Date/Time: Mon, 25 Nov 2024 12:42:00 +0000
Charts tiling
View Count: 1305
[2014-02-07 15:03:25] |
User33552 - Posts: 23 |
WTV in toolbar gives different output than vertical tiling. Screenshots attached. Two questions embedded in screenshots and posted here for you as well. (Question 1 = How can I get the tiling shown in the screenshot? Question 2 = How can I get WTV to be consistent in the way it "orders" the windows?) Thank you. |
TILING.doc - Attached On 2014-02-07 15:00:54 UTC - Size: 372.5 KB - 421 views |
[2014-02-07 20:06:01] |
We have verified that the ToolBar buttons for tiling vertically and horizontally do function properly and correspond to the Menu commands on the Window menu. This is from our documentation for Tile Vertically: This command is implemented by the operating system. When there are more than a certain number of windows within the main Sierra Chart window, the layout will no longer be vertical. The operating system uses its own algorithm to arrange the layout.
When I choose WTV in the toolbar and have multiple windows open, it does not “order” them by number or by the way I have them placed. It just places them in random order. How can I get it to be a consistent order so I can plan for the same thing every time? How can I get it to look like this and remain in this format? When I save this as a chartbook and open it again, it comes back as above Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
