Date/Time: Tue, 15 Sep 2026 08:45:28 +0000
Charts Stopped updating for 15 minutes today
View Count: 1142
[2020-04-06 21:33:04]
User627712 - Posts: 16
Today my charts stopped updating between 4:00pm and 4:15pm EST. The connection was still green, so I am not sure if this was a data issue, or something else. Please advise. Thank you.
[2020-04-07 00:43:58]
There could not have been a problem on the Sierra Chart side. The data feeds were up and running.
It must have been some issue specific to your Internet connectivity or some other reason.
If there is any missing data in the charts, then follow these instructions:
Date Time Of Last Edit: 2020-04-07 00:45:02
[2020-04-07 21:00:45]
Hello, this happened again today from 16:14 to 16:30 EST. When it was stopped, i tried to "delete and download data from the current position to end" which used 16:14 as default start time, but it didn't work. This time I captured the message log (see below), please take a look and let me know. Thanks.
Reading Internal Order ID file. | 2020-04-07 15:23:28.286
Reading Trade Orders file. | 2020-04-07 15:23:28.411
Reading Trade Positions file. | 2020-04-07 15:23:28.416
Reading Account Balance file. | 2020-04-07 15:23:28.419
UDPListener (1392). Port 22904 | Listening on UDP port 22904. | 2020-04-07 15:23:28.437
Software version: 2078 64-bit | 2020-04-07 15:23:28.438
Primary Thread ID: 7504 | 2020-04-07 15:23:28.438
Enabled for: Advanced Features 2. | 2020-04-07 15:23:28.438
Enabled for: Sierra Chart Historical Data Service. | 2020-04-07 15:23:28.438
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-04-07 15:23:28.438
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-07 15:23:28.438
Enabled for exchange2: CME (Trading Account Required) | 2020-04-07 15:23:28.438
Enabled for exchange2: CBOT (Trading Account Required) | 2020-04-07 15:23:28.438
Enabled for exchange2: COMEX (Trading Account Required) | 2020-04-07 15:23:28.438
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-04-07 15:23:28.438
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-07 15:23:28.438
Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-04-07 15:23:28.438
Custom symbol settings values: enabled | 2020-04-07 15:23:28.438
Chart Update Interval: 500 | 2020-04-07 15:23:28.438
Intraday Data Storage Time Unit: 0 | 2020-04-07 15:23:28.438
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-04-07 15:23:28.438
2020-04-07 15:23:28 Local computer time | 2020-04-07 15:23:28.438
2020-04-07 19:23:28 Local computer time in UTC | 2020-04-07 15:23:28.438
2020-04-07 15:23:28 Local computer time in SC Time Zone | 2020-04-07 15:23:28.438
2020-04-07 19:23:27 Server time in UTC | 2020-04-07 15:23:28.438
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-04-07 15:23:28.438
Program path: C:\SierraChart\ | 2020-04-07 15:23:28.438
Data Files path: C:\SierraChart\Data\ | 2020-04-07 15:23:28.438
OS Version Number: 10.0 | 2020-04-07 15:23:28.438
Locale Setting: C | 2020-04-07 15:23:28.438
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2020-04-07 15:23:28.438
Date Time Of Last Edit: 2020-04-08 10:21:38
[2020-04-08 10:21:10]
Therefore, the chart Session Times must be filtering out that time period. Refer to this subsection about this:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time
[2020-04-08 12:21:11]
All session times are set at: Start time: 09:30:00 End Time: 16:59:59.
Looking above in this thread, it seems my message log may have been truncated. Below were message log results of my 4 attempts to "delete and download data from the current position to end". Seems to not go past 16:14:59.024 for all attempts. I have attached the full message log in a word document just in case part was missing above. Hope this helps in figuring this out. Thank you.
HD Request # 19 | Received 1544 records from 2020-04-07 16:14:45.000 to 2020-04-07 16:14:59.024 (14.0 seconds) and wrote 1447 records for ESM20_FUT_CME | 2020-04-07 16:19:19.592
HD Request # 20 | Received 25 records from 2020-04-07 16:14:59.000 to 2020-04-07 16:14:59.024 (0.0 seconds) and wrote 1 record for ESM20_FUT_CME | 2020-04-07 16:23:30.166
HD Request # 21 | Received 295 records from 2020-04-07 16:14:55.000 to 2020-04-07 16:14:59.024 (4.0 seconds) and wrote 254 records for ESM20_FUT_CME | 2020-04-07 16:26:16.217
HD Request # 22 | Received 25 records from 2020-04-07 16:14:59.000 to 2020-04-07 16:14:59.024 (0.0 seconds) and wrote 1 record for ESM20_FUT_CME | 2020-04-07 16:29:06.101
Private File
[2020-04-08 12:45:38]
User907968 - Posts: 883
https://www.cmegroup.com/trading/equity-index/us-index/e-mini-sandp500_contract_specifications.html
E-mini S&P 500 Futures Contract Specs -
CME Globex: Sunday - Friday 6:00 p.m. - 5:00 p.m. Eastern Time (ET) with trading halt 4:15 p.m. - 4:30 p.m.
[2020-04-09 11:29:58]
This identifies the cause. Thank you for posting.
