Date/Time: Fri, 07 Feb 2025 08:05:43 +0000
Sierra Chart Not Loading More Than 4 Years of Intraday Data
View Count: 645
[2020-05-28 12:05:29] |
Alberto Gauer - Posts: 121 |
Hi there. Is there any reason why Sierra won´t load more than 4 years of intraday data, even if the data is available at the Data folder? I have ES data there that starts in 2010. In chart settings I have more than enough days to load (Set to 5000), I choose the start date as 2014-05-04, but Sierra starts loading from june 2016. It was supposed to load from 2010 if I wanted to (the data is there). Even if I choose the "Use date range" option and set for example 2014-05-04 - 2019-12-31 it will start from june 2016. I remember I could create intraday continuous chart of 10 years or more in Sierra, what happened? |
[2020-05-28 12:32:39] |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
