Date/Time: Tue, 04 Nov 2025 13:55:24 +0000
DATA
View Count: 828
[2020-06-22 19:55:21]
Robert Wojczak - Posts: 155
I would like to set up a 2nd instance with CME feed. Can you help me do that? Thank you
[2020-06-22 20:36:52]
Okay so you are fine with paying the CME exchange fees a second time?
[2020-06-22 21:36:24]
yes
[2020-06-23 13:27:00]
John - SC Support - Posts: 42737
Just to make sure, you are also OK with activating the 2nd connection today, which will cost you the full amount for the remainder of June ($31.20)?
[2020-06-23 14:38:56]
You know what in hindsight. please activate on July 1
thank you
[2020-06-23 14:47:38]
We will take care of this for you on July 1.
[2020-06-23 14:58:13]
Thank You very much
[2020-06-23 17:52:39]
Also post here on or after July 1 as a reminder.
[2020-06-30 12:17:53]
Ok Guys If you can please help me with the following. As of tomorrow I would like 2 complete CME packages. Right now I have 3 separate exchanges so I would like to cancel that and go with the 2 full CME. Please advise me what I need to do so I dont get charged for the current configuration. You guys also said you would set up the 2nd exchange for me.
Thank You
Rob
[2020-06-30 13:29:17]
We have gone ahead and "Deactivated" the exchanges for you. You will still have data through the end of the day today. When you get on your computer tomorrow morning, you will need to go to the Exchanges section of the Denali Exchange Data Feed and "Activate" the exchanges that you want. You can access the page here:
https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges
You can also set the option for 2 systems on that same page, if you want. First Activate the exchanges, then set the Number of Systems to 2 Systems. Just let us know if you still want/need us to take care of it for you.
And be sure you have enough funds in your account to cover the costs for 2x the costs of the data feeds that you activate in order to be able to activate the 2nd computer.
[2020-06-30 15:35:45]
I just put money in my account. I can do it myself.. it shouldn't be too difficult? So my 1 Denali feed will work simultaneously on both instances?
Thank you
[2020-06-30 15:50:17]
When you have everything setup and you have 2 systems selected, then yes, your Denali Exchange Data Feed will work on two computers at the same time.
[2020-07-01 13:28:48]
We just checked and it looks like you have everything setup properly. Let us know if you have any issues.
[2020-07-01 13:33:23]
Thank You
