Date/Time: Tue, 04 Nov 2025 12:18:42 +0000
SC Order Routing - undocumented new connection config field
View Count: 929
|   [2020-04-23 20:55:22]     |
| User12089 - Posts: 380 |
                SC Order Routing - undocumented new connection config field: "Use London Relay Server as Primary for Market Data"? I am a London based trader and keenly interested in knowing the exact functionality of the above. I am also SC Market Data subscriber (the main SC Data Feed not the Denali) Does the above mean that I would be receiving SC Market Data from the SC London Server and hence thats supposed to be "faster and more reliable" ? Btw there is a similar field for Order Submission ie Primary Server = Server6 is supposed to be the London TT Server - correct? So as a London based trader i am supposed to use it correct - for faster order submission to TT and from there to CME, Eurex etc?  |
|   [2020-04-24 03:37:44]     |
                That option to use the London Relay Server only applies to the Denali Exchange Data Feed. We will update the documentation about that. e Primary Server = Server6 is supposed to be the London TT Server - correct? If you are just trading the CME markets we would recommend using  one of the Chicago servers which now use a direct Cross Connect to TT rather than utilizing Internet connections. If you are also trading EUREX, London may be the best choice. However, you can also use our order routing server in Germany for that. In this case you can install two copies of Sierra Chart. One for CME trading and one for EUREX and then use the best server for each. You can use the Sierra Chart Exchange Data Feed for EUREX data. And then cancel the CME exchange fee on that and then use the Denali Exchange Data Feed for CME data. In this case you get a 12 USD/month credit to your account. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2020-04-27 12:13:58]     |
                wow i have been thinking about something like that for some time: "You can use the Sierra Chart Exchange Data Feed for EUREX data. And then cancel the CME exchange fee on that and then use the Denali Exchange Data Feed for CME data. In this case you get a 12 USD/month credit to your account." However from previous postings i vaugley remember that the above was NOT "allowed" in the same SC account ? Are we now definitely saying that the following is Allowed / Supported IN THE SAME SC Account: 1. CME Market Data - Denali 2. Eurex Market Data - SC Exchange Data Feed 3. Order Routing (for both CME and Eurex) - AMP / SC Order Routing And even if ALLOWED, how is the above supposed to be setup: you suggested this "In this case you can install two copies of Sierra Chart. One for CME trading and one for EUREX and then use the best server for each." but the SC Trading Data (SC Order Routing) data connection adapter in SC doesnt differntiate between Denali or SC Exchage Data Feed even IF i have separate SC instances for CME and Eurex. So how do i tell the Eurex SC instance to use the SC Exchange Data Feed and the CME SC instance to use the Denali data feed - provided i use THE SAME SC Account which in turn is configured for SC Order Routing Date Time Of Last Edit: 2020-04-27 12:18:25
