Date/Time: Sat, 19 Sep 2026 04:52:00 +0000
Possible bug - New and changed 'Keyboard Shortcuts' don't take effect until reload of SC
View Count: 796
| [2020-05-05 15:16:14] |
| JohnR - User831573 - Posts: 338 |
Not a big issue. I recently made some keyboard shortcuts to better suit the way I use SC. I did notice they did not appear in the menu structure of my chart window until reloaded SC. Not sure if it was designed that way. I'm OK reloading, since I do not plan to change the shortcuts after I get the set to my liking, as long as I know that is what I need to do. If it is working as designed, you may want to add a comment in the docs --> the changes will not appear in menu structure until SC reloaded. Also, as your docs suggest, I will be using AutoHotKey to some some other things, like combine drawing a rectangle and then changing it to my desired template setup. I have used AutoHotKey before. A good program. Very flexible --> like SierraChart. JohnR Date Time Of Last Edit: 2020-05-05 15:18:17
| [2020-05-06 00:07:24] |
The issue you describe is definitely not the case. The menus are updated immediately. We confirmed that. Keyboard shortcuts go into effect immediately. If there is a problem we have to say it is the system specific issue. We have no other reports of an issue and we cannot reproduce and we know how the code works. This can only be a system specific issue. , like combine drawing a rectangle and then changing it to my desired template setup. You can already do this within Sierra Chart:Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-06 00:07:30
