Date/Time: Tue, 22 Sep 2026 20:03:11 +0000
Denali Intraday Downloads Hanging For Long Periods
View Count: 831
| [2020-09-14 16:37:25] |
| User379468 - Posts: 508 |
v2168, this issue is unchanged in the multiple instances, a new startup or switching symbols returns to downloading state again where it has already been downloaded previously and also set to constantly update intraday file list.
| [2020-09-14 18:25:36] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-16 01:54:30] |
Thank you, I actually found the trick a user shared here of deleting all old daily files in all instances, and it finally seems resolved: Continuous contract data is re-downloaded on startup | Post: 214664 . Since this worked for multiple users, you may want to document this. It still reverts to downloading state again on symbol change even after already downloaded previously, but only for a few seconds now instead of minutes, assume this is normal? I have a couple other issues to fix, want to minimize your time spent, do you prefer here, all in one other thread, or separate threads for each? Date Time Of Last Edit: 2020-09-16 04:35:32
| [2020-09-16 19:00:46] |
That procedure of deleting files does not make sense to us. If there is some issue with the historical data in a Continuous Futures Contract chart, causing the data to be re-downloaded for some unknown reason which would not make sense to us, then just simply follow the procedure here to re-download the data for all contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data It still reverts to downloading state again on symbol change even after already downloaded previously, Yes this makes sense if there was no data previously downloaded on the current connection or in the case of a historical daily chart if the rules for downloading have been met.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-16 19:01:53
