Date/Time: Thu, 06 Feb 2025 23:48:03 +0000
demo feed
View Count: 690
[2020-05-15 16:04:43] |
User565831 - Posts: 4 |
Hi i am having a nightmare trying to get an amp/cqg demo feed / acc setup on my sierra. could anyone recommend a demo feed to test the platform out properly? Thanks Andrew |
[2020-05-15 16:11:33] |
John - SC Support - Posts: 37800 |
Refer to the information here regarding the CQG Demo Accounts. It also gives you information on solutions provided by Sierra Chart. CQG Trading Platform Service: CQG Demo Accounts Not Supported For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-16 00:13:37] |
You need to use the Trading Evaluator-Delayed service. You cannot use the real-time one. So you need to create a trading account for the delayed one, not the real-time one, which you did. However, none of this is necessary. There is an easier way and we will make clear this alternative in the documentation. could anyone recommend a demo feed to test the platform out properly? You just simply need to set Global Settings >> Data/Trade Service Settings >> Service to SC Data-All Services. You then have access to the delayed exchange data feed. Full instructions are here: Delayed Exchange Data Feed This is the default configuration. There simply is no need for any external data service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-16 00:16:17
[2020-05-16 01:48:40] |
Here is the updated relevant documentation: Basic Instructions for Sierra Chart Demo for Brokerage Customers Let us know if you need further help. And be sure to refer to our post above. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-16 01:48:56
