Date/Time: Wed, 05 Feb 2025 06:58:51 +0000
[Programming Help] - no real time data
View Count: 582
[2020-03-02 19:03:26]
User568539 - Posts: 18
Hi. I have not been receiving any real time data on my charts, since 7:35 a.m. Pacific time today, 2020-03-02. Earlier today I changed from the data feed from Sierra Chart CQG to Sierra Chart TT Fix Denali. Could that be causing the problem, and what should I do to remedy it? Thank you. Richard
Date Time Of Last Edit: 2020-03-02 19:31:47
[2020-03-02 19:31:37]
Could you contact your broker AMP and tell them to fully activate the Denali Exchange Data Feed on your account. They did one of the steps, but they still need to specifically activate the data feed connection and also the exchange.
[2020-03-03 13:37:49]
Hi. I just contacted my broker, AMP, and they said they did activate the data feed connection for the CBOT exchange, but I am still not receiving live data, and they told me to contact Sierra Chart support for help.
[2020-03-03 17:49:20]
First thing we want you to do is to translate the symbols if that is not already done:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-03-03 17:50:31
[2020-03-03 18:15:07]
Here is a copy of the message log. After I did the "translate the symbols", the real time data started coming through, and everything seems to be working fine now. Thank you.
Software version: 2059 64-bit | 2020-03-03 10:07:03.654
Enabled for: Sierra Chart Historical Data Service. | 2020-03-03 10:07:03.654
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-03-03 10:07:03.654
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-03 10:07:03.654
Enabled for exchange2: CME | 2020-03-03 10:07:03.654
Enabled for exchange2: CBOT | 2020-03-03 10:07:03.654
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-03 10:07:03.654
Current selected Data/Trading service: SC Futures Order Routing/Data | 2020-03-03 10:07:03.654
Custom symbol settings values: enabled | 2020-03-03 10:07:03.654
Chart Update Interval: 500 | 2020-03-03 10:07:03.654
Intraday Data Storage Time Unit: 1 | 2020-03-03 10:07:03.654
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-03-03 10:07:03.654
2020-03-03 10:07:03 Local computer time | 2020-03-03 10:07:03.654
2020-03-03 18:07:03 Local computer time in UTC | 2020-03-03 10:07:03.654
2020-03-03 10:07:03 Local computer time in SC Time Zone | 2020-03-03 10:07:03.654
2020-03-03 17:57:25 Server time in UTC | 2020-03-03 10:07:03.654
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-03-03 10:07:03.654
Program path: C:\SierraChart\ | 2020-03-03 10:07:03.654
Data Files path: C:\SierraChart\Data\ | 2020-03-03 10:07:03.654
OS Version Number: 10.0 | 2020-03-03 10:07:03.654
Locale Setting: C | 2020-03-03 10:07:03.654
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-03-03 10:07:03.654
File >> Disconnect selected. | 2020-03-03 10:07:37.275
DTC Client socket (1) | CloseSocket call. | 2020-03-03 10:07:37.276
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-03 10:07:37.276
DTC Client socket (2) | CloseSocket call. | 2020-03-03 10:07:37.280
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-03 10:07:37.281
SC Data - All Services | Disconnected from the server. | 2020-03-03 10:07:37.281
SC Futures Order Routing/Data | Disconnected. | 2020-03-03 10:07:37.281
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-03-03 10:07:37.343
DTC Client socket (1) | Closed. | 2020-03-03 10:07:37.343
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-03 10:07:37.451
DTC Client socket (2) | Closed. | 2020-03-03 10:07:37.451
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-03-03 10:07:47.068
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-03-03 10:07:47.108
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-03-03 10:07:47.108
SC Futures Order Routing/Data | Connected to server. | 2020-03-03 10:07:47.174
SC Futures Order Routing/Data | Starting socket receive thread. | 2020-03-03 10:07:47.174
