
DTC Client socket (1) | Closed. | 2020-10-07 06:35:43.378
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:36:13.353
DTC Client socket (2) | Creating socket. | 2020-10-07 06:36:13.354
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 06:36:13.354
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:36:13.354
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:36:13.400
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:36:13.400
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:36:13.400
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:36:13.427
SC Data - All Services | Sending logon request message. | 2020-10-07 06:36:13.427
SC Data - All Services | Received logon response. | 2020-10-07 06:36:14.147
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:36:14.147
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:36:14.147
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:36:14.147
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:36:14.147
DTC Client socket (2) | CloseSocket call. | 2020-10-07 06:36:14.147
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:36:14.147
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:36:14.147
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:36:14.147
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:36:14.147
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 06:36:14.172
DTC Client socket (2) | Closed. | 2020-10-07 06:36:14.172
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:36:44.146
DTC Client socket (1) | Creating socket. | 2020-10-07 06:36:44.146
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:36:44.147
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:36:44.147
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:36:44.168
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:36:44.168
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:36:44.168
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:36:44.207
SC Data - All Services | Sending logon request message. | 2020-10-07 06:36:44.207
SC Data - All Services | Received logon response. | 2020-10-07 06:36:44.863
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:36:44.863
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:36:44.863
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:36:44.863
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:36:44.863
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:36:44.863
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:36:44.863
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:36:44.863
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:36:44.863
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:36:44.863
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:36:44.877
DTC Client socket (1) | Closed. | 2020-10-07 06:36:44.877
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:37:14.858
DTC Client socket (1) | Creating socket. | 2020-10-07 06:37:14.859
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:37:14.859
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:37:14.859
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:37:14.888
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:37:14.888
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:37:14.889
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:37:14.932
SC Data - All Services | Sending logon request message. | 2020-10-07 06:37:14.932
SC Data - All Services | Received logon response. | 2020-10-07 06:37:15.135
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:37:15.135
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:37:15.135
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:37:15.135
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:37:15.135
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:37:15.135
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:37:15.135
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:37:15.135
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:37:15.135
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:37:15.135
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:37:15.148
DTC Client socket (1) | Closed. | 2020-10-07 06:37:15.148
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:37:45.139
DTC Client socket (1) | Creating socket. | 2020-10-07 06:37:45.139
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:37:45.139
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:37:45.139
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:37:45.155
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:37:45.155
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:37:45.155
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:37:45.184
SC Data - All Services | Sending logon request message. | 2020-10-07 06:37:45.184
SC Data - All Services | Received logon response. | 2020-10-07 06:37:45.820
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:37:45.820
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:37:45.820
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:37:45.820
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:37:45.820
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:37:45.821
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:37:45.821
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:37:45.821
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:37:45.821
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:37:45.821
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:37:45.834
DTC Client socket (1) | Closed. | 2020-10-07 06:37:45.834
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:38:15.827
DTC Client socket (1) | Creating socket. | 2020-10-07 06:38:15.827
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:38:15.827
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:38:15.827
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:38:15.856
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:38:15.856
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:38:15.856
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:38:15.904
SC Data - All Services | Sending logon request message. | 2020-10-07 06:38:15.904
SC Data - All Services | Received logon response. | 2020-10-07 06:38:16.610
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:38:16.610
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:38:16.610
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:38:16.610
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:38:16.610
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:38:16.610
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:38:16.610
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:38:16.610
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:38:16.610
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:38:16.610
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:38:16.634
DTC Client socket (1) | Closed. | 2020-10-07 06:38:16.634
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:38:46.611
DTC Client socket (1) | Creating socket. | 2020-10-07 06:38:46.612
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:38:46.612
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:38:46.612
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:38:46.640
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:38:46.640
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:38:46.640
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:38:46.686
SC Data - All Services | Sending logon request message. | 2020-10-07 06:38:46.686
SC Data - All Services | Received logon response. | 2020-10-07 06:38:47.341
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:38:47.341
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:38:47.341
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:38:47.341
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:38:47.341
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:38:47.343
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:38:47.343
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:38:47.343
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:38:47.343
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:38:47.343
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:38:47.356
DTC Client socket (1) | Closed. | 2020-10-07 06:38:47.356
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:39:17.342
DTC Client socket (1) | Creating socket. | 2020-10-07 06:39:17.343
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:39:17.343
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:39:17.343
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:39:17.374
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:39:17.374
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:39:17.374
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:39:17.417
SC Data - All Services | Sending logon request message. | 2020-10-07 06:39:17.417
SC Data - All Services | Received logon response. | 2020-10-07 06:39:18.079
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:39:18.079
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:39:18.079
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:39:18.079
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:39:18.079
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:39:18.079
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:39:18.079
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:39:18.079
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:39:18.079
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:39:18.080
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:39:18.104
DTC Client socket (1) | Closed. | 2020-10-07 06:39:18.104
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:39:48.084
DTC Client socket (1) | Creating socket. | 2020-10-07 06:39:48.084
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:39:48.084
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:39:48.084
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:39:48.114
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:39:48.114
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:39:48.114
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:39:48.157
SC Data - All Services | Sending logon request message. | 2020-10-07 06:39:48.157
SC Data - All Services | Received logon response. | 2020-10-07 06:39:48.795
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:39:48.795
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:39:48.795
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:39:48.795
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:39:48.795
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:39:48.795
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:39:48.795
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:39:48.795
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:39:48.795
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:39:48.795
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:39:48.809
DTC Client socket (1) | Closed. | 2020-10-07 06:39:48.809
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:40:18.793
DTC Client socket (1) | Creating socket. | 2020-10-07 06:40:18.793
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:40:18.793
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:40:18.793
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:40:18.822
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:40:18.822
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:40:18.822
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:40:18.851
SC Data - All Services | Sending logon request message. | 2020-10-07 06:40:18.851
SC Data - All Services | Received logon response. | 2020-10-07 06:40:19.547
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:40:19.547
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:40:19.547
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:40:19.547
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:40:19.547
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:40:19.547
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:40:19.547
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:40:19.547
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:40:19.547
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:40:19.547
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:40:19.573
DTC Client socket (1) | Closed. | 2020-10-07 06:40:19.573
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:40:49.550
DTC Client socket (1) | Creating socket. | 2020-10-07 06:40:49.551
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:40:49.551
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:40:49.551
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:40:49.581
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:40:49.581
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:40:49.581
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:40:49.609
SC Data - All Services | Sending logon request message. | 2020-10-07 06:40:49.609
SC Data - All Services | Received logon response. | 2020-10-07 06:40:50.267
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:40:50.267
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:40:50.267
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:40:50.267
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:40:50.267
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:40:50.267
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:40:50.267
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:40:50.267
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:40:50.267
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:40:50.267
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:40:50.281
DTC Client socket (1) | Closed. | 2020-10-07 06:40:50.282
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:41:20.260
DTC Client socket (1) | Creating socket. | 2020-10-07 06:41:20.260
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:41:20.260
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:41:20.260
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:41:20.269
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:41:20.269
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:41:20.269
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:41:20.316
SC Data - All Services | Sending logon request message. | 2020-10-07 06:41:20.316
SC Data - All Services | Received logon response. | 2020-10-07 06:41:20.982
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:41:20.982
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:41:20.982
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:41:20.982
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:41:20.982
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:41:20.983
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:41:20.983
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:41:20.983
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:41:20.983
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:41:20.983
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:41:21.000
DTC Client socket (1) | Closed. | 2020-10-07 06:41:21.000
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:41:50.979
DTC Client socket (1) | Creating socket. | 2020-10-07 06:41:50.979
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:41:50.979
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:41:50.979
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:41:51.000
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:41:51.000
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:41:51.000
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:41:51.039
SC Data - All Services | Sending logon request message. | 2020-10-07 06:41:51.039
SC Data - All Services | Received logon response. | 2020-10-07 06:41:51.655
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:41:51.655
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:41:51.655
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:41:51.655
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:41:51.655
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:41:51.655
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:41:51.655
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:41:51.655
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:41:51.655
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:41:51.655
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:41:51.669
DTC Client socket (1) | Closed. | 2020-10-07 06:41:51.669
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:42:21.652
DTC Client socket (1) | Creating socket. | 2020-10-07 06:42:21.653
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:42:21.653
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:42:21.653
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:42:21.681
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:42:21.681
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:42:21.681
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:42:21.721
SC Data - All Services | Sending logon request message. | 2020-10-07 06:42:21.721
SC Data - All Services | Received logon response. | 2020-10-07 06:42:22.343
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:42:22.343
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:42:22.343
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:42:22.343
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:42:22.343
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:42:22.343
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:42:22.343
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:42:22.343
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:42:22.343
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:42:22.343
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:42:22.368
DTC Client socket (1) | Closed. | 2020-10-07 06:42:22.368
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1054 seconds. | 2020-10-07 06:42:29.127
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0419 seconds. | 2020-10-07 06:42:29.170
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:42:52.338
DTC Client socket (1) | Creating socket. | 2020-10-07 06:42:52.338
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:42:52.339
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:42:52.339
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:42:52.354
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:42:52.354
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:42:52.354
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:42:52.399
SC Data - All Services | Sending logon request message. | 2020-10-07 06:42:52.399
SC Data - All Services | Received logon response. | 2020-10-07 06:42:53.074
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:42:53.074
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:42:53.074
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:42:53.074
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:42:53.074
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:42:53.074
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:42:53.074
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:42:53.074
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:42:53.074
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:42:53.074
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:42:53.086
DTC Client socket (1) | Closed. | 2020-10-07 06:42:53.086
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:43:23.085
DTC Client socket (1) | Creating socket. | 2020-10-07 06:43:23.086
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:43:23.086
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:43:23.086
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:43:23.104
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:43:23.104
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:43:23.104
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:43:23.130
SC Data - All Services | Sending logon request message. | 2020-10-07 06:43:23.130
SC Data - All Services | Received logon response. | 2020-10-07 06:43:23.754
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:43:23.754
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:43:23.754
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:43:23.754
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:43:23.754
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:43:23.754
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:43:23.754
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:43:23.754
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:43:23.754
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:43:23.754
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:43:23.767
DTC Client socket (1) | Closed. | 2020-10-07 06:43:23.767
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:43:53.744
DTC Client socket (1) | Creating socket. | 2020-10-07 06:43:53.745
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:43:53.745
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:43:53.745
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:43:53.760
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:43:53.760
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:43:53.760
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:43:53.791
SC Data - All Services | Sending logon request message. | 2020-10-07 06:43:53.791
SC Data - All Services | Received logon response. | 2020-10-07 06:43:54.390
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:43:54.390
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:43:54.390
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:43:54.390
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:43:54.390
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:43:54.390
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:43:54.390
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:43:54.390
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:43:54.390
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:43:54.390
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:43:54.403
DTC Client socket (1) | Closed. | 2020-10-07 06:43:54.403
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:44:24.385
DTC Client socket (1) | Creating socket. | 2020-10-07 06:44:24.386
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:44:24.386
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:44:24.386
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:44:24.412
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:44:24.412
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:44:24.412
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:44:24.455
SC Data - All Services | Sending logon request message. | 2020-10-07 06:44:24.455
SC Data - All Services | Received logon response. | 2020-10-07 06:44:25.159
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:44:25.159
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:44:25.159
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:44:25.159
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:44:25.159
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:44:25.159
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:44:25.159
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:44:25.159
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:44:25.159
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:44:25.159
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:44:25.183
DTC Client socket (1) | Closed. | 2020-10-07 06:44:25.184
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:44:55.151
DTC Client socket (1) | Creating socket. | 2020-10-07 06:44:55.151
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:44:55.151
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:44:55.151
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:44:55.181
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:44:55.181
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:44:55.181
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:44:55.233
SC Data - All Services | Sending logon request message. | 2020-10-07 06:44:55.233
SC Data - All Services | Received logon response. | 2020-10-07 06:44:55.867
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:44:55.867
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:44:55.867
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:44:55.867
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:44:55.867
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:44:55.867
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:44:55.867
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:44:55.867
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:44:55.867
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:44:55.867
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:44:55.881
DTC Client socket (1) | Closed. | 2020-10-07 06:44:55.881
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:45:25.897
DTC Client socket (1) | Creating socket. | 2020-10-07 06:45:25.897
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:45:25.897
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:45:25.897
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:45:25.913
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:45:25.913
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:45:25.913
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:45:25.950
SC Data - All Services | Sending logon request message. | 2020-10-07 06:45:25.950
SC Data - All Services | Received logon response. | 2020-10-07 06:45:26.581
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:45:26.581
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:45:26.581
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:45:26.581
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:45:26.581
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:45:26.581
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:45:26.581
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:45:26.581
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:45:26.581
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:45:26.581
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:45:26.595
DTC Client socket (1) | Closed. | 2020-10-07 06:45:26.595
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:45:56.573
DTC Client socket (1) | Creating socket. | 2020-10-07 06:45:56.573
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:45:56.573
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:45:56.573
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:45:56.595
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:45:56.595
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:45:56.595
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:45:56.613
SC Data - All Services | Sending logon request message. | 2020-10-07 06:45:56.613
SC Data - All Services | Received logon response. | 2020-10-07 06:45:57.233
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:45:57.233
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:45:57.233
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:45:57.233
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:45:57.233
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:45:57.233
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:45:57.233
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:45:57.233
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:45:57.233
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:45:57.233
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:45:57.248
DTC Client socket (1) | Closed. | 2020-10-07 06:45:57.248
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:46:27.226
DTC Client socket (1) | Creating socket. | 2020-10-07 06:46:27.226
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:46:27.226
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:46:27.226
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:46:27.254
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:46:27.254
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:46:27.254
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:46:27.303
SC Data - All Services | Sending logon request message. | 2020-10-07 06:46:27.303
SC Data - All Services | Received logon response. | 2020-10-07 06:46:27.999
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:46:27.999
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:46:27.999
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:46:27.999
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:46:27.999
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:46:27.999
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:46:27.999
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:46:27.999
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:46:27.999
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:46:27.999
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:46:28.024
DTC Client socket (1) | Closed. | 2020-10-07 06:46:28.024
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:46:58.004
DTC Client socket (1) | Creating socket. | 2020-10-07 06:46:58.005
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:46:58.005
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:46:58.005
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:46:58.020
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:46:58.020
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:46:58.020
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:46:58.042
SC Data - All Services | Sending logon request message. | 2020-10-07 06:46:58.042
SC Data - All Services | Received logon response. | 2020-10-07 06:46:58.728
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:46:58.728
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:46:58.728
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:46:58.728
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:46:58.728
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:46:58.728
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:46:58.728
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:46:58.728
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:46:58.728
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:46:58.728
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:46:58.742
DTC Client socket (1) | Closed. | 2020-10-07 06:46:58.742
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:47:28.730
DTC Client socket (1) | Creating socket. | 2020-10-07 06:47:28.730
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:47:28.730
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:47:28.730
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:47:28.745
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:47:28.745
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:47:28.745
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:47:28.793
SC Data - All Services | Sending logon request message. | 2020-10-07 06:47:28.793
SC Data - All Services | Received logon response. | 2020-10-07 06:47:29.422
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:47:29.422
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:47:29.422
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:47:29.422
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:47:29.422
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:47:29.422
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:47:29.422
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:47:29.422
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:47:29.422
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:47:29.422
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:47:29.437
DTC Client socket (1) | Closed. | 2020-10-07 06:47:29.437
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:47:59.416
DTC Client socket (1) | Creating socket. | 2020-10-07 06:47:59.417
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:47:59.417
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:47:59.417
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:47:59.442
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:47:59.442
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:47:59.442
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:47:59.486
SC Data - All Services | Sending logon request message. | 2020-10-07 06:47:59.486
SC Data - All Services | Received logon response. | 2020-10-07 06:48:00.111
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:48:00.111
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:48:00.111
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:48:00.111
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:48:00.111
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:48:00.111
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:48:00.111
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:48:00.111
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:48:00.111
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:48:00.112
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:48:00.126
DTC Client socket (1) | Closed. | 2020-10-07 06:48:00.126
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:48:30.115
DTC Client socket (1) | Creating socket. | 2020-10-07 06:48:30.115
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:48:30.115
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:48:30.115
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:48:30.144
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:48:30.144
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:48:30.144
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:48:30.179
SC Data - All Services | Sending logon request message. | 2020-10-07 06:48:30.179
SC Data - All Services | Received logon response. | 2020-10-07 06:48:30.911
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:48:30.911
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:48:30.911
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:48:30.911
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:48:30.911
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:48:30.911
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:48:30.911
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:48:30.911
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:48:30.911
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:48:30.911
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:48:30.936
DTC Client socket (1) | Closed. | 2020-10-07 06:48:30.936
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:49:00.902
DTC Client socket (1) | Creating socket. | 2020-10-07 06:49:00.902
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:49:00.902
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:49:00.902
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:49:00.923
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:49:00.923
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:49:00.923
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:49:00.966
