Date/Time: Tue, 11 Feb 2025 09:09:37 +0000
How to Open a Stock Chart?
View Count: 1160
[2020-09-01 17:30:44]
krisnara - Posts: 7
I am using trial version of Sierra.I tried a few times but i am unsuccessful.I am mainly going to be using Sierra for US stocks.How do I open CSCO or AMZN ?
I tried FIND SYMBOL -->STOCKS-->ENTER TEXT TO SEARCH NYSE ETC--> Below box I TYPE CSCO,AMZN etc but no results.I dont have any other data Feed other than the one given in Trial.
I have no issues seeing others charts.The problem is only with Stock Charts.
Regards
Kris
[2020-09-01 18:39:06]
John - SC Support - Posts: 37869
You just need to manually enter the stock symbol that you want in File >> Find Symbol >> Selected Symbol. Refer to the information in the fourth paragraph in this section:
File Menu: Find Symbol (File)
Date Time Of Last Edit: 2020-09-02 20:39:54
[2020-09-02 03:55:43]
krisnara - Posts: 7
Thank you John . I am doing the same.But symbols are not showing up.Do I need additional Datafeeds Or do I have to download
names first. ?
[2020-09-02 08:05:35]
krisnara - Posts: 7
In the Message Log..I get the following message.
SC Exchange Data Feed not enabled. c_ServiceManager::GetOrSearchForSymbolsUsingServiceClient | 2020-09-02 08:04:04.328
SC Exchange Data Feed not enabled. c_ServiceManager::GetOrSearchForSymbolsUsingServiceClient | 2020-09-02 08:04:05.232
[2020-09-02 13:39:23]
Given your setup, you will not be getting Real-Time data, but you should be able to open a stock symbol and get delayed data.
Please follow these instructions to get us the entire Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-09-02 20:40:58]
Date Time Of Last Edit: 2020-09-02 20:41:05