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2020-03-03 10:07:47.174
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-03-03 10:07:47.383
SC Futures Order Routing/Data | Sending logon request message. | 2020-03-03 10:07:47.383
SC Futures Order Routing/Data | Received logon response. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Trading is supported. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Order cancel and replace is supported. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | OCO Orders supported. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Bracket Orders supported. | 2020-03-03 10:07:47.454
SC Futures Order Routing/Data | Connected to data and trading server. | 2020-03-03 10:07:47.454
Triggering next historical data download in queue. | 2020-03-03 10:07:47.454
Updated verified funded futures trading account ending date to: 2020-04-04 18:07:47 | 2020-03-03 10:07:47.454
Using SC exchange feed2. Symbol: ZN?##_FUT_CBOT | 2020-03-03 10:07:47.790
Mapping ZNM20_FUT_CBOT to ZNM20. Service code: cbot | 2020-03-03 10:07:47.790
SC Data - All Services | Starting real-time market data updates for: ZNM20_FUT_CBOT (ZNM20). ID: 1 Service code: cbot | 2020-03-03 10:07:47.790
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-03-03 10:07:47.790
SC Data - All Services | Requesting security definition data for: ZNM20_FUT_CBOT (ZNM20). ID: 1 | 2020-03-03 10:07:47.790
Added historical Intraday data request for ZNM20_FUT_CBOT to the queue. | 2020-03-03 10:07:47.790
Intraday data recording state for symbol ZNM20_FUT_CBOT is set to download 'Pending'. | 2020-03-03 10:07:47.790
Triggering next historical data download in queue. | 2020-03-03 10:07:47.790
Delaying start of download for ZNM20_FUT_CBOT | 2020-03-03 10:07:47.806
Using SC exchange feed2. Symbol: ZF?##_FUT_CBOT | 2020-03-03 10:07:47.806
Mapping ZFM20_FUT_CBOT to ZFM20. Service code: cbot | 2020-03-03 10:07:47.806
SC Data - All Services | Starting real-time market data updates for: ZFM20_FUT_CBOT (ZFM20). ID: 2 Service code: cbot | 2020-03-03 10:07:47.806
SC Data - All Services | Requesting security definition data for: ZFM20_FUT_CBOT (ZFM20). ID: 2 | 2020-03-03 10:07:47.806
Added historical Intraday data request for ZFM20_FUT_CBOT to the queue. | 2020-03-03 10:07:47.806
Intraday data recording state for symbol ZFM20_FUT_CBOT is set to download 'Pending'. | 2020-03-03 10:07:47.806
Triggering next historical data download in queue. | 2020-03-03 10:07:47.806
Using SC exchange feed2. Symbol: ZB?##_FUT_CBOT | 2020-03-03 10:07:47.822
Mapping ZBM20_FUT_CBOT to ZBM20. Service code: cbot | 2020-03-03 10:07:47.822
SC Data - All Services | Starting real-time market data updates for: ZBM20_FUT_CBOT (ZBM20). ID: 3 Service code: cbot | 2020-03-03 10:07:47.822
SC Data - All Services | Requesting security definition data for: ZBM20_FUT_CBOT (ZBM20). ID: 3 | 2020-03-03 10:07:47.822
Added historical Intraday data request for ZBM20_FUT_CBOT to the queue. | 2020-03-03 10:07:47.822
Intraday data recording state for symbol ZBM20_FUT_CBOT is set to download 'Pending'. | 2020-03-03 10:07:47.822
Triggering next historical data download in queue. | 2020-03-03 10:07:47.822
DTC Client socket (2) | Creating socket. | 2020-03-03 10:07:47.830
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-03-03 10:07:47.831
SC Futures Order Routing/Data | Received security definition for symbol ZNM20_FUT_CBOT | 2020-03-03 10:07:47.856
SC Futures Order Routing/Data | Received security definition for symbol ZFM20_FUT_CBOT | 2020-03-03 10:07:47.872
SC Futures Order Routing/Data | Received security definition for symbol ZBM20_FUT_CBOT | 2020-03-03 10:07:47.888
SC Data - All Services | Connected to server. | 2020-03-03 10:07:47.898
SC Data - All Services | Starting socket receive thread. | 2020-03-03 10:07:47.898
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-03 10:07:47.898
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-03 10:07:47.969