SC Data - All Services | Sending logon request message. | 2020-10-07 06:49:00.966
SC Data - All Services | Received logon response. | 2020-10-07 06:49:01.659
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:49:01.659
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:49:01.659
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:49:01.659
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:49:01.659
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:49:01.659
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:49:01.659
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:49:01.659
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:49:01.659
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:49:01.659
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:49:01.672
DTC Client socket (1) | Closed. | 2020-10-07 06:49:01.672
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:49:31.650
DTC Client socket (1) | Creating socket. | 2020-10-07 06:49:31.654
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:49:31.654
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:49:31.654
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:49:31.673
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:49:31.673
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:49:31.673
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:49:31.697
SC Data - All Services | Sending logon request message. | 2020-10-07 06:49:31.697
SC Data - All Services | Received logon response. | 2020-10-07 06:49:32.352
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:49:32.352
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:49:32.352
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:49:32.352
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:49:32.352
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:49:32.352
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:49:32.352
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:49:32.353
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:49:32.353
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:49:32.353
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:49:32.367
DTC Client socket (1) | Closed. | 2020-10-07 06:49:32.367
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:50:02.361
DTC Client socket (1) | Creating socket. | 2020-10-07 06:50:02.361
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:50:02.361
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:50:02.361
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:50:02.392
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:50:02.392
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:50:02.392
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:50:02.437
SC Data - All Services | Sending logon request message. | 2020-10-07 06:50:02.437
SC Data - All Services | Received logon response. | 2020-10-07 06:50:03.092
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:50:03.092
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:50:03.092
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:50:03.092
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:50:03.092
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:50:03.092
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:50:03.092
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:50:03.092
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:50:03.092
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:50:03.092
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:50:03.106
DTC Client socket (1) | Closed. | 2020-10-07 06:50:03.106
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:50:33.099
DTC Client socket (1) | Creating socket. | 2020-10-07 06:50:33.099
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:50:33.099
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:50:33.099
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:50:33.127
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:50:33.127
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:50:33.127
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:50:33.155
SC Data - All Services | Sending logon request message. | 2020-10-07 06:50:33.155
SC Data - All Services | Received logon response. | 2020-10-07 06:50:33.845
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:50:33.845
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:50:33.845
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:50:33.845
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:50:33.845
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:50:33.846
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:50:33.846
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:50:33.846
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:50:33.846
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:50:33.846
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:50:33.874
DTC Client socket (1) | Closed. | 2020-10-07 06:50:33.874
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:51:03.851
DTC Client socket (1) | Creating socket. | 2020-10-07 06:51:03.851
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:51:03.851
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:51:03.851
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:51:03.873
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:51:03.873
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:51:03.873
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:51:03.913
SC Data - All Services | Sending logon request message. | 2020-10-07 06:51:03.913
SC Data - All Services | Received logon response. | 2020-10-07 06:51:04.585
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:51:04.585
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:51:04.585
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:51:04.585
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:51:04.585
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:51:04.585
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:51:04.585
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:51:04.585
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:51:04.585
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:51:04.585
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:51:04.598
DTC Client socket (1) | Closed. | 2020-10-07 06:51:04.598
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:51:34.577
DTC Client socket (1) | Creating socket. | 2020-10-07 06:51:34.577
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:51:34.577
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:51:34.577
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:51:34.602
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:51:34.602
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:51:34.602
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:51:34.623
SC Data - All Services | Sending logon request message. | 2020-10-07 06:51:34.623
SC Data - All Services | Received logon response. | 2020-10-07 06:51:35.302
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:51:35.302
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:51:35.302
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:51:35.302
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:51:35.302
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:51:35.302
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:51:35.302
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:51:35.302
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:51:35.302
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:51:35.302
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:51:35.315
DTC Client socket (1) | Closed. | 2020-10-07 06:51:35.315
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:52:05.294
DTC Client socket (1) | Creating socket. | 2020-10-07 06:52:05.294
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:52:05.294
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:52:05.294
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:52:05.323
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:52:05.323
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:52:05.323
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:52:05.350
SC Data - All Services | Sending logon request message. | 2020-10-07 06:52:05.350
SC Data - All Services | Received logon response. | 2020-10-07 06:52:05.998
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:52:05.998
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:52:05.998
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:52:05.998
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:52:05.998
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:52:05.998
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:52:05.998
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:52:05.998
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:52:05.998
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:52:05.998
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:52:06.013
DTC Client socket (1) | Closed. | 2020-10-07 06:52:06.013
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:52:35.998
DTC Client socket (1) | Creating socket. | 2020-10-07 06:52:35.998
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:52:35.998
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:52:35.999
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:52:36.025
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:52:36.025
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:52:36.025
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:52:36.068
SC Data - All Services | Sending logon request message. | 2020-10-07 06:52:36.068
SC Data - All Services | Received logon response. | 2020-10-07 06:52:36.756
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:52:36.756
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:52:36.756
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:52:36.756
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:52:36.756
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:52:36.756
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:52:36.756
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:52:36.756
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:52:36.756
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:52:36.756
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:52:36.781
DTC Client socket (1) | Closed. | 2020-10-07 06:52:36.782
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:53:06.748
DTC Client socket (1) | Creating socket. | 2020-10-07 06:53:06.749
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:53:06.749
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:53:06.749
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:53:06.769
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:53:06.769
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:53:06.769
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:53:06.804
SC Data - All Services | Sending logon request message. | 2020-10-07 06:53:06.804
SC Data - All Services | Received logon response. | 2020-10-07 06:53:07.477
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:53:07.477
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:53:07.477
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:53:07.477
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:53:07.477
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:53:07.477
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:53:07.477
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:53:07.477
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:53:07.477
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:53:07.477
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:53:07.490
DTC Client socket (1) | Closed. | 2020-10-07 06:53:07.491
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:53:37.477
DTC Client socket (1) | Creating socket. | 2020-10-07 06:53:37.477
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:53:37.477
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:53:37.477
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:53:37.499
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:53:37.499
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:53:37.500
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:53:37.530
SC Data - All Services | Sending logon request message. | 2020-10-07 06:53:37.530
SC Data - All Services | Received logon response. | 2020-10-07 06:53:38.120
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:53:38.120
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:53:38.120
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:53:38.120
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:53:38.120
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:53:38.120
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:53:38.120
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:53:38.120
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:53:38.120
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:53:38.120
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:53:38.133
DTC Client socket (1) | Closed. | 2020-10-07 06:53:38.133
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:54:08.117
DTC Client socket (1) | Creating socket. | 2020-10-07 06:54:08.117
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:54:08.117
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:54:08.117
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:54:08.142
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:54:08.142
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:54:08.142
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:54:08.159
SC Data - All Services | Sending logon request message. | 2020-10-07 06:54:08.159
SC Data - All Services | Received logon response. | 2020-10-07 06:54:08.776
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:54:08.776
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:54:08.776
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:54:08.776
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:54:08.776
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:54:08.777
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:54:08.777
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:54:08.777
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:54:08.777
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:54:08.777
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:54:08.796
DTC Client socket (1) | Closed. | 2020-10-07 06:54:08.796
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:54:38.783
DTC Client socket (1) | Creating socket. | 2020-10-07 06:54:38.784
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:54:38.784
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:54:38.784
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:54:38.812
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:54:38.812
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:54:38.812
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:54:38.849
SC Data - All Services | Sending logon request message. | 2020-10-07 06:54:38.849
SC Data - All Services | Received logon response. | 2020-10-07 06:54:39.538
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:54:39.538
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:54:39.538
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:54:39.538
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:54:39.538
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:54:39.538
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:54:39.538
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:54:39.538
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:54:39.538
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:54:39.538
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:54:39.567
DTC Client socket (1) | Closed. | 2020-10-07 06:54:39.567
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:55:09.532
DTC Client socket (1) | Creating socket. | 2020-10-07 06:55:09.533
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:55:09.533
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:55:09.533
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:55:09.547
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:55:09.547
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:55:09.547
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:55:09.585
SC Data - All Services | Sending logon request message. | 2020-10-07 06:55:09.585
SC Data - All Services | Received logon response. | 2020-10-07 06:55:10.274
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:55:10.274
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:55:10.274
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:55:10.274
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:55:10.274
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:55:10.274
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:55:10.274
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:55:10.274
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:55:10.274
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:55:10.275
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:55:10.288
DTC Client socket (1) | Closed. | 2020-10-07 06:55:10.288
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:55:40.283
DTC Client socket (1) | Creating socket. | 2020-10-07 06:55:40.283
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:55:40.283
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:55:40.283
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:55:40.299
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:55:40.299
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:55:40.299
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:55:40.344
SC Data - All Services | Sending logon request message. | 2020-10-07 06:55:40.344
SC Data - All Services | Received logon response. | 2020-10-07 06:55:40.944
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:55:40.944
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:55:40.944
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:55:40.944
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:55:40.944
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:55:40.944
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:55:40.944
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:55:40.944
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:55:40.944
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:55:40.944
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:55:40.957
DTC Client socket (1) | Closed. | 2020-10-07 06:55:40.957
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:56:10.931
DTC Client socket (2) | Creating socket. | 2020-10-07 06:56:10.932
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 06:56:10.932
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:56:10.932
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:56:10.949
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:56:10.949
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:56:10.949
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:56:10.970
SC Data - All Services | Sending logon request message. | 2020-10-07 06:56:10.970
SC Data - All Services | Received logon response. | 2020-10-07 06:56:11.601
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:56:11.601
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:56:11.601
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:56:11.601
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:56:11.601
DTC Client socket (2) | CloseSocket call. | 2020-10-07 06:56:11.601
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:56:11.601
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:56:11.601
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:56:11.601
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:56:11.601
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 06:56:11.615
DTC Client socket (2) | Closed. | 2020-10-07 06:56:11.615
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:56:41.598
DTC Client socket (1) | Creating socket. | 2020-10-07 06:56:41.599
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:56:41.599
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:56:41.599
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:56:41.631
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:56:41.631
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:56:41.631
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:56:41.677
SC Data - All Services | Sending logon request message. | 2020-10-07 06:56:41.677
SC Data - All Services | Received logon response. | 2020-10-07 06:56:42.382
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:56:42.382
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:56:42.382
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:56:42.382
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:56:42.382
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:56:42.382
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:56:42.382
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:56:42.382
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:56:42.382
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:56:42.382
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:56:42.410
DTC Client socket (1) | Closed. | 2020-10-07 06:56:42.410
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:57:12.377
DTC Client socket (1) | Creating socket. | 2020-10-07 06:57:12.377
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:57:12.377
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:57:12.377
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:57:12.397
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:57:12.397
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:57:12.397
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:57:12.446
SC Data - All Services | Sending logon request message. | 2020-10-07 06:57:12.446
SC Data - All Services | Received logon response. | 2020-10-07 06:57:13.129
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:57:13.129
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:57:13.129
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:57:13.129
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:57:13.129
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:57:13.129
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:57:13.129
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:57:13.129
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:57:13.129
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:57:13.129
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:57:13.142
DTC Client socket (1) | Closed. | 2020-10-07 06:57:13.142
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1102 seconds. | 2020-10-07 06:57:29.277
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0409 seconds. | 2020-10-07 06:57:29.319
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:57:43.126
DTC Client socket (1) | Creating socket. | 2020-10-07 06:57:43.127
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:57:43.127
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:57:43.127
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:57:43.150
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:57:43.150
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:57:43.150
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:57:43.186
SC Data - All Services | Sending logon request message. | 2020-10-07 06:57:43.186
SC Data - All Services | Received logon response. | 2020-10-07 06:57:43.772
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:57:43.772
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:57:43.772
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:57:43.772
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:57:43.772
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:57:43.772
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:57:43.772
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:57:43.772
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:57:43.772
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:57:43.773
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:57:43.789
DTC Client socket (1) | Closed. | 2020-10-07 06:57:43.789
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 06:58:13.777
DTC Client socket (1) | Creating socket. | 2020-10-07 06:58:13.777
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:58:13.777
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 06:58:13.777
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:58:13.808
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:58:13.808
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:58:13.808
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:58:13.855
SC Data - All Services | Sending logon request message. | 2020-10-07 06:58:13.855
SC Data - All Services | Received logon response. | 2020-10-07 06:58:14.503
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:58:14.503
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:58:14.503
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:58:14.503
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:58:14.503
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:58:14.504
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:58:14.504
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:58:14.504
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:58:14.504
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:58:14.504
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:58:14.520
DTC Client socket (1) | Closed. | 2020-10-07 06:58:14.520
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 06:58:44.507
DTC Client socket (1) | Creating socket. | 2020-10-07 06:58:44.508
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:58:44.508
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 06:58:44.508
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:58:44.536
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:58:44.536
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:58:44.536
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:58:44.592
SC Data - All Services | Sending logon request message. | 2020-10-07 06:58:44.592
SC Data - All Services | Received logon response. | 2020-10-07 06:58:45.246
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:58:45.246
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:58:45.246
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:58:45.246
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:58:45.246
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:58:45.246
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:58:45.246
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:58:45.246
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:58:45.246
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:58:45.246
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:58:45.271
DTC Client socket (1) | Closed. | 2020-10-07 06:58:45.271
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 06:59:15.246
DTC Client socket (1) | Creating socket. | 2020-10-07 06:59:15.246
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:59:15.246
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 06:59:15.246
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:59:15.262
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:59:15.262
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:59:15.263
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:59:15.285
SC Data - All Services | Sending logon request message. | 2020-10-07 06:59:15.285
SC Data - All Services | Received logon response. | 2020-10-07 06:59:15.926
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:59:15.926
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:59:15.926
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:59:15.926
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:59:15.926
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:59:15.927
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:59:15.927
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:59:15.927
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:59:15.927
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:59:15.927
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:59:15.939
DTC Client socket (1) | Closed. | 2020-10-07 06:59:15.940
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 06:59:45.915
DTC Client socket (1) | Creating socket. | 2020-10-07 06:59:45.915
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 06:59:45.916
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 06:59:45.916
SC Data - All Services | Network connection to server complete. | 2020-10-07 06:59:45.930
SC Data - All Services | Starting socket receive thread. | 2020-10-07 06:59:45.930
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 06:59:45.931
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 06:59:45.956
SC Data - All Services | Sending logon request message. | 2020-10-07 06:59:45.957
SC Data - All Services | Received logon response. | 2020-10-07 06:59:46.599
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 06:59:46.599
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 06:59:46.599
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 06:59:46.599
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 06:59:46.599
DTC Client socket (1) | CloseSocket call. | 2020-10-07 06:59:46.599
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 06:59:46.599
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 06:59:46.600
SC Data - All Services | Disconnected from the server. | 2020-10-07 06:59:46.600
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 06:59:46.600
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 06:59:46.612
DTC Client socket (1) | Closed. | 2020-10-07 06:59:46.612
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:00:16.591
DTC Client socket (1) | Creating socket. | 2020-10-07 07:00:16.591
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:00:16.591
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:00:16.591
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:00:16.612
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:00:16.612
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:00:16.613
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:00:16.654
SC Data - All Services | Sending logon request message. | 2020-10-07 07:00:16.654
SC Data - All Services | Received logon response. | 2020-10-07 07:00:17.305
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:00:17.305
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:00:17.305
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:00:17.305
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:00:17.305
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:00:17.305
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:00:17.305
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:00:17.305
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:00:17.305
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:00:17.305
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:00:17.320
DTC Client socket (1) | Closed. | 2020-10-07 07:00:17.320
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:00:47.317
DTC Client socket (1) | Creating socket. | 2020-10-07 07:00:47.317
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:00:47.317
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:00:47.317
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:00:47.346
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:00:47.346
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:00:47.346
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:00:47.389
SC Data - All Services | Sending logon request message. | 2020-10-07 07:00:47.389
SC Data - All Services | Received logon response. | 2020-10-07 07:00:48.101
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:00:48.101
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:00:48.101
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:00:48.101
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:00:48.101
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:00:48.101
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:00:48.101
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:00:48.101
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:00:48.101
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:00:48.101
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:00:48.126
DTC Client socket (1) | Closed. | 2020-10-07 07:00:48.126
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:01:18.091
DTC Client socket (1) | Creating socket. | 2020-10-07 07:01:18.091
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:01:18.091
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:01:18.091
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:01:18.104
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:01:18.104
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:01:18.104
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:01:18.155
SC Data - All Services | Sending logon request message. | 2020-10-07 07:01:18.155
SC Data - All Services | Received logon response. | 2020-10-07 07:01:18.830
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:01:18.830
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:01:18.830
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:01:18.830
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:01:18.830
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:01:18.831
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:01:18.831
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:01:18.831
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:01:18.831
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:01:18.831
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:01:18.844
DTC Client socket (1) | Closed. | 2020-10-07 07:01:18.844
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:01:48.820
DTC Client socket (1) | Creating socket. | 2020-10-07 07:01:48.821
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:01:48.821
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:01:48.821
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:01:48.848
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:01:48.848
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:01:48.848
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:01:48.877
SC Data - All Services | Sending logon request message. | 2020-10-07 07:01:48.877
SC Data - All Services | Received logon response. | 2020-10-07 07:01:49.486
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:01:49.487
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:01:49.487
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:01:49.487
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:01:49.487
