Date/Time: Fri, 07 Feb 2025 20:07:44 +0000
[Programming Help] - please support, I can't connect, I get this notice, what should I do.
View Count: 594
[2020-06-12 20:55:12]
User942756 - Posts: 2
Reading Internal Order ID file. | 2020-06-12 16:49:53.099
Reading Trade Orders file. | 2020-06-12 16:49:53.197
Reading Trade Positions file. | 2020-06-12 16:49:53.198
Reading Account Balance file. | 2020-06-12 16:49:53.199
UDPListener (1496). Port 22904 | Listening on UDP port 22904. | 2020-06-12 16:49:53.224
Software version: 2115 32-bit | 2020-06-12 16:49:53.224
Primary Thread ID: 1144 | 2020-06-12 16:49:53.224
Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2020-06-12 16:49:53.224
To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2020-06-12 16:49:53.224 *
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-12 16:49:53.224
Current selected Data/Trading service: CQG WebAPI | 2020-06-12 16:49:53.224
Custom symbol settings values: enabled | 2020-06-12 16:49:53.224
Chart Update Interval: 500 | 2020-06-12 16:49:53.224
Intraday Data Storage Time Unit: 1 | 2020-06-12 16:49:53.224
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-06-12 16:49:53.224
2020-06-12 15:49:53 Local computer time | 2020-06-12 16:49:53.224
2020-06-12 20:49:53 Local computer time in UTC | 2020-06-12 16:49:53.224
2020-06-12 16:49:53 Local computer time in SC Time Zone | 2020-06-12 16:49:53.224
2020-06-12 20:49:51 Server time in UTC | 2020-06-12 16:49:53.224
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-06-12 16:49:53.224
Program path: C:\SierraChart\ | 2020-06-12 16:49:53.224
Data Files path: C:\SierraChart\Data\ | 2020-06-12 16:49:53.224
OS Version Number: 10.0 | 2020-06-12 16:49:53.224
Locale Setting: C | 2020-06-12 16:49:53.224
Allowed protected custom studies: | 2020-06-12 16:49:53.225
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2020-06-12 16:49:53.225
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-12 16:49:53.250
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-12 16:49:53.411
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-12 16:49:53.411
Received 5 login tokens. | 2020-06-12 16:49:53.770
Symbol settings MD5 received. Request ID: 1. | 2020-06-12 16:49:53.998
Symbol settings are up-to-date for cqg. | 2020-06-12 16:49:53.998
Files to Open on Start up | Opening file: MNQ 1.Cht | 2020-06-12 16:49:56.952
F.US.MNQM20 5 Min #1 | Reloading chart. | 2020-06-12 16:49:56.973
F.US.MNQM20 2 Min #2 | Reloading chart. | 2020-06-12 16:49:57.165
Starting DelayedDownloadMonitoringTimer | 2020-06-12 16:49:57.475
Starting HDTimeoutTimer | 2020-06-12 16:49:57.475
Historical data service client indicated that downloads are not enabled. Symbol: F.US.MNQM20. Data Type: Intraday data | 2020-06-12 16:49:57.475
Historical data download ID 1 not found when removing ID from outstanding request set. | 2020-06-12 16:49:57.475
F.US.MNQM20 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-12 16:49:57.542
F.US.MNQM20 2 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2020-06-12 16:49:57.680
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-06-12 16:49:59.186 *
[2020-06-12 21:47:17]
This is the problem:
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu.
You can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password.
2. Choose the particular Service Package that you want to automatically renew and press the "Update" button.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
[2020-06-12 21:57:31]
As I understand using the platform is free with future amp accounts, I already registered my cqg data on the platform,?
[2020-06-12 22:05:10]
We cannot help with this. You do need to pay for Sierra Chart.
Date Time Of Last Edit: 2020-06-13 03:54:53
