Date/Time: Sun, 09 Feb 2025 05:42:49 +0000
Chart name to be same as Symbol
View Count: 1188
[2020-08-12 11:56:20]
vish100 - Posts: 111
I want my chart name to have the symbol name that I use in 'Chart Settings'
Somehow when I change the symbol (which the main chart price graph is for) the chart name remains the previous one and I have to change manually
How can I do this/
thanks
[2020-08-13 19:25:12]
John - SC Support - Posts: 37842
By default, the symbol for the chart is the name that is used for the chart tab along with the time period. It sounds like you have entered the symbol into the Title Bar Name and enabled the option for Use Title Bar Name as Tab Label.
If you remove the Title Bar Name and deselect the option for Use Title Bar Name as Tab Label, then you would see the symbol and time period as the tab label.
Refer to the information here:
Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu)