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:01:49.487
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:01:49.487
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:01:49.487
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:01:49.487
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:01:49.487
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:01:49.501
DTC Client socket (1) | Closed. | 2020-10-07 07:01:49.501
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:02:19.489
DTC Client socket (1) | Creating socket. | 2020-10-07 07:02:19.490
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:02:19.490
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:02:19.490
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:02:19.511
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:02:19.511
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:02:19.511
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:02:19.549
SC Data - All Services | Sending logon request message. | 2020-10-07 07:02:19.549
SC Data - All Services | Received logon response. | 2020-10-07 07:02:20.147
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:02:20.147
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:02:20.147
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:02:20.147
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:02:20.147
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:02:20.147
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:02:20.147
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:02:20.147
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:02:20.147
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:02:20.147
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:02:20.163
DTC Client socket (1) | Closed. | 2020-10-07 07:02:20.163
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:02:50.135
DTC Client socket (1) | Creating socket. | 2020-10-07 07:02:50.135
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:02:50.135
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:02:50.135
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:02:50.163
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:02:50.163
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:02:50.163
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:02:50.230
SC Data - All Services | Sending logon request message. | 2020-10-07 07:02:50.230
SC Data - All Services | Received logon response. | 2020-10-07 07:02:50.932
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:02:50.932
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:02:50.932
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:02:50.932
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:02:50.932
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:02:50.932
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:02:50.932
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:02:50.932
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:02:50.932
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:02:50.932
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:02:50.957
DTC Client socket (1) | Closed. | 2020-10-07 07:02:50.957
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:03:20.944
DTC Client socket (1) | Creating socket. | 2020-10-07 07:03:20.945
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:03:20.945
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:03:20.945
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:03:20.960
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:03:20.960
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:03:20.960
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:03:20.998
SC Data - All Services | Sending logon request message. | 2020-10-07 07:03:20.998
SC Data - All Services | Received logon response. | 2020-10-07 07:03:21.662
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:03:21.662
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:03:21.662
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:03:21.662
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:03:21.662
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:03:21.662
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:03:21.662
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:03:21.662
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:03:21.662
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:03:21.663
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:03:21.675
DTC Client socket (1) | Closed. | 2020-10-07 07:03:21.675
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:03:51.658
DTC Client socket (1) | Creating socket. | 2020-10-07 07:03:51.659
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:03:51.659
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:03:51.659
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:03:51.674
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:03:51.674
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:03:51.674
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:03:51.697
SC Data - All Services | Sending logon request message. | 2020-10-07 07:03:51.697
SC Data - All Services | Received logon response. | 2020-10-07 07:03:52.267
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:03:52.267
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:03:52.267
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:03:52.267
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:03:52.267
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:03:52.267
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:03:52.267
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:03:52.267
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:03:52.267
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:03:52.267
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:03:52.279
DTC Client socket (1) | Closed. | 2020-10-07 07:03:52.280
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:04:22.260
DTC Client socket (1) | Creating socket. | 2020-10-07 07:04:22.260
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:04:22.260
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:04:22.260
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:04:22.291
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:04:22.291
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:04:22.291
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:04:22.338
SC Data - All Services | Sending logon request message. | 2020-10-07 07:04:22.338
SC Data - All Services | Received logon response. | 2020-10-07 07:04:22.995
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:04:22.995
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:04:22.995
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:04:22.995
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:04:22.995
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:04:22.996
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:04:22.996
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:04:22.996
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:04:22.996
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:04:22.996
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:04:23.010
DTC Client socket (1) | Closed. | 2020-10-07 07:04:23.010
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:04:52.992
DTC Client socket (1) | Creating socket. | 2020-10-07 07:04:52.993
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:04:52.993
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:04:52.993
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:04:53.019
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:04:53.019
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:04:53.019
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:04:53.068
SC Data - All Services | Sending logon request message. | 2020-10-07 07:04:53.068
SC Data - All Services | Received logon response. | 2020-10-07 07:04:53.711
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:04:53.711
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:04:53.711
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:04:53.711
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:04:53.711
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:04:53.711
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:04:53.711
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:04:53.711
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:04:53.711
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:04:53.711
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:04:53.736
DTC Client socket (1) | Closed. | 2020-10-07 07:04:53.736
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:05:23.712
DTC Client socket (1) | Creating socket. | 2020-10-07 07:05:23.712
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:05:23.713
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:05:23.713
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:05:23.727
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:05:23.727
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:05:23.727
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:05:23.759
SC Data - All Services | Sending logon request message. | 2020-10-07 07:05:23.759
SC Data - All Services | Received logon response. | 2020-10-07 07:05:24.440
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:05:24.440
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:05:24.440
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:05:24.440
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:05:24.440
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:05:24.441
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:05:24.441
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:05:24.441
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:05:24.441
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:05:24.441
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:05:24.454
DTC Client socket (1) | Closed. | 2020-10-07 07:05:24.454
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:05:54.434
DTC Client socket (1) | Creating socket. | 2020-10-07 07:05:54.435
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:05:54.436
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:05:54.436
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:05:54.463
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:05:54.463
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:05:54.463
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:05:54.502
SC Data - All Services | Sending logon request message. | 2020-10-07 07:05:54.502
SC Data - All Services | Received logon response. | 2020-10-07 07:05:55.129
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:05:55.130
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:05:55.130
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:05:55.130
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:05:55.130
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:05:55.130
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:05:55.130
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:05:55.130
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:05:55.130
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:05:55.130
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:05:55.144
DTC Client socket (1) | Closed. | 2020-10-07 07:05:55.144
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:06:25.125
DTC Client socket (1) | Creating socket. | 2020-10-07 07:06:25.126
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:06:25.126
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:06:25.126
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:06:25.154
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:06:25.154
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:06:25.154
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:06:25.180
SC Data - All Services | Sending logon request message. | 2020-10-07 07:06:25.180
SC Data - All Services | Received logon response. | 2020-10-07 07:06:25.810
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:06:25.810
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:06:25.810
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:06:25.810
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:06:25.810
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:06:25.810
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:06:25.810
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:06:25.810
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:06:25.811
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:06:25.811
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:06:25.825
DTC Client socket (1) | Closed. | 2020-10-07 07:06:25.825
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:06:55.818
DTC Client socket (1) | Creating socket. | 2020-10-07 07:06:55.818
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:06:55.818
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:06:55.818
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:06:55.854
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:06:55.854
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:06:55.854
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:06:55.893
SC Data - All Services | Sending logon request message. | 2020-10-07 07:06:55.893
SC Data - All Services | Received logon response. | 2020-10-07 07:06:56.634
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:06:56.634
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:06:56.634
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:06:56.634
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:06:56.634
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:06:56.635
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:06:56.635
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:06:56.635
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:06:56.635
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:06:56.635
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:06:56.660
DTC Client socket (1) | Closed. | 2020-10-07 07:06:56.660
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:07:26.635
DTC Client socket (1) | Creating socket. | 2020-10-07 07:07:26.636
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:07:26.636
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:07:26.636
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:07:26.652
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:07:26.652
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:07:26.652
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:07:26.674
SC Data - All Services | Sending logon request message. | 2020-10-07 07:07:26.674
SC Data - All Services | Received logon response. | 2020-10-07 07:07:27.364
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:07:27.364
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:07:27.364
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:07:27.364
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:07:27.364
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:07:27.364
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:07:27.364
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:07:27.364
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:07:27.364
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:07:27.364
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:07:27.376
DTC Client socket (1) | Closed. | 2020-10-07 07:07:27.376
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:07:57.360
DTC Client socket (1) | Creating socket. | 2020-10-07 07:07:57.361
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:07:57.361
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:07:57.362
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:07:57.382
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:07:57.382
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:07:57.382
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:07:57.429
SC Data - All Services | Sending logon request message. | 2020-10-07 07:07:57.429
SC Data - All Services | Received logon response. | 2020-10-07 07:07:58.107
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:07:58.107
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:07:58.107
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:07:58.107
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:07:58.107
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:07:58.108
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:07:58.108
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:07:58.108
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:07:58.108
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:07:58.108
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:07:58.121
DTC Client socket (1) | Closed. | 2020-10-07 07:07:58.121
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:08:28.102
DTC Client socket (1) | Creating socket. | 2020-10-07 07:08:28.103
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:08:28.103
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:08:28.103
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:08:28.124
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:08:28.124
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:08:28.124
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:08:28.140
SC Data - All Services | Sending logon request message. | 2020-10-07 07:08:28.140
SC Data - All Services | Received logon response. | 2020-10-07 07:08:28.787
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:08:28.787
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:08:28.787
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:08:28.787
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:08:28.787
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:08:28.787
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:08:28.787
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:08:28.787
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:08:28.787
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:08:28.787
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:08:28.803
DTC Client socket (1) | Closed. | 2020-10-07 07:08:28.803
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:08:58.777
DTC Client socket (1) | Creating socket. | 2020-10-07 07:08:58.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:08:58.778
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:08:58.778
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:08:58.809
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:08:58.809
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:08:58.810
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:08:58.854
SC Data - All Services | Sending logon request message. | 2020-10-07 07:08:58.854
SC Data - All Services | Received logon response. | 2020-10-07 07:08:59.486
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:08:59.486
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:08:59.486
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:08:59.486
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:08:59.486
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:08:59.486
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:08:59.486
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:08:59.486
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:08:59.486
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:08:59.486
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:08:59.508
DTC Client socket (1) | Closed. | 2020-10-07 07:08:59.508
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:09:29.495
DTC Client socket (1) | Creating socket. | 2020-10-07 07:09:29.495
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:09:29.495
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:09:29.495
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:09:29.511
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:09:29.511
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:09:29.511
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:09:29.539
SC Data - All Services | Sending logon request message. | 2020-10-07 07:09:29.539
SC Data - All Services | Received logon response. | 2020-10-07 07:09:30.196
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:09:30.196
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:09:30.196
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:09:30.196
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:09:30.196
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:09:30.196
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:09:30.196
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:09:30.196
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:09:30.197
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:09:30.197
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:09:30.211
DTC Client socket (1) | Closed. | 2020-10-07 07:09:30.211
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:10:00.199
DTC Client socket (1) | Creating socket. | 2020-10-07 07:10:00.199
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:10:00.199
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:10:00.199
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:10:00.226
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:10:00.226
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:10:00.226
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:10:00.273
SC Data - All Services | Sending logon request message. | 2020-10-07 07:10:00.273
SC Data - All Services | Received logon response. | 2020-10-07 07:10:00.895
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:10:00.895
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:10:00.895
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:10:00.895
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:10:00.895
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:10:00.896
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:10:00.896
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:10:00.896
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:10:00.896
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:10:00.896
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:10:00.910
DTC Client socket (1) | Closed. | 2020-10-07 07:10:00.910
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:10:30.896
DTC Client socket (1) | Creating socket. | 2020-10-07 07:10:30.896
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:10:30.896
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:10:30.897
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:10:30.912
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:10:30.912
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:10:30.912
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:10:30.927
SC Data - All Services | Sending logon request message. | 2020-10-07 07:10:30.927
SC Data - All Services | Received logon response. | 2020-10-07 07:10:31.578
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:10:31.578
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:10:31.578
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:10:31.578
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:10:31.578
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:10:31.578
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:10:31.578
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:10:31.578
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:10:31.578
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:10:31.578
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:10:31.593
DTC Client socket (1) | Closed. | 2020-10-07 07:10:31.593
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:11:01.579
DTC Client socket (1) | Creating socket. | 2020-10-07 07:11:01.579
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:11:01.579
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:11:01.579
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:11:01.616
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:11:01.616
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:11:01.616
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:11:01.648
SC Data - All Services | Sending logon request message. | 2020-10-07 07:11:01.648
SC Data - All Services | Received logon response. | 2020-10-07 07:11:02.373
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:11:02.373
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:11:02.373
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:11:02.373
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:11:02.373
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:11:02.375
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:11:02.375
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:11:02.375
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:11:02.375
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:11:02.375
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:11:02.399
DTC Client socket (1) | Closed. | 2020-10-07 07:11:02.399
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:11:32.374
DTC Client socket (1) | Creating socket. | 2020-10-07 07:11:32.374
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:11:32.374
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:11:32.374
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:11:32.395
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:11:32.395
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:11:32.395
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:11:32.411
SC Data - All Services | Sending logon request message. | 2020-10-07 07:11:32.411
SC Data - All Services | Received logon response. | 2020-10-07 07:11:33.118
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:11:33.118
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:11:33.118
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:11:33.118
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:11:33.119
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:11:33.119
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:11:33.119
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:11:33.119
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:11:33.119
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:11:33.119
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:11:33.133
DTC Client socket (1) | Closed. | 2020-10-07 07:11:33.133
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:12:03.130
DTC Client socket (2) | Creating socket. | 2020-10-07 07:12:03.131
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:12:03.131
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:12:03.131
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:12:03.148
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:12:03.148
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:12:03.148
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:12:03.208
SC Data - All Services | Sending logon request message. | 2020-10-07 07:12:03.208
SC Data - All Services | Received logon response. | 2020-10-07 07:12:03.847
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:12:03.847
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:12:03.847
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:12:03.847
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:12:03.847
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:12:03.847
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:12:03.847
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:12:03.848
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:12:03.848
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:12:03.848
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:12:03.860
DTC Client socket (2) | Closed. | 2020-10-07 07:12:03.860
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1294 seconds. | 2020-10-07 07:12:29.441
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0371 seconds. | 2020-10-07 07:12:29.480
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:12:33.840
DTC Client socket (1) | Creating socket. | 2020-10-07 07:12:33.841
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:12:33.841
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:12:33.841
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:12:33.869
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:12:33.869
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:12:33.870
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:12:33.901
SC Data - All Services | Sending logon request message. | 2020-10-07 07:12:33.901
SC Data - All Services | Received logon response. | 2020-10-07 07:12:34.527
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:12:34.527
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:12:34.527
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:12:34.527
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:12:34.527
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:12:34.528
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:12:34.528
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:12:34.528
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:12:34.528
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:12:34.528
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:12:34.544
DTC Client socket (1) | Closed. | 2020-10-07 07:12:34.544
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:13:04.537
DTC Client socket (1) | Creating socket. | 2020-10-07 07:13:04.538
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:13:04.538
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:13:04.538
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:13:04.568
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:13:04.569
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:13:04.569
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:13:04.633
SC Data - All Services | Sending logon request message. | 2020-10-07 07:13:04.633
SC Data - All Services | Received logon response. | 2020-10-07 07:13:05.311
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:13:05.311
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:13:05.311
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:13:05.311
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:13:05.311
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:13:05.312
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:13:05.312
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:13:05.312
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:13:05.312
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:13:05.312
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:13:05.338
DTC Client socket (1) | Closed. | 2020-10-07 07:13:05.338
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:13:35.315
DTC Client socket (1) | Creating socket. | 2020-10-07 07:13:35.316
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:13:35.316
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:13:35.316
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:13:35.337
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:13:35.337
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:13:35.338
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:13:35.355
SC Data - All Services | Sending logon request message. | 2020-10-07 07:13:35.355
SC Data - All Services | Received logon response. | 2020-10-07 07:13:36.026
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:13:36.026
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:13:36.026
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:13:36.026
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:13:36.026
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:13:36.026
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:13:36.026
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:13:36.027
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:13:36.027
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:13:36.027
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:13:36.039
DTC Client socket (1) | Closed. | 2020-10-07 07:13:36.039
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:14:06.029
DTC Client socket (1) | Creating socket. | 2020-10-07 07:14:06.029
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:14:06.030
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:14:06.030
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:14:06.060
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:14:06.060
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:14:06.060
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:14:06.084
SC Data - All Services | Sending logon request message. | 2020-10-07 07:14:06.084
SC Data - All Services | Received logon response. | 2020-10-07 07:14:06.757
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:14:06.757
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:14:06.757
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:14:06.757
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:14:06.757
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:14:06.757
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:14:06.757
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:14:06.757
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:14:06.757
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:14:06.757
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:14:06.771
DTC Client socket (1) | Closed. | 2020-10-07 07:14:06.771
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:14:36.754
DTC Client socket (1) | Creating socket. | 2020-10-07 07:14:36.755
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:14:36.755
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:14:36.755
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:14:36.769
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:14:36.769
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:14:36.769
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:14:36.812
SC Data - All Services | Sending logon request message. | 2020-10-07 07:14:36.812
SC Data - All Services | Received logon response. | 2020-10-07 07:14:37.450
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:14:37.450
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:14:37.450
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:14:37.450
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:14:37.450
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:14:37.450
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:14:37.450
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:14:37.451
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:14:37.451
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:14:37.451
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:14:37.466
DTC Client socket (1) | Closed. | 2020-10-07 07:14:37.466
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:15:07.458
DTC Client socket (1) | Creating socket. | 2020-10-07 07:15:07.458
