Date/Time: Fri, 02 Oct 2026 08:17:20 +0000
Adding NYMEX data
View Count: 761
| [2020-09-03 12:30:36] |
| User585019 - Posts: 27 |
Hello, I have had CME data active and just this month added NYMEX. However CL only load the data for that moment in time, it's not a continuous data stream. The symbol is right and I've relaunched my platform. Is there something else in the Data Connection settings that needs to be adjusted? The CME data is coming through just fine, as before. It's the CL data, though, that isn't flowing. TIA for your assistance |
| [2020-09-03 15:16:40] |
| John - SC Support - Posts: 48086 |
Most likely the reason is what is described in the documentation here: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges But, if you think it may be something else, then we would need to see your Message Log. Follow these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-04 06:35:54] |
Thank you so much!! That was the information I needed.
