Date/Time: Mon, 10 Feb 2025 15:39:26 +0000
Chart
View Count: 922
[2020-08-12 00:47:31] |
TrinhTuan - Posts: 3 |
Hello Does sierrachart provide a chart like this attached file ? (Source: 141 West Jackson By J. Peter Steidlmayer) Thank you very much |
[2020-08-12 20:45:00] |
No, we do not have a chart that is in that form. Although, take a look at the documentation here and see if the Point and Figure bars may work for your purposes: Chart Settings: Point and Figure Bar (Intraday Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-12 21:18:03
[2020-08-13 01:51:38] |
Thank for yours reply. My account is TrinhTuan. I have another question: When i start sierrachat, it says: i miss a agreement. (See attachment file). === I trade in ICMarkets, I use Sierrachart (connect Denali Exchange Data Feed Service) in order to make trade decision, and trade at ICMarkets. How do I declare the following items ? - Clearing Firm: Not Set - Trading Account Number: Not Set - Name of Salesperson at the broker / FCM: Not Set Thank you |
Private File |
[2020-08-13 17:40:05] |
If you want to be viewed as a professional and just pay the professional fees for the CME Exchange(s), then you need to fill out the Market Data Agreements again, and you need to leave the fields for "Clearing Firm", "Trading Account Number", and "Name of Salesperson" blank (as you have already done). But then you also need to not declare yourself as a Non-Professional on the CME Non-Professional Certification. You would press the No button to do this on that page. Another option would be to use the Easy Solution to CME Funded Trading. You will find the information here: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-13 17:57:00
[2020-08-26 07:08:22] |
I followed your instructions: 1. fill out the Market Data Agreements again, and you need to leave the fields for "Clearing Firm", "Trading Account Number", and "Name of Salesperson" blank (as you have already done). 2. But then you also need to not declare yourself as a Non-Professional on the CME Non-Professional Certification. You would press the No button to do this on that page. === But systerm still not accepted ! === I did 2 steps at the same time and do each step separately, but it is not acceptable. === Can you handle my case manually? Thank you |
Private File |
[2020-08-26 16:07:14] |
SC Support - Posts: 1930 |
Hi TrinhTuan, please complete the Market Data Agreements with the Professional Designation. Thank you. https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements |