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:15:07.459
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:15:07.459
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:15:07.486
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:15:07.486
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:15:07.486
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:15:07.519
SC Data - All Services | Sending logon request message. | 2020-10-07 07:15:07.519
SC Data - All Services | Received logon response. | 2020-10-07 07:15:08.221
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:15:08.221
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:15:08.221
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:15:08.221
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:15:08.221
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:15:08.221
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:15:08.221
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:15:08.221
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:15:08.221
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:15:08.221
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:15:08.246
DTC Client socket (1) | Closed. | 2020-10-07 07:15:08.246
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:15:38.218
DTC Client socket (1) | Creating socket. | 2020-10-07 07:15:38.219
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:15:38.219
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:15:38.219
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:15:38.233
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:15:38.233
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:15:38.234
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:15:38.280
SC Data - All Services | Sending logon request message. | 2020-10-07 07:15:38.280
SC Data - All Services | Received logon response. | 2020-10-07 07:15:38.935
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:15:38.935
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:15:38.935
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:15:38.935
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:15:38.935
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:15:38.936
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:15:38.936
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:15:38.936
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:15:38.936
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:15:38.936
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:15:38.950
DTC Client socket (1) | Closed. | 2020-10-07 07:15:38.950
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:16:08.942
DTC Client socket (2) | Creating socket. | 2020-10-07 07:16:08.942
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:16:08.942
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:16:08.942
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:16:08.957
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:16:08.957
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:16:08.957
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:16:08.982
SC Data - All Services | Sending logon request message. | 2020-10-07 07:16:08.982
SC Data - All Services | Received logon response. | 2020-10-07 07:16:09.639
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:16:09.639
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:16:09.639
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:16:09.639
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:16:09.639
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:16:09.639
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:16:09.639
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:16:09.639
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:16:09.639
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:16:09.639
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:16:09.653
DTC Client socket (2) | Closed. | 2020-10-07 07:16:09.653
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:16:39.638
DTC Client socket (1) | Creating socket. | 2020-10-07 07:16:39.638
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:16:39.638
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:16:39.638
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:16:39.667
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:16:39.667
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:16:39.667
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:16:39.695
SC Data - All Services | Sending logon request message. | 2020-10-07 07:16:39.695
SC Data - All Services | Received logon response. | 2020-10-07 07:16:40.328
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:16:40.328
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:16:40.328
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:16:40.328
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:16:40.328
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:16:40.328
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:16:40.328
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:16:40.328
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:16:40.329
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:16:40.329
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:16:40.343
DTC Client socket (1) | Closed. | 2020-10-07 07:16:40.343
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:17:10.321
DTC Client socket (1) | Creating socket. | 2020-10-07 07:17:10.321
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:17:10.321
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:17:10.321
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:17:10.347
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:17:10.347
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:17:10.347
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:17:10.382
SC Data - All Services | Sending logon request message. | 2020-10-07 07:17:10.382
SC Data - All Services | Received logon response. | 2020-10-07 07:17:11.056
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:17:11.056
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:17:11.056
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:17:11.056
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:17:11.056
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:17:11.056
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:17:11.056
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:17:11.056
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:17:11.056
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:17:11.057
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:17:11.085
DTC Client socket (1) | Closed. | 2020-10-07 07:17:11.085
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:17:41.063
DTC Client socket (1) | Creating socket. | 2020-10-07 07:17:41.063
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:17:41.063
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:17:41.063
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:17:41.086
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:17:41.086
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:17:41.086
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:17:41.133
SC Data - All Services | Sending logon request message. | 2020-10-07 07:17:41.133
SC Data - All Services | Received logon response. | 2020-10-07 07:17:41.801
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:17:41.801
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:17:41.801
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:17:41.801
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:17:41.801
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:17:41.801
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:17:41.801
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:17:41.801
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:17:41.801
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:17:41.801
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:17:41.814
DTC Client socket (1) | Closed. | 2020-10-07 07:17:41.814
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:18:11.792
DTC Client socket (1) | Creating socket. | 2020-10-07 07:18:11.793
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:18:11.793
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:18:11.793
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:18:11.814
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:18:11.814
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:18:11.814
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:18:11.861
SC Data - All Services | Sending logon request message. | 2020-10-07 07:18:11.861
SC Data - All Services | Received logon response. | 2020-10-07 07:18:12.496
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:18:12.496
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:18:12.496
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:18:12.496
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:18:12.496
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:18:12.496
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:18:12.496
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:18:12.496
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:18:12.496
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:18:12.496
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:18:12.509
DTC Client socket (1) | Closed. | 2020-10-07 07:18:12.509
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:18:42.496
DTC Client socket (1) | Creating socket. | 2020-10-07 07:18:42.497
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:18:42.497
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:18:42.497
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:18:42.518
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:18:42.518
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:18:42.518
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:18:42.535
SC Data - All Services | Sending logon request message. | 2020-10-07 07:18:42.535
SC Data - All Services | Received logon response. | 2020-10-07 07:18:43.156
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:18:43.156
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:18:43.156
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:18:43.156
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:18:43.156
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:18:43.156
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:18:43.156
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:18:43.156
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:18:43.156
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:18:43.156
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:18:43.179
DTC Client socket (1) | Closed. | 2020-10-07 07:18:43.179
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:19:13.167
DTC Client socket (1) | Creating socket. | 2020-10-07 07:19:13.167
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:19:13.168
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:19:13.168
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:19:13.194
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:19:13.194
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:19:13.194
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:19:13.244
SC Data - All Services | Sending logon request message. | 2020-10-07 07:19:13.244
SC Data - All Services | Received logon response. | 2020-10-07 07:19:13.952
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:19:13.952
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:19:13.952
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:19:13.952
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:19:13.952
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:19:13.952
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:19:13.952
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:19:13.952
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:19:13.952
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:19:13.952
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:19:13.976
DTC Client socket (1) | Closed. | 2020-10-07 07:19:13.976
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:19:43.947
DTC Client socket (1) | Creating socket. | 2020-10-07 07:19:43.947
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:19:43.947
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:19:43.947
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:19:43.962
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:19:43.962
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:19:43.963
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:19:44.001
SC Data - All Services | Sending logon request message. | 2020-10-07 07:19:44.001
SC Data - All Services | Received logon response. | 2020-10-07 07:19:44.640
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:19:44.641
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:19:44.641
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:19:44.641
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:19:44.641
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:19:44.641
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:19:44.641
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:19:44.641
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:19:44.641
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:19:44.641
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:19:44.653
DTC Client socket (1) | Closed. | 2020-10-07 07:19:44.653
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:20:14.636
DTC Client socket (1) | Creating socket. | 2020-10-07 07:20:14.637
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:20:14.637
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:20:14.637
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:20:14.659
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:20:14.659
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:20:14.660
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:20:14.677
SC Data - All Services | Sending logon request message. | 2020-10-07 07:20:14.677
SC Data - All Services | Received logon response. | 2020-10-07 07:20:15.378
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:20:15.378
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:20:15.378
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:20:15.378
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:20:15.378
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:20:15.379
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:20:15.379
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:20:15.379
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:20:15.379
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:20:15.379
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:20:15.393
DTC Client socket (1) | Closed. | 2020-10-07 07:20:15.393
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:20:45.368
DTC Client socket (1) | Creating socket. | 2020-10-07 07:20:45.369
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:20:45.369
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:20:45.369
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:20:45.391
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:20:45.391
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:20:45.391
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:20:45.446
SC Data - All Services | Sending logon request message. | 2020-10-07 07:20:45.446
SC Data - All Services | Received logon response. | 2020-10-07 07:20:46.082
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:20:46.082
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:20:46.082
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:20:46.082
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:20:46.082
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:20:46.082
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:20:46.082
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:20:46.082
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:20:46.083
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:20:46.083
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:20:46.098
DTC Client socket (1) | Closed. | 2020-10-07 07:20:46.098
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:21:16.075
DTC Client socket (1) | Creating socket. | 2020-10-07 07:21:16.076
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:21:16.076
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:21:16.076
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:21:16.106
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:21:16.106
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:21:16.106
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:21:16.150
SC Data - All Services | Sending logon request message. | 2020-10-07 07:21:16.150
SC Data - All Services | Received logon response. | 2020-10-07 07:21:16.804
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:21:16.804
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:21:16.804
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:21:16.804
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:21:16.804
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:21:16.804
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:21:16.804
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:21:16.804
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:21:16.804
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:21:16.804
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:21:16.834
DTC Client socket (1) | Closed. | 2020-10-07 07:21:16.834
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:21:46.814
DTC Client socket (1) | Creating socket. | 2020-10-07 07:21:46.815
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:21:46.815
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:21:46.815
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:21:46.846
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:21:46.846
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:21:46.846
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:21:46.889
SC Data - All Services | Sending logon request message. | 2020-10-07 07:21:46.889
SC Data - All Services | Received logon response. | 2020-10-07 07:21:47.576
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:21:47.576
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:21:47.576
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:21:47.576
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:21:47.576
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:21:47.576
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:21:47.576
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:21:47.576
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:21:47.576
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:21:47.576
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:21:47.588
DTC Client socket (1) | Closed. | 2020-10-07 07:21:47.588
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:22:17.581
DTC Client socket (1) | Creating socket. | 2020-10-07 07:22:17.581
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:22:17.581
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:22:17.581
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:22:17.602
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:22:17.602
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:22:17.602
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:22:17.630
SC Data - All Services | Sending logon request message. | 2020-10-07 07:22:17.630
SC Data - All Services | Received logon response. | 2020-10-07 07:22:18.287
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:22:18.287
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:22:18.287
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:22:18.287
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:22:18.287
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:22:18.287
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:22:18.287
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:22:18.287
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:22:18.287
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:22:18.287
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:22:18.299
DTC Client socket (1) | Closed. | 2020-10-07 07:22:18.299
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:22:48.273
DTC Client socket (1) | Creating socket. | 2020-10-07 07:22:48.273
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:22:48.273
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:22:48.273
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:22:48.288
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:22:48.288
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:22:48.288
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:22:48.320
SC Data - All Services | Sending logon request message. | 2020-10-07 07:22:48.320
SC Data - All Services | Received logon response. | 2020-10-07 07:22:48.976
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:22:48.976
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:22:48.976
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:22:48.976
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:22:48.976
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:22:48.977
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:22:48.977
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:22:48.977
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:22:48.977
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:22:48.977
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:22:48.992
DTC Client socket (1) | Closed. | 2020-10-07 07:22:48.993
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:23:18.984
DTC Client socket (1) | Creating socket. | 2020-10-07 07:23:18.985
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:23:18.985
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:23:18.985
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:23:19.012
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:23:19.012
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:23:19.012
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:23:19.088
SC Data - All Services | Sending logon request message. | 2020-10-07 07:23:19.088
SC Data - All Services | Received logon response. | 2020-10-07 07:23:19.788
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:23:19.788
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:23:19.788
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:23:19.788
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:23:19.788
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:23:19.788
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:23:19.788
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:23:19.789
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:23:19.789
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:23:19.789
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:23:19.815
DTC Client socket (1) | Closed. | 2020-10-07 07:23:19.815
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:23:49.800
DTC Client socket (1) | Creating socket. | 2020-10-07 07:23:49.801
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:23:49.801
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:23:49.801
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:23:49.814
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:23:49.814
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:23:49.814
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:23:49.863
SC Data - All Services | Sending logon request message. | 2020-10-07 07:23:49.863
SC Data - All Services | Received logon response. | 2020-10-07 07:23:50.507
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:23:50.507
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:23:50.507
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:23:50.507
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:23:50.507
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:23:50.507
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:23:50.507
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:23:50.507
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:23:50.507
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:23:50.507
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:23:50.521
DTC Client socket (1) | Closed. | 2020-10-07 07:23:50.521
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:24:20.502
DTC Client socket (1) | Creating socket. | 2020-10-07 07:24:20.503
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:24:20.503
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:24:20.503
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:24:20.516
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:24:20.516
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:24:20.516
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:24:20.548
SC Data - All Services | Sending logon request message. | 2020-10-07 07:24:20.548
SC Data - All Services | Received logon response. | 2020-10-07 07:24:21.175
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:24:21.175
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:24:21.175
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:24:21.175
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:24:21.175
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:24:21.175
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:24:21.175
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:24:21.175
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:24:21.175
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:24:21.175
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:24:21.187
DTC Client socket (1) | Closed. | 2020-10-07 07:24:21.187
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:24:51.165
DTC Client socket (1) | Creating socket. | 2020-10-07 07:24:51.166
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:24:51.166
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:24:51.166
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:24:51.187
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:24:51.187
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:24:51.187
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:24:51.220
SC Data - All Services | Sending logon request message. | 2020-10-07 07:24:51.220
SC Data - All Services | Received logon response. | 2020-10-07 07:24:51.865
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:24:51.865
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:24:51.865
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:24:51.865
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:24:51.865
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:24:51.867
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:24:51.867
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:24:51.867
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:24:51.867
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:24:51.867
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:24:51.880
DTC Client socket (1) | Closed. | 2020-10-07 07:24:51.880
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:25:21.866
DTC Client socket (1) | Creating socket. | 2020-10-07 07:25:21.867
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:25:21.867
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:25:21.867
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:25:21.894
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:25:21.894
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:25:21.894
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:25:21.938
SC Data - All Services | Sending logon request message. | 2020-10-07 07:25:21.938
SC Data - All Services | Received logon response. | 2020-10-07 07:25:22.624
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:25:22.624
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:25:22.624
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:25:22.624
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:25:22.624
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:25:22.624
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:25:22.624
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:25:22.624
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:25:22.624
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:25:22.624
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:25:22.653
DTC Client socket (1) | Closed. | 2020-10-07 07:25:22.653
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:25:52.623
DTC Client socket (1) | Creating socket. | 2020-10-07 07:25:52.624
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:25:52.624
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:25:52.624
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:25:52.645
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:25:52.645
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:25:52.645
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:25:52.668
SC Data - All Services | Sending logon request message. | 2020-10-07 07:25:52.668
SC Data - All Services | Received logon response. | 2020-10-07 07:25:53.332
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:25:53.332
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:25:53.332
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:25:53.332
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:25:53.332
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:25:53.332
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:25:53.332
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:25:53.332
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:25:53.332
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:25:53.332
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:25:53.345
DTC Client socket (1) | Closed. | 2020-10-07 07:25:53.345
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:26:23.339
DTC Client socket (1) | Creating socket. | 2020-10-07 07:26:23.339
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:26:23.339
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:26:23.339
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:26:23.354
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:26:23.354
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:26:23.354
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:26:23.394
SC Data - All Services | Sending logon request message. | 2020-10-07 07:26:23.394
SC Data - All Services | Received logon response. | 2020-10-07 07:26:24.035
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:26:24.035
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:26:24.035
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:26:24.035
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:26:24.035
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:26:24.035
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:26:24.035
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:26:24.035
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:26:24.035
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:26:24.035
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:26:24.048
DTC Client socket (1) | Closed. | 2020-10-07 07:26:24.048
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:26:54.025
DTC Client socket (1) | Creating socket. | 2020-10-07 07:26:54.025
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:26:54.026
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:26:54.026
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:26:54.047
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:26:54.047
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:26:54.047
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:26:54.093
SC Data - All Services | Sending logon request message. | 2020-10-07 07:26:54.094
SC Data - All Services | Received logon response. | 2020-10-07 07:26:54.729
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:26:54.729
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:26:54.729
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:26:54.729
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:26:54.729
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:26:54.729
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:26:54.729
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:26:54.729
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:26:54.729
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:26:54.729
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:26:54.743
DTC Client socket (1) | Closed. | 2020-10-07 07:26:54.743
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:27:24.729
DTC Client socket (1) | Creating socket. | 2020-10-07 07:27:24.729
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:27:24.729
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:27:24.729
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:27:24.756
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:27:24.756
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:27:24.756
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:27:24.814
SC Data - All Services | Sending logon request message. | 2020-10-07 07:27:24.814
SC Data - All Services | Received logon response. | 2020-10-07 07:27:25.520
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:27:25.520
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:27:25.520
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:27:25.520
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:27:25.520
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:27:25.521
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:27:25.521
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:27:25.521
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:27:25.521
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:27:25.521
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:27:25.546
DTC Client socket (1) | Closed. | 2020-10-07 07:27:25.546
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1694 seconds. | 2020-10-07 07:27:29.654
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0448 seconds. | 2020-10-07 07:27:29.700
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:27:55.516
DTC Client socket (1) | Creating socket. | 2020-10-07 07:27:55.517
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:27:55.517
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:27:55.517
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:27:55.539
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:27:55.539
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:27:55.539
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:27:55.580
SC Data - All Services | Sending logon request message. | 2020-10-07 07:27:55.580
SC Data - All Services | Received logon response. | 2020-10-07 07:27:56.250
