Date/Time: Fri, 07 Feb 2025 12:02:01 +0000
[User Discussion] - Study Alert - Customised Alert Format
View Count: 766
[2020-06-03 00:43:07]
User582996 - Posts: 7
I have setup some alerts to notify me of chart conditions that signal a buy or sell scenario with alerts being generated as an email message as well. I have the Alerts box open on my screen to follow relevant alerts over the trading day.
The way that the alerts are produced is either extremely short if I select 'Use User Defined Name Only in Alert Message' in Global Settings/general Settings/Alerts and does not include the chart name/currency pair.
Using the full message alert is very long which results in needing a large Alerts box open on my desktop. I would like to be able to set an alert of include the chart name (eg. GBPCAD), Time and 'defined Alert Name' only similar to the attached image.
I cannot find a way to display alerts in a condensed for like this or see a solution on the support board.
Can anyone assist in advising if a custom selected alert message can be created in SC that also inputs the time and chart name?
Many thanks
imageSC Alerts Example.JPG / V - Attached On 2020-06-03 00:41:02 UTC - Size: 164.93 KB - 252 views
[2020-06-03 01:04:34]
Ackin - Posts: 1865
Hi, You can create an ACSIL study for this and call it from another chart.
btw For an abbreviated "time range" formula, I would use the study the Time range Highlight from the default SCH list
