Date/Time: Tue, 04 Nov 2025 12:54:26 +0000
Error Message in Studies
View Count: 620
| [2020-09-09 09:17:51] |
| Yoshi-san - Posts: 11 |
Hi there, I receive the following error message when opening the study settings window on a chart: Failed to get the function address for scsf_RenkoChartEnhanced in D:\SierraChart\Data\SierraChartStudies.dll. Error: Windows error code 127: Die angegebene Prozedur wurde nicht gefunden. | 2020-09-09 11:07:45.790 *
The text in german basically says that the procedure couldn't be found. Is that a known issue, and is there a fix in planning or already available? Thanks in advance, best regards. |
| [2020-09-09 13:30:27] |
This study has been removed: RenkoChartEnhanced
It has been out of date for many years now. You need to use the standard Renko bars functionality: Renko Bar Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-09 16:29:13] |
That was my first thought, too. Thanks a lot for clarifying. However, it seems that the software is still searching for the study in the dll, which it can't find, of course. So, my question would rather be, how can I get rid of the error message, since it opens every time open the study settings? |
| [2020-09-09 19:08:50] |
You just need to remove all instances of it from the charts: How to Use an Advanced Custom Study or a Study Collection: Custom Study Function Not Found You need to go through all of the charts within the open Chartbooks. You can do this through the CW and CB menus. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-10 12:38:38] |
There were no instances of the Renko Chart running on any of the charts. However, downloading and installing the current version did the trick. Thanks again! |