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:27:56.250
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:27:56.250
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:27:56.250
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:27:56.250
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:27:56.252
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:27:56.252
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:27:56.252
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:27:56.252
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:27:56.252
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:27:56.265
DTC Client socket (1) | Closed. | 2020-10-07 07:27:56.265
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:28:26.252
DTC Client socket (1) | Creating socket. | 2020-10-07 07:28:26.253
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:28:26.253
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:28:26.253
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:28:26.268
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:28:26.268
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:28:26.268
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:28:26.284
SC Data - All Services | Sending logon request message. | 2020-10-07 07:28:26.284
SC Data - All Services | Received logon response. | 2020-10-07 07:28:26.940
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:28:26.940
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:28:26.940
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:28:26.940
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:28:26.940
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:28:26.940
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:28:26.940
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:28:26.940
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:28:26.940
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:28:26.940
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:28:26.954
DTC Client socket (1) | Closed. | 2020-10-07 07:28:26.954
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:28:56.934
DTC Client socket (1) | Creating socket. | 2020-10-07 07:28:56.934
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:28:56.934
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:28:56.934
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:28:56.961
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:28:56.961
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:28:56.961
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:28:56.987
SC Data - All Services | Sending logon request message. | 2020-10-07 07:28:56.987
SC Data - All Services | Received logon response. | 2020-10-07 07:28:57.648
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:28:57.648
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:28:57.648
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:28:57.648
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:28:57.648
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:28:57.649
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:28:57.649
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:28:57.649
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:28:57.649
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:28:57.649
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:28:57.666
DTC Client socket (1) | Closed. | 2020-10-07 07:28:57.666
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:29:27.660
DTC Client socket (1) | Creating socket. | 2020-10-07 07:29:27.661
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:29:27.661
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:29:27.661
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:29:27.707
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:29:27.707
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:29:27.707
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:29:27.764
SC Data - All Services | Sending logon request message. | 2020-10-07 07:29:27.764
SC Data - All Services | Received logon response. | 2020-10-07 07:29:28.499
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:29:28.499
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:29:28.499
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:29:28.500
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:29:28.500
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:29:28.500
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:29:28.500
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:29:28.500
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:29:28.500
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:29:28.500
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:29:28.542
DTC Client socket (1) | Closed. | 2020-10-07 07:29:28.542
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:29:58.500
DTC Client socket (1) | Creating socket. | 2020-10-07 07:29:58.501
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:29:58.501
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:29:58.501
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:29:58.562
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:29:58.562
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:29:58.562
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:29:58.610
SC Data - All Services | Sending logon request message. | 2020-10-07 07:29:58.610
SC Data - All Services | Received logon response. | 2020-10-07 07:29:59.269
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:29:59.269
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:29:59.269
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:29:59.269
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:29:59.269
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:29:59.269
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:29:59.269
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:29:59.269
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:29:59.269
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:29:59.269
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:29:59.292
DTC Client socket (1) | Closed. | 2020-10-07 07:29:59.292
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:30:29.262
DTC Client socket (1) | Creating socket. | 2020-10-07 07:30:29.262
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:30:29.262
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:30:29.262
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:30:29.299
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:30:29.299
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:30:29.299
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:30:29.337
SC Data - All Services | Sending logon request message. | 2020-10-07 07:30:29.337
SC Data - All Services | Received logon response. | 2020-10-07 07:30:29.598
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:30:29.598
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:30:29.598
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:30:29.598
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:30:29.598
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:30:29.598
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:30:29.598
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:30:29.598
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:30:29.598
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:30:29.598
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:30:29.616
DTC Client socket (1) | Closed. | 2020-10-07 07:30:29.616
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:30:59.592
DTC Client socket (1) | Creating socket. | 2020-10-07 07:30:59.593
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:30:59.593
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:30:59.593
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:30:59.623
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:30:59.623
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:30:59.623
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:30:59.661
SC Data - All Services | Sending logon request message. | 2020-10-07 07:30:59.661
SC Data - All Services | Received logon response. | 2020-10-07 07:31:00.291
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:31:00.291
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:31:00.291
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:31:00.291
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:31:00.291
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:31:00.291
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:31:00.291
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:31:00.291
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:31:00.291
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:31:00.291
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:31:00.306
DTC Client socket (1) | Closed. | 2020-10-07 07:31:00.306
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:31:30.297
DTC Client socket (1) | Creating socket. | 2020-10-07 07:31:30.298
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:31:30.298
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:31:30.298
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:31:30.327
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:31:30.327
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:31:30.327
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:31:30.382
SC Data - All Services | Sending logon request message. | 2020-10-07 07:31:30.382
SC Data - All Services | Received logon response. | 2020-10-07 07:31:31.036
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:31:31.036
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:31:31.036
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:31:31.036
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:31:31.036
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:31:31.036
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:31:31.036
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:31:31.036
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:31:31.036
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:31:31.036
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:31:31.067
DTC Client socket (1) | Closed. | 2020-10-07 07:31:31.067
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:32:01.065
DTC Client socket (1) | Creating socket. | 2020-10-07 07:32:01.068
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:32:01.068
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:32:01.068
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:32:01.087
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:32:01.087
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:32:01.087
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:32:01.111
SC Data - All Services | Sending logon request message. | 2020-10-07 07:32:01.111
SC Data - All Services | Received logon response. | 2020-10-07 07:32:01.768
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:32:01.768
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:32:01.768
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:32:01.768
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:32:01.768
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:32:01.768
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:32:01.768
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:32:01.768
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:32:01.768
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:32:01.768
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:32:01.779
DTC Client socket (1) | Closed. | 2020-10-07 07:32:01.779
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:32:31.768
DTC Client socket (1) | Creating socket. | 2020-10-07 07:32:31.768
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:32:31.768
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:32:31.768
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:32:31.783
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:32:31.783
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:32:31.783
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:32:31.814
SC Data - All Services | Sending logon request message. | 2020-10-07 07:32:31.814
SC Data - All Services | Received logon response. | 2020-10-07 07:32:32.449
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:32:32.449
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:32:32.449
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:32:32.449
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:32:32.449
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:32:32.450
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:32:32.450
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:32:32.450
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:32:32.450
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:32:32.450
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:32:32.464
DTC Client socket (1) | Closed. | 2020-10-07 07:32:32.464
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:33:02.450
DTC Client socket (1) | Creating socket. | 2020-10-07 07:33:02.451
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:33:02.451
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:33:02.451
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:33:02.481
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:33:02.481
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:33:02.481
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:33:02.505
SC Data - All Services | Sending logon request message. | 2020-10-07 07:33:02.506
SC Data - All Services | Received logon response. | 2020-10-07 07:33:03.150
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:33:03.150
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:33:03.150
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:33:03.150
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:33:03.150
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:33:03.150
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:33:03.150
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:33:03.150
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:33:03.150
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:33:03.150
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:33:03.165
DTC Client socket (1) | Closed. | 2020-10-07 07:33:03.165
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:33:33.160
DTC Client socket (1) | Creating socket. | 2020-10-07 07:33:33.160
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:33:33.160
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:33:33.160
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:33:33.194
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:33:33.194
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:33:33.194
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:33:33.245
SC Data - All Services | Sending logon request message. | 2020-10-07 07:33:33.245
SC Data - All Services | Received logon response. | 2020-10-07 07:33:33.946
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:33:33.946
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:33:33.946
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:33:33.946
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:33:33.946
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:33:33.946
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:33:33.946
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:33:33.946
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:33:33.946
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:33:33.946
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:33:33.972
DTC Client socket (1) | Closed. | 2020-10-07 07:33:33.972
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:34:03.960
DTC Client socket (1) | Creating socket. | 2020-10-07 07:34:03.960
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:34:03.960
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:34:03.960
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:34:03.976
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:34:03.976
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:34:03.976
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:34:04.008
SC Data - All Services | Sending logon request message. | 2020-10-07 07:34:04.008
SC Data - All Services | Received logon response. | 2020-10-07 07:34:04.690
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:34:04.690
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:34:04.690
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:34:04.690
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:34:04.690
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:34:04.690
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:34:04.690
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:34:04.690
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:34:04.690
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:34:04.690
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:34:04.705
DTC Client socket (1) | Closed. | 2020-10-07 07:34:04.705
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:34:34.691
DTC Client socket (1) | Creating socket. | 2020-10-07 07:34:34.692
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:34:34.692
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:34:34.692
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:34:34.711
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:34:34.711
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:34:34.711
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:34:34.725
SC Data - All Services | Sending logon request message. | 2020-10-07 07:34:34.725
SC Data - All Services | Received logon response. | 2020-10-07 07:34:35.364
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:34:35.364
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:34:35.364
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:34:35.364
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:34:35.364
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:34:35.364
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:34:35.364
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:34:35.365
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:34:35.365
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:34:35.365
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:34:35.378
DTC Client socket (1) | Closed. | 2020-10-07 07:34:35.378
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:35:05.356
DTC Client socket (1) | Creating socket. | 2020-10-07 07:35:05.357
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:35:05.357
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:35:05.357
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:35:05.381
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:35:05.381
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:35:05.382
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:35:05.414
SC Data - All Services | Sending logon request message. | 2020-10-07 07:35:05.414
SC Data - All Services | Received logon response. | 2020-10-07 07:35:06.054
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:35:06.054
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:35:06.054
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:35:06.054
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:35:06.054
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:35:06.054
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:35:06.054
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:35:06.054
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:35:06.054
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:35:06.054
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:35:06.068
DTC Client socket (1) | Closed. | 2020-10-07 07:35:06.068
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:35:36.049
DTC Client socket (1) | Creating socket. | 2020-10-07 07:35:36.050
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:35:36.050
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:35:36.050
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:35:36.078
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:35:36.078
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:35:36.078
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:35:36.159
SC Data - All Services | Sending logon request message. | 2020-10-07 07:35:36.159
SC Data - All Services | Received logon response. | 2020-10-07 07:35:36.854
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:35:36.854
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:35:36.854
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:35:36.854
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:35:36.854
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:35:36.854
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:35:36.854
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:35:36.854
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:35:36.854
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:35:36.854
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:35:36.881
DTC Client socket (1) | Closed. | 2020-10-07 07:35:36.881
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:36:06.851
DTC Client socket (2) | Creating socket. | 2020-10-07 07:36:06.852
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:36:06.852
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:36:06.852
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:36:06.878
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:36:06.878
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:36:06.878
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:36:06.920
SC Data - All Services | Sending logon request message. | 2020-10-07 07:36:06.920
SC Data - All Services | Received logon response. | 2020-10-07 07:36:07.562
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:36:07.562
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:36:07.562
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:36:07.562
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:36:07.562
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:36:07.562
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:36:07.562
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:36:07.562
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:36:07.562
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:36:07.562
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:36:07.574
DTC Client socket (2) | Closed. | 2020-10-07 07:36:07.574
File >> Disconnect selected. | 2020-10-07 07:36:27.323
DTC Client socket (0) | CloseSocket call. | 2020-10-07 07:36:27.394
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:36:27.394
SC Data - All Services | Disconnected. | 2020-10-07 07:36:27.394
SC Data - All Services | Connected to server complete. | 2020-10-07 07:36:37.641
Triggering next historical data download in queue. | 2020-10-07 07:36:37.641
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-07 07:36:37.715
SC Data - All Services | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2020-10-07 07:36:37.715
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:36:37.715
SC Data - All Services | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2020-10-07 07:36:37.715
Requesting market depth updates for: ESZ20 if supported. | 2020-10-07 07:36:37.715
Separate subscription for market depth updates not supported. ESZ20 | 2020-10-07 07:36:37.715
Mapping MESZ20 to MESZ20. Service code: cme | 2020-10-07 07:36:37.715
SC Data - All Services | Starting real-time market data updates for: MESZ20 (MESZ20). ID: 2 Service code: cme | 2020-10-07 07:36:37.715
SC Data - All Services | Requesting security definition data for: MESZ20 (MESZ20). ID: 2 | 2020-10-07 07:36:37.715
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:36:37.716
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:36:37.716
Triggering next historical data download in queue. | 2020-10-07 07:36:37.716
DTC Client socket (1) | Creating socket. | 2020-10-07 07:36:37.716
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:36:37.716
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:36:37.716
Delaying start of download for ESZ20 | 2020-10-07 07:36:37.723
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:36:37.730
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:36:37.730
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:36:37.730
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:36:37.776
SC Data - All Services | Sending logon request message. | 2020-10-07 07:36:37.776
SC Data - All Services | Received logon response. | 2020-10-07 07:36:38.472
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:36:38.472
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:36:38.472
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:36:38.472
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:36:38.472
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:36:38.472
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:36:38.472
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:36:38.472
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:36:38.472
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:36:38.472
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:36:38.486
DTC Client socket (1) | Closed. | 2020-10-07 07:36:38.486
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:37:08.465
DTC Client socket (1) | Creating socket. | 2020-10-07 07:37:08.465
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:37:08.465
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:37:08.465
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:37:08.492
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:37:08.492
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:37:08.492
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:37:08.524
SC Data - All Services | Sending logon request message. | 2020-10-07 07:37:08.524
SC Data - All Services | Received logon response. | 2020-10-07 07:37:09.154
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:37:09.154
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:37:09.154
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:37:09.154
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:37:09.154
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:37:09.154
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:37:09.154
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:37:09.154
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:37:09.154
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:37:09.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:37:09.170
DTC Client socket (1) | Closed. | 2020-10-07 07:37:09.170
HD Request # 33 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:37:38.291
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:37:38.292
HD Request # 33 | Download start date-time: 2020-10-06 22:06:54.000000. File last date-time: 2020-10-06 22:06:54.704000 | 2020-10-07 07:37:38.292
HD Request # 33 | Using server: ds23.sierracharts.com port 10150 | 2020-10-07 07:37:38.292
Socket (1) | Creating socket. | 2020-10-07 07:37:38.292
Socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:37:38.292
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:37:38.292
HD Request # 33 | Setting DTC encoding to Binary VLS | 2020-10-07 07:37:38.334
HD Request # 33 | Sending historical data logon request message. | 2020-10-07 07:37:38.334
HD Request # 33 | Requesting Intraday data. Start date-time: 2020-10-06 22:06:54. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:37:38.789
HD Request # 33 | Decompressing data. | 2020-10-07 07:37:38.801
HD Request # 33 | Receiving Intraday data for ESZ20 starting at 2020-10-06 22:06:54.704000 | 2020-10-07 07:37:38.846
HD Request # 33 | Timestamp of first Intraday data file record written: 2020-10-06 22:07:06.769000 | 2020-10-07 07:37:38.990
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:37:39.151
DTC Client socket (2) | Creating socket. | 2020-10-07 07:37:39.151
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:37:39.151
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:37:39.151
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:37:39.178
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:37:39.178
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:37:39.178
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:37:39.220
SC Data - All Services | Sending logon request message. | 2020-10-07 07:37:39.220
Socket (1) | CloseSocket call. | 2020-10-07 07:37:39.310
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:37:39.310
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:37:39.311
Historical data download thread signaled to stop. | 2020-10-07 07:37:39.313
HD Request # 33 | Received 118500 records from 2020-10-06 22:06:54.704000 to 2020-10-07 07:37:35.195010 (9.5 hours) and wrote 118499 records for ESZ20 | 2020-10-07 07:37:39.313
HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2020-10-07 12:37:35.195010 | 2020-10-07 07:37:39.317
HD Request # 33 | Completion time: 1s | 2020-10-07 07:37:39.317
HD Request # 33 | Intraday data download complete for ESZ20. Unique request ID: 33 | 2020-10-07 07:37:39.317
Removing historical data download ID 33. | 2020-10-07 07:37:39.317
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-07 07:37:39.317
Intraday chart data file opened for ESZ20 | 2020-10-07 07:37:39.317
HD Request # 33 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:37:39.317
Triggering next historical data download in queue. | 2020-10-07 07:37:39.317
Socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:37:39.336
Socket (1) | Closed. | 2020-10-07 07:37:39.336
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:39.840
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:39.876
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:37:39.957
SC Data - All Services | Received logon response. | 2020-10-07 07:37:39.985
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:37:39.985
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:37:39.985
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:37:39.985
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:37:39.985
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:37:39.985
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:37:39.985
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-10-07 07:37:39.985
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:37:39.985
DTC Client socket (2) | Closed. | 2020-10-07 07:37:39.985
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:37:39.985
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.004
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.068
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.105
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.169
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.283
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.310
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.342
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.639
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.710
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:40.754
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:37:40.844
Chart #26 has tagged chart #13 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:51.972
Chart #26 has tagged chart #24 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:51.972
Chart #26 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:51.972
Chart #26 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:51.972
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.463
ESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:37:52.735
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.751
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.839
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.853
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.917
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.937
ESZ20[M] Point & Figure 1-34 #24 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:52.968
ESZ20 [CB][M] Aligned Renko 12t #13 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.009
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.033
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.076
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.165
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.208
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:37:53.213
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:38:09.983
DTC Client socket (1) | Creating socket. | 2020-10-07 07:38:09.984
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:38:09.984
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:38:09.984
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:38:10.008
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:38:10.008
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:38:10.008
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:38:10.038
SC Data - All Services | Sending logon request message. | 2020-10-07 07:38:10.038
SC Data - All Services | Received logon response. | 2020-10-07 07:38:10.699
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:38:10.699
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:38:10.699
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:38:10.699
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:38:10.699
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:38:10.699
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:38:10.699
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:38:10.699
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:38:10.699
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:38:10.699
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:38:10.713
DTC Client socket (1) | Closed. | 2020-10-07 07:38:10.713
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:38:40.703
DTC Client socket (1) | Creating socket. | 2020-10-07 07:38:40.703
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:38:40.703
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:38:40.703
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:38:40.718
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:38:40.718
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:38:40.718
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:38:40.757
SC Data - All Services | Sending logon request message. | 2020-10-07 07:38:40.757
SC Data - All Services | Received logon response. | 2020-10-07 07:38:41.426
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:38:41.426
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:38:41.426
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:38:41.426
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:38:41.426
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:38:41.426
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:38:41.426
