Date/Time: Mon, 16 Sep 2024 19:13:34 +0000
Drawings linked to the symobol not window?
View Count: 1075
[2014-02-02 09:09:28] |
User98465 - Posts: 12 |
I've drawn few horizontal lines on fx pair GBPCAD on 1d timeframe. Then I switched to other symbols (GBPAUD or GBPUSD or EURUSD) and the lines drawn for gbpcad pair are stil there which doesn't make any sense as they are totaly useless and even adverse. How to link chart drawings to the symbol not to chart window? |
[2014-02-02 11:01:20] |
Disable Chart >> Chart Settings >> Advanced Settings 2 >> Show Chart Drawings for Different Symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-02 15:40:08] |
Thank you for your fast reply especially on Sunday. I was also wondering how to use the same drawings (lines,fibs) on different timeframe charts but on the same pair (symbol). Example: If I draw some lines on weekly chart, I would like to see them on daily and 4hr chart as well. Thank you in advance! |
[2014-02-02 18:26:12] |
tobi - Posts: 351 |
... that is just in the field above ;-) For example, click on the daily chart, then Chart >> Chart Settings >> Advanced Settings 2 and in the field below Copy Chart Drawings From Chart #'s type in the chart # of your weekly chart. Details see here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart |
[2014-02-02 20:31:28] |
The answer given in post #4 is correct.
