Date/Time: Tue, 04 Nov 2025 14:13:47 +0000
DATA Hotspot
View Count: 662
|   [2020-05-26 18:16:28]     |
| Crtfyd - Posts: 287 |
                I am thinking about switching to a Mobile Hotspot plan. The deals vary with amount and speed. I cant see in SC a place to check this info. Since my charts are set to "1 tick", I imagine it doesn't matter what kind of charts I have (ie:1min,vol,tick), as the downloaded data will all be the same, just different how I apply it to my charts. Do you know how many GB(?) a typ day +/- of data would be downloaded to my laptop with this info? I imagine some days would have more/less ticks, but not much variance (except for march), so typically is there a way to calculate or see in SC? T-Mobile says i could have 30GB (on their "unlimited" plan) but then slowed to MAX 128 kbps. Is this sufficient to receive data in SC? I imagine its not really speed fragile, just constant. Thanks  |
|   [2020-05-26 19:25:16]     |
                Refer to: Data/Trade Service Settings: Bandwidth Usage Also the status bar shows the amount of data received in bytes: Status Bar Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
