Date/Time: Tue, 11 Feb 2025 01:29:00 +0000
ANYONE ELSE HAVING ISSUES with SPREAD CHARTS CUSTOM SYMBOLS?
View Count: 905
[2020-08-19 16:12:18]
User220914 - Posts: 239
Anyone else on the board use custom symbols for spread charts?
if you do can you reach out to compare a couple of things so I can try and figure out what
is up with my sierra chart.
thank you
if you are having issues with custom symbols just type a little bit about what your
issues are please so i can see if we have the same issues?
my issues are many times SIERRA will not recognize my CUSTOM SYMBOL as VALID eventhough it worked yesterday and i valid
my other issues are custom symbols do not update intraday historical data
just trying to find out if this is just on my end or if this is working for everyone else.
thanks for your time.
Date Time Of Last Edit: 2020-08-19 20:17:48
[2020-08-19 21:03:24]
The only way we can help with this kind of advanced usage is through a remote assistance session. Please let us know if you want to do that. There is an additional cost for this but we will do this at a reduced price. Should not be more than about 25 USD.
Date Time Of Last Edit: 2020-08-19 22:00:21
[2020-08-21 20:26:58]
John - SC Support - Posts: 37869
Let us know when would be a good time for us to contact you.
[2020-08-27 18:18:30]
Hi Sierra Chart engineers,
I LOVE SIERRA CHART!!
ok well as usual it took me to turn off my stubborness and actually try a few diffrent things.
I was able to get the CUSTOM SYMBOLS to work and update in my second instance by ..drum roll
by setting up the custom symbols in my "MAIN INSTANCE" they are all working perfectly and updating
as they should.
I would say to always try stuff first in the main instance before and after if they do not work in the second or third instance of
sierra chart.
1. create custom symbols in main instance
2. log off and log back in on the main instance and save all
3. when you open you second insatnce the custom symbols will be there and should work.
