Date/Time: Tue, 11 Feb 2025 08:22:33 +0000
[User Discussion] - ZZ turning point- H or L
View Count: 678
[2020-09-04 09:59:17] |
User238343 - Posts: 20 |
want to get last ZZ turning point H or L - color background. - if last turning point is L - color green - if last turning point is H - color red whaat is the easiest way to do this? |
[2020-09-05 01:57:20] |
ForgivingComputers.com - Posts: 1001 |
want to get last ZZ turning point H or L - color background. In the Zig-Zag study set "Additional Output for Spreadsheets" to Yes and then you can see the Reversal Price in SG3. Use the "Color Background Based on Alert Condition" study and create an alert formula comparing SG3 to the Zig Zag Midpoint (SG7). If above the midpoint it is a H and if below it is a L. You will need one study for each color you want to use.- if last turning point is L - color green - if last turning point is H - color red whaat is the easiest way to do this? High: =id1.sg3>id1.sg7 Low: =and(id1.sg3>0,id1.sg1<id1.sg7) Date Time Of Last Edit: 2020-09-05 01:59:03