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:38:41.427
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:38:41.427
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:38:41.427
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:38:41.440
DTC Client socket (1) | Closed. | 2020-10-07 07:38:41.440
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:39:11.424
DTC Client socket (1) | Creating socket. | 2020-10-07 07:39:11.425
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:39:11.425
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:39:11.425
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:39:11.452
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:39:11.452
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:39:11.452
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:39:11.485
SC Data - All Services | Sending logon request message. | 2020-10-07 07:39:11.485
SC Data - All Services | Received logon response. | 2020-10-07 07:39:12.116
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:39:12.116
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:39:12.116
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:39:12.116
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:39:12.116
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:39:12.116
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:39:12.116
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:39:12.116
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:39:12.116
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:39:12.116
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:39:12.133
DTC Client socket (1) | Closed. | 2020-10-07 07:39:12.133
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:39:42.111
DTC Client socket (1) | Creating socket. | 2020-10-07 07:39:42.111
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:39:42.111
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:39:42.111
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:39:42.137
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:39:42.137
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:39:42.137
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:39:42.197
SC Data - All Services | Sending logon request message. | 2020-10-07 07:39:42.197
SC Data - All Services | Received logon response. | 2020-10-07 07:39:42.915
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:39:42.916
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:39:42.916
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:39:42.916
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:39:42.916
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:39:42.916
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:39:42.916
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:39:42.916
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:39:42.916
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:39:42.916
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:39:42.940
DTC Client socket (1) | Closed. | 2020-10-07 07:39:42.940
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:40:12.924
DTC Client socket (1) | Creating socket. | 2020-10-07 07:40:12.925
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:40:12.925
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:40:12.925
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:40:12.941
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:40:12.941
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:40:12.942
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:40:12.967
SC Data - All Services | Sending logon request message. | 2020-10-07 07:40:12.967
SC Data - All Services | Received logon response. | 2020-10-07 07:40:13.649
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:40:13.649
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:40:13.649
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:40:13.649
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:40:13.649
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:40:13.650
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:40:13.650
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:40:13.650
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:40:13.650
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:40:13.650
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:40:13.669
DTC Client socket (1) | Closed. | 2020-10-07 07:40:13.669
DTC Client socket (0) | CloseSocket call. | 2020-10-07 07:40:42.469
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:40:42.469
SC Data - All Services | Disconnected. | 2020-10-07 07:40:42.469
SC Data - All Services | Disconnected. | 2020-10-07 07:40:42.564
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 4. | 2020-10-07 07:40:42.570
Current selected Data/Trading service: Interactive Brokers | 2020-10-07 07:40:42.570
Symbol settings MD5 received. Request ID: 4. | 2020-10-07 07:40:43.649
Requested symbol settings for service code interactive_brokers.trading. Request ID: 5. | 2020-10-07 07:40:43.649
Symbol settings received. Request ID: 5. | 2020-10-07 07:40:45.049
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-07 07:40:45.697
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #4 | Reloading chart. | 2020-10-07 07:40:45.807
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #11 | Reloading chart. | 2020-10-07 07:40:45.824
Mapping ES-202012-GLOBEX to ESZ20. Service code: cme | 2020-10-07 07:40:45.845
Mapping MES-202012-GLOBEX-USD to MESZ20. Service code: cme | 2020-10-07 07:40:45.845
Added historical Intraday data request for ES-202012-GLOBEX to the queue. | 2020-10-07 07:40:45.846
Intraday data recording state for symbol ES-202012-GLOBEX is set to download 'Pending'. | 2020-10-07 07:40:45.846
Triggering next historical data download in queue. | 2020-10-07 07:40:45.846
HD Request # 34 | Downloading Intraday chart data for ES-202012-GLOBEX to the file ES-202012-GLOBEX.scid. Service: cme | 2020-10-07 07:40:45.847
Enabling compression for file: C:\SierraChart IB\Data\ES-202012-GLOBEX.scid. This may take a while. | 2020-10-07 07:40:45.847
HD Request # 34 | Download start date-time: 2020-10-02 15:59:59.000000. File last date-time: 2020-10-02 15:59:59.937000 | 2020-10-07 07:40:45.847
HD Request # 34 | Using server: ds21.sierracharts.com port 10149 | 2020-10-07 07:40:45.847
Socket (1) | Creating socket. | 2020-10-07 07:40:45.847
Socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:40:45.847
Socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:40:45.847
HD Request # 34 | Setting DTC encoding to Binary VLS | 2020-10-07 07:40:45.877
HD Request # 34 | Sending historical data logon request message. | 2020-10-07 07:40:45.877
Loading market depth data. | 2020-10-07 07:40:46.145
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:40:46.250
ES-202012-GLOBEX[M] Point & Figure 1-21 #2 | Reloading chart. | 2020-10-07 07:40:46.267
ES-202012-GLOBEX[M] Point & Figure 1-21 #1 | Reloading chart. | 2020-10-07 07:40:46.279
ES-202012-GLOBEX[M] Point & Figure 1-21 #4 | Reloading chart. | 2020-10-07 07:40:46.287
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:40:46.295
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Performing historical Daily data download for symbol ES-202012-GLOBEX starting at last date in file. | 2020-10-07 07:40:46.322
Added historical Daily data request for ES-202012-GLOBEX to the queue. | 2020-10-07 07:40:46.322
Triggering next historical data download in queue. | 2020-10-07 07:40:46.322
HD Request # 34 | Requesting Intraday data. Start date-time: 2020-10-02 15:59:59. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:40:46.334
HD Request # 34 | Decompressing data. | 2020-10-07 07:40:46.347
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.348
HD Request # 35 | Downloading Historical Daily chart data for ES-202012-GLOBEX. Starting date: 2020-09-30. Service: interactive_brokers.trading | 2020-10-07 07:40:46.352
HD Request # 35 | Requesting historical Daily data for ESZ20 starting at 2020-09-29. SC External HD service. | 2020-10-07 07:40:46.352
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:40:46.354
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.377
ES-202012-GLOBEX [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:40:46.380
HD Request # 34 | Receiving Intraday data for ES-202012-GLOBEX starting at 2020-10-02 15:59:59.144000 | 2020-10-07 07:40:46.386
ES-202012-GLOBEX [CB][M] 1 Day #8 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.460
ES-202012-GLOBEX [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:40:46.463
ES-202012-GLOBEX [CBV][M] 60 Min #20 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.485
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:40:46.490
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #12 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.496
ES-202012-GLOBEX [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:40:46.500
ES-202012-GLOBEX [CBV][M] 60 Min #21 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.524
ES-202012-GLOBEX[M] Point & Figure 1-21 #3 | Reloading chart. | 2020-10-07 07:40:46.528
ES-202012-GLOBEX [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:40:46.539
ES-202012-GLOBEX [CBV][M] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.544
ES-202012-GLOBEX[M] Point & Figure 1-21 #1 | Reloading chart. | 2020-10-07 07:40:46.549
ES-202012-GLOBEX [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:40:46.560
HD Request # 34 | Timestamp of first Intraday data file record written: 2020-10-04 17:00:00.000000 | 2020-10-07 07:40:46.576
ES-202012-GLOBEX [CBV][M] 60 Min #16 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.589
ES-202012-GLOBEX [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:40:46.679
ES-202012-GLOBEX [CBV][M] 60 Min #19 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.705
ES-202012-GLOBEX[M] Point & Figure 1-21 #3 | Reloading chart. | 2020-10-07 07:40:46.719
ES-202012-GLOBEX[M] Point & Figure 1-21 #7 | Reloading chart. | 2020-10-07 07:40:46.724
ES-202012-GLOBEX[M] Point & Figure 1-34 #24 | Reloading chart. | 2020-10-07 07:40:46.731
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:40:46.739
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:46.854
Loading market depth data. | 2020-10-07 07:40:46.976
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 18:03:48 to 2020-09-28 19:00:00. | 2020-10-07 07:40:47.030
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:40:47.065
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #15 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.075
ES-202012-GLOBEX [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:40:47.108
ES-202012-GLOBEX [CBV][M] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.114
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:40:47.118
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:40:47.122
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #6 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.123
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:40:47.127
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.164
ES-202012-GLOBEX [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:40:47.169
ES-202012-GLOBEX [CBV][M] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.175
ES-202012-GLOBEX[M] Point & Figure 1-21 #5 | Reloading chart. | 2020-10-07 07:40:47.177
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:40:47.225
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:40:47.277
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Waiting for historical downloads to complete with the IDs: 35, | 2020-10-07 07:40:47.393
HD Request # 35 | Receiving historical Daily data for ES-202012-GLOBEX starting at 2020-09-30 | 2020-10-07 07:40:47.472
HD Request # 35 | Writing historical Daily data to the file ES-202012-GLOBEX.dly | 2020-10-07 07:40:47.472
HD Request # 35 | Bytes received: 415 | 2020-10-07 07:40:47.474
HD Request # 35 | Received 7 records from 2020-09-30 00:00:00 to 2020-10-07 00:00:00 (8.0 days) and wrote 6 records for ES-202012-GLOBEX | 2020-10-07 07:40:47.474
HD Request # 35 | Completion time: 1s | 2020-10-07 07:40:47.497
HD Request # 35 | Daily data download complete for ES-202012-GLOBEX. Unique request ID: 35 | 2020-10-07 07:40:47.497
Removing historical data download ID 35. | 2020-10-07 07:40:47.497
Triggering next historical data download in queue. | 2020-10-07 07:40:47.502
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:47.566
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:40:47.567
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:47.579
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:40:47.581
ES-202012-GLOBEX [CB][M] 1 Day #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:47.591
ES-202012-GLOBEX [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:40:47.593
ES-202012-GLOBEX [CBV][M] 60 Min #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:47.851
ES-202012-GLOBEX [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:40:47.852
Loading market depth data. | 2020-10-07 07:40:48.004
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 12:45:22 to 2020-09-28 19:00:00. | 2020-10-07 07:40:48.014
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:40:48.143
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 16:50:38 to 2020-10-01 19:00:00. | 2020-10-07 07:40:48.262
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.269
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:40:48.270
ES-202012-GLOBEX [CBV][M] 60 Min #21 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.279
ES-202012-GLOBEX [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:40:48.281
ES-202012-GLOBEX [CBV][M] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.353
ES-202012-GLOBEX [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:40:48.354
ES-202012-GLOBEX [CBV][M] 60 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.361
ES-202012-GLOBEX [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:40:48.362
ES-202012-GLOBEX [CBV][M] 60 Min #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.472
ES-202012-GLOBEX [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:40:48.485
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:48.660
: Array is unallocated. | 2020-10-07 07:40:48.660
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.693
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:40:48.694
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:48.840
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:40:49.050
ES-202012-GLOBEX [CBV][M] 1 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:49.055
ES-202012-GLOBEX [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:40:49.056
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:49.062
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:40:49.064
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:49.077
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:40:49.124
ES-202012-GLOBEX [CBV][M] 1 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:49.129
ES-202012-GLOBEX [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:40:49.130
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:40:49.148
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:40:49.150
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:40:49.179
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:40:49.354
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:49.563
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:40:49.608
ES-202012-GLOBEX [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:40:49.919
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:50.280
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2020-10-07 07:40:50.331
IB TWS socket (3) | Creating socket. | 2020-10-07 07:40:50.331
IB TWS socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:40:50.331
IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2020-10-07 07:40:50.331
Interactive Brokers | Sending API sign: API | 2020-10-07 07:40:50.841
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2020-10-07 07:40:50.841
ES-202012-GLOBEX [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:40:51.025
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:51.212
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:40:51.224
ES-202012-GLOBEX [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:40:51.280
Socket (1) | CloseSocket call. | 2020-10-07 07:40:51.535
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:40:51.535
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:40:51.535
Socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:40:51.549
Socket (1) | Closed. | 2020-10-07 07:40:51.549
HD Request # 34 | Historical data for ES-202012-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-10-07 07:40:51.681
Historical data download thread signaled to stop. | 2020-10-07 07:40:51.681
HD Request # 34 | Received 1827831 records from 2020-10-02 15:59:59.144000 to 2020-10-07 07:40:44.289002 (4.7 days) and wrote 1827817 records for ES-202012-GLOBEX | 2020-10-07 07:40:51.681
HD Request # 34 | Completion time: 6s | 2020-10-07 07:40:51.698
HD Request # 34 | Intraday data download complete for ES-202012-GLOBEX. Unique request ID: 34 | 2020-10-07 07:40:51.698
Removing historical data download ID 34. | 2020-10-07 07:40:51.698
HD Request # 34 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:40:51.698
Triggering next historical data download in queue. | 2020-10-07 07:40:51.709
ES-202012-GLOBEX [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:40:51.930
ES-202012-GLOBEX [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:40:52.039
ES-202012-GLOBEX [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:40:52.066
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:52.208
: Array is unallocated. | 2020-10-07 07:40:52.382
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:40:52.387
Interactive Brokers | TWS server version: 136 | 2020-10-07 07:40:52.537
Interactive Brokers | TWS time: 20201007 07:40:51 Central Standard Time | 2020-10-07 07:40:52.537
Interactive Brokers | Connected. Sending Start API command. | 2020-10-07 07:40:52.798
Interactive Brokers | Waiting for account information. | 2020-10-07 07:40:52.798
IB Account information received. | 2020-10-07 07:40:53.115
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2020-10-07 07:40:53.115
Interactive Brokers | Connected to Live account. | 2020-10-07 07:40:53.115
Interactive Brokers | Connected to server complete. | 2020-10-07 07:40:53.115
Triggering next historical data download in queue. | 2020-10-07 07:40:53.115
Updated verified funded futures trading account ending date to: 2020-11-06 12:40:53 | 2020-10-07 07:40:53.115
Next valid order ID: 2259 | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2020-10-07 07:40:53.123
Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2020-10-07 07:40:53.123
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:40:53.125
Mapping ES-202012-GLOBEX to ESZ20. Service code: cme | 2020-10-07 07:40:53.341
SC Data - All Services | Starting real-time market data updates for: ES-202012-GLOBEX (ESZ20). ID: 1 Service code: cme | 2020-10-07 07:40:53.341
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:40:53.341
SC Data - All Services | Requesting security definition data for: ES-202012-GLOBEX (ESZ20). ID: 1 | 2020-10-07 07:40:53.341
Added historical Intraday data request for ES-202012-GLOBEX to the queue. | 2020-10-07 07:40:53.342
Intraday data recording state for symbol ES-202012-GLOBEX is set to download 'Pending'. | 2020-10-07 07:40:53.342
Triggering next historical data download in queue. | 2020-10-07 07:40:53.342
DTC Client socket (1) | Creating socket. | 2020-10-07 07:40:53.346
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:40:53.346
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:40:53.346
Delaying start of download for ES-202012-GLOBEX | 2020-10-07 07:40:53.509
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:40:53.509
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:40:53.509
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:40:53.509
Next valid order ID: 2259 | 2020-10-07 07:40:53.510
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:40:53.575
SC Data - All Services | Sending logon request message. | 2020-10-07 07:40:53.575
: Array is unallocated. | 2020-10-07 07:40:53.580
Array message repeat count limit reached. | 2020-10-07 07:40:53.580
Requesting market depth updates for: ES-202012-GLOBEX if supported. | 2020-10-07 07:40:53.658
Separate subscription for market depth updates not supported. ES-202012-GLOBEX | 2020-10-07 07:40:53.658
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:40:53.663
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:40:53.675
Loading market depth data. | 2020-10-07 07:40:53.762
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 12:45:22 to 2020-09-28 19:00:00. | 2020-10-07 07:40:53.769
ES-202012-GLOBEX [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:40:53.775
ES-202012-GLOBEX [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:40:53.789
ES-202012-GLOBEX/MES-202012-GLOBEX-USD [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:40:53.801
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:40:53.813
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:40:53.830
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:40:53.917
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:40:54.102
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #11 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:40:54.426
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:40:54.631
SC Data - All Services | Received logon response. | 2020-10-07 07:40:54.664
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:40:54.664
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:40:54.664
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:40:54.664
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:40:54.664
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:40:54.664
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:40:54.664
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:40:54.664
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:40:54.664
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-10-07 07:40:54.674
DTC Client socket (1) | Closed. | 2020-10-07 07:40:54.674
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #11 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:40:54.703
Mapping MES-202012-GLOBEX-USD to MESZ20. Service code: cme | 2020-10-07 07:40:54.703
SC Data - All Services | Starting real-time market data updates for: MES-202012-GLOBEX-USD (MESZ20). ID: 2 Service code: cme | 2020-10-07 07:40:54.703
SC Data - All Services | Requesting security definition data for: MES-202012-GLOBEX-USD (MESZ20). ID: 2 | 2020-10-07 07:40:54.703
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:40:56.160
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:40:56.292
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #4 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:40:56.710
Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U242* | 2020-10-07 07:40:58.151
Interactive Brokers | Received Trade Positions download end message for account U242* | 2020-10-07 07:40:58.177
Interactive Brokers | Begin Trade Positions processing. | 2020-10-07 07:40:58.177
Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2020-10-07 07:40:58.177
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:40:59.323
ES-202012-GLOBEX [CBV][M] 60 Min #16 | StartDateTimeForLoadingOrderFills: 2020-09-23 07:40:44 | 2020-10-07 07:40:59.326
Loading market depth data. | 2020-10-07 07:41:02.626
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 12:45:22 to 2020-09-28 19:00:00. | 2020-10-07 07:41:02.634
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:41:02.701
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:41:02.741
Loading market depth data. | 2020-10-07 07:41:05.360
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 12:45:22 to 2020-09-28 19:00:00. | 2020-10-07 07:41:05.392
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:41:05.446
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:41:05.535
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:41:05.945
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | StartDateTimeForLoadingOrderFills: 2020-09-06 17:00:00 | 2020-10-07 07:41:05.947
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:05.951
ES-202012-GLOBEX[M] Point & Figure 1-21 #1 | StartDateTimeForLoadingOrderFills: 2020-08-28 15:30:16 | 2020-10-07 07:41:07.138
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:07.173
Loading market depth data. | 2020-10-07 07:41:08.030
Loaded depth data records for ES-202012-GLOBEX 2020-09-28 from 2020-09-28 12:45:22 to 2020-09-28 19:00:00. | 2020-10-07 07:41:08.039
Loaded depth data records for ES-202012-GLOBEX 2020-09-29 from 2020-09-28 19:00:00 to 2020-09-29 10:06:45. | 2020-10-07 07:41:08.097
Loaded depth data records for ES-202012-GLOBEX 2020-10-01 from 2020-10-01 17:00:00 to 2020-10-01 19:00:00. | 2020-10-07 07:41:08.145
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:41:08.956
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:10.340
Loaded depth data records for ES-202012-GLOBEX 2020-10-02 from 2020-10-01 19:00:00 to 2020-10-02 16:00:00. | 2020-10-07 07:41:10.592
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | StartDateTimeForLoadingOrderFills: 2020-08-02 17:00:00 | 2020-10-07 07:41:10.594
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:41:24.663
DTC Client socket (1) | Creating socket. | 2020-10-07 07:41:24.663
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:41:24.664
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:41:24.664
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:41:24.682
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:41:24.682
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:41:24.682
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:41:24.703
SC Data - All Services | Sending logon request message. | 2020-10-07 07:41:24.703
SC Data - All Services | Received logon response. | 2020-10-07 07:41:25.353
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:41:25.353
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:41:25.353
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:41:25.353
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:41:25.353
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:41:25.353
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:41:25.353
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:41:25.353
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:41:25.353
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:41:25.353
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:41:25.370
DTC Client socket (1) | Closed. | 2020-10-07 07:41:25.370
File >> Disconnect selected. | 2020-10-07 07:41:41.391
IB TWS socket (3) | CloseSocket call. | 2020-10-07 07:41:41.418
IB TWS socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:41:41.418
DTC Client socket (0) | CloseSocket call. | 2020-10-07 07:41:41.418
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:41:41.418
IB TWS socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:41:41.418
Interactive Brokers | Disconnected. | 2020-10-07 07:41:41.418
IB TWS socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:41:41.419
IB TWS socket (3) | Closed. | 2020-10-07 07:41:41.419
HD Request # 36 | Downloading Intraday chart data for ES-202012-GLOBEX to the file ES-202012-GLOBEX.scid. Service: cme | 2020-10-07 07:41:41.421
Enabling compression for file: C:\SierraChart IB\Data\ES-202012-GLOBEX.scid. This may take a while. | 2020-10-07 07:41:41.422
HD Request # 36 | Download start date-time: 2020-10-07 07:40:44.000000. File last date-time: 2020-10-07 07:40:44.289002 | 2020-10-07 07:41:41.422
HD Request # 36 | Using server: ds23.sierracharts.com port 10150 | 2020-10-07 07:41:41.422
Socket (1) | Creating socket. | 2020-10-07 07:41:41.422
Socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:41:41.422
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:41:41.422
HD Request # 36 | Setting DTC encoding to Binary VLS | 2020-10-07 07:41:41.460
HD Request # 36 | Sending historical data logon request message. | 2020-10-07 07:41:41.460
HD Request # 36 | Requesting Intraday data. Start date-time: 2020-10-07 07:40:44. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:41:41.917
HD Request # 36 | Decompressing data. | 2020-10-07 07:41:41.932
HD Request # 36 | Receiving Intraday data for ES-202012-GLOBEX starting at 2020-10-07 07:40:44.252000 | 2020-10-07 07:41:41.934
Socket (1) | CloseSocket call. | 2020-10-07 07:41:41.935
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:41:41.935
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:41:41.935
HD Request # 36 | Historical data for ES-202012-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-10-07 07:41:41.935
Historical data download thread signaled to stop. | 2020-10-07 07:41:41.935
HD Request # 36 | Timestamp of first Intraday data file record written: 2020-10-07 07:40:46.932000 | 2020-10-07 07:41:41.935
HD Request # 36 | Received 472 records from 2020-10-07 07:40:44.252000 to 2020-10-07 07:41:37.411004 (53.2 seconds) and wrote 463 records for ES-202012-GLOBEX | 2020-10-07 07:41:41.935
HD Request # 36 | Completion time: 0s | 2020-10-07 07:41:41.938
HD Request # 36 | Intraday data download complete for ES-202012-GLOBEX. Unique request ID: 36 | 2020-10-07 07:41:41.938
Removing historical data download ID 36. | 2020-10-07 07:41:41.938
HD Request # 36 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:41:41.938
Triggering next historical data download in queue. | 2020-10-07 07:41:41.938
Socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:41:41.951
Socket (1) | Closed. | 2020-10-07 07:41:41.951
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.068
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.071
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.094
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.140
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:41:42.446
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.604
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.636
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.684
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:42.769
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 6. | 2020-10-07 07:41:54.347
Current selected Data/Trading service: SC Data - All Services | 2020-10-07 07:41:54.347
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #4 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:41:54.405
ES-202012-GLOBEX/MES-202012-GLOBEX-USD[M] Point & Figure 1-21 #11 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:41:54.433
ES-202012-GLOBEX [CB][M] Aligned Renko 12t #13 | StartDateTimeForLoadingOrderFills: 2020-09-06 17:00:00 | 2020-10-07 07:41:54.465
ES-202012-GLOBEX [CBV][M] 60 Min #16 | StartDateTimeForLoadingOrderFills: 2020-09-23 07:41:37 | 2020-10-07 07:41:54.494
ES-202012-GLOBEX[M] Point & Figure 1-21 #1 | StartDateTimeForLoadingOrderFills: 2020-08-28 15:30:16 | 2020-10-07 07:41:54.543
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:41:54.655
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #25 | StartDateTimeForLoadingOrderFills: 2020-08-02 17:00:00 | 2020-10-07 07:41:54.868
Symbol settings MD5 received. Request ID: 6. | 2020-10-07 07:41:55.431
Requested symbol settings for service code scdataallservices. Request ID: 7. | 2020-10-07 07:41:55.432
SC Data - All Services | Disconnected. | 2020-10-07 07:41:56.406
SC Data - All Services | Disconnected. | 2020-10-07 07:41:56.407
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-07 07:41:56.407
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Reloading chart. | 2020-10-07 07:41:56.489
ESZ20/MESZ20[M] Point & Figure 1-21 #11 | Reloading chart. | 2020-10-07 07:41:56.499
ESZ20 [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:41:56.511
ESZ20 [CBV][M] 1 Min #2 | Performing historical Daily data download for symbol ESZ20 starting at last date in file. | 2020-10-07 07:41:56.543
Added historical Daily data request for ESZ20 to the queue. | 2020-10-07 07:41:56.543
Triggering next historical data download in queue. | 2020-10-07 07:41:56.543
Loading market depth data. | 2020-10-07 07:41:56.549
ESZ20 [CBV][M] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:56.550
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-07 07:41:56.552
HD Request # 37 | Downloading Historical Daily chart data for ESZ20. Starting date: 2020-10-02. Service: scdataallservices | 2020-10-07 07:41:56.554
HD Request # 37 | Requesting historical Daily data for ESZ20 starting at 2020-10-01. SC External HD service. | 2020-10-07 07:41:56.554
ESZ20 [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:41:56.560
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-06 17:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:41:56.602
ESZ20 [CBV][M] 60 Min #19 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:56.611
ESZ20 [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:41:56.616
ESZ20 [CB][M] Point & Figure 1-34 #10 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:56.644
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:41:56.649
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #12 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:56.655
Mapping MESZ20 to MESZ20. Service code: cme | 2020-10-07 07:41:56.664
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:41:56.664
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:41:56.664
Triggering next historical data download in queue. | 2020-10-07 07:41:56.664
HD Request # 38 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:41:56.664
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:41:56.664
HD Request # 38 | Download start date-time: 2020-10-07 07:37:35.000000. File last date-time: 2020-10-07 07:37:35.195010 | 2020-10-07 07:41:56.664
HD Request # 38 | Using server: ds21.sierracharts.com port 10149 | 2020-10-07 07:41:56.664
Socket (4) | Creating socket. | 2020-10-07 07:41:56.664
Socket (4) | New receive buffer size: 5242880 | 2020-10-07 07:41:56.664
Socket (4) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:41:56.664
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:41:56.702
ESZ20/MESZ20[M] Point & Figure 1-21 #11 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:41:56.713
HD Request # 38 | Setting DTC encoding to Binary VLS | 2020-10-07 07:41:56.716
HD Request # 38 | Sending historical data logon request message. | 2020-10-07 07:41:56.716
ESZ20[M] Point & Figure 1-21 #7 | Reloading chart. | 2020-10-07 07:41:56.801
ESZ20[M] Point & Figure 1-21 #3 | Reloading chart. | 2020-10-07 07:41:56.809
ESZ20[M] Point & Figure 1-34 #24 | Reloading chart. | 2020-10-07 07:41:56.816
ESZ20 [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:41:56.825
ESZ20 [CBV][M] 60 Min #21 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:56.873
