Date/Time: Tue, 11 Feb 2025 01:50:36 +0000
Volume Value Area Lines study stopped TSLA chart from plotting 8-31-20, 1st post split day
View Count: 459
[2020-09-01 02:55:04]
gjockey - Posts: 48
Just ran into this quirk. I use the "Volume Area Lines" study with a bunch of other studies and I usually have intraday charts up for symbols TSLA and AAPL. Both had their first day post split today (8-31-20). The AAPL chart was fine today, but the TSLA chart stopped at 8-28-20 and was not plotting any intraday data today. After the close today, I duplicated the TSLA chart and messed around removing studies to see if that would get it to chart. I found removing the Volume Value Area Lines study did the trick. Just thought I'd let you know. It was more of a nuisance and not a big deal (assuming it's just a 1 day post split quirk on the symbol). I attached a pic. Chart 1 is AAPL + "Volume Area Lines" study. Chart 2 is TSLA + "Volume Area Lines" study. Chart 3 is TSLA - "Volume Area Lines" study.
imageSierra.jpg / V - Attached On 2020-09-01 02:53:52 UTC - Size: 364.75 KB - 210 views
