Date/Time: Mon, 14 Sep 2026 00:41:07 +0000
Real time intraday futures CME data for SIM trading
View Count: 869
| [2020-04-14 18:08:18] |
| User928999 - Posts: 10 |
I've read through all your data feed information multiple times but still can't decide what the best route is for my particular case. I trade futures (ES/MES) and will be trading in a SIM environment for the foreseeable future and would like to minimize my costs, however Tradovate said there's no way to connect to their SIM account through sierra because you have not written to their API. Thus I've boiled it down to two potential options for data while trading a SIM account in Sierra Chart... 1. Use Denali through sierra chart and cancel data with my broker. Not sure if this is even possible. 2. Deposit money into an AMP account and use the direct FIX feed. (I'd prefer not to have to allocate money to do this as I just funded the Tradovate account thinking I would be able to use sierra chart and Tradovate in tandem for SIM trading. Thanks for your help, I know you have tried to address all of this in great detail but I still an unclear as to what I needed to do to get up and running with SC and how much it is going to cost me. |
| [2020-04-14 19:31:54] |
If you are fine with 10 minute delayed data, then for no additional cost other than the cost of Sierra Chart, you can use this service: Simulated Futures Trading Service Or if you need real-time data you can use the Denali Exchange Data Feed with the simulated trading service : Denali Exchange Data Feed And to take advantage of the lower-cost nonprofessional fees you can use this solution: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-14 19:33:10
