Date/Time: Wed, 12 Feb 2025 10:13:19 +0000
DAX Futures
View Count: 1702
[2020-09-18 18:39:47]
User450463 - Posts: 128
Currently using SC Futures Order Routing and Data Service. Can I get DAX futures data and order routing on this feed?
Thanks.
[2020-09-22 11:22:19]
Yes this is fully supported.
[2020-09-22 20:28:37]
SC Support - Posts: 1930
Hi there, since your interest is in the EUREX, you will also need to use the Sierra Chart Exchange Data Feed:
Set-up instructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
Your broker AMP does support Order Routing to the EUREX on the Sierra Chart TTFIX Based Order Routing:
Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction
(Also other Exchanges Available to you on the Sierra Chart Exchange Data Feed:)
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SupportedExchanges
Date Time Of Last Edit: 2020-09-28 09:56:12
[2020-09-26 13:11:18]
I don't quite understand this. I'm using the Sierra chart order routing and data feed. Are you telling me I need to switch to Sierra Chart exchange data feed? I don't want to have to be switching between data feeds all day. If I can't get Dax on my current feed then I'm not interested.
Do I set this up through AMP?
[2020-09-28 09:56:46]
No this is not the case. Refer to:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
You have to pay for this data feed directly through your Sierra Chart account which you can do.
[2020-10-15 20:21:52]
OK, I set this up.
1. Do I have to buy 150 symbols AND the EUREX Feed? I don't want 150 symbols... I want the EUREX feed and one symbol: DAX FUTURES.
2. If I do have to buy both, where is the 20 symbols choice shown in the setup page? All I saw was 150 and 500.
3. Why do I have to sign agreements for the NYSE? I'm not using NYSE data.
4. What do I have to do on the AMP end for order routing?
5. Frankfurt hours of course, are quite different from CME. How should I set my chart up for this. Use the Frankfurt hours in my local time? Set a time zone somewhere?
It appears to be working. At least I can find the symbol and produce a chart. No idea if I can route and order.
I would appreciate it if you would answer the questions instead of pointing me to a web page with a WALL OF TEXT.
Thank you.
Date Time Of Last Edit: 2020-10-15 20:38:01
[2020-10-16 09:55:28]
1. Yes.
2. This is no longer available. And it does not matter because the prices are the same. The documentation has been updated to no longer show that option.
3. You do not. There is a separate link for signing the agreements for equities. Do not complete that one.
4. Let them know you want to trade EUREX over TT if that is what you are asking about.
5. You will want to use Central European Time in the charts for EUREX symbols:
Time Zone Setting: Using Different Time Zone in Individual Charts
Date Time Of Last Edit: 2020-10-16 09:55:46
[2020-10-17 08:48:40]
Thank you for the clarity in responding.
Regarding #5 - Could I also just not set the hours based on my local time in Chart Settings...Session Times? I would prefer to look at the times in my location. That is, for Central Time zone, set the sessions hours to 2:00 AM through 10:30 AM?
Date Time Of Last Edit: 2020-10-17 08:49:34