ESZ20 [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:41:56.876
Loading market depth data. | 2020-10-07 07:41:56.911
ESZ20 [CB][M] Point & Figure 1-34 #9 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.027
Symbol settings received. Request ID: 7. | 2020-10-07 07:41:57.034
HD Request # 38 | Requesting Intraday data. Start date-time: 2020-10-07 07:37:35. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:41:57.172
ESZ20 [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:41:57.186
HD Request # 38 | Decompressing data. | 2020-10-07 07:41:57.187
HD Request # 38 | Receiving Intraday data for ESZ20 starting at 2020-10-07 07:37:35.008000 | 2020-10-07 07:41:57.188
Socket (4) | CloseSocket call. | 2020-10-07 07:41:57.201
Socket (4) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:41:57.201
Socket (4) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:41:57.201
Socket (4) | Socket gracefully closed by remote side. | 2020-10-07 07:41:57.214
Socket (4) | Closed. | 2020-10-07 07:41:57.214
ESZ20 [CB][M] Point & Figure 1-34 #25 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.222
HD Request # 38 | Historical data for ESZ20 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-10-07 07:41:57.225
Historical data download thread signaled to stop. | 2020-10-07 07:41:57.225
HD Request # 38 | Timestamp of first Intraday data file record written: 2020-10-07 07:37:37.387000 | 2020-10-07 07:41:57.225
HD Request # 38 | Received 2037 records from 2020-10-07 07:37:35.008000 to 2020-10-07 07:41:53.510001 (4.3 minutes) and wrote 1985 records for ESZ20 | 2020-10-07 07:41:57.225
HD Request # 38 | Completion time: 1s | 2020-10-07 07:41:57.249
HD Request # 38 | Intraday data download complete for ESZ20. Unique request ID: 38 | 2020-10-07 07:41:57.249
Removing historical data download ID 38. | 2020-10-07 07:41:57.249
HD Request # 38 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:41:57.249
Triggering next historical data download in queue. | 2020-10-07 07:41:57.251
ESZ20[M] Point & Figure 1-21 #5 | Reloading chart. | 2020-10-07 07:41:57.343
ESZ20[M] Point & Figure 1-21 #2 | Reloading chart. | 2020-10-07 07:41:57.349
ESZ20[M] Point & Figure 1-21 #4 | Reloading chart. | 2020-10-07 07:41:57.359
ESZ20[M] Point & Figure 1-21 #1 | Reloading chart. | 2020-10-07 07:41:57.365
ESZ20 [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:41:57.371
ESZ20 [CB][M] 1 Day #8 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.471
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:41:57.471
ESZ20 [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:41:57.474
ESZ20 [CB][M] Aligned Renko 12t #13 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.508
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:41:57.514
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #15 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.519
ESZ20 [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:41:57.523
ESZ20 [CBV][M] 60 Min #20 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.552
ESZ20 [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:41:57.556
ESZ20 [CBV][M] 60 Min #16 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.611
ESZ20 [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:41:57.616
ESZ20 [CBV][M] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.622
ESZ20[M] Point & Figure 1-21 #3 | Reloading chart. | 2020-10-07 07:41:57.625
ESZ20[M] Point & Figure 1-21 #1 | Reloading chart. | 2020-10-07 07:41:57.634
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:41:57.645
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #6 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.651
ESZ20 [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:41:57.653
ESZ20 [CBV][M] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.675
ESZ20 [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:41:57.677
ESZ20 [CB][M] 15 Sec #26 | Waiting for historical downloads to complete with the IDs: 37, | 2020-10-07 07:41:57.767
HD Request # 37 | Receiving historical Daily data for ESZ20 starting at 2020-10-02 | 2020-10-07 07:41:57.768
HD Request # 37 | Writing historical Daily data to the file ESZ20.dly | 2020-10-07 07:41:57.769
HD Request # 37 | Bytes received: 295 | 2020-10-07 07:41:57.771
HD Request # 37 | Received 5 records from 2020-10-02 00:00:00 to 2020-10-07 00:00:00 (6.0 days) and wrote 4 records for ESZ20 | 2020-10-07 07:41:57.771
HD Request # 37 | Completion time: 1s | 2020-10-07 07:41:57.828
HD Request # 37 | Daily data download complete for ESZ20. Unique request ID: 37 | 2020-10-07 07:41:57.828
Removing historical data download ID 37. | 2020-10-07 07:41:57.828
Triggering next historical data download in queue. | 2020-10-07 07:41:57.833
ESZ20 [CBV][M] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.859
ESZ20 [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:41:57.861
ESZ20 [CBV][M] 60 Min #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.873
ESZ20 [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:41:57.875
ESZ20 [CB][M] Point & Figure 1-34 #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.893
ESZ20 [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:41:57.894
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.904
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:41:57.906
ESZ20 [CBV][M] 60 Min #21 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.914
ESZ20 [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:41:57.915
ESZ20 [CB][M] Point & Figure 1-34 #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:57.940
ESZ20 [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:41:57.941
ES-202012-GLOBEX [CB][M] Point & Figure 1-34 #9 | Chart Data Loading Thread: Load canceled. | 2020-10-07 07:41:57.961
Restarting the loading process. | 2020-10-07 07:41:58.010
: Array is unallocated. | 2020-10-07 07:41:58.161
ESZ20 [CB][M] Point & Figure 1-34 #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.285
ESZ20 [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:41:58.287
ESZ20 [CB][M] 1 Day #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.427
ESZ20 [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:41:58.528
ES-202012-GLOBEX [CB][M] 1 Day #8 | Chart Data Loading Thread: Load canceled. | 2020-10-07 07:41:58.542
Restarting the loading process. | 2020-10-07 07:41:58.542
ESZ20 [CB][M] Aligned Renko 12t #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.789
ESZ20 [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:41:58.843
ESZ20 [CBV][M] 60 Min #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.859
ESZ20 [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:41:58.861
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.878
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:41:58.879
ESZ20 [CBV][M] 60 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.883
ESZ20 [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:41:58.885
ESZ20 [CBV][M] 1 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.903
ESZ20 [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:41:58.905
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.914
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:41:58.915
ESZ20 [CBV][M] 1 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.920
ESZ20 [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:41:58.921
ESZ20 [CB][M] 15 Sec #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-10-07 07:41:58.928
ESZ20 [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:41:58.930
ES-202012-GLOBEX [CB][M] 15 Sec #26 | Chart Data Loading Thread: Load canceled. | 2020-10-07 07:41:59.046
Restarting the loading process. | 2020-10-07 07:41:59.047
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:41:59.439
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:41:59.667
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | StartDateTimeForLoadingOrderFills: 2020-10-06 17:00:00 | 2020-10-07 07:41:59.760
ESZ20 [CBV][M] 1 Min #2 | Reloading chart. | 2020-10-07 07:41:59.784
ESZ20 [CBV][M] 60 Min #19 | Reloading chart. | 2020-10-07 07:41:59.903
Loading market depth data. | 2020-10-07 07:41:59.976
Loaded depth data records for ESZ20 2020-09-30 from 2020-09-30 17:41:30 to 2020-09-30 18:57:10. | 2020-10-07 07:42:00.366
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:00.564
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:00.865
ESZ20 [CB][M] Point & Figure 1-34 #10 | Reloading chart. | 2020-10-07 07:42:00.892
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #12 | Reloading chart. | 2020-10-07 07:42:00.962
ESZ20 [CBV][M] 60 Min #21 | Reloading chart. | 2020-10-07 07:42:01.035
ESZ20 [CB][M] Point & Figure 1-34 #9 | Reloading chart. | 2020-10-07 07:42:01.160
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:01.357
: Array is unallocated. | 2020-10-07 07:42:01.544
: Array is unallocated. | 2020-10-07 07:42:01.545
ESZ20 [CB][M] Point & Figure 1-34 #25 | Reloading chart. | 2020-10-07 07:42:01.573
SC Data - All Services | Connected to server complete. | 2020-10-07 07:42:01.652
Triggering next historical data download in queue. | 2020-10-07 07:42:01.652
Triggering next historical data download in queue. | 2020-10-07 07:42:01.653
ESZ20 [CB][M] 1 Day #8 | Reloading chart. | 2020-10-07 07:42:01.662
Loading market depth data. | 2020-10-07 07:42:01.795
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-07 07:42:01.850
SC Data - All Services | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2020-10-07 07:42:01.850
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:42:01.850
SC Data - All Services | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2020-10-07 07:42:01.850
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:42:01.850
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:42:01.850
Triggering next historical data download in queue. | 2020-10-07 07:42:01.850
Delaying start of download for ESZ20 | 2020-10-07 07:42:01.850
DTC Client socket (3) | Creating socket. | 2020-10-07 07:42:01.853
DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:42:01.853
DTC Client socket (3) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:42:01.853
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:42:01.928
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:42:01.928
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:42:01.928
: Array is unallocated. | 2020-10-07 07:42:01.933
Array message repeat count limit reached. | 2020-10-07 07:42:01.933
Requesting market depth updates for: ESZ20 if supported. | 2020-10-07 07:42:02.021
Separate subscription for market depth updates not supported. ESZ20 | 2020-10-07 07:42:02.021
Loaded depth data records for ESZ20 2020-09-27 from 00:00:00 to 00:00:00. | 2020-10-07 07:42:02.636
ESZ20 [CB][M] Aligned Renko 12t #13 | Reloading chart. | 2020-10-07 07:42:02.861
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:42:02.944
SC Data - All Services | Sending logon request message. | 2020-10-07 07:42:02.944
ESZ20 [CBV][M] 60 Min #20 | Reloading chart. | 2020-10-07 07:42:02.948
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #15 | Reloading chart. | 2020-10-07 07:42:03.036
ESZ20 [CBV][M] 60 Min #16 | Reloading chart. | 2020-10-07 07:42:03.051
ESZ20 [CBV][M] 1 Min #9 | Reloading chart. | 2020-10-07 07:42:03.181
ESZ20 [CBV][M] 1 Min #5 | Reloading chart. | 2020-10-07 07:42:03.232
ESZ20/MESZ20 [CBV][M] Aligned Renko 4t #6 | Reloading chart. | 2020-10-07 07:42:03.244
ESZ20 [CB][M] 15 Sec #26 | Reloading chart. | 2020-10-07 07:42:03.279
Loaded depth data records for ESZ20 2020-09-28 from 2020-09-28 12:59:18 to 2020-09-28 17:38:00. | 2020-10-07 07:42:03.472
Mapping MESZ20 to MESZ20. Service code: cme | 2020-10-07 07:42:03.571
SC Data - All Services | Starting real-time market data updates for: MESZ20 (MESZ20). ID: 2 Service code: cme | 2020-10-07 07:42:03.571
SC Data - All Services | Requesting security definition data for: MESZ20 (MESZ20). ID: 2 | 2020-10-07 07:42:03.571
SC Data - All Services | Received logon response. | 2020-10-07 07:42:03.649
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:42:03.649
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:42:03.649
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:42:03.649
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:42:03.649
DTC Client socket (3) | CloseSocket call. | 2020-10-07 07:42:03.649
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:42:03.649
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:42:03.649
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:42:03.649
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:42:03.649
DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:42:03.676
DTC Client socket (3) | Closed. | 2020-10-07 07:42:03.677
Loaded depth data records for ESZ20 2020-09-29 from 2020-09-28 19:46:36 to 2020-09-29 07:48:14. | 2020-10-07 07:42:04.371
Loaded depth data records for ESZ20 2020-09-30 from 2020-09-30 17:41:30 to 2020-09-30 18:57:10. | 2020-10-07 07:42:04.422
Loaded depth data records for ESZ20 2020-10-01 from 2020-09-30 19:00:00 to 2020-10-01 16:50:12. | 2020-10-07 07:42:06.796
Loaded depth data records for ESZ20 2020-10-01 from 2020-09-30 19:00:00 to 2020-10-01 16:00:00. | 2020-10-07 07:42:08.172
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:42:08.393
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:42:09.578
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:42:11.235
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:42:11.477
Loading market depth data. | 2020-10-07 07:42:11.799
Loaded depth data records for ESZ20 2020-09-27 from 00:00:00 to 00:00:00. | 2020-10-07 07:42:11.799
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:42:12.049
Loaded depth data records for ESZ20 2020-09-28 from 2020-09-28 12:59:18 to 2020-09-28 17:38:00. | 2020-10-07 07:42:12.287
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:42:12.295
ESZ20 [CBV][M] 60 Min #16 | StartDateTimeForLoadingOrderFills: 2020-09-23 07:41:54 | 2020-10-07 07:42:12.307
Loading market depth data. | 2020-10-07 07:42:12.463
Loaded depth data records for ESZ20 2020-09-27 from 00:00:00 to 00:00:00. | 2020-10-07 07:42:12.464
Loaded depth data records for ESZ20 2020-09-29 from 2020-09-28 19:46:36 to 2020-09-29 07:48:14. | 2020-10-07 07:42:12.770
Loaded depth data records for ESZ20 2020-09-30 from 2020-09-30 17:41:30 to 2020-09-30 18:57:10. | 2020-10-07 07:42:12.817
Loaded depth data records for ESZ20 2020-09-28 from 2020-09-28 12:59:18 to 2020-09-28 17:38:00. | 2020-10-07 07:42:12.906
Loaded depth data records for ESZ20 2020-09-29 from 2020-09-28 19:46:36 to 2020-09-29 07:48:14. | 2020-10-07 07:42:13.444
Loaded depth data records for ESZ20 2020-09-30 from 2020-09-30 17:41:30 to 2020-09-30 18:57:10. | 2020-10-07 07:42:13.475
Loaded depth data records for ESZ20 2020-10-01 from 2020-09-30 19:00:00 to 2020-10-01 16:00:00. | 2020-10-07 07:42:15.408
Loaded depth data records for ESZ20 2020-10-01 from 2020-09-30 19:00:00 to 2020-10-01 16:00:00. | 2020-10-07 07:42:16.115
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:42:16.191
ESZ20[M] Point & Figure 1-21 #1 | StartDateTimeForLoadingOrderFills: 2020-09-02 15:30:00 | 2020-10-07 07:42:16.392
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:16.452
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:42:16.807
Loading market depth data. | 2020-10-07 07:42:17.287
Loaded depth data records for ESZ20 2020-09-27 from 00:00:00 to 00:00:00. | 2020-10-07 07:42:17.287
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:42:17.627
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:42:17.805
Loaded depth data records for ESZ20 2020-09-28 from 2020-09-28 12:59:18 to 2020-09-28 17:38:00. | 2020-10-07 07:42:17.889
Loaded depth data records for ESZ20 2020-09-29 from 2020-09-28 19:46:36 to 2020-09-29 07:48:14. | 2020-10-07 07:42:18.331
Loaded depth data records for ESZ20 2020-09-30 from 2020-09-30 17:41:30 to 2020-09-30 18:57:10. | 2020-10-07 07:42:18.358
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:42:18.361
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:42:18.477
ESZ20 [CB][M] Aligned Renko 12t #13 | StartDateTimeForLoadingOrderFills: 2020-09-06 17:00:00 | 2020-10-07 07:42:18.480
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:18.484
Loaded depth data records for ESZ20 2020-10-01 from 2020-09-30 19:00:00 to 2020-10-01 16:00:00. | 2020-10-07 07:42:19.964
Loaded depth data records for ESZ20 2020-10-05 from 2020-10-05 10:11:14 to 2020-10-05 19:00:00. | 2020-10-07 07:42:20.485
Loaded depth data records for ESZ20 2020-10-06 from 2020-10-05 19:00:00 to 2020-10-06 19:00:00. | 2020-10-07 07:42:21.361
Loaded depth data records for ESZ20 2020-10-07 from 2020-10-06 19:00:00 to 2020-10-06 22:07:02. | 2020-10-07 07:42:21.449
ESZ20 [CB][M] Point & Figure 1-34 #25 | StartDateTimeForLoadingOrderFills: 2020-08-02 17:00:00 | 2020-10-07 07:42:21.451
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:42:22.693
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.0458 seconds. | 2020-10-07 07:42:29.750
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0255 seconds. | 2020-10-07 07:42:29.776
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:42:33.654
DTC Client socket (3) | Creating socket. | 2020-10-07 07:42:33.654
DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:42:33.654
DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:42:33.654
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:42:33.684
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:42:33.684
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:42:33.684
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:42:33.710
SC Data - All Services | Sending logon request message. | 2020-10-07 07:42:33.710
SC Data - All Services | Received logon response. | 2020-10-07 07:42:34.368
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:42:34.368
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:42:34.368
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:42:34.368
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:42:34.368
DTC Client socket (3) | CloseSocket call. | 2020-10-07 07:42:34.368
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:42:34.368
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:42:34.368
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:42:34.368
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:42:34.368
DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:42:34.380
DTC Client socket (3) | Closed. | 2020-10-07 07:42:34.380
HD Request # 39 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:43:02.409
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:43:02.410
HD Request # 39 | Download start date-time: 2020-10-07 07:41:53.000000. File last date-time: 2020-10-07 07:41:53.510001 | 2020-10-07 07:43:02.410
HD Request # 39 | Using server: ds23.sierracharts.com port 10150 | 2020-10-07 07:43:02.410
Socket (3) | Creating socket. | 2020-10-07 07:43:02.490
Socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:43:02.490
Socket (3) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:43:02.490
HD Request # 39 | Setting DTC encoding to Binary VLS | 2020-10-07 07:43:02.623
HD Request # 39 | Sending historical data logon request message. | 2020-10-07 07:43:02.623
HD Request # 39 | Requesting Intraday data. Start date-time: 2020-10-07 07:41:53. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:43:03.081
HD Request # 39 | Decompressing data. | 2020-10-07 07:43:03.092
HD Request # 39 | Receiving Intraday data for ESZ20 starting at 2020-10-07 07:41:53.510000 | 2020-10-07 07:43:03.094
Socket (3) | CloseSocket call. | 2020-10-07 07:43:03.096
Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:43:03.096
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:43:03.096
Historical data download thread signaled to stop. | 2020-10-07 07:43:03.097
HD Request # 39 | Timestamp of first Intraday data file record written: 2020-10-07 07:41:55.192000 | 2020-10-07 07:43:03.097
HD Request # 39 | Received 416 records from 2020-10-07 07:41:53.510000 to 2020-10-07 07:43:00.213000 (66.7 seconds) and wrote 414 records for ESZ20 | 2020-10-07 07:43:03.097
HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2020-10-07 12:43:00.213000 | 2020-10-07 07:43:03.103
HD Request # 39 | Completion time: 1s | 2020-10-07 07:43:03.103
HD Request # 39 | Intraday data download complete for ESZ20. Unique request ID: 39 | 2020-10-07 07:43:03.103
Removing historical data download ID 39. | 2020-10-07 07:43:03.103
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-07 07:43:03.103
Intraday chart data file opened for ESZ20 | 2020-10-07 07:43:03.103
HD Request # 39 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:43:03.103
Triggering next historical data download in queue. | 2020-10-07 07:43:03.103
Socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:43:03.112
Socket (3) | Closed. | 2020-10-07 07:43:03.112
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.422
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.565
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:43:03.572
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.596
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.676
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.755
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:43:03.991
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:43:04.371
DTC Client socket (3) | Creating socket. | 2020-10-07 07:43:04.386
DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:43:04.386
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:43:04.386
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:43:04.400
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:43:04.400
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:43:04.400
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:43:04.427
SC Data - All Services | Sending logon request message. | 2020-10-07 07:43:04.427
SC Data - All Services | Received logon response. | 2020-10-07 07:43:05.095
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:43:05.095
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:43:05.095
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:43:05.095
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:43:05.095
DTC Client socket (3) | CloseSocket call. | 2020-10-07 07:43:05.095
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:43:05.095
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:43:05.095
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:43:05.095
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:43:05.113
DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:43:05.126
DTC Client socket (3) | Closed. | 2020-10-07 07:43:05.126
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:43:35.098
DTC Client socket (3) | Creating socket. | 2020-10-07 07:43:35.098
DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:43:35.098
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:43:35.098
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:43:35.120
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:43:35.120
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:43:35.120
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:43:35.139
SC Data - All Services | Sending logon request message. | 2020-10-07 07:43:35.139
SC Data - All Services | Received logon response. | 2020-10-07 07:43:35.766
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:43:35.766
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:43:35.766
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:43:35.766
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:43:35.766
DTC Client socket (3) | CloseSocket call. | 2020-10-07 07:43:35.766
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:43:35.766
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:43:35.766
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:43:35.766
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:43:35.766
DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:43:35.786
DTC Client socket (3) | Closed. | 2020-10-07 07:43:35.786
ESZ20 [CB][M] 15 Sec #26 | StartDateTimeForLoadingOrderFills: 2019-12-31 15:30:00 | 2020-10-07 07:43:52.376
Chart #26 has tagged chart #13 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:44:26.806
Chart #26 has tagged chart #24 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:44:26.806
Chart #26 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:44:26.806
Chart #26 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:44:26.806
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.039
ESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:45:15.076
ESZ20 [CB][M] Aligned Renko 12t #13 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.086
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.145
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.159
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.164
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.208
ESZ20[M] Point & Figure 1-34 #24 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.215
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.321
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:45:15.382
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:45:15.382
DTC Client socket (2) | Creating socket. | 2020-10-07 07:45:15.383
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:45:15.383
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:45:15.383
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:45:15.441
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:45:15.441
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:45:15.441
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:45:15.467
SC Data - All Services | Sending logon request message. | 2020-10-07 07:45:15.467
SC Data - All Services | Received logon response. | 2020-10-07 07:45:16.196
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:45:16.196
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:45:16.196
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:45:16.196
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:45:16.196
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:45:16.196
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:45:16.196
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:45:16.196
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:45:16.196
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:45:16.196
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:45:16.222
DTC Client socket (2) | Closed. | 2020-10-07 07:45:16.222
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:45:46.199
DTC Client socket (1) | Creating socket. | 2020-10-07 07:45:46.199
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:45:46.199
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:45:46.199
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:45:46.227
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:45:46.227
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:45:46.227
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:45:46.244
SC Data - All Services | Sending logon request message. | 2020-10-07 07:45:46.244
SC Data - All Services | Received logon response. | 2020-10-07 07:45:46.907
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:45:46.907
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:45:46.907
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:45:46.907
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:45:46.907
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:45:46.908
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:45:46.908
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:45:46.908
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:45:46.908
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:45:46.908
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:45:46.921
DTC Client socket (1) | Closed. | 2020-10-07 07:45:46.921
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:46:16.901
DTC Client socket (1) | Creating socket. | 2020-10-07 07:46:16.901
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:46:16.901
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:46:16.901
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:46:16.922
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:46:16.922
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:46:16.922
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:46:16.945
SC Data - All Services | Sending logon request message. | 2020-10-07 07:46:16.945
SC Data - All Services | Received logon response. | 2020-10-07 07:46:17.602
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:46:17.602
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:46:17.602
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:46:17.602
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:46:17.602
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:46:17.602
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:46:17.602
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:46:17.603
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:46:17.603
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:46:17.603
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:46:17.616
DTC Client socket (1) | Closed. | 2020-10-07 07:46:17.616
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:46:47.614
DTC Client socket (1) | Creating socket. | 2020-10-07 07:46:47.615
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:46:47.615
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:46:47.615
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:46:47.645
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:46:47.645
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:46:47.645
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:46:47.684
SC Data - All Services | Sending logon request message. | 2020-10-07 07:46:47.684
SC Data - All Services | Received logon response. | 2020-10-07 07:46:48.312
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:46:48.312
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:46:48.312
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:46:48.312
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:46:48.312
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:46:48.313
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:46:48.313
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:46:48.313
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:46:48.313
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:46:48.313
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:46:48.326
DTC Client socket (1) | Closed. | 2020-10-07 07:46:48.326
File >> Disconnect selected. | 2020-10-07 07:47:07.030
DTC Client socket (0) | CloseSocket call. | 2020-10-07 07:47:07.104
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:47:07.104
SC Data - All Services | Disconnected. | 2020-10-07 07:47:07.104
SC Data - All Services | Connected to server complete. | 2020-10-07 07:47:29.112
Triggering next historical data download in queue. | 2020-10-07 07:47:29.113
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-07 07:47:29.198
SC Data - All Services | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2020-10-07 07:47:29.198
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:47:29.198
SC Data - All Services | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2020-10-07 07:47:29.198
Requesting market depth updates for: ESZ20 if supported. | 2020-10-07 07:47:29.198
Separate subscription for market depth updates not supported. ESZ20 | 2020-10-07 07:47:29.198
Mapping MESZ20 to MESZ20. Service code: cme | 2020-10-07 07:47:29.198
SC Data - All Services | Starting real-time market data updates for: MESZ20 (MESZ20). ID: 2 Service code: cme | 2020-10-07 07:47:29.198
SC Data - All Services | Requesting security definition data for: MESZ20 (MESZ20). ID: 2 | 2020-10-07 07:47:29.198
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:47:29.199
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:47:29.199
Triggering next historical data download in queue. | 2020-10-07 07:47:29.199
DTC Client socket (1) | Creating socket. | 2020-10-07 07:47:29.199
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:47:29.199
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:47:29.199
Delaying start of download for ESZ20 | 2020-10-07 07:47:29.207
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:47:29.278
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:47:29.278
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:47:29.278
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:47:29.335
SC Data - All Services | Sending logon request message. | 2020-10-07 07:47:29.335
SC Data - All Services | Received logon response. | 2020-10-07 07:47:30.040
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:47:30.040
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:47:30.040
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:47:30.040
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:47:30.040
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:47:30.040
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:47:30.040
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:47:30.040
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:47:30.040
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:47:30.040
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:47:30.066
DTC Client socket (1) | Closed. | 2020-10-07 07:47:30.066
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:48:00.044
DTC Client socket (1) | Creating socket. | 2020-10-07 07:48:00.044
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:48:00.045
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:48:00.045
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:48:00.058
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:48:00.058
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:48:00.059
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:48:00.098
SC Data - All Services | Sending logon request message. | 2020-10-07 07:48:00.098
SC Data - All Services | Received logon response. | 2020-10-07 07:48:00.756
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:48:00.756
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:48:00.756
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:48:00.756
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:48:00.756
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:48:00.756
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:48:00.756
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:48:00.756
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:48:00.756
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:48:00.756
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:48:00.771
DTC Client socket (1) | Closed. | 2020-10-07 07:48:00.771
HD Request # 40 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:48:30.463
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:48:30.463
HD Request # 40 | Download start date-time: 2020-10-07 07:43:00.000000. File last date-time: 2020-10-07 07:43:00.213000 | 2020-10-07 07:48:30.464
