Date/Time: Sat, 18 May 2024 08:16:27 +0000
ABC icon
View Count: 594
[2020-04-06 18:15:59] |
Fawaz - Posts: 1 |
Hi there, > Please I need your help. I couldn’t find ABC icon to draw support and resistance levels? > > Best regards, |
[2020-04-06 18:34:21] |
Did you just want to draw Horizontal lines? If so, use this tool: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line There is also the text tool: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
