Date/Time: Tue, 04 Nov 2025 14:59:26 +0000
[User Discussion] - Quote Board New High or New Low
View Count: 1175
|   [2020-07-21 18:09:21]     |
| User117499 - Posts: 6 |
                This is a suggestion regarding number of seconds a new high/low stays highlighted on a quote board. Current default value for it is set at 30 seconds. Wouldn't 2 or 3 seconds be a better default value? Appreciated  |
|   [2020-08-11 18:30:47]     |
                We will make this controllable.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-24 19:38:38]     |
| User90125 - Posts: 715 |
                Now that it's working, could you update the QuoteBoard help page as well? General Settings Window: Quote Board High/Low Timeout Time in Seconds (Global Settings >> General Settings >> General >> Update Intervals) Thanks.  |