SC Data - All Services | Sending logon request message. | 2020-03-03 10:07:47.969
SC Data - All Services | Received logon response. | 2020-03-03 10:07:48.566
SC Data - All Services | Server Name: SC Realtime Server. | 2020-03-03 10:07:48.566
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-03 10:07:48.566
SC Data - All Services | Successfully connected. | 2020-03-03 10:07:48.566
SC Data - All Services | Trading is not supported. | 2020-03-03 10:07:48.566
SC Data - All Services | Restarting real-time data updates for symbol: ZBM20_FUT_CBOT -> ZBM20 | 2020-03-03 10:07:48.566
SC Data - All Services | Restarting real-time data updates for symbol: ZFM20_FUT_CBOT -> ZFM20 | 2020-03-03 10:07:48.566
SC Data - All Services | Restarting real-time data updates for symbol: ZNM20_FUT_CBOT -> ZNM20 | 2020-03-03 10:07:48.566
SC Data - All Services | Received security definition for symbol ZBM20_FUT_CBOT | 2020-03-03 10:07:48.661
SC Data - All Services | Received security definition for symbol ZFM20_FUT_CBOT | 2020-03-03 10:07:48.661
SC Data - All Services | Received security definition for symbol ZNM20_FUT_CBOT | 2020-03-03 10:07:48.661
HD Request # 8 | Downloading Intraday chart data for ZNM20_FUT_CBOT to the file ZNM20_FUT_CBOT.scid. Service: cbot | 2020-03-03 10:07:53.810
HD Request # 8 | Download start date-time: 2020-03-03 10:07:33.000 | 2020-03-03 10:07:53.810
HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2020-03-03 10:07:53.811
Socket (3) | Creating socket. | 2020-03-03 10:07:53.811
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-03-03 10:07:53.811
HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-03-03 10:07:53.947
HD Request # 8 | Sending historical data logon request message. | 2020-03-03 10:07:53.947
HD Request # 8 | Requesting Intraday data. Start date-time: 2020-03-03 10:07:33. Record interval: 1. Symbol: ZNM20 | 2020-03-03 10:07:54.461
HD Request # 8 | Decompressing data. | 2020-03-03 10:07:54.528
HD Request # 8 | Receiving Intraday data for ZNM20_FUT_CBOT starting at 2020-03-03 10:07:33 | 2020-03-03 10:07:54.528
Socket (3) | CloseSocket call. | 2020-03-03 10:07:54.528
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-03-03 10:07:54.528
Historical data download thread signaled to stop. | 2020-03-03 10:07:54.529
HD Request # 8 | Timestamp of first Intraday data file record written: 2020-03-03 10:07:33 | 2020-03-03 10:07:54.529
HD Request # 8 | Received 4 records from 2020-03-03 10:07:33.000 to 2020-03-03 10:07:40.000 (7.0 seconds) and wrote 4 records for ZNM20_FUT_CBOT | 2020-03-03 10:07:54.529
HD Request # 8 | Completion time: 1s | 2020-03-03 10:07:54.533
HD Request # 8 | Intraday data download complete for ZNM20_FUT_CBOT. Unique request ID: 7 | 2020-03-03 10:07:54.533
Removing historical data download ID 7. | 2020-03-03 10:07:54.533
Real-time Intraday chart data file updates started for ZNM20_FUT_CBOT | 2020-03-03 10:07:54.533
Opened cached Intraday file: C:\SierraChart\Data\ZNM20_FUT_CBOT.scid | 2020-03-03 10:07:54.534
Intraday chart data file opened for ZNM20_FUT_CBOT | 2020-03-03 10:07:54.534
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2020-03-03 10:07:54.534
Triggering next historical data download in queue. | 2020-03-03 10:07:54.534
HD Request # 9 | Downloading Intraday chart data for ZFM20_FUT_CBOT to the file ZFM20_FUT_CBOT.scid. Service: cbot | 2020-03-03 10:07:54.534
HD Request # 9 | Download start date-time: 2020-03-03 10:07:22.000 | 2020-03-03 10:07:54.534
HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2020-03-03 10:07:54.534
Socket (4) | Creating socket. | 2020-03-03 10:07:54.534
Socket (4) | Connecting to IP: 216.1.90.130. | 2020-03-03 10:07:54.534
Socket (3) | Socket gracefully closed by remote side. | 2020-03-03 10:07:54.594
Socket (3) | Closed. | 2020-03-03 10:07:54.594
HD Request # 9 | Setting DTC encoding to Binary VLS | 2020-03-03 10:07:54.676
HD Request # 9 | Sending historical data logon request message. | 2020-03-03 10:07:54.676
