Date/Time: Tue, 11 Feb 2025 18:30:16 +0000
data feed
View Count: 543
[2020-08-24 16:38:01]
User130767 - Posts: 7
Apologies for opening the ticket but I have been trying to resolve this issue for a couple of days and am making no progress.
I am not receiving realtime data for indicies. I have an assigned funded trading account with AMP. I believe I have followed all the instructions for installation and worked through the suggestions in the help section.
I'm guessing the resolution is something simple that I have missed or not purchased. I have live data for oil and a green data connection, so I'm assuming I've made a beginner's error somewhere.
Have I purchased the correct package to receive data or is this something I need to pursue with AMP?
Kind regards
Anthony
[2020-08-24 17:46:51]
Sierra Chart - Max - Posts: 5790
What are the indicies that you are looking to get data for.
What are the symbols that you are using?
Sierra Chart Support
[2020-09-16 06:21:02]
Hi Max,
Apologies for the late reply, I have been on a break.
I'm looking for order flow and TPO data for S&P, Dax, E-mini S&P 500 futures and Nas if possible.
My subscriptions are due for renewal and I would like to make sure I have the right packages.
Kind regards
Anthony
[2020-09-16 10:34:11]
You will need to use both the Denali Exchange Data Feed for the CME Group futures.
And the SC Exchange Data Feed for EUREX. All of this is explained here:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
Date Time Of Last Edit: 2020-09-16 10:34:23
