Date/Time: Thu, 06 Feb 2025 04:50:30 +0000
DTS Not Connecting
View Count: 599
[2020-04-16 19:57:21]
User676039 - Posts: 5
I cannot get a connection to the CQG WebAPI. It's been working fine for the last few months until today. I've been in touch with CQG and they said they're not seeing errors on their end.
After the problem happened i updated from v2053 to v2086. No change unfortunately.
I trade with a group of people and none have had this issue with the same CQG data connection. Logs below.
Software version: 2086 64-bit | 2020-04-16 15:51:04.355
Primary Thread ID: 11008 | 2020-04-16 15:51:04.355
Usage end date: 2020-05-07 | 2020-04-16 15:51:04.355
Enabled for: Advanced Features 2. | 2020-04-16 15:51:04.355
Enabled for: Sierra Chart Historical Data Service. | 2020-04-16 15:51:04.355
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-16 15:51:04.355
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-16 15:51:04.355
Current selected Data/Trading service: CQG WebAPI | 2020-04-16 15:51:04.355
Custom symbol settings values: enabled | 2020-04-16 15:51:04.355
Chart Update Interval: 500 | 2020-04-16 15:51:04.355
Intraday Data Storage Time Unit: 0 | 2020-04-16 15:51:04.355
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-04-16 15:51:04.355
2020-04-17 05:51:04 Local computer time | 2020-04-16 15:51:04.355
2020-04-16 19:51:04 Local computer time in UTC | 2020-04-16 15:51:04.355
2020-04-16 15:51:04 Local computer time in SC Time Zone | 2020-04-16 15:51:04.355
2020-04-16 19:50:20 Server time in UTC | 2020-04-16 15:51:04.355
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-04-16 15:51:04.355
Program path: D:\SierraChart\ | 2020-04-16 15:51:04.355
Data Files path: D:\SierraChart\Data\ | 2020-04-16 15:51:04.355
OS Version Number: 10.0 | 2020-04-16 15:51:04.355
Locale Setting: C | 2020-04-16 15:51:04.355
DLLs: sst_ateam.dll, sst_ateam_64.dll, sst_local_pressure.dll, sst_local_pressure_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-04-16 15:51:04.355
CQG WebSocket socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2020-04-16 15:51:11.935 *
CQG WebSocket socket (1) | CloseSocket call. | 2020-04-16 15:51:11.935
CQG WebSocket | WebSocket closed. | 2020-04-16 15:51:11.935
CQG WebAPI | WebSocket closed. | 2020-04-16 15:51:11.935
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-16 15:51:11.935
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-16 15:51:11.935
CQG WebSocket socket (1) | Closed. | 2020-04-16 15:51:11.935
CQG WebSocket socket (0) | CloseSocket call. | 2020-04-16 15:51:11.950
CQG WebAPI | Disconnected. | 2020-04-16 15:51:11.950
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-16 15:51:11.950
CQG WebAPI | Connecting to server api.cqg.com | 2020-04-16 15:51:14.955
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2020-04-16 15:51:14.955
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2020-04-16 15:51:14.956
CQG WebSocket socket (1) | Connecting to IP: 203.192.64.152. | 2020-04-16 15:51:14.956
Can you assist?
[2020-04-16 20:35:00]
I forgot to mention, I’ve searched the forum and support pages for this error code. One suggestion was my firewall. As a result, I booted in’ safe mode with networking’ and had the same issue.
[2020-04-17 05:02:12]
There is some connectivity issue to this address and port somewhere from your computer to the server:
Refer to help topic 1.1:
Data/Trading Service Connection and Symbol Issues: 1.1. Data or Trading Service Setup Issue. Unable to Connect to Data or Trade Server.
So it does not appear to be due to a firewall based upon what you did.
What exchanges are you trading?
Date Time Of Last Edit: 2020-04-17 05:03:21
[2020-04-17 05:19:14]
Thanks for the response!
I trade crude futures (CME).
I’ll try the suggestions from the post you linked to shortly.
[2020-04-17 07:58:10]
Hi Support,
It seems my data has reappeared. I ultimately haven't made any changes (other than updating to v2086). Fingers crossed it continues.
Thanks again!
[2020-04-17 08:45:10]
Okay. If you are just trading the CME markets we recommend looking at this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
It offers many connectivity points and if there is any connectivity problem to one, another one is automatically used.
Date Time Of Last Edit: 2020-04-17 08:45:24