HD Request # 9 | Requesting Intraday data. Start date-time: 2020-03-03 10:07:22. Record interval: 1. Symbol: ZFM20 | 2020-03-03 10:07:55.202
HD Request # 9 | Decompressing data. | 2020-03-03 10:07:55.268
HD Request # 9 | Receiving Intraday data for ZFM20_FUT_CBOT starting at 2020-03-03 10:07:22 | 2020-03-03 10:07:55.268
Socket (4) | CloseSocket call. | 2020-03-03 10:07:55.269
Socket (4) | Shutdown started. Waiting for graceful close. | 2020-03-03 10:07:55.269
Historical data download thread signaled to stop. | 2020-03-03 10:07:55.269
HD Request # 9 | Timestamp of first Intraday data file record written: 2020-03-03 10:07:22 | 2020-03-03 10:07:55.269
HD Request # 9 | Received 4 records from 2020-03-03 10:07:22.000 to 2020-03-03 10:07:49.000 (27.0 seconds) and wrote 4 records for ZFM20_FUT_CBOT | 2020-03-03 10:07:55.269
Added 1 Time and Sales records to Intraday data file for ZFM20_FUT_CBOT after download. | 2020-03-03 10:07:55.274
HD Request # 9 | Completion time: 1s | 2020-03-03 10:07:55.277
HD Request # 9 | Intraday data download complete for ZFM20_FUT_CBOT. Unique request ID: 8 | 2020-03-03 10:07:55.277
Removing historical data download ID 8. | 2020-03-03 10:07:55.277
Real-time Intraday chart data file updates started for ZFM20_FUT_CBOT | 2020-03-03 10:07:55.277
Opened cached Intraday file: C:\SierraChart\Data\ZFM20_FUT_CBOT.scid | 2020-03-03 10:07:55.277
Intraday chart data file opened for ZFM20_FUT_CBOT | 2020-03-03 10:07:55.277
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2020-03-03 10:07:55.277
Triggering next historical data download in queue. | 2020-03-03 10:07:55.277
HD Request # 10 | Downloading Intraday chart data for ZBM20_FUT_CBOT to the file ZBM20_FUT_CBOT.scid. Service: cbot | 2020-03-03 10:07:55.277
HD Request # 10 | Download start date-time: 2020-03-03 10:07:36.000 | 2020-03-03 10:07:55.277
HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2020-03-03 10:07:55.277
Socket (3) | Creating socket. | 2020-03-03 10:07:55.278
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-03-03 10:07:55.278
Socket (4) | Socket gracefully closed by remote side. | 2020-03-03 10:07:55.334
Socket (4) | Closed. | 2020-03-03 10:07:55.334
HD Request # 10 | Setting DTC encoding to Binary VLS | 2020-03-03 10:07:55.415
HD Request # 10 | Sending historical data logon request message. | 2020-03-03 10:07:55.415
HD Request # 10 | Requesting Intraday data. Start date-time: 2020-03-03 10:07:36. Record interval: 1. Symbol: ZBM20 | 2020-03-03 10:07:55.480
HD Request # 10 | Decompressing data. | 2020-03-03 10:07:55.546
HD Request # 10 | Receiving Intraday data for ZBM20_FUT_CBOT starting at 2020-03-03 10:07:36 | 2020-03-03 10:07:55.546
Socket (3) | CloseSocket call. | 2020-03-03 10:07:55.546
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-03-03 10:07:55.546
Historical data download thread signaled to stop. | 2020-03-03 10:07:55.546
HD Request # 10 | Timestamp of first Intraday data file record written: 2020-03-03 10:07:36 | 2020-03-03 10:07:55.546
HD Request # 10 | Received 3 records from 2020-03-03 10:07:36.000 to 2020-03-03 10:07:43.000 (7.0 seconds) and wrote 3 records for ZBM20_FUT_CBOT | 2020-03-03 10:07:55.546
HD Request # 10 | Completion time: 0s | 2020-03-03 10:07:55.552
HD Request # 10 | Intraday data download complete for ZBM20_FUT_CBOT. Unique request ID: 9 | 2020-03-03 10:07:55.552
Removing historical data download ID 9. | 2020-03-03 10:07:55.552
Real-time Intraday chart data file updates started for ZBM20_FUT_CBOT | 2020-03-03 10:07:55.552
Opened cached Intraday file: C:\SierraChart\Data\ZBM20_FUT_CBOT.scid | 2020-03-03 10:07:55.552
Intraday chart data file opened for ZBM20_FUT_CBOT | 2020-03-03 10:07:55.552
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2020-03-03 10:07:55.552
Triggering next historical data download in queue. | 2020-03-03 10:07:55.552
Socket (3) | Socket gracefully closed by remote side. | 2020-03-03 10:07:55.612
Socket (3) | Closed. | 2020-03-03 10:07:55.612
