Date/Time: Tue, 22 Sep 2026 11:33:06 +0000
Volume Bars in TradeDOM alignment
View Count: 1379
| [2020-03-27 20:40:22] |
| joshtrader - Posts: 569 |
I have the "Bid Size/Buy Column" and the "Ask Size/Sell Column". As you can see, the text is aligned to the right for the buy column, and to the left for the sell column. However, the volume bars in each are aligned opposite--the dark blue is the volume bar color and is left aligned, and the dark red is the volume bar color and is right aligned. How do I align the volume bars for the buy column to the right, and for the sell column to the left, as the text is? On another note: if I select "Automatic Sizing" for both of these columns, click OK, and reenter the "Customize Trade DOM Columns" dialog, the "Automatic Sizing" option is still selected but greyed out and unable to change. Date Time Of Last Edit: 2020-03-27 20:41:05
| [2020-03-30 14:57:34] |
| John - SC Support - Posts: 47955 |
It is not supported to change the location of the Volume Bars for the Bid Size and Ask Size columns. They are fixed to the left. With regards to the Automatic Sizing, the option is disabled until you make a manual change the column. This is stated in the 3rd paragraph here: Global Trade Settings Windows: Automatic Sizing (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
