Date/Time: Tue, 11 Feb 2025 21:35:11 +0000
Chart Drawings
View Count: 429
[2020-09-22 15:50:26]
User377189 - Posts: 203
I had chart drawings and merged TPO's on a chart and today when i opened my chartbook i had lost all the merged profiles and drawings.
How can i get these back or will i have to do it manually?
[2020-09-22 15:53:09]
John - SC Support - Posts: 37887
The only reason these would be lost is if you either did not save the Chartbook prior to closing, or if you are opening a different Chartbook.
Make sure you have the correct Chartbook, but if it is the correct one and the information is not there, then you would have to recreate it manually.
You can also check your backup Chartbooks to see if the changes you made might be in one of them, although it is doubtful given the above scenarios. Refer to the information here for how to access a backup chartbook:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
