Date/Time: Fri, 07 Feb 2025 20:59:59 +0000
Time Range Highlight - Transparent doesn't work with log scale
View Count: 767
[2020-06-13 13:51:42] |
User266903 - Posts: 26 |
Since Time Range Highlight does the highlighting based on X axis, and log scale affects Y axis, they are independent, and shouldn't affect the highlighting. Reproduction: Take a non-log scale chart, apply "Time Range Highlight". It works as expected. Then, turn on Chart -> Logarithmic Scale. Highlighting disappears. Date Time Of Last Edit: 2020-06-13 13:54:57
[2020-06-17 12:00:13] |
This will be solved in the next release.
