Date/Time: Thu, 10 Sep 2026 13:12:43 +0000
Denali Feedd
View Count: 850
[2020-09-25 13:35:32]
wingz - Posts: 121
Why is the Denali feed not working this morning? Price bars are waaaay behind actual price.
[2020-09-25 15:24:43]
John - SC Support - Posts: 47822
We are not seeing any issues. It sounds like you may be getting delayed data for some reason.
First, make sure the option for File >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds is enabled.
If it is enabled, then attach your Message Log to this thread using these instructions:
Reconnect to the data feed:
[2020-09-25 23:49:08]
wingz - Posts: 121
I used another data feed all day today with no problem whatsoever. As soon as I started using the other data feed this morning, the charts updated and ran perfectly all day long so I guess that answers the question of me getting delayed data. I just downloaded the current version(2175). Is that going take care of the lagging data problem?
[2020-09-27 05:30:05]
wingz - Posts: 121
It would be nice to have an answer to my last question.
[2020-09-27 08:06:11]
Are you still noticing an issue? There is no way we can help you, unless you provide the information requested in post #2.
We need our instructions followed.
[2020-09-27 17:17:36]
wingz - Posts: 121
I have no way of knowing if the issue is still present until the open at 6:00 this evening. Hopefully it won't be. If it is, I'll try to follow your instructions and get it to you.
