Date/Time: Mon, 21 Sep 2026 09:23:53 +0000
Drawing persistent line from last visible bar to edge
View Count: 1295
[2020-04-12 09:30:11]
ACWalker - Posts: 6
I am trying to draw risk/reward levels in the fill space between the last bar drawn and the edge of the chart.
I would like this line to persistently display when scrolling through the chart, even through historic data.
At the moment, I am using the subgraph drawstyle DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE and setting the value once to the lastVisibleBar.
Unfortunately, this way the line is only visible when you are scrolled to this bar.
Currently, a solution I can think of is constantly setting the value to the index of the last visible bar and, but I don't know if this is the proper/efficient way to do this.
Is there a better or standard way that this can be done?
Thanks,
Alex
Date Time Of Last Edit: 2020-04-12 09:39:09
[2020-04-13 06:59:42]
The only proper way to do this, is to fill in all elements of the Subgraph array of the study with the value that you want.
[2020-04-13 07:13:59]
Actually there is a more efficient way to do this. Have a look at using this particular Subgraph Draw Style:
Chart Studies: Line at Last Bar to Left Side (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_LEFT_SIDE)
Now this is not exactly what you are looking for, but this is really the only Draw Style available which is always going to be visible no matter where the chart is scrolled to.
Date Time Of Last Edit: 2020-04-13 07:15:05
[2020-04-13 07:18:29]
Disregard what we said at post #3. This is not really the right Draw Style to use. Since it uses only the value at the last visible bar. We will need to add a new Draw Style to accomplish what you need. We will do that.
Date Time Of Last Edit: 2020-04-13 07:21:33
