Date/Time: Thu, 06 Feb 2025 15:00:20 +0000
I'm unable to update
View Count: 532
[2020-05-04 00:20:47]
User992714 - Posts: 4
I'm using version 2057 and trying to update to the latest. I click on help > download current version. The popup says " The software has been downloaded. Sierra chart needs to be closed. Press "Yes" to close the program or "No" to not continue the update. I clicked yes, and Sierra closes. Another popup flashes open and then closes instantly. The update doesn't complete. I tried downloading the update.exe file you have, and that doesn't do anything either. I checked in the logs folder and all it shows is Installer version: 9 | 2020-05-03 20:16:43. I tried turning off my antivirus and that didn't make any difference.
[2020-05-04 00:34:58]
So you cannot even run this installer here?:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
[2020-05-04 00:56:52]
Yeah, I tried that as well. It does the same thing, and won't work. The box pops open and closes in a flash. I have no idea what it's saying.
[2020-05-04 01:45:23]
Not sure why you are having a problem, we cannot reproduce this on Windows 10. At point we recommend using the zip installer:
Software Download: Sierra Chart Zip Installer
