Date/Time: Thu, 06 Feb 2025 09:28:59 +0000
Automatic Chart shift to right
View Count: 878
[2020-04-17 14:51:50]
User551971 - Posts: 34
What settings should I make so that the chart automatically moves to the right
[2020-04-17 22:19:30]
We are not sure exactly what you are looking for, but the most likely thing is make sure you enable the following setting:
General Settings Window: Allow New Data In Unlocked Fill Space (Global Settings >> General Settings >> Charts >> Charts)
The other thing that is possible is that you have the Fill Space locked. Refer to this setting:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
[2020-04-20 18:22:40]
I want always see the current price.
In my screenshot the price goes down but i dont see them. i have to scroll in the chart.
imagenot_moving.png / V - Attached On 2020-04-20 18:21:21 UTC - Size: 40.73 KB - 255 views
[2020-04-21 13:23:58]
Make sure the Chart Scale is set to Automatic. Refer to the information here:
Chart Scale and Scale Adjusting: Automatic (Scale Range)
Also, make sure the scale is reset so that the chart bars are always within the current view. Refer to the following to reset the scales:
Chart Scale and Scale Adjusting: Resetting the Scale
Date Time Of Last Edit: 2020-04-21 13:24:40
[2020-04-23 07:26:40]
When I reset the Scale, then I see the chart as in the appendix scale_reset. then this may work but it does not bring me. It must also work when the view is like in appendix scale1
imageScale.png / V - Attached On 2020-04-23 07:09:29 UTC - Size: 26.17 KB - 222 views
imageScale1.png / V - Attached On 2020-04-23 07:22:01 UTC - Size: 33.63 KB - 229 views
imagescale_reset.png / V - Attached On 2020-04-23 07:26:32 UTC - Size: 22.31 KB - 219 views
