Date/Time: Wed, 05 Feb 2025 09:49:52 +0000
OCO target and stopped cancelled when parent order filled
View Count: 585
[2020-03-10 16:58:41]
User265134 - Posts: 5
Hello SC,
This morning I placed a OCO bracket order with 1 target and 1 stop on the platform. The order triggered while I was walking to work and laptop was not connected to the internet. When I got to work the parent order had been triggered but both the target and stop had been cancelled and I was down 52 points on the ES Micros. These cancellations have happened before and I want to fully understand the causes of these so I can prevent this in the future. I just looked and the box had been ticked under general trade settings for use server side brackets but the server side OCO box was not ticked. I have also just now ticked the box for auto-send market order on rejected stop attached order. Should I input trades using the MT5 mobile App I have linked with my AMP Futures account when I know that I may not be connected to the internet when a trade triggers? What can I do to ensure my platform entered bracket OCO stop and targets remain in place anytime a parent order is filled even if the laptop is not connected to the internet.
Thanks for your help!
Ryan
[2020-03-10 17:36:30]
You really need to use server-side bracket orders which are supported with the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
They are not supported with CQG.
So the problem will be solved by changing to the Sierra Chart order routing service.
Date Time Of Last Edit: 2020-03-10 17:38:12