HD Request # 40 | Using server: ds21.sierracharts.com port 10149 | 2020-10-07 07:48:30.464
Socket (1) | Creating socket. | 2020-10-07 07:48:30.464
Socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:48:30.464
Socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:48:30.464
HD Request # 40 | Setting DTC encoding to Binary VLS | 2020-10-07 07:48:30.494
HD Request # 40 | Sending historical data logon request message. | 2020-10-07 07:48:30.494
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:48:30.747
DTC Client socket (2) | Creating socket. | 2020-10-07 07:48:30.748
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:48:30.748
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:48:30.748
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:48:30.761
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:48:30.761
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:48:30.761
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:48:30.790
SC Data - All Services | Sending logon request message. | 2020-10-07 07:48:30.790
HD Request # 40 | Requesting Intraday data. Start date-time: 2020-10-07 07:43:00. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:48:30.945
HD Request # 40 | Decompressing data. | 2020-10-07 07:48:30.958
HD Request # 40 | Receiving Intraday data for ESZ20 starting at 2020-10-07 07:43:00.213000 | 2020-10-07 07:48:30.989
Socket (1) | CloseSocket call. | 2020-10-07 07:48:30.996
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:48:30.996
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:48:30.996
Historical data download thread signaled to stop. | 2020-10-07 07:48:30.996
HD Request # 40 | Timestamp of first Intraday data file record written: 2020-10-07 07:43:02.159000 | 2020-10-07 07:48:30.996
HD Request # 40 | Received 4960 records from 2020-10-07 07:43:00.213000 to 2020-10-07 07:48:28.825001 (5.5 minutes) and wrote 4959 records for ESZ20 | 2020-10-07 07:48:30.997
HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2020-10-07 12:48:28.825001 | 2020-10-07 07:48:31.008
HD Request # 40 | Completion time: 1s | 2020-10-07 07:48:31.008
HD Request # 40 | Intraday data download complete for ESZ20. Unique request ID: 40 | 2020-10-07 07:48:31.008
Removing historical data download ID 40. | 2020-10-07 07:48:31.008
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-07 07:48:31.008
Intraday chart data file opened for ESZ20 | 2020-10-07 07:48:31.008
HD Request # 40 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:48:31.008
Triggering next historical data download in queue. | 2020-10-07 07:48:31.008
Socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:48:31.009
Socket (1) | Closed. | 2020-10-07 07:48:31.009
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.330
Chart #26 has tagged chart #13 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.499
Chart #26 has tagged chart #24 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.499
Chart #26 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.499
Chart #26 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.499
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.532
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:48:31.535
SC Data - All Services | Received logon response. | 2020-10-07 07:48:31.541
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:48:31.541
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:48:31.541
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:48:31.541
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:48:31.541
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:48:31.541
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:48:31.541
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-10-07 07:48:31.541
DTC Client socket (2) | Closed. | 2020-10-07 07:48:31.541
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:48:31.541
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:48:31.541
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.555
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.651
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.656
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.733
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:48:31.745
ESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:48:31.764
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.782
ESZ20 [CB][M] Aligned Renko 12t #13 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.787
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.804
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.856
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.877
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.878
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.899
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.906
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.949
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:31.952
ESZ20[M] Point & Figure 1-34 #24 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:32.029
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:48:32.267
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:49:01.549
DTC Client socket (1) | Creating socket. | 2020-10-07 07:49:01.549
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:49:01.549
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:49:01.549
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:49:01.580
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:49:01.580
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:49:01.580
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:49:01.619
SC Data - All Services | Sending logon request message. | 2020-10-07 07:49:01.619
SC Data - All Services | Received logon response. | 2020-10-07 07:49:02.230
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:49:02.230
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:49:02.230
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:49:02.230
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:49:02.230
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:49:02.230
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:49:02.230
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:49:02.230
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:49:02.230
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:49:02.230
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:49:02.245
DTC Client socket (1) | Closed. | 2020-10-07 07:49:02.245
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:49:32.227
DTC Client socket (1) | Creating socket. | 2020-10-07 07:49:32.227
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:49:32.228
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:49:32.228
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:49:32.256
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:49:32.256
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:49:32.256
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:49:32.295
SC Data - All Services | Sending logon request message. | 2020-10-07 07:49:32.295
SC Data - All Services | Received logon response. | 2020-10-07 07:49:33.107
SC Data - All Services | Server Name: SC Realtime Server. | 2020-10-07 07:49:33.107
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:49:33.107
SC Data - All Services | Successfully connected. | 2020-10-07 07:49:33.107
SC Data - All Services | Trading is not supported. | 2020-10-07 07:49:33.107
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:49:33.107
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:49:33.107
Triggering next historical data download in queue. | 2020-10-07 07:49:33.107
SC Data - All Services | Restarting real-time data updates for symbol: ESZ20 -> ESZ20. Market Depth data restarted. | 2020-10-07 07:49:33.107
SC Data - All Services | Restarting real-time data updates for symbol: MESZ20 -> MESZ20 | 2020-10-07 07:49:33.107
HD Request # 41 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:49:33.107
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:49:33.108
HD Request # 41 | Download start date-time: 2020-10-07 07:48:28.000000. File last date-time: 2020-10-07 07:48:28.825001 | 2020-10-07 07:49:33.108
HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2020-10-07 07:49:33.108
Socket (2) | Creating socket. | 2020-10-07 07:49:33.108
Socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:49:33.108
Socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:49:33.108
HD Request # 41 | Setting DTC encoding to Binary VLS | 2020-10-07 07:49:33.145
HD Request # 41 | Sending historical data logon request message. | 2020-10-07 07:49:33.145
SC Data - All Services | Clearing market depth for ESZ20 | 2020-10-07 07:49:33.324
Enabling compression for file: C:\SierraChart IB\Data\MarketDepthData\ESZ20.2020-10-07.depth. This may take a while. | 2020-10-07 07:49:33.325
Opened cached Depth file: C:\SierraChart IB\Data\MarketDepthData\ESZ20.2020-10-07.depth | 2020-10-07 07:49:33.325
SC Data - All Services | Received security definition for symbol ESZ20 | 2020-10-07 07:49:33.336
SC Data - All Services | Received security definition for symbol MESZ20 | 2020-10-07 07:49:33.336
HD Request # 41 | Requesting Intraday data. Start date-time: 2020-10-07 07:48:28. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:49:33.619
HD Request # 41 | Decompressing data. | 2020-10-07 07:49:33.636
HD Request # 41 | Receiving Intraday data for ESZ20 starting at 2020-10-07 07:48:28.825000 | 2020-10-07 07:49:33.638
Socket (2) | CloseSocket call. | 2020-10-07 07:49:33.638
Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:49:33.638
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:49:33.638
Historical data download thread signaled to stop. | 2020-10-07 07:49:33.644
HD Request # 41 | Timestamp of first Intraday data file record written: 2020-10-07 07:48:29.640000 | 2020-10-07 07:49:33.644
HD Request # 41 | Received 370 records from 2020-10-07 07:48:28.825000 to 2020-10-07 07:49:28.839000 (60.0 seconds) and wrote 368 records for ESZ20 | 2020-10-07 07:49:33.644
Socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:49:33.653
Socket (2) | Closed. | 2020-10-07 07:49:33.653
HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2020-10-07 12:49:28.839000 | 2020-10-07 07:49:33.653
Added 9 Time and Sales records to Intraday data file for ESZ20 after download. | 2020-10-07 07:49:33.653
HD Request # 41 | Completion time: 0s | 2020-10-07 07:49:33.661
HD Request # 41 | Intraday data download complete for ESZ20. Unique request ID: 41 | 2020-10-07 07:49:33.661
Removing historical data download ID 41. | 2020-10-07 07:49:33.661
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-07 07:49:33.661
Intraday chart data file opened for ESZ20 | 2020-10-07 07:49:33.661
HD Request # 41 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:49:33.661
Triggering next historical data download in queue. | 2020-10-07 07:49:33.661
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:33.963
Chart #26 has tagged chart #13 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.023
Chart #26 has tagged chart #24 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.023
Chart #26 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.023
Chart #26 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.023
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.059
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.077
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.189
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.191
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.272
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:49:34.292
ESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:49:34.301
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.314
ESZ20 [CB][M] Aligned Renko 12t #13 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.319
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.334
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.399
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.424
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.424
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.436
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.441
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.484
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.497
ESZ20[M] Point & Figure 1-34 #24 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.588
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:49:34.856
Opened cached Intraday file: C:\SierraChart IB\Data\ESZ20.scid. Thread ID: 6400 | 2020-10-07 07:49:36.558
File >> Disconnect selected. | 2020-10-07 07:54:19.354
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:54:19.415
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:54:19.416
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:54:19.416
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2020-10-07 07:54:19.416
DTC Client socket (1) | Max send buffer size during socket life: 176 | 2020-10-07 07:54:19.416
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:54:19.416
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:54:19.416
SC Data - All Services | Disconnected. | 2020-10-07 07:54:19.416
SC Data - All Services | Connected to server complete. | 2020-10-07 07:54:59.718
Triggering next historical data download in queue. | 2020-10-07 07:54:59.719
Mapping ESZ20 to ESZ20. Service code: cme | 2020-10-07 07:54:59.800
SC Data - All Services | Starting real-time market data updates for: ESZ20 (ESZ20). ID: 1 Service code: cme | 2020-10-07 07:54:59.800
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:54:59.800
SC Data - All Services | Requesting security definition data for: ESZ20 (ESZ20). ID: 1 | 2020-10-07 07:54:59.800
Added historical Intraday data request for ESZ20 to the queue. | 2020-10-07 07:54:59.800
Intraday data recording state for symbol ESZ20 is set to download 'Pending'. | 2020-10-07 07:54:59.800
Triggering next historical data download in queue. | 2020-10-07 07:54:59.800
DTC Client socket (2) | Creating socket. | 2020-10-07 07:54:59.800
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:54:59.800
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:54:59.800
Delaying start of download for ESZ20 | 2020-10-07 07:54:59.806
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:54:59.820
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:54:59.820
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:54:59.820
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:54:59.919
SC Data - All Services | Sending logon request message. | 2020-10-07 07:54:59.919
Requesting market depth updates for: ESZ20 if supported. | 2020-10-07 07:55:00.016
Separate subscription for market depth updates not supported. ESZ20 | 2020-10-07 07:55:00.016
Mapping MESZ20 to MESZ20. Service code: cme | 2020-10-07 07:55:00.016
SC Data - All Services | Starting real-time market data updates for: MESZ20 (MESZ20). ID: 2 Service code: cme | 2020-10-07 07:55:00.016
SC Data - All Services | Requesting security definition data for: MESZ20 (MESZ20). ID: 2 | 2020-10-07 07:55:00.016
SC Data - All Services | Received logon response. | 2020-10-07 07:55:00.139
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:55:00.139
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:55:00.139
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:55:00.139
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:55:00.139
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:55:00.139
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:55:00.139
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:55:00.139
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:55:00.139
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:55:00.139
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:55:00.152
DTC Client socket (2) | Closed. | 2020-10-07 07:55:00.152
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:55:30.139
DTC Client socket (2) | Creating socket. | 2020-10-07 07:55:30.140
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:55:30.140
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:55:30.140
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:55:30.156
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:55:30.156
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:55:30.156
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:55:30.200
SC Data - All Services | Sending logon request message. | 2020-10-07 07:55:30.200
SC Data - All Services | Received logon response. | 2020-10-07 07:55:30.874
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:55:30.874
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:55:30.874
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:55:30.874
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:55:30.874
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:55:30.874
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:55:30.874
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:55:30.874
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:55:30.874
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:55:30.874
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:55:30.888
DTC Client socket (2) | Closed. | 2020-10-07 07:55:30.888
HD Request # 42 | Downloading Intraday chart data for ESZ20 to the file ESZ20.scid. Service: cme | 2020-10-07 07:56:00.572
Enabling compression for file: C:\SierraChart IB\Data\ESZ20.scid. This may take a while. | 2020-10-07 07:56:00.573
HD Request # 42 | Download start date-time: 2020-10-07 07:54:11.000000. File last date-time: 2020-10-07 07:54:11.573000 | 2020-10-07 07:56:00.573
HD Request # 42 | Using server: ds21.sierracharts.com port 10149 | 2020-10-07 07:56:00.573
Socket (2) | Creating socket. | 2020-10-07 07:56:00.573
Socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:56:00.573
Socket (2) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:56:00.573
HD Request # 42 | Setting DTC encoding to Binary VLS | 2020-10-07 07:56:00.601
HD Request # 42 | Sending historical data logon request message. | 2020-10-07 07:56:00.601
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:56:00.870
DTC Client socket (3) | Creating socket. | 2020-10-07 07:56:00.871
DTC Client socket (3) | New receive buffer size: 5242880 | 2020-10-07 07:56:00.871
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:56:00.871
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:56:00.893
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:56:00.893
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:56:00.893
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:56:00.923
SC Data - All Services | Sending logon request message. | 2020-10-07 07:56:00.924
HD Request # 42 | Requesting Intraday data. Start date-time: 2020-10-07 07:54:11. Record interval: 0. Symbol: ESZ20 | 2020-10-07 07:56:01.062
HD Request # 42 | Decompressing data. | 2020-10-07 07:56:01.076
HD Request # 42 | Receiving Intraday data for ESZ20 starting at 2020-10-07 07:54:11.573000 | 2020-10-07 07:56:01.091
Socket (2) | CloseSocket call. | 2020-10-07 07:56:01.092
Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:56:01.092
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:56:01.092
Historical data download thread signaled to stop. | 2020-10-07 07:56:01.092
HD Request # 42 | Timestamp of first Intraday data file record written: 2020-10-07 07:54:22.634000 | 2020-10-07 07:56:01.093
HD Request # 42 | Received 1968 records from 2020-10-07 07:54:11.573000 to 2020-10-07 07:55:58.418009 (106.8 seconds) and wrote 1967 records for ESZ20 | 2020-10-07 07:56:01.093
HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2020-10-07 12:55:58.418009 | 2020-10-07 07:56:01.099
HD Request # 42 | Completion time: 1s | 2020-10-07 07:56:01.099
HD Request # 42 | Intraday data download complete for ESZ20. Unique request ID: 42 | 2020-10-07 07:56:01.099
Removing historical data download ID 42. | 2020-10-07 07:56:01.099
Real-time Intraday chart data file updates started for ESZ20 | 2020-10-07 07:56:01.099
Intraday chart data file opened for ESZ20 | 2020-10-07 07:56:01.099
HD Request # 42 | Enabling Intraday chart updating for symbol. | 2020-10-07 07:56:01.099
Triggering next historical data download in queue. | 2020-10-07 07:56:01.099
Socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:56:01.109
Socket (2) | Closed. | 2020-10-07 07:56:01.109
Chart #19 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.370
Chart #10 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.375
Chart #12 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.379
Chart #5 has tagged chart #4 for full recalculation. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:56:01.390
ESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: PF22 Long Term.Cht | 2020-10-07 07:56:01.397
Chart #21 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.407
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.411
Chart #20 has tagged chart #16 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.452
Chart #15 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.462
ESZ20 [CBV][M] 60 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.463
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.533
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.539
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.595
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.598
SC Data - All Services | Received logon response. | 2020-10-07 07:56:01.607
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:56:01.607
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:56:01.607
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:56:01.607
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:56:01.607
DTC Client socket (3) | CloseSocket call. | 2020-10-07 07:56:01.608
DTC Client socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:56:01.608
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:56:01.608
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:56:01.608
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:56:01.608
DTC Client socket (3) | Socket gracefully closed by remote side. | 2020-10-07 07:56:01.622
DTC Client socket (3) | Closed. | 2020-10-07 07:56:01.622
Chart #6 has tagged chart #3 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.776
Chart #26 has tagged chart #13 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.935
Chart #26 has tagged chart #24 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.935
Chart #26 has tagged chart #25 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.935
Chart #26 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.935
ESZ20 [CB][M] Point & Figure 1-34 #25 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:01.967
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.066
ESZ20 [CB][M] Aligned Renko 12t #13 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.210
Chart #13 has tagged chart #1 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.231
ESZ20[M] Point & Figure 1-21 #3 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.443
ESZ20[M] Point & Figure 1-21 #1 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.449
Chart #1 has tagged chart #4 for full recalculation. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.492
ESZ20/MESZ20[M] Point & Figure 1-21 #4 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.495
ESZ20[M] Point & Figure 1-34 #24 | Performing a full recalculation because it has been tagged. Chartbook: Comp2 Intance 1.Cht | 2020-10-07 07:56:02.616
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:56:31.612
DTC Client socket (2) | Creating socket. | 2020-10-07 07:56:31.612
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:56:31.613
DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:56:31.613
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:56:31.638
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:56:31.638
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:56:31.639
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:56:31.688
SC Data - All Services | Sending logon request message. | 2020-10-07 07:56:31.688
SC Data - All Services | Received logon response. | 2020-10-07 07:56:32.359
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:56:32.359
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:56:32.360
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:56:32.360
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:56:32.360
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:56:32.360
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:56:32.360
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:56:32.360
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:56:32.360
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:56:32.360
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:56:32.386
DTC Client socket (2) | Closed. | 2020-10-07 07:56:32.386
DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2020-10-07 07:56:38.859
DTC Client socket (1) | Closed. | 2020-10-07 07:56:38.859
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:57:02.355
DTC Client socket (2) | Creating socket. | 2020-10-07 07:57:02.355
DTC Client socket (2) | New receive buffer size: 5242880 | 2020-10-07 07:57:02.355
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:57:02.355
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:57:02.369
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:57:02.369
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:57:02.370
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:57:02.402
SC Data - All Services | Sending logon request message. | 2020-10-07 07:57:02.402
SC Data - All Services | Received logon response. | 2020-10-07 07:57:03.042
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:57:03.042
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:57:03.042
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:57:03.042
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:57:03.042
DTC Client socket (2) | CloseSocket call. | 2020-10-07 07:57:03.042
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:57:03.042
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:57:03.042
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:57:03.042
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:57:03.042
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-10-07 07:57:03.054
DTC Client socket (2) | Closed. | 2020-10-07 07:57:03.054
DTC Client socket (1) | Deleting network socket now after delay. | 2020-10-07 07:57:08.867
Saved Chartbook: Comp2 Intance 1.Cht. Time: 0.1281 seconds. | 2020-10-07 07:57:29.909
Saved Chartbook: PF22 Long Term.Cht. Time: 0.0344 seconds. | 2020-10-07 07:57:29.945
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10059 | 2020-10-07 07:57:33.042
DTC Client socket (1) | Creating socket. | 2020-10-07 07:57:33.043
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:57:33.043
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2020-10-07 07:57:33.043
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:57:33.067
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:57:33.067
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:57:33.067
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:57:33.098
SC Data - All Services | Sending logon request message. | 2020-10-07 07:57:33.098
SC Data - All Services | Received logon response. | 2020-10-07 07:57:33.774
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:57:33.774
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:57:33.774
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:57:33.774
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:57:33.774
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:57:33.774
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:57:33.774
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:57:33.774
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:57:33.774
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:57:33.774
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:57:33.788
DTC Client socket (1) | Closed. | 2020-10-07 07:57:33.788
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10059 | 2020-10-07 07:58:03.778
DTC Client socket (1) | Creating socket. | 2020-10-07 07:58:03.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:58:03.778
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-07 07:58:03.778
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:58:03.796
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:58:03.797
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:58:03.797
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:58:03.831
SC Data - All Services | Sending logon request message. | 2020-10-07 07:58:03.831
SC Data - All Services | Received logon response. | 2020-10-07 07:58:04.477
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:58:04.477
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:58:04.477
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:58:04.477
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:58:04.477
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:58:04.477
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:58:04.477
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:58:04.477
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:58:04.477
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:58:04.478
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:58:04.491
DTC Client socket (1) | Closed. | 2020-10-07 07:58:04.491
SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 10059 | 2020-10-07 07:58:34.481
DTC Client socket (1) | Creating socket. | 2020-10-07 07:58:34.482
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:58:34.482
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2020-10-07 07:58:34.482
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:58:34.509
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:58:34.509
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:58:34.509
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:58:34.570
SC Data - All Services | Sending logon request message. | 2020-10-07 07:58:34.570
SC Data - All Services | Received logon response. | 2020-10-07 07:58:35.290
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:58:35.290
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:58:35.290
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:58:35.290
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:58:35.290
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:58:35.290
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:58:35.290
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:58:35.290
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:58:35.290
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:58:35.290
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:58:35.316
DTC Client socket (1) | Closed. | 2020-10-07 07:58:35.316
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10059 | 2020-10-07 07:59:05.302
DTC Client socket (1) | Creating socket. | 2020-10-07 07:59:05.303
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-07 07:59:05.303
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-10-07 07:59:05.303
SC Data - All Services | Network connection to server complete. | 2020-10-07 07:59:05.335
SC Data - All Services | Starting socket receive thread. | 2020-10-07 07:59:05.335
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-10-07 07:59:05.335
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-10-07 07:59:05.383
SC Data - All Services | Sending logon request message. | 2020-10-07 07:59:05.383
SC Data - All Services | Received logon response. | 2020-10-07 07:59:06.039
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-10-07 07:59:06.039
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-10-07 07:59:06.039
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-10-07 07:59:06.039
SC Data - All Services | Waiting for socket receive thread to end | 2020-10-07 07:59:06.039
DTC Client socket (1) | CloseSocket call. | 2020-10-07 07:59:06.039
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-07 07:59:06.039
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-07 07:59:06.039
SC Data - All Services | Disconnected from the server. | 2020-10-07 07:59:06.039
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-10-07 07:59:06.039
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-07 07:59:06.053
DTC Client socket (1) | Closed. | 2020-10-07 07:59:06.053
[2020-10-07 14:57:49]
John - SC Support - Posts: 37891
The following is the relevant information:
This is stating that you are trying to make a total of 3 connections. So you have a connection somewhere else to the data feed that you will need to disconnect, then you can use the two computers that you are trying to use.
[2020-10-07 16:40:17]
User736044 - Posts: 51
That cannot be, I have 2 separate instances in each comp, I don't have anything else on
[2020-10-07 16:42:04]
You guys said that I can have 2 separate instances in each comp and it will be fine
[2020-10-07 16:49:18]
You can have 2 connections from each computer with 2 computers both connecting at the same time. That is not a problem.
But there is a 3rd computer somewhere that is also connected. We can tell you that the following Computer Names have been recently used. Please check these systems to see if they are still connected to the data feed:
- Main
- Juniper
- AnnvoL
- D474
[2020-10-07 17:32:09]
I understand, but only 2 computers were turned on in the last 3 days.
[2020-10-07 17:53:09]
Please guys, I need some help, don't know what else to do. I only have Main and Juniper on. There is no 3rd comp connected anywhere.
[2020-10-07 18:06:46]
On Juniper we see that there are 3 separate Sierra Chart instances running.
On Main we see that there are 4 separate Sierra Chart instances running.
We do not know if all of these are connected to the data feed, but you can only have 2 connections on up to 2 computers at the same time, so a total of 4 concurrent connections on 2 computers.
The message you are getting is telling us that one of these additional instances is already connected to the data feed, therefore the one you are trying to connect, cannot do so. You will need to look through these instances and see what is happening.
[2020-10-07 19:02:01]
That is impossible, I only have 2 in each comp. I uploaded files to show you. I have a couple of chartbooks open in one instance
image20201007_135501.jpg / V - Attached On 2020-10-07 18:57:54 UTC - Size: 911.42 KB - 148 views
image20201007_135454.jpg / V - Attached On 2020-10-07 18:58:10 UTC - Size: 1.2 MB - 148 views
[2020-10-07 19:14:33]
Then the only thing we can recommend doing is to disconnect from all the instances and then go back and reconnect. Refer to the following:
[2020-10-07 19:15:14]
When I disconnect one instance in Main, both instances in juniper go live
[2020-10-07 19:21:25]
The thing to do is to disconnect all of them, then start them up one at a time and see if there is a particular one that gives you a problem.
