Date/Time: Sat, 08 Feb 2025 14:06:41 +0000
New User Discussion and Programming Help Message Board for Users
View Count: 2291
[2020-07-02 02:34:42] |
Sierra_Chart Engineering - Posts: 18338 |
We have a new message board for User Discussion for Sierra Chart help and usage and for Sierra Chart Programming Help. This is strictly meant for communication between Sierra Chart users and does not receive any "official" Sierra Chart help from Sierra Chart engineers or support engineers. The board is here: https://www.sierrachart.com/SupportBoard.php?ForumID=5 Please begin to use that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-13 09:55:22] |
User365411 - Posts: 192 |
... Please begin to use that. Thanks for the excellent initiative that I suggested some time ago, but I think that as long as the posts marked as user discussion or programming help will not be moved by you, automatically or manually from the main section to the new "User Discussion Board", nothing will change. |
[2020-07-14 08:12:59] |
We will have to see about moving the threads. Users would have to get an email notification that it has happened and given a new link.
[2020-07-14 08:51:52] |
Yes but it can be an extra job to you. Only a suggestion, you can tag the thread as [MOVED] and leave it as a temporary reference in the main section (for example 7 or 15 days then this reference disappear from the main forum) linking it to the new position in the new subforum. I don't know if your board can do that, it's a common practice on vbullettin board based forum. Date Time Of Last Edit: 2020-07-14 08:53:17
